  3. combining pulse counters
19 Posts 4 Posters 7.4k Views 3 Watching
  • htcaH
    htcaH
    htca
    I am trying to combine 3 pulse counters on 1 nano. I have a regular pulse counter based on a LDR, which counts the led pulses on the electricity meter and I have two pulse counters (one on the gas and one on the watermeter) counting the mirrors passages on the wheels.
    I would like to combine those on one nano and I started with the example of the electricity meter and modified it for 3 sensors. Than I got stuck...
    My errors starts here:
    MyMessage flowMsg(CHILD_ID_g,V_FLOW);
    MyMessage volumeMsg(CHILD_ID_g,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID_g,V_VAR3);
    The full script:
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a distance sensor using HC-SR04
     * Use this sensor to measure KWH and Watt of your house meeter
     * You need to set the correct pulsefactor of your meeter (blinks per KWH).
     * The sensor starts by fetching current KWH value from gateway.
     * Reports both KWH and Watt back to gateway.
     * Unfortunately millis() won't increment when the Arduino is in
     * sleepmode. So we cannot make this sensor sleep if we also want
     * to calculate/report watt-number.
     * http://www.mysensors.org/build/pulse_power
    // Enable debug prints
    #define SLEEP_MODE false        // values can only be reported when sleep mode is false.
    //electriciteit
    #define DIGITAL_INPUT_SENSOR_e 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR_e 1000       // Nummber of blinks per KWH of your meeter
    #define MAX_WATT_e 10000          // Max watt value to report. This filetrs outliers.
    #define CHILD_ID_e 1              // Id of the sensor child
    //water
    #define DIGITAL_INPUT_SENSOR_w 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR_w 1000       // Nummber of blinks per KWH of your meeter
    #define MAX_WATER 10000          // Max watt value to report. This filetrs outliers.
    #define CHILD_ID_w 2              // Id of the sensor child
    //gas
    #define DIGITAL_INPUT_SENSOR_g 4  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR_g 1000       // Nummber of blinks per KWH of your meeter
    #define MAX_GAS 10000          // Max watt value to report. This filetrs outliers.
    #define CHILD_ID_g 3              // Id of the sensor child
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh_e = ((double)PULSE_FACTOR_e)/1000; // Pulses per watt hour
    double ppwh_w = ((double)PULSE_FACTOR_w)/1000; // Pulses per watt hour
    double ppwh_g = ((double)PULSE_FACTOR_g)/1000; // Pulses per watt hour
    bool pcReceived = false;
    volatile unsigned long pulseCount_e = 0;
    volatile unsigned long pulseCount_w = 0;
    volatile unsigned long pulseCount_g = 0;
    volatile unsigned long lastBlink_e = 0;
    volatile unsigned long lastBlink_w = 0;
    volatile unsigned long lastBlink_g = 0;
    volatile unsigned long watt = 0;
    volatile unsigned long waterflow = 0;
    volatile unsigned long gasflow = 0;
    unsigned long oldPulseCount_e = 0;
    unsigned long oldPulseCount_w = 0;
    unsigned long oldPulseCount_g = 0;
    unsigned long oldWatt = 0;
    unsigned long oldWater = 0;
    unsigned long oldGas = 0;
    double oldKwh;
    double oldwater;
    double oldgas;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID_e,V_WATT);
    MyMessage kwhMsg(CHILD_ID_e,V_KWH);
    MyMessage pcMsg(CHILD_ID_e,V_VAR1);
    MyMessage flowMsg(CHILD_ID_w,V_FLOW);
    MyMessage volumeMsg(CHILD_ID_w,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID_w,V_VAR2);
      request(CHILD_ID_e, V_VAR1);
      request(CHILD_ID_w, V_VAR2);
      request(CHILD_ID_g, V_VAR3);
      // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
      // If no pullup is used, the reported usage will be too high because of the floating pin
      pinMode(DIGITAL_INPUT_SENSOR_e,INPUT_PULLUP);
      pinMode(DIGITAL_INPUT_SENSOR_w,INPUT_PULLUP);
      pinMode(DIGITAL_INPUT_SENSOR_g,INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_e), onPulse_e, RISING);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_w), onPulse_w, RISING);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_g), onPulse_g, RISING);
      lastSend=millis();
    void presentation() {
      sendSketchInfo("Marcel Meterkast", "1.0");
      present(CHILD_ID_e, S_POWER);
      present(CHILD_ID_w, S_WATER);
      present(CHILD_ID_g, S_GAS);
      unsigned long now = millis();
      bool sendTime = now - lastSend > SEND_FREQUENCY;
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        // New watt value has been calculated
        // electricity first
        if (!SLEEP_MODE && watt != oldWatt) {
          // Check that we dont get unresonable large watt value.
