  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.7k Views 6 Watching
  • pentti12P
    pentti12P
    pentti12
    Trying to set up OpenHAB 2 beta4 system to talk with MySensors GatewayW5100MQTT Client (2.0 Library) without success. I managed to install MySensors Binding into OpenHAB2 and i can add Things MySensors Ethernet Gateway on Paper UI. This gateway starts to initialize, but it will go into OFFLINE state.
    Have someone managed to get this working yet or shall I wait next beta OpenHAB release?
    T 1 Reply Last reply
    • pentti12P pentti12
      TimO
      @pentti12 The MQTT Gateway is not supported by the OH2 Mysensors binding. Use the MQTT binding from OH2 instead.
      • pentti12P
        pentti12P
        pentti12
        OK, but I am still confused, why MQTT Gateway is listed in Configuration Things of OpenHAB, but not the MQTT binding (binding-mqtt - 1.9.0.SNAPSHOT). OpenHAB shows that MQTT binding is installed state.
        • T
          TimO
          I suppose you have used the configuration instructions for the ethernet gateway to connect to your MQTT gateway. The binding will be able to establish a TCP/IP connection this way, but they don't speak the same language.
          • pentti12P
            pentti12P
            pentti12
            So, what is your suggestion? Shall I go back to OpenHAB 1.8 or something else?
            • T
              TimO
              No, just look for the instructions to use the MQTT gateway with OpenHAB. It works the same way with OH1 and OH2.
              If I recall correctly you need a MQTT broker like mosquitto and connect the gateway and OpenHAB to the broker. I'm using the MQTT binding with OH2 myself to communicate to nodered.
              The communication works this way:
              MQTT gateway --> Mosquitto --> OpenHAB
              (and vice versa)
              With the OH2 binding the communication is this way:
              Ethernet gateway --> OH2 binding --> OH2
              • pentti12P
                pentti12P
                pentti12
                I have mosquitto broker installed into Pine64 and it is up and running. MySensors GatewayW5100MQTT Client has establish the connection with mosquitto broker. But the OH2 log show:
                2016-11-20 10:09:15.875 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.items'
                2016-11-20 10:09:25.235 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
                2016-11-20 10:09:32.486 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                2016-11-20 10:09:34.022 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                2016-11-20 10:09:34.634 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
                2016-11-20 10:09:35.139 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                2016-11-20 10:09:36.492 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                2016-11-20 10:09:37.044 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
                What to do next?
                • pentti12P
                  pentti12P
                  pentti12
                  I changed my Arduino UNO Sketch to GatewayW5100. Now I get MySensors Ethernet Gateway at OH2 into ONLINE state.
                  Next question: how I configure MQTT gateway - Mosquitto - OpenHAB communication branch?
                  jogantJ 1 Reply Last reply
                    jogantJ
                    jogantJ
                    jogant
                    @pentti12
                    I think we should clarify what should be setup. If you want to use mqtt gateway the have a look at https://forum.mysensors.org/topic/3605/can-t-get-openhab2-to-see-my-mqtt-messages
                    Besides that I have the same setup like you. Openhab2 be, mysensors ethernet gateway. Works very reliable for four weeks now without any drops. I prefer this as we have a real oh2 binding with autodetection of things etc.
                    Best regards
                    jogant
                    • pentti12P
                      pentti12P
                      pentti12
                      Detection of Things worked from MySensors network (only one gateway and one node, which has temperature and humidity sensor). But I can't get real temperature nor humidity values to be shown on Paper UI control screen. I don't have glue what to do next.
                      I don't understand why the Arduino MQTT Gateway is not supported by the OH2 Mysensors binding, so shall I go still to mqtt gateway direction?
                        jogantJ
                        jogantJ
                        jogant
                        @pentti12
                        depends on what you want. At the moment there is no separate OH2 MQTT binding. You can use OH1 MQTT binding through compatibility layer but you will lose some features of OH2 like autodetection.
