  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P pentti12
    Now I am confused, why I should bridge Ethernet Gateway, if I have USB-connection to MySensors Gateway only?
    I tried to use Ethernet Gateway connected into my local IP-network without success, so I think that I will end this work to this point. There seems no good instructions available what is missing or wrong on the MySensors openhab binding..
    JicJ
    JicJ
    Jic
    @pentti12
    Ok, sorry, I think I was wrong.
    Here has a similar example
    http://www.makeuseof.com/tag/diy-smart-home-sensors-arduino-mysensors-openhab/
    Could you try connecting it again separately, and configure in your OH2 and ethernet binding with the ip from your gatweay?
    • pentti12P
      pentti12P
      pentti12
      Can someone explain, why I cannot get real values from MySensors node, which has only temperature and humidity sensors?
      I can get the MySensors Ethernet Gateway into ONLINE STATE. I can get humidity and Temperature Sensors ONLINE STATE, but I cannot get real values from the node.
      What I see from OpenHAB2 log side is:
      09:31:45.356 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
      09:31:45.375 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
      09:31:48.356 [WARN ] [otocol.MySensorsNetworkSanityChecker] - I_VERSION message response is not arrived. Remained attempts before disconnection 1
      09:31:55.377 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
      09:32:05.380 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
      I think that there must be some error in MySensors Binding at the moment, because for example the Philips HUE bridge is working corretly via Openhab2 in the same Pine64 controller.
      JicJ T 2 Replies Last reply
        JicJ
        JicJ
        Jic
        @pentti12
        This message is, following the information
        https://www.mysensors.org/download/serial_api_20
        node-id ; child-sensor-id ; message-type ; ack ; sub-type ; payload \n
        0; ;0 ;3 ;0 ;2 ;
        A message-type=3 means an internal message of the protocol
        Sub-type=2 means that it is ascking for the gateway version.
        You can find here how to disable it using skipStartupCheck=true
        https://github.com/tobof/openhab2-addons/wiki/Configuration
        Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200, skipStartupCheck=true ] {
             /** define things connected to that bridge here */
        I hope this help you.
          TimO
          Hey @pentti12!
          Which gateway are you using? Serial or Ethernet? You can't use the ethernet gateway via serial connection.
          Which sketch are you using?
          If you are using ethernet gateway sketch but used the serial connection this would explain why the binding could not get any response.
          • pentti12P
            pentti12P
            pentti12
            I am using Ethernet Gateway in my LAN. Gateway has static IP and it is accessible (ping works). Also port number 5003 is detected correctly.
            I am using standard GatewayW5100.ino sketch.
            How can I force OH2 to use only Ethernet-connection?
            • T
              TimO
              Have you configured the gateway in the *.things file? How does it look?
              • triceTT
                triceTT
                triceT
                Hello to all.
                I have similar problems as pentti12.
                Can not get values updated in OH2, there are always -NAN
                While with serial connection I get some reads in the log file, with eth connection I can't see any reads from gw.
                I've installed everything as per wiki several times without success.
                Radio connection between gw and nodes is running without problems.
                Previous testing gw with w5100MQTTClient sketch, was running perfectly
                My configuration:
                MySensors Binding: 2.0.0.201611221149
                OH2: 2.0.0-SNAPSHOT Build #629 running on debian
                gw: Arduino Uno with W5100 sketch
                Node: arduino nano with temp and humidity sensor.
                Could somebody help me in this.
                Regards!
                *** Debug for serial connection without skipping I-Version check
                2016-12-05 22:06:22.608 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                2016-12-05 22:06:22.634 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                2016-12-05 22:06:25.665 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
                2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
                2016-12-05 22:06:25.668 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
                2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
                2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
                2016-12-05 22:06:25.865 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:06:26.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
                2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                2016-12-05 22:06:27.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:06:28.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:06:29.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:27)
                2016-12-05 22:06:30.666 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                2016-12-05 22:06:30.666 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                2016-12-05 22:06:30.666 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialWriter
                2016-12-05 22:06:30.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                2016-12-05 22:06:30.670 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                *** Debug for serial connection skipping I-Version check
                2016-12-05 22:16:52.785 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                2016-12-05 22:16:52.786 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: true
                2016-12-05 22:16:52.787 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                2016-12-05 22:16:52.789 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                2016-12-05 22:16:52.793 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                2016-12-05 22:16:52.821 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                2016-12-05 22:16:55.852 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                2016-12-05 22:16:55.855 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
                2016-12-05 22:16:55.856 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
                2016-12-05 22:16:55.855 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
                2016-12-05 22:16:55.860 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:power:9ba30e1b
                2016-12-05 22:16:55.862 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
                2016-12-05 22:16:55.863 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                2016-12-05 22:16:55.863 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-6 not registered yet, registering...
