  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
  • NeverDieN
    NeverDieN
    The longest dimension of the discretes is about the height of the font on the "E pluribus unum" phrase of the dime. That's too tiny for me. I think I'll have to do my own board after all so that I may use larger components. 0603 is about as small as I want to go.
    • NeverDieN
      NeverDieN
      The Tindie board includes a tiny SMD LED which lights when Vbat_ok goes HIGH. So, in a room with dim indoor lighting, plugging just the cheap photovoltaic cell into the Tindie device makes the LED briefly flash about once every few seconds. The brighter the indoor light, the faster it flashes. Obviously, the act of flashing the LED drains the on-board storage capacitor, and the cycle repeats. I suppose simply counting the flashes might approximate a crude coulomb counter.
      • NeverDieN
        NeverDieN
        #23
        After playing around with the Tindie board, I think it's safe to say that for a low light energy harvesting application, having the LED on the board is a bug, not a feature because it rapidly throws away the harvested energy.
        So, I'm making my own BQ25504 board. I'm pretty much done with Version 1, except that the land pattern (see attached) may be a little tricky to do in Diptrace because the pads are not purely rectangle nor purely circular.
        • scalzS
          scalzS
          wrote on last edited by scalz
          #24
          i think simple pads should work. But sure it's better to follow recommanded footprint, that can avoid some short during soldering, and is also especially important when using stencils. This kind of shape can help for escaping solder during the process.
          That said, I'm using Eagle...and already did mine :)
          without led of course!
          I think in parameters you will also need to know how long take your capa to charge (if you want to press twice), what capa voltage range needed regarding bq25504 setup res etc.. I still think indoor it would need a little additional bat, because if it's a mote, lot of chance you could press once, and then wait for x sec/min before pushing again. especially if signing enabled. but perhaps you don't need signing with your mote..
          I hope this helps :)
          Edit: i updated the pic with the bottom. but if you want i can share gerbers if you want, as you're using diptrace
          NeverDieN 1 Reply Last reply
          • scalzS scalz
            NeverDieN
            NeverDieN
            @scalz
            Are you connecting your BQ25504 thermal pad to anything on the other side of the board using the via holes? I tentatively connected mine to the large copper ground pour on the other side of the board, on the theory that doing so would help dissipate heat.
            • scalzS
              scalzS
              @NeverDie nope. just copper on bottom. ground return through your powerpad, in this case, can give less perf.
              • scalzS scalz
                NeverDieN
                NeverDieN
                #27
                Yesterday it was sunny outside, and the indoor ambient light was plenty for driving the BQ25504. Today, in stark contrast, it's very overcast outdoors, and the BQ25504 is really struggling. Input voltage from the PV cell with the BQ25504 as the load is hovering around 0.5v or 0.6v. Just a preliminary observation, but I'm not sure the BQ25504 will be useful at input voltages less than about 0.7v. Or maybe the Tiindie board cut some corners or something. I'll have a better idea after I make my own board and compare its performance against the Tindie board.
                • scalzS scalz
                  NeverDieN
                  NeverDieN
                  Are you using tented via's? Because otherwise, it looks as though your thermal pad is electrically connected to the "just copper" on the bottom. But I guess you're not referring to the "just copper" as "ground" because it's not being used as a return path per se? Looking at the "Recommended Layout" (Figure 34 on page 26 of the datasheet), I see it refers to a "Top BND" and a "Bottom GND."
                  At the moment I'm not sure what to do, so I changed from having almost the entire bottom connected to ground to just creating an equivalent thermal pad on the bottom that's the same size as on the top, which is electrically connected via the 5 via's. I haven't specified that the via's be electrically isolated from the top thermal pad, because in the TI diagram (which I posted above) it doesn't appear that they are.
                  • NeverDieN
                    NeverDieN
                    #29
                    Problem solved. Looking more closely at the datasheet's "recommended layout," regular oval pads should be fine:
                    So, no need to go exotic on the pad geometry. I can't tell from looking at it whether the thermal pad on the bottom is isolated from "bottom GND" or not, though.
                    • NeverDieN NeverDie
                      NeverDieN
                      NeverDieN
                      #30
                      This post is deleted!
                        [[topic:post-is-deleted]]
                        NeverDieN
                        NeverDieN
                        #31
                        • NeverDieN
                          NeverDieN
                          • NeverDieN
                            NeverDieN
                            #33
                            Here's what I'm going with for now:
                            As you can see, this one uses only one ground plane. Board size is 22mmx18mm. It uses 0603 and 0805 discrete parts, which for me makes it easier to hand solder. The only tricky part to hand solder will be the BQ25504 itself, but there's nothing I can do about that.
                            • scalzS
                              scalzS
                              @NeverDie
                              sorry for delay..
                              i have a pad on bottom but it's not grounded on the bottom side. the power pad is grounded only on top. i don't remember but you should have a layout guideline included with the circuit footprint, for explaining.
                              i also use 0603/0805.
                              • NeverDieN
                                NeverDieN
                                #35
                                I guess my oval pads reverted to the default pattern when I re-synced with the schematic. So, fixing that again, here's what I'm going with:
                                There's a bit more clean-up I should probably do, but I need to learn a bit more about Diptrace before I can do it. Meanwhile, I sent Version 6 to the fab, since fabbing is the critical path.
                                • scalzS scalz
                                  @NeverDie
                                  sorry for delay..
                                  NeverDieN
                                  NeverDieN
                                  In that case, if you want to post your fab files, I can post mine. Then we can have a healthy competition to see whether they work the same or whether one works better than the other.
                                  • scalzS
                                    scalzS
                                    #37
                                    @NeverDie
                                    oh, no competition... or let me win please :laughing: I'm joking. that said i'm not sure, but I think i see Wally on your board ;)
                                    I'm back in an hour for sharing. i need to assemble few boards for myself :)
                                    • scalzS scalz
                                      @NeverDie
                                      NeverDieN
                                      NeverDieN
                                      #38
                                      LOL. You probably need better ventilation when you're soldering. The fumes are getting to you. :laughing:
                                      NeverDieN scalzS 2 Replies Last reply
                                        NeverDieN
                                        NeverDieN
                                        #39
                                        Interestingly, in today's mail I received the "BQ25504 Stripped" PCB
                                        https://oshpark.com/shared_projects/CYdxpE9S
                                        that I ordered on November 16. That's about twice faster than their normal turnaround speed when I send them new fab files. The board itself is noticeably smaller than the Tindie board.
                                          scalzS
                                          scalzS
                                          #40
                                          :laughing: no fumes tonight, reflow oven working for me :)
                                          Wally is in your GND pour, in each of your board I think.
                                          I mean you should not have any gnd around some settings resistors and capa.
                                          Check carefully the section 11.1 Layout Guidelines in datasheet.
                                          This is why on the reference layout you see Top GND only on half board. Or then it may happen less performance depending of mutliple factors.
                                          It's also explained how to route the GND.
                                          That said, in case it can help, here is my gerbers https://www.dropbox.com/s/tugdbc3cfrlmdu7/bq25504_gerbers.rar?dl=0
                                          Enjoy