                        To see values from a sensor in UI you have to define an item and link it to the thing whereas a thing can have lot of different sensors (two in your example) and you have to define an item for each sensor. You also can use autogeneration of items for new detected things. This is also a feature of OH2.
                        If you use MQTT there is no autodetection. You have to define things through things configuration file(s) and also have to link items to thing-values. But you have to do it by hand.
                        MQTT is the better choice if you plan to share your mysensors values with other controllers like node-red or similar. If you only use openhab then I would prefer using mysensors binding. That's what I did.
                        • pentti12P
                          pentti12P
                          pentti12
                          OK I stay with MySensors Binding and use MySensors Ethernet Gateway Things. And on Arduino side I use GatewayW5100 sketch.
                          Still problem with getting real values of temperature or humidity. For example the Humidity Sensor is ONLINE and it has linked into Humidity channels, but when I switch to control screen of Paper UI, there is no humidity values reported (show -NaN). What is missing from OH2?
                            jogantJ
                            jogantJ
                            jogant
                            wrote on last edited by jogant
                            @pentti12
                            did you debug your sensor? Does it transmit correct values for both temperature and humidity?
                            I recognized that sometimes the initialization of the OH binding is not complete. So what I did was first restart mysensors binding via OH console (bundle:restart <mysensors binding number>), made a reset of the gateway and a reset of the sensor node. Then sensor node remains online with valid values.
                            Or try to increase OH debugging and see what happens in OH logs. log:set DEBUG org.openhab.binding.mysensors and log:tail
                            There you should see mysensor messages coming in. What do you see there?
                            • pentti12P
                              pentti12P
                              pentti12
                              OK, I will try to debug. It will take some time to done. I'll be back later on.
                                TimO
                                @pentti12 This is a bug in the binding. Please restart OH2 (or just the binding as @jogant suggested) after discovery of a new device till I was able to fix the issue . After the restart it should work.
                                • pentti12P
                                  pentti12P
                                  pentti12
                                  Hi
                                  I switched from win7 laptop to pine64 in order to continue searching problem.
                                  What I did:
                                  I started Karaf Console and restarted mysensors binding --> no help
                                  I restarted Arduino UNO Ethernet Gateway --> no help
                                  I restarted Arduino UNO Node 9 (which has temperature and humidity sensor) --> no help
                                  Here is the listing of the DEBUG:
                                  10:15:32.075 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:humidity:a9d5757b': java.lang.NullPointerException
                                  java.util.concurrent.ExecutionException: java.lang.NullPointerException
                                  at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
                                  at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
                                  at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)
                                  at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)
                                  at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)
                                  at org.eclipse.smarthome.core.thing.internal.ThingManager.disposeHandler(ThingManager.java:857)
                                  at org.eclipse.smarthome.core.thing.internal.ThingManager.handlerRemoved(ThingManager.java:311)
                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:138)
                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:1)
                                  at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:967)[org.osgi.core-6.0.0.jar:]
                                  at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
                                  at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)[org.osgi.core-6.0.0.jar:]
                                  at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:909)[org.osgi.core-6.0.0.jar:]
                                  at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.unregisterHandler(BaseThingHandlerFactory.java:125)
                                  at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.deactivate(BaseThingHandlerFactory.java:79)
                                  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_101]
                                  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_101]
                                  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_101]
                                  at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_101]
                                  at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:342)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:157)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:783)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:757)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:550)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:725)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:530)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:414)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.Activator.access$300(Activator.java:53)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:273)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:290)[33:org.apache.felix.scr:2.0.2]
                                  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
                                  at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
                                  at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:312)[33:org.apache.felix.scr:2.0.2]
                                  at org.apache.felix.utils.extender.AbstractExtender.bundleChanged(AbstractExtender.java:186)[33:org.apache.felix.scr:2.0.2]
