  2. Enclosures / 3D Printing
  3. Clean looking sensor node
90 Posts 13 Posters 51.1k Views 22 Watching
    Here's another one, but this one I like. For a sense of scale, I photographed it with my large TH sensor sitting on top:
    • Nca78N
      You're receiving thing pretty quickly (as you received the PCB in less than 2 weeks, too), you're lucky !
      I have no problem with the white ring on mine, it's not the same color than the plastic but it's not looking bad to me. Maybe different model, maybe a question of taste ;)
      • Nca78N Nca78
        #27
        @Nca78
        What do you think of the black one above? Thumbs up or thumbs down? I was surprised at the way it photographed. On the sides it's actually the same glossy black color as it is on top, but its so glossy that when I photographed it (with a flash) you're actually seeing a reflection of the white tabletop that it's sitting on. Similarly, you can also see a reflection of the white antenna on the glossy black portion on the top (though not in the matted black top area).
        The things I received yesterday were shipped domestically. It still takes a long time to get things if they're shipped from China.
        • Nca78N
          @NeverDie I don't know, do you have any "commercial" image of this box ? Crude flash light from one direction only never does justice to object (or people :))
            In the spirit of KISS, I think in most instances the following might work well for me:
            https://www.aliexpress.com/item/New-Plastic-4-AAA-Battery-Srorage-Box-Holder-4pcs-AAA-Batteries-Case-with-a-Lid-ON/32579574841.html?spm=2114.30010308.3.2.l7ZbuM&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10069_10017_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10059_10032_10078_10079_10077_10073_10070_421_420_10052_10053_10050_10051,searchweb201603_4&btsid=53ae9427-799a-435b-9575-d6f3fba7ec42
            My smallest wireless node can fit inside the case along with 2x AAA batteries positioned to produce 3V, and the case already has an exposed switch to turn it on/off. Total case size is relatively small, around: 6.2 x 4.8 x 1.5cm / 2.4" x 1.9" x 0.6"(LWH)
            • Nca78N
              I'll definitely order this and the AA version too, to check.
              In the worse case it can be used for hidden node. It should fit a dedicated PCB even with pro mini as long as the radio is SMD to be flat enough.
              • sglueS
                sglueS
                sglue
                Newbie here.
                I have used battery casing for sensebender & DC DC step up converter (2.5v to 5v).
                Have to do a bit of filing & swapping of battery contacts and drill hole for sensebender.
                Attach photos.
                1_1476969117224_SenseBender_2.JPG 0_1476969117224_SenseBender_1.JPG 0_1476969177222_DC DC Step up.JPG
                • sglueS sglue
                  Newbie here.
                  Attach photos.
                  Yup, your photo captures the notion of what I'm planning to do:
                  My original inspiration for it came from this:
                  http://johan.kanflo.com/the-aaduino/
                  which I might have done, except that I prefer the RFM69HW, which I don't think would fit in just one battery slot very easily.
                    Here I just received the black "pucK' sensor case that was shown in the OP. Pretty fast considering it was free delivery using China Post. So far I like it the best because it has the air vents already a part of it. :smiley:
                    Cliff KarlssonC 1 Reply Last reply
                    • Nca78N
                      That's why I selected it, best suited for temp sensor.
                      Just received the first version of the PCB but it will need some improvements.
                      But looks like it will work, not too bad for my first PCB ever :)
                        Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        I really like the pcb´s you are using @NeverDie, is it possible to buy them anywhere?
                          #36
                          I'm just doing this for fun. If you want to buy something pre-made, I'd suggest buying a Moteino.
                            Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            Ok, but is the PCB availible at OSHpark or is the files availble for sharing?
                            • Nca78N Nca78
                              @Nca78
                              Are you sure there's space for the coincell holder? The case is pretty thin. I ordered some tabbed coincells, but am still waiting for them to arrive.
                                @Cliff-Karlsson
                                Maybe later. I'm still improving the design.
                                • Nca78N Nca78
                                  #40
                                  Here's a newer evolution of my small TH node that includes a co-planar antenna. So, no long monopole antenna sticking out of the case. :smile:
                                  I haven't attached the TH sensor yet because I've run out of them, but I'm pretty sure it will fit. :wink:
                                    @nca78
                                    What's the best way to remove the cover on this thing? Do I just go for it with a pry tool, or is there a special trick to it?
                                    I'm hopeful it will fit a CR2477 tabbed battery, but it would likely be a very close fit if it does. In case it doesn't, have you come across any options that are a bit thicker?
                                    Nca78N 1 Reply Last reply
                                      So, here's an example of such a $1 solar garden light:
                                      Don't buy them for outdoor use, although that's what they're sold for. They'll rapidly corrode in wet weather and then cease to function. However, that shouldn't be a problem indoors.
                                      Demounting the solar puck, it looks like this:
                                      Here's the flip side with the guts removed:
                                      Inside I put one of my RFM69HW temp-RH nodes. As you can hopefully see, there is room to spare.
                                      These close-up photos probably make the puck look larger than it is. It is just 2-1/4" in diameter and 1-1/8" tall.
                                      What do you think? Would it have good WAF? This one is a bit crufty because it was outside for about a year, and then I plucked it for these photos. When brand new they look more clean and polished, and so perhaps if kept indoors they would stay that way.
                                      One possible concern with this particular example is that it has a metal band around it. That's not so ideal for an RF node, but it may not matter, as I tested the PCB node (just by itself, without the solar puck) within a closed refrigerator and still got adequate signal from it.
                                      I tried running one of my nodes inside the solar puck that has the metal band (above). It's maybe a few dB worse, but the link budget is large enough that it just doesn't really matter. So, I think it remains a viable option as an enclosure for thicker nodes that don't easily fit inside the OP's thinner recharger puck.
                                        @nca78
                                        @NeverDie said:
                                        @nca78
                                        Sorry no magic solution to open :)
                                        For the cell it should fit a 2477 but you need a thin PCB + thin holder.
                                        Box is 10.6mm high minus 1.2mm thickness for the cover and 0.8mm PCB it leaves you with 8.6mm. 2477 is 7.7mm so you have 1mm left, not much but I think just enough if you use basic holder that's just made of a folded metal sheet.
                                        But for such a basic sensor you would not need such a huge cell, CR2032 should last a very long time already, and 2450 could match your need of extra long lifetime and at the same time easily fit in the box. If your sketch is programmed correctly by the time a 2450 is dead the sensor will probably have become completely off because of aging ;)
                                          I received the Q8 wireless charging pad (above):
                                          http://www.ebay.com/itm/Q8-QI-Wireless-Charging-Pad-2-USB-Port-Splitter-HUB-Charger-Pad-For-Phone-F5/301913729117?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D39345%26meid%3Decb1959e8f164eb5ad0a17aeaa297f59%26pid%3D100623%26rk%3D3%26rkt%3D6%26sd%3D252485416371
                                          However, it is even thinner than the OP's vented puck, and it's about double the square inches of foot print. So I don't see any real advantage to them.
