  3. DHT 22 battery sensor MySensors 2.01
12 Posts 4 Posters 4.4k Views 4 Watching
  • Maurice KrijtenbergM
    Maurice Krijtenberg
    I noticed the build guide says to use data pin 3, however, the sketch from the examples (DhtTemperatureAndHumiditySensor.ino) uses pin 2. So maybe you got a mismatch there as well.
    P 1 Reply Last reply
    • Maurice KrijtenbergM Maurice Krijtenberg
      P
      P
      pettib
      @Maurice-Krijtenberg
      I'm using an existing board so everything is already connected. I have the sensor on pin 3. Sadly it was not that easy 🤔
      • dbemowskD
        dbemowskD
        You can have the sensor connected to any data pin. When I built my first DHT 22 node I was using one of the newbie PCBs and I mistakenly connected the sensor to PIN5 instead of PIN3. I didn't realize it right away and I was not getting any readings. Once I realized my mistake I just changed the sketch to PIN5 and everything worked. I recently updated it to 2.01 and made sure I checked that. Still going strong.
        • dbemowskD dbemowsk
          P
          P
          pettib
          @dbemowsk can you please share your sketch ?
          And witch library for dht22 are you using ?
          //PT
          dbemowskD 1 Reply Last reply
            Not sure which DHT library you're using. But in the one provided with the mysensors examples you'll have to wait a bit while the sensor does its work, before fetching temp/hum.
            wait(dht.getMinimumSamplingPeriod());
            Serial.print(dht.getTemperature());
            • P pettib
              //PT
              dbemowskD
              dbemowskD
              I used the sketch from the examples. What I forgot to mention is that when I used the DHT library that I had installed from my old 1.54 setup, I got errors. If you look at the library linked on the Github page, there is a link to a zip file that they point you to at the bottom of the description. The zip file that is linked there is not the same as the files shown in the Github code pages. DO NOT use the zip file for the 2.01 example. That looked like the same files that I had in my old library that I had for the old 1.54 sketch at a quick glance. If you copy and paste the code shown in the dht.h and the dht.cpp files into your DHT library folder it should work.
              • P
                P
                pettib
                Hi again.
                Now i made a sketch that almost work.
                If i run it with debug enabled it works fine but when i run it with debug disabled it dosen´t work.
                Please help me to find the problem.
                 * Version 1.0: Henrik EKblad
                 * sensor using a DHT11/DHT-22.
                // Enable debug prints
                //#define MY_RS485
                #define MY_NODE_ID 23 //Uterum
                #define         READ_SAMPLE_INTERVAL         (10)    //define how many samples you are going to take in normal operation
                #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
                #define         VREF 3.3f
                #define DHT_DATA_PIN 3
                #define SENSOR_TEMP_OFFSET -3.4
                static const uint64_t UPDATE_INTERVAL = 60000;
                #define CHILD_ID_HUM 0
                #define CHILD_ID_TEMP 1
                #ifdef MY_DEBUG
                  unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                #define SKETCH_NAME "Temp_Humid_Bat_Uterum"                // Change to a fancy name you like
                #define SKETCH_VERSION "2.1"                    // Your version
                float lastTemp;
                float lastHum;
                uint8_t nNoUpdatesTemp;
                uint8_t nNoUpdatesHum;
                bool metric = true;
                DHT dht;
                  present(CHILD_ID_HUM, S_HUM);
                  delay(2000);
                  #ifdef MY_DEBUG
                    Serial.println("***Debug Activated***");
                    Serial.print("Sleep_Time: ");
                    Serial.print((SLEEP_TIME / 1000)/60);
                    Serial.println(" min");
                    Serial.println("***Debug Deactivated***");
                  dht.readSensor(true);
                  if (isnan(temperature)) {
                    lastTemp = temperature;
                    if (!metric) {
                    // Reset no updates counter
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                    Serial.print("T: ");
                    nNoUpdatesTemp++;
                  if (isnan(humidity)) {
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                    Serial.print("H: ");
                    Serial.println(humidity);
                    nNoUpdatesHum++;
                    //Read batteries
                  batM();
                  //Sleep!
                  sleep(SLEEP_TIME);
                   delay(500);
                   // Battery monitoring reading
                   delay(500);
                   // Calculate the battery in %
                   if (batLoop > 2) {
                   if (batteryPcnt > 100) {
                     batteryPcnt=100;
                       batLoop = 0;
                     batLoop++;
                • dbemowskD
                  dbemowskD
                  Out of curiosity, could it be this:
                  #ifdef MY_DEBUG
                  It may not be that it is not working, but that your sleep time is so long that you are not seeing the updates. Why are you changing the sleep time at all based on debug?
                    #ifdef MY_DEBUG
                    P
                    P
                    pettib
                    @dbemowsk
                    @dbemowsk
                    The reason that I use different sleep time is that this is a battery powered unit, and when debug I don't want to whait for 15 minutes to see the readings. I don't understand why the long sleep will stop me from get the readings ? It's the sleep between readings I change with this function.
                    • dbemowskD
                      dbemowskD
                      Just to rule it out, keep the same sleep time for both and see if your readings update the same as in debug mode. You can always change it back once you know it is working.
                        P
                        P
                        pettib
                        @dbemowsk I run that way now. Same time for both with debug and without. It works well with debug activated but not with debug inactive. Same time on both.
