  3. SerialGateway is rebooting on relay.
13 Posts 3 Posters 4.2k Views 2 Watching
  • delinendD
    delinendD
    delinend
    wrote on last edited by delinend
    Hi.
    Maybe someone has an idea.
    My setup is: Node6 and Node7, and a SerialGateway.
    When all 3 devices are ON, I can fine transmit from Node6 to Node7, via the SerialGateway.
    On Node 6, I use the command: send(msg.setDestination(7).set(value==HIGH)
    It all works fine.... but if I turn off Node7, then the SerialGateway, is restarting/resetting each time it tryes to reach Node7 (!TSF:MSG:SEND,6.0.7.7,s=3,c=1,t=16.pt=1,1=1,sg=0,ft=0,st=NACK:1)
    How can I prevent the SerialGateway, from doing a reset, when it can't reach a Node, that it is trying to relay to ?
    Btw: I'm using the last 2.0.1-beta develop build, from last night.
    • delinendD
      delinendD
      delinend
      Hmm. I can see, it at general problem, when sending a message from one Node to another Node (that is turned OFF), via a SerialGateway, that the SerialGateway is making a Reset/reinitialyzation (Gateway startup complete), upone tryning to relay/delivery the message to the Node, that now is turned OFF.
      Node(ID 6) -> SerialGateway -> Node(ID 7 and turned OFF).
      Using setDestination(7) on Node(ID 6).
      Error on the SerialGateway, just before it restarts (!TSF:MSG:SEND,6.0.7.7,s=3,c=1,t=16.pt=1,1=1,sg=0,ft=0,st=NACK:1)
        Do you have any capacitor mounted on the gateway radio?
        The radio will send a burst of messages (when no ack is received) which could result in power drop (resetting the arduino) if the radio isn't decoupled correctly.
        delinendD 1 Reply Last reply
          delinendD
          delinendD
          delinend
          @hek
          Yes. 100uF and a 10nF (parallel) on all Radio's.
          I see no problem, when I send from Node(ID 6) to the SerialGateway.
          And I see no problem when I send from Node(ID 6) via the SerialGateway to Node(ID 7).
          The SerialGateway reboot's, if I turn OFF Node(ID 7) and the SerialGateway can't send to it.
          tekkaT 1 Reply Last reply
          • delinendD delinend
            @hek
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @delinend Can you provide a full debug log of all involved nodes for both scenarios? This would help to investigate the issue further. Also, please indicate AVR board def version.
            • tekkaT tekka
              delinendD
              delinendD
              delinend
              @tekka
              Sure.. AVR Boards version 1.6.14
              Here the SerialGateway:
              0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              0;255;3;0;9;TSM:READY
              0;255;0;0;18;2.0.1-beta
              0;255;3;0;9;MCO:BGN:STP
              0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;TSF:MSG:BC
              0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6
              0;255;3;0;9;TSF:PNG:SEND,TO=0
              0;255;3;0;9;TSF:CKU:OK
              0;255;3;0;9;TSF:MSG:GWL OK
              0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1
              0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
              6;255;0;0;17;2.0.1-beta
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              6;255;3;0;6;0
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
              6;255;3;0;11;Binary Sensor
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
              6;255;3;0;12;1.0
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
              6;3;0;0;0;
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
              6;3;1;0;16;1
              0;255;3;0;9;TSF:MSG:READ,6-6-7,s=3,c=1,t=16,pt=1,l=1,sg=0:1
              0;255;3;0;9;TSF:MSG:REL MSG
              0;255;3;0;9;!TSF:MSG:SEND,6-0-7-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:1
              Here Node(ID 6) that sends data to the SerialGateway, and Node(ID 7). The Node(ID 7) is turned OFF.:
              0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta
              4 TSM:INIT
              10 TSM:INIT:TSP OK
              12 TSM:INIT:STATID=6
              14 TSF:SID:OK,ID=6
              16 TSM:FPAR
              53 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              137 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              143 TSF:MSG:FPAR OK,ID=0,D=1
              2062 TSM:FPAR:OK
              2062 TSM:ID
              2064 TSM:ID:OK
              2066 TSM:UPL
              2070 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2088 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2095 TSF:MSG:PONG RECV,HP=1
              2099 TSM:UPL:OK
              2101 TSM:READY
              2103 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2113 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
              2123 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2131 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              4134 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor
              4145 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              4153 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
              4161 MCO:REG:REQ
              4165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4175 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4182 MCO:PIM:NODE REG=1
              4184 MCO:BGN:STP
              4186 MCO:BGN:INIT OK,ID=6,PAR=0,DIS=1,REG=1
              4190 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
              4196 MCO:SLP:TPD
              4198 MCO:SLP:WUP=-1
              4202 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
              4210 TSF:MSG:SEND,6-6-0-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
              4218 MCO:SLP:MS=0,SMS=0,I1=0,M1=1,I2=255,M2=255
              4222 MCO:SLP:TPD
              Btw. I have tryed to set all radio's to MIN power. But same result. If I turn ON Node(ID 7), everything works fine.
                @tekka
                6;255;3;0;6;0
                6;255;3;0;12;1.0
                6;3;0;0;0;
                6;3;1;0;16;1
                4 TSM:INIT
                10 TSM:INIT:TSP OK
                14 TSF:SID:OK,ID=6
                16 TSM:FPAR
                2062 TSM:FPAR:OK
                2062 TSM:ID
                2064 TSM:ID:OK
                2066 TSM:UPL
                2099 TSM:UPL:OK
                2101 TSM:READY
                4161 MCO:REG:REQ
                4184 MCO:BGN:STP
                4196 MCO:SLP:TPD
                4198 MCO:SLP:WUP=-1
                4222 MCO:SLP:TPD
                tekkaT
                tekkaT
                tekka
                @delinend Ok, could you also enable MY_DEBUG_VERBOSE_RF24 in your GW, I need to see how far the message goes in the RF24 driver - I suspect a power issue.
                • tekkaT tekka
                  delinendD
                  delinendD
                  delinend
                  @tekka
                  Hmm.. That is ode..
                  If I enable the MY_DEBUG_VERBOSE_RF24, the SerialGateway is NOT rebooting ?!?!
                  Here a snip from the LOG:
                  0;255;3;0;9;RF24:read register, reg=23, value=17
                  0;255;3;0;9;RF24:read register, reg=23, value=16
                  0;255;3;0;9;RF24:read message, len=8
                  0;255;3;0;9;RF24:write register, reg=7, value=64
                  6;3;1;0;16;1
                  0;255;3;0;9;RF24:stop listening
                  0;255;3;0;9;RF24:write register, reg=0, value=14
                  0;255;3;0;9;RF24:open writing pipe, recipient=7
                  0;255;3;0;9;RF24:write register, reg=10, value=7
                  0;255;3;0;9;RF24:write register, reg=16, value=7
                  0;255;3;0;9;RF24:send message to 7, len=8
                  0;255;3;0;9;RF24:flushTX
                  0;255;3;0;9;RF24:write register, reg=7, value=48
                  0;255;3;0;9;RF24:MAX_RT
                  0;255;3;0;9;RF24:start listening
                  0;255;3;0;9;RF24:write register, reg=0, value=15
                  0;255;3;0;9;RF24:write register, reg=10, value=0
                  0;255;3;0;9;RF24:read register, reg=23, value=17```
                    @tekka
                    Hmm.. That is ode..
                    6;3;1;0;16;1
                    tekkaT
                    tekkaT
                    tekka
                    @delinend weird indeed. If you disable all debugs, how does it behave then?
                    delinendD 2 Replies Last reply
                    • tekkaT tekka
                      delinendD
                      delinendD
                      delinend
                      @tekka
                      Her my codes...
                      Node(ID 6):
                      #define MY_NODE_ID 6
                      //#define MY_DEFAULT_ERR_LED_PIN 4
                      #define MY_RF24_CHANNEL 101
                      #define MY_RF24_DATARATE RF24_250KBPS
                      #define MY_RF24_PA_LEVEL RF24_PA_MIN
                      //#define MY_PARENT_NODE_ID 0
                      //#define MY_TRANSPORT_DONT_CARE_MODE
                      #define SKETCH_NAME "Binary Sensor"
                      #define SKETCH_MAJOR_VER "1"
                      #define SKETCH_MINOR_VER "0"
                      #define PRIMARY_CHILD_ID 3
                      #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
                      MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
                        // Setup the buttons
                        pinMode(PRIMARY_BUTTON_PIN, INPUT);
                      void presentation() {
                        sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
                        // Register binary input sensor to sensor_node (they will be created as child devices)
                        present(PRIMARY_CHILD_ID, S_DOOR);
                        uint8_t value;
                        static uint8_t sentValue=2;
                        //static uint8_t sentValue2=2;
                        sleep(5);
                        value = digitalRead(PRIMARY_BUTTON_PIN);
                        if (value != sentValue) {
                           // Value has changed from last transmission, send the updated value
                           send(msg.setDestination(0).set(value==HIGH));
                           send(msg.setDestination(7).set(value==HIGH));
                           sentValue = value;
                        // Sleep until something happens with the sensor
                        sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
                      Here the SerialGateway code:
                      //#define MY_DEBUG_VERBOSE_RF24
                      // Enable serial gateway
                      #define MY_GATEWAY_SERIAL
                      // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                      #if F_CPU == 8000000L
                      //#define MY_BAUD_RATE 38400
                      // Enable inclusion mode
                      // Set blinking period
                      // Flash leds on rx/tx/err
                        delay(1);
                      • tekkaT tekka
                        delinendD
                        delinendD
                        delinend
                        @tekka
                        And yes... If I remove the MY_DEBUG, it do NOT reboot !?!
                        So the SerialGateway reboot only, when I use the #define MY_DEBUG
                        Strange :-(
                          @tekka
                          Strange :-(
                          tekkaT
                          tekkaT
                          tekka
                          @delinend Yeah, and I assume if you downgrade your AVR board defs to 1.6.11 or .12, everything is fine?
                          • tekkaT tekka
                            delinendD
                            delinendD
                            delinend
                            @tekka
                            Hmmm Strange. It work fine with 1.6.11 ?!?
                            Why is there errors with 1.6.14 - 1.6.13 and 1.6.12 ?