          // could hapen when long wraps or false interrupt triggered
          if (watt<((unsigned long)MAX_WATT)) {
            send(wattMsg.set(watt));  // Send watt value to gw
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // send water
        if (!SLEEP_MODE && waterflow != oldWater) {
          if (waterflow<((unsigned long)MAX_WATER)) {
            send(wattMsg.set(waterflow));  // Send watt value to gw
          Serial.print("Gas:");
          Serial.println(gasflow);
          oldWater = waterflow;
        // send gas
        if (!SLEEP_MODE && gasflow != oldGas) {
          if (gasflow<((unsigned long)MAX_GAS)) {
            send(wattMsg.set(gasflow));  // Send watt value to gw
          Serial.print("gas:");
          oldGas = gasflow;
        // Pulse cout has changed
        if (pulseCount_e != oldPulseCount_e) {
          send(pcMsg.set(pulseCount_e));  // Send pulse count value to gw
          double kwh = ((double)pulseCount_e/((double)PULSE_FACTOR_e));
          oldPulseCount_e = pulseCount_e;
          if (kwh != oldKwh) {
            send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        if (pulseCount_w != oldPulseCount_w) {
          send(pcMsg.set(pulseCount_w));  // Send pulse count value to gw
          double water = ((double)pulseCount_w/((double)PULSE_FACTOR_w));
          oldPulseCount_w = pulseCount_w;
          if (water != oldwater) {
            oldwater = water;
        if (pulseCount_g != oldPulseCount_g) {
          send(pcMsg.set(pulseCount_g));  // Send pulse count value to gw
          double gas = ((double)pulseCount_g/((double)PULSE_FACTOR_g));
          oldPulseCount_g = pulseCount_g;
          if (gas != oldgas) {
            send(kwhMsg.set(gas, 4));  // Send kwh value to gw
            oldgas = gas;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        Serial.print("Received last pulse count from gw for:");
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse_e()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink_e-lastBlink_e;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh_e;
        lastBlink_e = newBlink_e;
      pulseCount_e++;
    void onPulse_w()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink_w;
          return;
        waterflow = (3600000000.0 /interval) / ppwh_w;
        lastBlink_w = newBlink;
      pulseCount_w++;
    void onPulse_g()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink_g;
          return;
        gasflow = (3600000000.0 /interval) / ppwh_g;
        lastBlink_g = newBlink;
      pulseCount_w++;
    • htcaH htca
      The full script:
      //electriciteit
      //water
      //gas
      double oldKwh;
      double oldwater;
      double oldgas;
        lastSend=millis();
            oldWatt = watt;
          // send water
          // send gas
            oldGas = gasflow;
              oldKwh = kwh;
              oldwater = water;
              oldgas = gas;
          lastSend = now;
          lastSend=now;
        if (SLEEP_MODE) {
          pcReceived = true;
      void onPulse_e()
        if (!SLEEP_MODE) {
            return;
        pulseCount_e++;
      void onPulse_w()
        if (!SLEEP_MODE) {
            return;
        pulseCount_w++;
      void onPulse_g()
        if (!SLEEP_MODE) {
            return;
        pulseCount_w++;
      @htca welcome to the MySensors community!