                2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
                2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
                2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
                2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
                2016-12-05 22:16:57.553 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
                2016-12-05 22:16:57.558 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:BC
                2016-12-05 22:17:00.812 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:FPAR REQ (sender=4)
                2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:GWL OK
                2016-12-05 22:17:01.091 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                2016-12-05 22:17:02.854 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                2016-12-05 22:17:02.857 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=1)
                2016-12-05 22:17:02.868 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                2016-12-05 22:17:02.881 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                2016-12-05 22:17:02.924 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                2016-12-05 22:17:02.935 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                2016-12-05 22:17:04.940 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                2016-12-05 22:17:05.863 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-12-05 22:17:06.765 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                2016-12-05 22:17:08.599 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=0,t=1,pt=0,l=0,sg=0:
                2016-12-05 22:17:10.422 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=0,t=7,pt=0,l=0,sg=0:
                2016-12-05 22:17:12.248 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                2016-12-05 22:17:12.258 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                2016-12-05 22:17:12.261 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                2016-12-05 22:17:12.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1
                2016-12-05 22:17:12.309 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                2016-12-05 22:17:12.320 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                2016-12-05 22:17:12.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.3
                2016-12-05 22:17:14.157 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.8
                2016-12-05 22:17:15.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-12-05 22:17:15.980 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.788
                2016-12-05 22:17:25.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-12-05 22:17:34.431 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:1
                2016-12-05 22:17:35.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-12-05 22:17:36.265 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.4
                2016-12-05 22:17:38.088 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.6
                2016-12-05 22:17:39.911 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.768
                2016-12-05 22:17:41.744 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:0
                *** Debug for Ethernet connection without skipping I-Version check
                2016-12-05 22:23:12.927 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                2016-12-05 22:23:12.930 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: false
                2016-12-05 22:23:12.931 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                2016-12-05 22:23:12.934 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                2016-12-05 22:23:12.935 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                2016-12-05 22:23:12.937 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                2016-12-05 22:23:12.938 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
                2016-12-05 22:23:13.148 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:23:13.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:23:14.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:23:15.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:23:16.964 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-12-05 22:23:17.964 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                2016-12-05 22:23:17.967 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                2016-12-05 22:23:17.968 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                2016-12-05 22:23:17.968 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                2016-12-05 22:23:17.971 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                2016-12-05 22:23:17.975 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 10, revertState: false
                2016-12-05 22:23:17.976 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 11, revertState: false
                2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                2016-12-05 22:23:17.990 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                2016-12-05 22:23:17.991 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                *** Debug for Ethernet connection skipping I-Version check
                2016-12-05 22:27:59.514 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
                2016-12-05 22:27:59.515 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                2016-12-05 22:27:59.515 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                2016-12-05 22:27:59.525 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                2016-12-05 22:27:59.527 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
                2016-12-05 22:27:59.527 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                2016-12-05 22:27:59.528 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Network Sanity Checker thread disabled from bridge configuration
                2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
                2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                2016-12-05 22:28:09.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                2016-12-05 22:28:19.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                T 1 Reply Last reply
                • triceTT triceT
                  Hello to all.
                  My configuration:
                  Regards!
                  TimO
                  wrote on last edited by TimO
                  #68
                  @triceT you're trying to connect per serial to your ethernet gateway. Try connecting with the ethernet gateway configuration using the IP 192.168.1.66 and port 5003, like in the last output of your post. You only get the debug output of the serial gateway in OH2, the messages from the nodes are not forwarded to serial.
                  The connection seems to be get established, but there is no answer to the I_VERSION message. Are you using RFM69? Did you try a "telnet 192.168.1.66 5003"? Do you see messages incoming?
                  triceTT 1 Reply Last reply
                  • T TimO
                    triceTT
                    triceTT
                    triceT
                    @TimO Thanks for your help....
                    I'm using nrf24 radio.
