SerialGateway is rebooting on relay.
Hmm. I can see, it at general problem, when sending a message from one Node to another Node (that is turned OFF), via a SerialGateway, that the SerialGateway is making a Reset/reinitialyzation (Gateway startup complete), upone tryning to relay/delivery the message to the Node, that now is turned OFF.
Node(ID 6) -> SerialGateway -> Node(ID 7 and turned OFF).
Using setDestination(7) on Node(ID 6).
Error on the SerialGateway, just before it restarts (!TSF:MSG:SEND,6.0.7.7,s=3,c=1,t=16.pt=1,1=1,sg=0,ft=0,st=NACK:1)
Do you have any capacitor mounted on the gateway radio?
The radio will send a burst of messages (when no ack is received) which could result in power drop (resetting the arduino) if the radio isn't decoupled correctly.
@hek
Yes. 100uF and a 10nF (parallel) on all Radio's.
I see no problem, when I send from Node(ID 6) to the SerialGateway.
And I see no problem when I send from Node(ID 6) via the SerialGateway to Node(ID 7).The SerialGateway reboot's, if I turn OFF Node(ID 7) and the SerialGateway can't send to it.
@hek
@delinend Can you provide a full debug log of all involved nodes for both scenarios? This would help to investigate the issue further. Also, please indicate AVR board def version.
@tekka
Sure.. AVR Boards version 1.6.14Here the SerialGateway:
0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:INIT:TSP OK 0;255;3;0;9;TSM:INIT:GW MODE 0;255;3;0;9;TSM:READY 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.0.1-beta 0;255;3;0;9;MCO:REG:NOT NEEDED 0;255;3;0;9;MCO:BGN:STP 0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1 0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;TSF:MSG:BC 0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6 0;255;3;0;9;TSF:PNG:SEND,TO=0 0;255;3;0;9;TSF:CKU:OK 0;255;3;0;9;TSF:MSG:GWL OK 0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1 0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta 6;255;0;0;17;2.0.1-beta 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0 6;255;3;0;6;0 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor 6;255;3;0;11;Binary Sensor 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0 6;255;3;0;12;1.0 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0: 6;3;0;0;0; 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2 0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1 6;3;1;0;16;1 0;255;3;0;9;TSF:MSG:READ,6-6-7,s=3,c=1,t=16,pt=1,l=1,sg=0:1 0;255;3;0;9;TSF:MSG:REL MSG 0;255;3;0;9;!TSF:MSG:SEND,6-0-7-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:1 0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:INIT:TSP OK 0;255;3;0;9;TSM:INIT:GW MODE 0;255;3;0;9;TSM:READY 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.0.1-beta 0;255;3;0;9;MCO:REG:NOT NEEDED 0;255;3;0;9;MCO:BGN:STP 0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1Here Node(ID 6) that sends data to the SerialGateway, and Node(ID 7). The Node(ID 7) is turned OFF.:
0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta 4 TSM:INIT 10 TSM:INIT:TSP OK 12 TSM:INIT:STATID=6 14 TSF:SID:OK,ID=6 16 TSM:FPAR 53 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 137 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0 143 TSF:MSG:FPAR OK,ID=0,D=1 2062 TSM:FPAR:OK 2062 TSM:ID 2064 TSM:ID:OK 2066 TSM:UPL 2070 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2088 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2095 TSF:MSG:PONG RECV,HP=1 2099 TSM:UPL:OK 2101 TSM:READY 2103 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 2113 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta 2123 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 2131 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 4134 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor 4145 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0 4153 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK: 4161 MCO:REG:REQ 4165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 4175 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1 4182 MCO:PIM:NODE REG=1 4184 MCO:BGN:STP 4186 MCO:BGN:INIT OK,ID=6,PAR=0,DIS=1,REG=1 4190 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255 4196 MCO:SLP:TPD 4198 MCO:SLP:WUP=-1 4202 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1 4210 TSF:MSG:SEND,6-6-0-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1 4218 MCO:SLP:MS=0,SMS=0,I1=0,M1=1,I2=255,M2=255 4222 MCO:SLP:TPDBtw. I have tryed to set all radio's to MIN power. But same result. If I turn ON Node(ID 7), everything works fine.
@tekka
@delinend Ok, could you also enable MY_DEBUG_VERBOSE_RF24 in your GW, I need to see how far the message goes in the RF24 driver - I suspect a power issue.
@tekka
Hmm.. That is ode..