                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.container.Module.doStop(Module.java:624)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.container.Module.stop(Module.java:488)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:420)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:44)[39:org.apache.karaf.bundle.core:4.0.4]
                                  at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:54)[39:org.apache.karaf.bundle.core:4.0.4]
                                  at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:83)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:67)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:87)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:480)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:406)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.felix.gogo.runtime.Pipe.run(Pipe.java:108)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:182)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:119)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:94)[54:org.apache.karaf.shell.core:4.0.4]
                                  at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:270)[54:org.apache.karaf.shell.core:4.0.4]
                                  at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
                                  Caused by: java.lang.NullPointerException
                                  at org.openhab.binding.mysensors.handler.MySensorsHandler.getBridgeHandler(MySensorsHandler.java:207)[201:org.openhab.binding.mysensors:2.0.0.201601251249]
                                  at org.openhab.binding.mysensors.handler.MySensorsHandler.dispose(MySensorsHandler.java:67)[201:org.openhab.binding.mysensors:2.0.0.201601251249]
                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$12.call(ThingManager.java:860)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$12.call(ThingManager.java:1)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                                  at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
                                  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
                                  ... 1 more
                                  10:15:32.165 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
                                  10:15:32.167 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:temperature:9d001ab8': java.lang.NullPointerException
                                  ... 1 more
                                  10:15:32.485 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  10:15:32.488 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from INITIALIZING to ONLINE
                                  10:15:32.494 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:a8641691' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  10:15:32.513 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:a8641691' changed from INITIALIZING to ONLINE
                                  10:15:32.542 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a9d5757b' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  10:15:32.548 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a9d5757b' changed from INITIALIZING to ONLINE
                                  So lot of stuff, which are unclear to me.
                                    Hi
                                    What I did:
                                    ... 1 more
                                    ... 1 more
                                    jogantJ
                                    jogantJ
                                    jogant
                                    @pentti12
                                    At least the last 6 lines suggest that the initialization was successful. Seems that before mysensors has not been initialized completely and therefore dispose failed. Dispose is invoked through binding restart I think. So you can ignore theses failures.
                                    Are you now able to link items? Do you see incoming mysensors messages in the cycle you defined in the node?
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      If I look at the configuration from HABmin side, I see for example this:
                                      Channels [1 active, 2 total]
                                      Temperature
                                      Linked Items
                                      Temperature
                                      So there is some linked items!
                                        Temperature
                                        Linked Items
                                        Temperature
                                        jogantJ
                                        jogantJ
                                        jogant
                                        @pentti12
                                        ok, but you have to see mysensor messages in the log file on a regularly basis. At least the default sketch for temperature and humidity sends updates every minute. Maybe your temperature is very constant then you will see updates every hour I think. Try to heat the node and let it cool down again.
                                        And connect your node or the gateway to the serial monitor. There you will see the mysensors activity. You should see OK for status updates and not to much NACK. Then you have a problem with your mysensors network.
                                        good luck ...
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          Here is the serial monitor printout from MySensors W5100 Gateway. I think that this listing is OK, but still there is no actual temperature nor humidity values at control screen of OH2 .
                                          0;255;3;0;9;TSM:INIT
                                          0;255;3;0;9;TSM:RADIO:OK
                                          0;255;3;0;9;TSM:GW MODE
                                          0;255;3;0;9;TSM:READY
                                          IP: 192.168.1.201
                                          0;255;3;0;9;TSP:SANCHK:OK
                                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.6
                                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:37.9
                                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.7
                                          0;255;3;0;9;TSP:MSG:READ 9-9-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:BC
                                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=9)
                                          0;255;3;0;9;TSP:CHKUPL:OK
                                          0;255;3;0;9;TSP:MSG:GWL OK
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          0;255;3;0;9;TSP:MSG:PINGED (ID=9, hops=1)
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:38.0
                                          The problem must be on OpenHAB2 side. What to do next?