                    When I telnet I receive only this:
                    Trying 192.168.1.66...
                    Connected to 192.168.1.66.
                    Escape character is '^]'.
                    No mesages are shown
                    • triceTT
                      triceTT
                      triceT
                      This is what I'm getting on Arduino gw connecting over ethernet and setting skipstartupcheck to false. If I set skipstartupcheck to true, gw is not receiving anything from ethernet.
                      0;255;3;0;9;Eth: connect
                      0;255;3;0;9;Eth: 0;0;3;0;2;
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth: disconnect
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      • triceTT triceT
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        TimO
                        @triceT Are you sure the gateway isn't in a boot loop? Could you please check serial debug if it gets started over and over again?
                        • T TimO
                          triceTT
                          triceTT
                          triceT
                          @TimO I guess it is not in a loop. Here is the serial debug...
                          IP: 192.168.1.66
                          0;255;3;0;9;Eth:
                          0;255;3;0;9;Eth:
                          0;255;3;0;9;Eth:
                          0;255;3;0;9;Eth:
                          0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                          0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:61.7
                          0;255;3;0;9;Eth:
                          0;255;3;0;9;Eth:
                          0;255;3;0;9;TSP:SANCHK:OK
                          • carlylerC
                            carlylerC
                            carlyler
                            @TimO brief setup: controller and serial gateway on raspberryPi running OH2, serial working OK. Trying to add ESP8266 Huzzah gateway with only local sensor, DHT22 - no radio. It seems I have a similar situation as others, but before I post all my setup and logs a question for you: when using both a serial gateway and ethernet gateway can they be named the same, "gateway", in things file? What bothers me is the "channel" in the items file ends up looking like it is from the same source or am I missing something?
                            Things file:
                            Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyMySensorsGateway", sendDelay=200 ]
                               humidity         hum01   [ nodeId="1", childId="0" ]
                               temperature      temp01  [ nodeId="1", childId="1" ]
                               humidity         hum02   [ nodeId="1", childId="2" ]
                               temperature      temp02  [ nodeId="1", childId="3" ]
                               humidity         hum03   [ nodeId="1", childId="4" ]
                               temperature      temp03  [ nodeId="1", childId="5" ]
                               power            power01 [ nodeId="2", childId="0" ]
                               mySensorsMessage mySMsg01    [ nodeId="999", childId="999" ]
                            Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.113", tcpPort=5003, sendDelay=200 ]
                               humidity         hum04   [ nodeId="3", childId="0" ]
                               temperature      temp04  [ nodeId="3", childId="1" ]
                            Items file snippet (hum02/temp02 on serial GW and hum04/temp04 on eth GW)
                            Number mHum                 "Master Humidity [%.0f %%]"             <humidity>      (grpChart,grpTemperatures)  { channel="mysensors:humidity:gateway:hum02:hum" }
                            Number mTemp                "Master Temperature"                    <temperature>                               { channel="mysensors:temperature:gateway:temp02:temp" }
                            Number bHum                 "Bean's Humidity [%.0f %%]"             <humidity>      (grpChart,grpTemperatures)  { channel="mysensors:humidity:gateway:hum04:hum" }
                            Number bTemp                "Bean's Temperature"                    <temperature>                               { channel="mysensors:temperature:gateway:temp04:temp" }
                            • carlylerC carlyler
                              Things file:
                              TimO
                              @carlyler The name must be unique for each gateway. So please change that first and report back, if that solves the problem.
                              • triceTT triceT
                                IP: 192.168.1.66
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                TimO
                                @triceT Just to make sure it is still working with the current snapshot I made a clean install.
                                I've used:
                                • OH2 Snapshot #631
                                • current Binding
                                • MySensors 2.0.0
                                • Ethernet Gateway (Arduino Uno + Ethernet Shield + NRF24L01+)
                                Everything works just fine, so don't give up! :-)
                                • carlylerC
                                  carlylerC
                                  carlyler
                                  @TimO thanks for the reply. I changed mysensors:bridge-eth:gateway to mysensors:bridge-eth:ethGateway in things and items, restarted OH2, reset ESP8266, several times, but no luck. If I read this right the GW is not trying to do much, ie get node id, present sensor, send data, etc. Any idea?