If I enable the MY_DEBUG_VERBOSE_RF24, the SerialGateway is NOT rebooting ?!?!Here a snip from the LOG:
0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=16 0;255;3;0;9;RF24:read message, len=8 0;255;3;0;9;RF24:write register, reg=7, value=64 0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1 6;3;1;0;16;1 0;255;3;0;9;RF24:read register, reg=23, value=16 0;255;3;0;9;RF24:read message, len=8 0;255;3;0;9;RF24:write register, reg=7, value=64 0;255;3;0;9;TSF:MSG:READ,6-6-7,s=3,c=1,t=16,pt=1,l=1,sg=0:1 0;255;3;0;9;TSF:MSG:REL MSG 0;255;3;0;9;RF24:stop listening 0;255;3;0;9;RF24:write register, reg=0, value=14 0;255;3;0;9;RF24:open writing pipe, recipient=7 0;255;3;0;9;RF24:write register, reg=10, value=7 0;255;3;0;9;RF24:write register, reg=16, value=7 0;255;3;0;9;RF24:send message to 7, len=8 0;255;3;0;9;RF24:flushTX 0;255;3;0;9;RF24:write register, reg=7, value=48 0;255;3;0;9;RF24:MAX_RT 0;255;3;0;9;RF24:flushTX 0;255;3;0;9;RF24:start listening 0;255;3;0;9;RF24:write register, reg=0, value=15 0;255;3;0;9;RF24:write register, reg=10, value=0 0;255;3;0;9;!TSF:MSG:SEND,6-0-7-7,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:1 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17 0;255;3;0;9;RF24:read register, reg=23, value=17``` -
@tekka
Hmm.. That is ode..
@tekka
Her my codes...Node(ID 6):
// Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 #define MY_NODE_ID 6 //#define MY_DEFAULT_ERR_LED_PIN 4 #define MY_RF24_CHANNEL 101 #define MY_RF24_DATARATE RF24_250KBPS #define MY_RF24_PA_LEVEL RF24_PA_MIN //#define MY_PARENT_NODE_ID 0 //#define MY_TRANSPORT_DONT_CARE_MODE #include <MySensors.h> #define SKETCH_NAME "Binary Sensor" #define SKETCH_MAJOR_VER "1" #define SKETCH_MINOR_VER "0" #define PRIMARY_CHILD_ID 3 #define PRIMARY_BUTTON_PIN 2 // Arduino Digital I/O pin for button/reed switch // Change to V_LIGHT if you use S_LIGHT in presentation below MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED); void setup() { // Setup the buttons pinMode(PRIMARY_BUTTON_PIN, INPUT); } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER); // Register binary input sensor to sensor_node (they will be created as child devices) // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage. // If S_LIGHT is used, remember to update variable type you send in. See "msg" above. present(PRIMARY_CHILD_ID, S_DOOR); } // Loop will iterate on changes on the BUTTON_PINs void loop() { uint8_t value; static uint8_t sentValue=2; //static uint8_t sentValue2=2; // Short delay to allow buttons to properly settle sleep(5); value = digitalRead(PRIMARY_BUTTON_PIN); if (value != sentValue) { // Value has changed from last transmission, send the updated value send(msg.setDestination(0).set(value==HIGH)); send(msg.setDestination(7).set(value==HIGH)); sentValue = value; } // Sleep until something happens with the sensor sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0); }Here the SerialGateway code:
// Enable debug prints to serial monitor #define MY_DEBUG //#define MY_DEBUG_VERBOSE_RF24 // Enable and select radio type attached #define MY_RADIO_NRF24 #define MY_RF24_CHANNEL 101 #define MY_RF24_DATARATE RF24_250KBPS #define MY_RF24_PA_LEVEL RF24_PA_MIN // Enable serial gateway #define MY_GATEWAY_SERIAL // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender) #if F_CPU == 8000000L //#define MY_BAUD_RATE 38400 #endif // Enable inclusion mode #define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway //#define MY_INCLUSION_BUTTON_FEATURE // Inverses behavior of inclusion button (if using external pullup) //#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP // Set inclusion mode duration (in seconds) #define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button //#define MY_INCLUSION_MODE_BUTTON_PIN 3 // Set blinking period #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Inverses the behavior of leds //#define MY_WITH_LEDS_BLINKING_INVERSE // Flash leds on rx/tx/err // Uncomment to override default HW configurations //#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin //#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin //#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED #include <MySensors.h> void setup() { // Setup locally attached sensors } void presentation() { // Present locally attached sensors } void loop() { delay(1); } void receive(const MyMessage &message) { } -
@tekka
And yes... If I remove the MY_DEBUG, it do NOT reboot !?!So the SerialGateway reboot only, when I use the #define MY_DEBUG
Strange :-(
@delinend Yeah, and I assume if you downgrade your AVR board defs to 1.6.11 or .12, everything is fine?
