  3. Changing Node ID at run time
5 Posts 2 Posters 2.9k Views 5 Watching
  • L
    L
    lafleur
    Is it possible to change the node ID at run time in Setup???
    ie: MY_NODE_ID
    The way it looks now, it needs to be set prior to Setup or Loop being invoked using a:
    #define MY_NODE_ID 10
    I'm using an MQTT GW and would like each device to get its ID from a jumper on the board...
      Yes, it should be possible with something like this...
      int8_t myNodeId;
      #define MY_NODE_ID myNodeId
      void before () {
            // read pins and set myNodeId
      • L
        L
        lafleur
        Good idea, but it did not worked...
        The node was at 10, so I set the myNodeId = 12 in before() function, node continued to use ID of 10, most likely from Flash.... before() might be running prior to initialization of all variables...
        L 1 Reply Last reply
        • L lafleur
          L
          L
          lafleur
          @lafleur
          See issue #675 in Github...
          https://github.com/mysensors/MySensors/issues/675
          • L
            L
            lafleur
            wrote on last edited by lafleur
            I have this working now, it was a setup issue on my part...
            int8_t myNodeId;
            void before () {
                // read I/O pins and set myNodeId
                myNodeId = 32;
                Serial.println( myNodeId );