                                  GW serial:
                                  0;255;3;0;9;MCO:BGN:STP
                                  0;255;3;0;9;MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  0;255;3;0;9;MCO:SLP:WUP=-2
                                  0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
                                  Getting temperature
                                  T: 20.00
                                  H: 34.70
                                  Getting temperature
                                  T: 20.10
                                  H: 33.90
                                  I am trying to set node id in sketch:
                                  #define DHT_DATA_PIN 2
                                  #define MY_GATEWAY_ESP8266
                                  // ethernet settings
                                  #define MY_ESP8266_SSID "xxxxxx"
                                  #define MY_ESP8266_PASSWORD "xxxxxxxxxx"
                                  // Enable UDP communication
                                  //#define MY_USE_UDP
                                  #define MY_ESP8266_HOSTNAME "HuzzahGateway"
                                  //#define MY_IP_ADDRESS 192,168,213,113
                                  //#define MY_IP_GATEWAY_ADDRESS 192,168,213,1
                                  #define MY_PORT 5003
                                  #define MY_GATEWAY_MAX_CLIENTS 1
                                  //#define MY_CONTROLLER_IP_ADDRESS 192,168,213,116
                                  // Flash leds on rx/tx/err
                                  // Led pins used if blinking feature is enabled above
                                  #define MY_NODE_ID 3
                                  #include <ESP8266WiFi.h>
                                  #include <DHT.h>
                                    GW serial:
                                    Getting temperature
                                    T: 20.00
                                    H: 34.70
                                    Getting temperature
                                    T: 20.10
                                    H: 33.90
                                    #include <DHT.h>
                                    TimO
                                    @carlyler Serial log looks good. The gateway is receiving it's IP per DHCP, right? Is the IP you configured above still correct? I prefer a static IP for my gateway to prevent a changing of the IP.
                                    Is the gateway reachable by ping? Are you able to connect with "telnet IP 5003" to the gateway?
                                    • carlylerC
                                      carlylerC
                                      carlyler
                                      @TimO DHCP: yes, but it is actually static by way of reserved addresses via MAC in the router.
                                      IP: same
                                      ping: yes, works
                                      telnet, yes, all I see is:
                                      Serial is OK? I do not see the send of the Temp and hum; it is printing it because there is code to do that, but I am expecting the MySensors send command; right? My thought was it is not transmitting them for some reason. This is an area I am not confident about and have yet to find a good explanation of it: how a GW handles local sensors. Thoughts?
                                      • T TimO
                                        I've used:
                                        • OH2 Snapshot #631
                                        • current Binding
                                        • MySensors 2.0.0
                                        triceTT
                                        triceTT
                                        triceT
                                        @TimO I have the exact hardware (Mine is Chinese) and SW versions as you, but still can't connect via Ethernet gw. I will not give up till it is working :) I've ordered another Ethernet shield and will try with the new one.
                                        Regards
                                        • carlylerC
                                          carlylerC
                                          carlyler
                                          @TimO Good news! I finally got it to work; I have been using the dev, 2.1.0, and decided to try master, 2.0.0 and it came right up! I did notice one thing though that you may be interested in: if I start the ethGateway after OH2 is up, or turn it off and back on, the binding does not reconnect. Not sure if there is anything you can do about that.
                                          One other change to mention (before changing to v2.0.0): I found a note from hek about the node id of gateway local sensors will always be 0; I changed that in my things file and in my sketch.
                                          16:34:59.286 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;12.5
                                          16:34:59.291 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.289-0500
                                          16:34:59.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.297-0500
                                          16:34:59.333 [INFO ] [marthome.event.ItemStateChangedEvent] - bTemp changed from 12.8 to 12.5
                                          16:34:59.354 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempF changed from 55.04 to 54.50
                                          16:34:59.365 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempC_F changed from 12.8 °C / 55.0 °F to 12.5 °C / 54.5 °F
                                          16:34:59.490 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          16:34:59.583 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;0;1;0;1;34.1
                                          16:34:59.593 [INFO ] [marthome.event.ItemStateChangedEvent] - bHum changed from 34.2 to 34.1
                                          @hek I could be wrong, or maybe something has changed configuration wise but as you can see from above posts, dev branch v2.1.0, the radioless ethernet (ESP8266) gateway with local temp & hum sensors was not sending local sensor data. When I switched back to master v2.0.0 it started sending.
                                          jogantJ 1 Reply Last reply