      What errors are you getting? Knowing the errors would make it much easier to troubleshoot the problem.
      • htcaH
        htcaH
        htca
        wrote on last edited by htca
        I managed to have the script compiled without errors. But I found out that the 3rd sensor is not checked or giving interrupts (the led on the sensor indicates that there are pulses). With playing around and checking some regular sketches, I made a mistake on my breadboard and I burnt my nano :-(. So I ordered a new one.....
        Script so far is shown below, but it might be that I have to built a script from scratch with mysensors api. If anyone has any directions to follow on this, it would be great!
        //electriciteit
        #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
        //water
        //gas
        unsigned long oldWaterf = 0;
        unsigned long oldgasf = 0;
        double oldKwh;
        double oldwater;
        double oldgas;
        MyMessage waterMsg(CHILD_ID_w,V_FLOW);
        MyMessage watervolumeMsg(CHILD_ID_w,V_VOLUME);
        MyMessage lastCounterwaterMsg(CHILD_ID_w,V_VAR2);
        MyMessage gasMsg(CHILD_ID_g,V_FLOW);
        MyMessage gasvolumeMsg(CHILD_ID_g,V_VOLUME);
        MyMessage lastCountegasrMsg(CHILD_ID_g,V_VAR3);
          lastSend=millis();
              oldWatt = watt;
            // send water
            if (!SLEEP_MODE && waterflow != oldWaterf) {
              Serial.print("water:");
              Serial.println(waterflow);
              oldWaterf = waterflow;
            // send gas
            if (!SLEEP_MODE && gasflow != oldgasf) {
              oldgas = gasflow;
                oldKwh = kwh;
                send(watervolumeMsg.set(water, 4));  // Send watervolume value to gw
                oldwater = water;
                send(gasvolumeMsg.set(gas, 4));  // Send gas value to gw
                oldgas = gas;
            lastSend = now;
            lastSend=now;
          if (SLEEP_MODE) {
            pulseCount_e = oldPulseCount_e = message.getLong();
            Serial.println(pulseCount_e);
            pcReceived = true;
        void onPulse_e()
          Serial.println("electricity pulse!");
          if (!SLEEP_MODE) {
            unsigned long interval = newBlink-lastBlink_e;
              return;
            lastBlink_e = newBlink;
          pulseCount_e++;
        void onPulse_w()
          Serial.println("water pulse!");
          if (!SLEEP_MODE) {
              return;
          pulseCount_w++;
        void onPulse_g()
          Serial.println("gas pulse!");
          if (!SLEEP_MODE) {
              return;
          pulseCount_w++;
        • E
          E
          ericvdb
          There are only 2 interrupts available, thats why you are not seeing the pulses from the 3th
          htcaH 1 Reply Last reply
          • E ericvdb
            htcaH
            htcaH
            htca
            @ericvdb but it should be possible to make a 3rd one available I think?
            • E
              E
              ericvdb
              yes but not interrupt based.
              Have a look at button sketch
              • E ericvdb
                htcaH
                htcaH
                htca
                @ericvdb So the only solution is to use 2 nano's?
                • E
                  E
                  ericvdb
                  No, use 1 nano, use interrupts for electricity and gas, and use digital input for water.
                  Unless you want everything interrupt based, then you will need 2 x nano (or a mega)
                  • E ericvdb
                    htcaH
                    htcaH
                    htca
                    @ericvdb What's the difference between a interrupt and a digital input (I am a civil engineer with some programming background)
                    • E
                      E
                      ericvdb
                      Interrupt: whenever you input changes from low-to-high or high-to-low, the atmega will fire the method you told it to do.
                      Digital IO: if you want to know the state of the digital io, you have to constantly poll the io.
                      Regarding 3 counters on 1 nano, have a look at 12 input pulse counter
                      • E
                        E
                        ericvdb
                        Here is the difference in code.
