  3. Best or any way to get battery before regulator
12 Posts 3 Posters 3.0k Views 3 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    As I understand after some failed attempt to do a soil moisture sensor with battery check included I can't use any analog pins when using this method described in Battery Powered sensors.
    My sensor looks like this:
    And this does it impossible to use the VCC library since I have a regulator.
    Any other way to get the batterylevel in my setup?
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    AWIA 1 Reply Last reply
    • Martin TellblomM Martin Tellblom
      AWIA
      AWIA
      AWI
      @Martin-Tellblom why can't you use analog pins? You need one of these to measure. As your battery voltage is lower than the Arduino vcc you do not need a voltage divider. Just connect the battery (+) to an analog pin.
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        If I use this code:
          analogReference(INTERNAL1V1);
        #else
          analogReference(INTERNAL);
        And try to use the analog pins for this soil moisture sensor the values I get from the other analog pins goes all crazy with its values
          If I use this code:
          #else
          AWIA
          AWIA
          AWI
          @Martin-Tellblom don't use the internal reference, stick to the external (default)
          • Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            @AWI How do I do that? This is my first battery node tryout :)
              AWIA
              AWIA
              AWI
              @Martin-Tellblom Try to comment out the
              //analogReference(INTERNAL1V1);
              • Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                @AWI So that should be enought? I'll try that
                  AWIA
                  AWIA
                  AWI
                  analogReference(DEFAULT); is the alternative for using a 5v (vcc) reference.
                  Martin TellblomM 1 Reply Last reply
                  • AWIA AWI
                    Martin TellblomM
                    Martin TellblomM
                    Martin Tellblom
                    @AWI But that is always 5V until the end of the battery since I use a step-up or am I thinking completely wrong here
                    • clio75C
                      clio75C
                      clio75
                      If you are using the internal ref 1.1 you need to divide the voltage on the pin down to this level.
                      If you like in the example using a 1M and 470K you will have a approx 1Volt in the point.
                        AWIA
                        AWIA
                        AWI
                        @Martin-Tellblom The 5 volt is the reference... the analog pin is where you measure with respect to the reference. Try reading this article
                        • AWIA AWI
                          Martin TellblomM
                          Martin TellblomM
                          Martin Tellblom
                          Once again. Big thank you @AWI . As you understand I'm new to this battery thing and it's kind of driving me crazy :)
