  2. Bug Reports
  3. Heartbeat error ?
Heartbeat error ?
4 Posts 3 Posters 3.0k Views 3 Watching
  • clio75C
    clio75C
    clio75
    I have a relay node that don't have any sensors, and therefore don't have communication between the vera and the node. like this 0_1476877480815_upload-2c34fc65-9174-4f19-8dcb-9a2ea935b695
    So I have been playing with heartbeat and I cas see in serial log local on the node that it is transmitted.
    BUT my node in VERA dont update the last update time : Is tyhis how is sopose to be or do I something wrong?
    Here are my code :
     * Version 1.0 - Henrik Ekblad
    // #define MY_REPEATER_FEATURE
     long double last_heartbeat_time = millis();
     long double HEARTBEAT_TIME = 120000;
    void before() {
        pinMode(pin, OUTPUT);
        present(sensor, S_LIGHT);
      long double temp = (millis() - last_heartbeat_time);
      if (temp > HEARTBEAT_TIME) {
      // If it exceeds the heartbeat time then send a heartbeat
      sendHeartbeat();
      #ifdef MY_DEBUG
        Serial.print("Sent heartbeat" );
        Serial.println(temp)
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    • korttomaK
      korttomaK
      korttoma
      According to the Controller compatibility list Vera does not yet support heartbeat -> https://www.mysensors.org/controller
      • Tomas
      • clio75C
        clio75C
        clio75
        @korttoma
        :cry: I did not see that :cry:
        Is there any plan for implementing this ?
          You can just send the last state every HEARTBEAT_TIME... should have the same effect.