                        Digital IO polling:
                        int inPin = 7;   // pushbutton connected to digital pin 7
                        int val = 0;     // variable to store the read value
                          pinMode(inPin, INPUT);      // sets the digital pin 7 as input
                          val = digitalRead(inPin);   // read the input pin
                        Interrupt based:
                        const byte interruptPin = 2;
                        volatile byte state = LOW;
                          pinMode(interruptPin, INPUT_PULLUP);
                          attachInterrupt(digitalPinToInterrupt(interruptPin), blink, CHANGE);
                          // do whatever you want here
                        void blink() {
                          // this gets called whenever the input changes
                          state = !state;
                        • Nca78N
                          Nca78N
                          Hello, a digital input allows you to read a digital signal value. You call "digitalRead" and then you get the current value of the pin.
                          An interrupt will ... interrupt your code to call the method you have associated to the interrupt. On atmega328 which is used by the nano you have only 2 external interrupts.
                          You could also use the pin change interrupts but it's much more complicated, and if you're not clear with the concept of the interrupt yet it's better to read and learn about it first.
                          Another solution is to use an arduino mega which has 6 external interrupts.
                          Also, interrupt methods should execute as fast as possible, you should never have a serial.write inside an interrupt. Instead, set a flag, and check the flag in the loop method: if flag is set do the serial.write and reset the flag.
                          • htcaH
                            htcaH
                            htca
                            Thanks! I ordered 2 mega's to experiment....
                            • htcaH
                              htcaH
                              htca
                              I managed to get it working. First issue was to get the Mega working with the mega.
                              I needed to change MyConfig.h:
                              #define MY_RF24_CS_PIN 53
                              I used CE on pin 9 (and not 40) and further more:
                              My sketch:
                              // electricity
                              #define DIGITAL_INPUT_SENSOR_e 18  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                              #define SLEEP_MODE false           // Watt-value can only be reported when sleep mode is false.
                              // Water
                              #define DIGITAL_INPUT_SENSOR_w 19                 // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                              #define PULSE_FACTOR_w 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                              #define MAX_FLOW_w 40                             // Max flow (l/min) value to report. This filters outliers.
                              // Gas
                              #define DIGITAL_INPUT_SENSOR_g 20                 // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                              #define PULSE_FACTOR_g 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                              #define MAX_FLOW_g 40                             // Max flow (l/min) value to report. This filters outliers.
                              unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                              //unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                              double ppwh = ((double)PULSE_FACTOR_e)/1000; // Pulses per watt hour
                              double pplw = ((double)PULSE_FACTOR_w)/1000;
                              double pplg = ((double)PULSE_FACTOR_g)/1000;
                              //electricity
                              bool pcReceived_e = false;
                              double oldKwh;
                              unsigned long lastSend_e;
                              // water
                              volatile double flow_w = 0;
                              bool pcReceived_w = false;
                              unsigned long newBlink_w = 0;
                              double oldflow_w = 0;
                              double volume_w =0;
                              double oldvolume_w =0;
                              unsigned long lastSend_w =0;
                              unsigned long lastPulse_w =0;
                              // gas
                              volatile double flow_g = 0;
                              bool pcReceived_g = false;
                              unsigned long newBlink_g = 0;
                              double oldflow_g = 0;
                              double volume_g =0;
                              double oldvolume_g =0;
                              unsigned long lastSend_g =0;
                              unsigned long lastPulse_g =0;
                              // electricity
                              // Water
                              MyMessage waterflowMsg(CHILD_ID_w,V_FLOW);
                              MyMessage waterlastCounterMsg(CHILD_ID_w,V_VAR2);
                              // Gas
                              MyMessage gasflowMsg(CHILD_ID_g,V_FLOW);
                              MyMessage gaslastCounterMsg(CHILD_ID_g,V_VAR3);
                                lastSend_e=millis();
                                lastSend_w=millis();
                                lastSend_g=millis();
                                sendSketchInfo("Meterkast Marcel", "1.0");
                                bool sendTime = now - lastSend_e > SEND_FREQUENCY;
                                if (pcReceived_e && (SLEEP_MODE || sendTime)) {
                                    if (watt<((unsigned long)MAX_WATT_e)) {
                                    oldWatt = watt;
                                  // Pulse count has changed
                                      oldKwh = kwh;
                                  lastSend_e = now;
                                } else if (sendTime && !pcReceived_e) {
                                  lastSend_e=now;
                                  unsigned long currentTime = millis();
                                if (SLEEP_MODE || (currentTime - lastSend_w > SEND_FREQUENCY))
                                  lastSend_w=currentTime;
                                  if (!pcReceived_w) {
                                    //Last Pulsecount not yet received from controller, request it again
                                    return;
                                  if (!SLEEP_MODE && flow_w != oldflow_w) {
                                    oldflow_w = flow_w;
                                    Serial.print("l/min:");
                                    Serial.println(flow_w);
                                    // Check that we dont get unresonable large flow value.
                                    if (flow_w<((unsigned long)MAX_FLOW_w)) {
                                      send(waterflowMsg.set(flow_w, 2));                   // Send flow value to gw
                                  // No Pulse count received in 2min
                                  if(currentTime - lastPulse_w > 120000){
                                    flow_w = 0;
                                  if ((pulseCount_w != oldPulseCount_w)||(!SLEEP_MODE)) {
                                    Serial.print("pulsecount_w:");
                                    Serial.println(pulseCount_w);
                                    send(waterlastCounterMsg.set(pulseCount_w));                  // Send  pulsecount value to gw in VAR1
                                    double volume_w = ((double)pulseCount_w/((double)PULSE_FACTOR_w));
                                    if ((volume_w != oldvolume_w)||(!SLEEP_MODE)) {
                                      oldvolume_w = volume_w;
                                      Serial.print("volume_w:");
                                      Serial.println(volume_w, 3);
                                      send(watervolumeMsg.set(volume_w, 3));               // Send volume value to gw
                                if (SLEEP_MODE || (currentTime - lastSend_g > SEND_FREQUENCY))
                                  lastSend_g=currentTime;
                                  if (!pcReceived_g) {
                                    return;
                                  if (!SLEEP_MODE && flow_g != oldflow_g) {
                                    oldflow_g = flow_g;
                                    Serial.println(flow_g);
                                    if (flow_g<((unsigned long)MAX_FLOW_g)) {
                                      send(gasflowMsg.set(flow_g, 2));                   // Send flow value to gw
                                  if(currentTime - lastPulse_g > 120000){
                                    flow_g = 0;
                                  if ((pulseCount_g != oldPulseCount_g)||(!SLEEP_MODE)) {
                                    Serial.print("pulsecount_g:");
                                    Serial.println(pulseCount_g);
                                    send(gaslastCounterMsg.set(pulseCount_g));                  // Send  pulsecount value to gw in VAR1
                                    double volume_g = ((double)pulseCount_g/((double)PULSE_FACTOR_g));
                                    if ((volume_g != oldvolume_g)||(!SLEEP_MODE)) {
                                      oldvolume_g = volume_g;
                                      Serial.print("volume_g:");
                                      Serial.println(volume_g, 3);
                                      send(gasvolumeMsg.set(volume_g, 3));               // Send volume value to gw
                                if (SLEEP_MODE) {
                                  Serial.print("Received last pulse count from gw_e:");
                                  pcReceived_e = true;
                                if (message.type==V_VAR2) {
                                  unsigned long gwPulseCount_w=message.getULong();
                                  pulseCount_w += gwPulseCount_w;
                                  flow_w=oldflow_w=0;
                                  Serial.print("Received last pulse count from gw_w:");
                                  pcReceived_w = true;
                                if (message.type==V_VAR3) {
                                  unsigned long gwPulseCount_g=message.getULong();
                                  pulseCount_g += gwPulseCount_g;
                                  flow_g=oldflow_g=0;
                                  Serial.print("Received last pulse count from gw_g:");
                                  pcReceived_g = true;
                              void onPulse_e()
                                if (!SLEEP_MODE) {
                                  unsigned long newBlink_e = micros();
                                  unsigned long interval_e = newBlink_e-lastBlink_e;
                                  if (interval_e<10000L) { // Sometimes we get interrupt on RISING
                                    return;
                                  watt = (3600000000.0 /interval_e) / ppwh;
                                pulseCount_e++;
                              void onPulse_w()
                                if (!SLEEP_MODE)
                                  unsigned long newBlink_w = micros();
                                  unsigned long interval_w = newBlink_w-lastBlink_w;
                                  if (interval_w!=0)
                                    lastPulse_w = millis();
                                    if (interval_w<500000L) {
                                      // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                                      return;
                                    flow_w = (60000000.0 /interval_w) / pplw;
                                  lastBlink_w = newBlink_w;
