  3. DHT 22 battery sensor MySensors 2.01
12 Posts 4 Posters 4.3k Views 4 Watching
  • P Offline
    P Offline
    pettib
    Hi
    I have changed to MySensors 2.01 and trying to fix my sketches.
    Are you or somebody else able to locate the error in my sketch. I can´t read the temp and humid.
    The hardware is the same as i used with my old sketch, so it will work.
    Here are the debug:
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta
    4 TSM:INIT
    10 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=22
    14 TSF:SID:OK,ID=22
    15 TSM:FPAR
    34 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2041 !TSM:FPAR:NO REPLY
    2043 TSM:FPAR
    2062 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2460 TSF:MSG:READ,50-50-22,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2465 TSF:MSG:FPAR OK,ID=50,D=2
    2540 TSF:MSG:READ,0-0-22,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2545 TSF:MSG:FPAR OK,ID=0,D=1
    4070 TSM:FPAR:OK
    4071 TSM:ID
    4072 TSM:ID:OK
    4074 TSM:UPL
    4076 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4083 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4088 TSF:MSG:PONG RECV,HP=1
    4090 TSM:UPL:OK
    4092 TSM:READY
    4094 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4102 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4108 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
    4118 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    6126 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:Temp_Humid_Bat
    6135 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
    6142 TSF:MSG:SEND,22-22-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6150 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    6156 MCO:REG:REQ
    6159 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    6165 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    6170 MCO:PIM:NODE REG=1
    6173 MCO:BGN:STP
    6175 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    6180 MCO:SLP:TPD
    6182 MCO:SLP:WUP=-1
    6184 MCO:BGN:INIT OK,ID=22,PAR=0,DIS=1,REG=1
    Failed reading temperature from DHT!
    Failed reading humidity from DHT
    Battery percent: 117 %
    7207 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    7214 MCO:SLP:TPD
    7216 MCO:SLP:WUP=-1
    Here are the sketch:
    #define MY_NODE_ID 22
    #include <DHT.h>
    #include <Wire.h>
    //#include <Adafruit_BMP085.h>
    #define DHT_DATA_PIN 3
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define SENSOR_TEMP_OFFSET 0
    #define         READ_SAMPLE_INTERVAL         (10)    //define how many samples you are going to take in normal operation
    #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
    #define         VREF 3.3f
    static const uint64_t UPDATE_INTERVAL = 60000;// Sleep time between sensor updates (in milliseconds)
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    unsigned long preSleepTime = 5*6000; //  sleep time for extra pre hum-reading for simple avaraging filter
    #define SKETCH_NAME "Temp_Humid_Bat"                // Change to a fancy name you like
    #define SKETCH_VERSION "2.0"                    // Your version
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
    void presentation()  {
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
    void setup()  {
    analogReference(INTERNAL);             // For battery sensing
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("Temp: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("Humid: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      //Read batteries
      batM();
      //Sleep!
      sleep(SLEEP_TIME);
    void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 2) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         else
         batLoop++;
    • Maurice KrijtenbergM Offline
      Maurice Krijtenberg
      I noticed the build guide says to use data pin 3, however, the sketch from the examples (DhtTemperatureAndHumiditySensor.ino) uses pin 2. So maybe you got a mismatch there as well.
      P 1 Reply Last reply
      • Maurice KrijtenbergM Maurice Krijtenberg
        P Offline
        P Offline
        pettib
        @Maurice-Krijtenberg
        I'm using an existing board so everything is already connected. I have the sensor on pin 3. Sadly it was not that easy 🤔
        • D Offline
          You can have the sensor connected to any data pin. When I built my first DHT 22 node I was using one of the newbie PCBs and I mistakenly connected the sensor to PIN5 instead of PIN3. I didn't realize it right away and I was not getting any readings. Once I realized my mistake I just changed the sketch to PIN5 and everything worked. I recently updated it to 2.01 and made sure I checked that. Still going strong.
          • D dbemowsk
            P Offline
            P Offline
            pettib
            @dbemowsk can you please share your sketch ?
            And witch library for dht22 are you using ?
            //PT
            D 1 Reply Last reply
            • hekH Offline
              hekH Offline
              Not sure which DHT library you're using. But in the one provided with the mysensors examples you'll have to wait a bit while the sensor does its work, before fetching temp/hum.
              wait(dht.getMinimumSamplingPeriod());
              Serial.print(dht.getTemperature());
              • P pettib
                //PT
                I used the sketch from the examples. What I forgot to mention is that when I used the DHT library that I had installed from my old 1.54 setup, I got errors. If you look at the library linked on the Github page, there is a link to a zip file that they point you to at the bottom of the description. The zip file that is linked there is not the same as the files shown in the Github code pages. DO NOT use the zip file for the 2.01 example. That looked like the same files that I had in my old library that I had for the old 1.54 sketch at a quick glance. If you copy and paste the code shown in the dht.h and the dht.cpp files into your DHT library folder it should work.
                • P Offline
                  P Offline
                  pettib
                  Hi again.
                  Now i made a sketch that almost work.
                  If i run it with debug enabled it works fine but when i run it with debug disabled it dosen´t work.
                  Please help me to find the problem.
                   * Version 1.0: Henrik EKblad
                  // Enable debug prints
                  //#define MY_DEBUG
                  //#define MY_RS485
                  #define MY_NODE_ID 23 //Uterum
                  #include <DHT.h>
                  #include <Wire.h>
                  #define         VREF 3.3f
                  #define SENSOR_TEMP_OFFSET -3.4
                  #ifdef MY_DEBUG
                  #else
                    unsigned long SLEEP_TIME = 900000; // Sleep time between reads (in milliseconds)
                  #define SKETCH_NAME "Temp_Humid_Bat_Uterum"                // Change to a fancy name you like
                  #define SKETCH_VERSION "2.1"                    // Your version
                  float lastTemp;
                  float lastHum;
                  bool metric = true;
                  DHT dht;
                    delay(2000);
                    #ifdef MY_DEBUG
                      Serial.println("***Debug Activated***");
                      Serial.print("Sleep_Time: ");
                      Serial.print((SLEEP_TIME / 1000)/60);
                      Serial.println(" min");
                    #else
                      Serial.println("***Debug Deactivated***");
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      Serial.print("T: ");
                    } else {
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      Serial.print("H: ");
                    } else {
                      nNoUpdatesHum++;
                      //Read batteries
                    batM();
                    //Sleep!
                    sleep(SLEEP_TIME);
                     delay(500);
                     delay(500);
                     if (batLoop > 2) {
                       batteryPcnt=100;
                         batLoop = 0;
                       else
                       batLoop++;
                  • D Offline
                    Out of curiosity, could it be this:
                    #ifdef MY_DEBUG
                    #else
                    It may not be that it is not working, but that your sleep time is so long that you are not seeing the updates. Why are you changing the sleep time at all based on debug?
                    • D dbemowsk
                      #ifdef MY_DEBUG
                      #else
                      P Offline
                      P Offline
                      pettib
                      @dbemowsk
                      @dbemowsk
                      The reason that I use different sleep time is that this is a battery powered unit, and when debug I don't want to whait for 15 minutes to see the readings. I don't understand why the long sleep will stop me from get the readings ? It's the sleep between readings I change with this function.
                      • D Offline
                        Just to rule it out, keep the same sleep time for both and see if your readings update the same as in debug mode. You can always change it back once you know it is working.
                        • D dbemowsk
                          P Offline
                          P Offline
                          pettib
                          @dbemowsk I run that way now. Same time for both with debug and without. It works well with debug activated but not with debug inactive. Same time on both.
