  2. Enclosures / 3D Printing
  3. Clean looking sensor node
90 Posts 13 Posters 50.7k Views 22 Watching
  • Nca78N
    Nca78N
    Ah yes the "Q8" square charger looks great, I'm waiting for my new credit card to arrive to be able to order one :D It's a bit bigger but it looks slick and it would allow to combine a few sensors inside. It could also contain a charging circuit and lipo to have rechargeable sensor.
    For the others, well I believe I would get high WRF (with R like rejection) instead of WAF :D
    NeverDieN 1 Reply Last reply
    • Nca78N Nca78
      NeverDieN
      NeverDieN
      #22
      @Nca78
      I'm not really offended by the QB logo, but I'm guessing you would prefer one without the QB logo:
      https://www.aliexpress.com/item/White-Q8-QI-Wireless-Charging-USB-Splitter-HUB-Charger-Pad-For-iPhone-Samsung-LG-etc/32644680733.html?spm=2114.01010208.3.10.IWHDx5&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_10067_10069_10017_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10078_10079_10073_10070_421_420_10052_10053_10050_10051,searchweb201603_6&btsid=9078bcb7-63c3-4672-9239-d3b0d07991e9
      or
      https://www.aliexpress.com/item/Black-Qi-Wireless-Battery-Charger-Power-Charging-Pad-for-Samsung-Galaxy-S6-S5-S4-S3-LG/32643330290.html?spm=2114.10010108.1000013.2.UYL2eK&scm=1007.13339.33317.0&pvid=4c770213-1630-4721-9d9e-0913fa511f44&tpp=1
      Mainly because of the lengthy shipping delay, I think I'll get one of each and then decide which I prefer. Things don't always look the same on a website as they do in real life.
      • NeverDieN
        NeverDieN
        Looking at the containers in our pantry here, I notice a lot of them have lids that, though they lack "bottoms", in many respects look a lot like the generic "puck" shape of the OP. For something that sits on a table top, you'd never know it doesn't have a bottom. These would be entirely free, because as my family here uses up a container, we invariably just throw it out. :-)
        • NeverDieN NeverDie
          NeverDieN
          NeverDieN
          #24
          @Nca78 said:
          https://www.aliexpress.com/item/QI-Wireless-Charger-Charging-Pad-for-Samsung-Galaxy-S7-S6-edge-Note-5-Nokia-HTC-8X/32694769031.html
          I just today received an all white version of this (purchased it from ebay), but I wouldn't recommend it (well, at least not this color). The case itself is all white, which is what I wanted, but the silicon ring embedded in it is more of a cream color, and so it ruins the look by making it look old and/or dirty. It doesn't look like the photo on the web page. Also, as perhaps the OP pointed out, there are no vent holes, though they could be drilled.
          • NeverDieN
            NeverDieN
            Here's another one, but this one I like. For a sense of scale, I photographed it with my large TH sensor sitting on top:
            • Nca78N
              Nca78N
              You're receiving thing pretty quickly (as you received the PCB in less than 2 weeks, too), you're lucky !
              I have no problem with the white ring on mine, it's not the same color than the plastic but it's not looking bad to me. Maybe different model, maybe a question of taste ;)
              • Nca78N Nca78
                NeverDieN
                NeverDieN
                #27
                @Nca78
                What do you think of the black one above? Thumbs up or thumbs down? I was surprised at the way it photographed. On the sides it's actually the same glossy black color as it is on top, but its so glossy that when I photographed it (with a flash) you're actually seeing a reflection of the white tabletop that it's sitting on. Similarly, you can also see a reflection of the white antenna on the glossy black portion on the top (though not in the matted black top area).
                The things I received yesterday were shipped domestically. It still takes a long time to get things if they're shipped from China.
                • Nca78N
                  Nca78N
                  @NeverDie I don't know, do you have any "commercial" image of this box ? Crude flash light from one direction only never does justice to object (or people :))
                  • NeverDieN
                    NeverDieN
                    In the spirit of KISS, I think in most instances the following might work well for me:
                    https://www.aliexpress.com/item/New-Plastic-4-AAA-Battery-Srorage-Box-Holder-4pcs-AAA-Batteries-Case-with-a-Lid-ON/32579574841.html?spm=2114.30010308.3.2.l7ZbuM&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10069_10017_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10059_10032_10078_10079_10077_10073_10070_421_420_10052_10053_10050_10051,searchweb201603_4&btsid=53ae9427-799a-435b-9575-d6f3fba7ec42
                    My smallest wireless node can fit inside the case along with 2x AAA batteries positioned to produce 3V, and the case already has an exposed switch to turn it on/off. Total case size is relatively small, around: 6.2 x 4.8 x 1.5cm / 2.4" x 1.9" x 0.6"(LWH)
                    • Nca78N
                      Nca78N
                      I'll definitely order this and the AA version too, to check.
                      In the worse case it can be used for hidden node. It should fit a dedicated PCB even with pro mini as long as the radio is SMD to be flat enough.
                      • sglueS
                        sglueS
                        sglue
                        Newbie here.
                        I have used battery casing for sensebender & DC DC step up converter (2.5v to 5v).
                        Have to do a bit of filing & swapping of battery contacts and drill hole for sensebender.
                        Attach photos.
                        1_1476969117224_SenseBender_2.JPG 0_1476969117224_SenseBender_1.JPG 0_1476969177222_DC DC Step up.JPG
                        • sglueS sglue
                          Newbie here.
                          Attach photos.
                          NeverDieN
                          NeverDieN
                          Yup, your photo captures the notion of what I'm planning to do:
                          My original inspiration for it came from this:
                          http://johan.kanflo.com/the-aaduino/
                          which I might have done, except that I prefer the RFM69HW, which I don't think would fit in just one battery slot very easily.
                            NeverDieN
                            NeverDieN
                            @NeverDie
                            Here I just received the black "pucK' sensor case that was shown in the OP. Pretty fast considering it was free delivery using China Post. So far I like it the best because it has the air vents already a part of it. :smiley:
                            Cliff KarlssonC 1 Reply Last reply
                            • Nca78N
                              Nca78N
                              That's why I selected it, best suited for temp sensor.
                              Just received the first version of the PCB but it will need some improvements.
                              But looks like it will work, not too bad for my first PCB ever :)
                                @NeverDie
                                Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                I really like the pcb´s you are using @NeverDie, is it possible to buy them anywhere?
                                  NeverDieN
                                  NeverDieN
                                  #36
                                  I'm just doing this for fun. If you want to buy something pre-made, I'd suggest buying a Moteino.
                                    Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    @NeverDie
                                    Ok, but is the PCB availible at OSHpark or is the files availble for sharing?
                                    • Nca78N Nca78
                                      NeverDieN
                                      NeverDieN
                                      @Nca78
                                      Are you sure there's space for the coincell holder? The case is pretty thin. I ordered some tabbed coincells, but am still waiting for them to arrive.
                                        @NeverDie
                                        NeverDieN
                                        NeverDieN
                                        @Cliff-Karlsson
                                        Maybe later. I'm still improving the design.
                                        • Nca78N Nca78
                                          NeverDieN
                                          NeverDieN
                                          #40
                                          Here's a newer evolution of my small TH node that includes a co-planar antenna. So, no long monopole antenna sticking out of the case. :smile:
                                          I haven't attached the TH sensor yet because I've run out of them, but I'm pretty sure it will fit. :wink:
