  3. SerialGateway is rebooting on relay.
13 Posts 3 Posters 4.2k Views 2 Watching
    Do you have any capacitor mounted on the gateway radio?
    The radio will send a burst of messages (when no ack is received) which could result in power drop (resetting the arduino) if the radio isn't decoupled correctly.
    delinendD
    delinendD
    delinend
    @hek
    Yes. 100uF and a 10nF (parallel) on all Radio's.
    I see no problem, when I send from Node(ID 6) to the SerialGateway.
    And I see no problem when I send from Node(ID 6) via the SerialGateway to Node(ID 7).
    The SerialGateway reboot's, if I turn OFF Node(ID 7) and the SerialGateway can't send to it.
    tekkaT 1 Reply Last reply
    • delinendD delinend
      @hek
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @delinend Can you provide a full debug log of all involved nodes for both scenarios? This would help to investigate the issue further. Also, please indicate AVR board def version.
      delinendD 1 Reply Last reply
      • tekkaT tekka
        delinendD
        delinendD
        delinend
        wrote on last edited by delinend
        @tekka
        Sure.. AVR Boards version 1.6.14
        Here the SerialGateway:
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        0;255;3;0;9;TSM:READY
        0;255;0;0;18;2.0.1-beta
        0;255;3;0;9;MCO:BGN:STP
        0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
        0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSF:MSG:BC
        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6
        0;255;3;0;9;TSF:PNG:SEND,TO=0
        0;255;3;0;9;TSF:CKU:OK
        0;255;3;0;9;TSF:MSG:GWL OK
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
        6;255;0;0;17;2.0.1-beta
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        6;255;3;0;6;0
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
        6;255;3;0;11;Binary Sensor
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        6;255;3;0;12;1.0
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
        6;3;0;0;0;
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
        6;3;1;0;16;1
        0;255;3;0;9;TSF:MSG:READ,6-6-7,s=3,c=1,t=16,pt=1,l=1,sg=0:1
        0;255;3;0;9;TSF:MSG:REL MSG
        0;255;3;0;9;!TSF:MSG:SEND,6-0-7-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:1
        Here Node(ID 6) that sends data to the SerialGateway, and Node(ID 7). The Node(ID 7) is turned OFF.:
        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta
        4 TSM:INIT
        10 TSM:INIT:TSP OK
        12 TSM:INIT:STATID=6
        14 TSF:SID:OK,ID=6
        16 TSM:FPAR
        53 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        137 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        143 TSF:MSG:FPAR OK,ID=0,D=1
        2062 TSM:FPAR:OK
        2062 TSM:ID
        2064 TSM:ID:OK
        2066 TSM:UPL
        2070 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2088 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2095 TSF:MSG:PONG RECV,HP=1
        2099 TSM:UPL:OK
        2101 TSM:READY
        2103 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2113 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
        2123 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        2131 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        4134 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor
        4145 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        4153 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
        4161 MCO:REG:REQ
        4165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        4175 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        4182 MCO:PIM:NODE REG=1
        4184 MCO:BGN:STP
        4186 MCO:BGN:INIT OK,ID=6,PAR=0,DIS=1,REG=1
        4190 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        4196 MCO:SLP:TPD
        4198 MCO:SLP:WUP=-1
        4202 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
        4210 TSF:MSG:SEND,6-6-0-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
        4218 MCO:SLP:MS=0,SMS=0,I1=0,M1=1,I2=255,M2=255
        4222 MCO:SLP:TPD
        Btw. I have tryed to set all radio's to MIN power. But same result. If I turn ON Node(ID 7), everything works fine.
          @tekka
          6;255;3;0;6;0
          6;255;3;0;12;1.0
          6;3;0;0;0;
          6;3;1;0;16;1
          4 TSM:INIT
          10 TSM:INIT:TSP OK
          14 TSF:SID:OK,ID=6
          16 TSM:FPAR
          2062 TSM:FPAR:OK
          2062 TSM:ID
          2064 TSM:ID:OK
          2066 TSM:UPL
          2099 TSM:UPL:OK
          2101 TSM:READY
          4161 MCO:REG:REQ
          4184 MCO:BGN:STP
          4196 MCO:SLP:TPD
          4198 MCO:SLP:WUP=-1
          4222 MCO:SLP:TPD
          tekkaT
          tekkaT
          tekka
          @delinend Ok, could you also enable MY_DEBUG_VERBOSE_RF24 in your GW, I need to see how far the message goes in the RF24 driver - I suspect a power issue.
          • tekkaT tekka
            delinendD
            delinendD
            delinend
            @tekka
            Hmm.. That is ode..
            If I enable the MY_DEBUG_VERBOSE_RF24, the SerialGateway is NOT rebooting ?!?!
            Here a snip from the LOG:
            0;255;3;0;9;RF24:read register, reg=23, value=17
            0;255;3;0;9;RF24:read register, reg=23, value=16
            0;255;3;0;9;RF24:read message, len=8
            0;255;3;0;9;RF24:write register, reg=7, value=64
            6;3;1;0;16;1
            0;255;3;0;9;RF24:stop listening
            0;255;3;0;9;RF24:write register, reg=0, value=14
            0;255;3;0;9;RF24:open writing pipe, recipient=7
            0;255;3;0;9;RF24:write register, reg=10, value=7
            0;255;3;0;9;RF24:write register, reg=16, value=7
            0;255;3;0;9;RF24:send message to 7, len=8
            0;255;3;0;9;RF24:flushTX
            0;255;3;0;9;RF24:write register, reg=7, value=48
            0;255;3;0;9;RF24:MAX_RT
            0;255;3;0;9;RF24:start listening
            0;255;3;0;9;RF24:write register, reg=0, value=15
            0;255;3;0;9;RF24:write register, reg=10, value=0
            0;255;3;0;9;RF24:read register, reg=23, value=17```
              @tekka
              Hmm.. That is ode..
              6;3;1;0;16;1
              tekkaT
              tekkaT
              tekka
              @delinend weird indeed. If you disable all debugs, how does it behave then?
              delinendD 2 Replies Last reply
              • tekkaT tekka
                delinendD
                delinendD
                delinend
                @tekka
                Her my codes...
                Node(ID 6):
                #define MY_NODE_ID 6
                //#define MY_DEFAULT_ERR_LED_PIN 4
                #define MY_RF24_CHANNEL 101
                #define MY_RF24_PA_LEVEL RF24_PA_MIN
                //#define MY_PARENT_NODE_ID 0
                //#define MY_TRANSPORT_DONT_CARE_MODE
                #define SKETCH_MAJOR_VER "1"
                #define SKETCH_MINOR_VER "0"
                #define PRIMARY_CHILD_ID 3
                  // Setup the buttons
                  uint8_t value;
                  static uint8_t sentValue=2;
                  //static uint8_t sentValue2=2;
                  sleep(5);
                  if (value != sentValue) {
                     send(msg.setDestination(0).set(value==HIGH));
                     send(msg.setDestination(7).set(value==HIGH));
                     sentValue = value;
                  sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
                Here the SerialGateway code:
                // Enable serial gateway
                #define MY_GATEWAY_SERIAL
                #if F_CPU == 8000000L
                //#define MY_BAUD_RATE 38400
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                  delay(1);
                • tekkaT tekka
                  delinendD
                  delinendD
                  delinend
                  @tekka
                  And yes... If I remove the MY_DEBUG, it do NOT reboot !?!
                  So the SerialGateway reboot only, when I use the #define MY_DEBUG
                  Strange :-(
                    @tekka
                    Strange :-(
                    tekkaT
                    tekkaT
                    tekka
                    @delinend Yeah, and I assume if you downgrade your AVR board defs to 1.6.11 or .12, everything is fine?
                    • tekkaT tekka
                      delinendD
                      delinendD
                      delinend
                      @tekka
                      Hmmm Strange. It work fine with 1.6.11 ?!?
                      Why is there errors with 1.6.14 - 1.6.13 and 1.6.12 ?
                      12.5k