                                pulseCount_w++;
                              void onPulse_g()
                                if (!SLEEP_MODE)
                                  unsigned long newBlink_g = micros();
                                  unsigned long interval_g = newBlink_g-lastBlink_g;
                                  if (interval_g!=0)
                                    lastPulse_g = millis();
                                    if (interval_g<500000L) {
                                      return;
                                    flow_g = (60000000.0 /interval_g) / pplg;
                                  lastBlink_g = newBlink_g;
                                pulseCount_g++;
                              I still got one issue; my led on the meter does not give enough light to have a n interrupt. does anybody have a suggestion how to get the interrupt?
                              • htcaH htca
                                My sketch:
                                // electricity
                                // Water
                                // Gas
                                //electricity
                                double oldKwh;
                                // water
                                double volume_w =0;
                                // gas
                                double volume_g =0;
                                // electricity
                                // Water
                                // Gas
                                      oldWatt = watt;
                                        oldKwh = kwh;
                                    lastSend_e = now;
                                    lastSend_e=now;
                                      return;
                                      oldflow_w = flow_w;
                                      flow_w = 0;
                                      return;
                                      oldflow_g = flow_g;
                                      flow_g = 0;
                                  if (SLEEP_MODE) {
                                    flow_w=oldflow_w=0;
                                    flow_g=oldflow_g=0;
                                void onPulse_e()
                                  if (!SLEEP_MODE) {
                                      return;
                                  pulseCount_e++;
                                void onPulse_w()
                                  if (!SLEEP_MODE)
                                    if (interval_w!=0)
                                        return;
                                  pulseCount_w++;
                                void onPulse_g()
                                  if (!SLEEP_MODE)
                                    if (interval_g!=0)
                                        return;
                                  pulseCount_g++;
                                @htca what are you using to detect the light? You mentioned a LDR in the first post. If that's what you are using, here are a few options:
                                1. More light. See if you can get the ldr closer to the led and more directly pointing towards it. You might be able to focus the light by using a lens in front of the LDR.
                                2. adjust the value of the pullup. (Don't use the built-in, add an external with a higher value instead - which value depends on your ldr. Measure the max and min resistance (led is off + led is on) and calculate what size the pullup should be)
                                3. get a ldr with different resistance
                                • htcaH
                                  htcaH
                                  htca
                                  I use this one:
                                  I used earlier which I made myself, but on a raspberry pi. Reading out analogue, passed it through a ADC and fed it to the pi.
                                  Now use the one above and linked it to the mega. Adjusting the resistance by the pot-meter will get me always on or always off.
                                  • htcaH htca
                                    I use this one:
                                    @htca how dark is the room? Can you prevent the ambient light from hitting the led, by using non-transparent tape or something? If that is possible, adjusting the potentiometer should be easier.
                                    • htcaH
                                      htcaH
                                      htca
                                      I will give it a try. I ordered also the LDR variants of these.
                                      M.
                                      • htcaH htca
                                        M.
                                        htcaH
                                        htcaH
                                        htca
                                        I finally built my set-up with the LDR (were lying in my working room for months...). Conclusion: it works!
