  3. Vera
  4. pool/spa temperature sensor for VeraLite???
veratemperatureveralite
8 Posts 4 Posters 8.2k Views 2 Watching
  • C
    C
    callagga
    Any advice/directions regarding how implementing pool/spa temperature sensor for my VeraLite?
    I stumbled across mysensors.org and then https://github.com/mysensors/Vera but I still bit confused. Is the mysensors project something that could solve what I'm after, and what would the solution look like? i.e. would I need an Arduino board + temperature probe, plus some Arduino software from mysensors.org, plus then a VeraLite plugin from code from https://github.com/mysensors/Vera? Wonder how complicated it all would be.
    thanks
    • greglG
      greglG
      gregl
      i have a pool controller i built around an arduino and have nearly finished rebuilding around mySensors and Vera for instrumentation, datamine and pump control.
      Ive been wanting to do a writeup about it...but not got there yet.
      But to answer your question, yes you will need a temp sensor in the pool plumbing. I made mine by drilling out a 1/4 BSP stainless steel bolt in which i embedded a temp sensor.. this bolt is then insterted into the pvc pipe....
      here's a pic
      This then connects to the controller which does a bit more, but could just be as simple as the example.... http://www.mysensors.org/build/temp
      • AnticimexA
        AnticimexA
        Anticimex
        Vera, Arduino, wiring, gateway etc. is covered by the examples.
        Gateway selection
        Vera
        Temperature sensor
        MySensor library
        The temperature example also suggest a waterproof sensor. Should be enough to get you started :)
        C 1 Reply Last reply
        • AnticimexA Anticimex
          Gateway selection
          Vera
          Temperature sensor
          MySensor library
          C
          C
          callagga
          wrote on last edited by callagga
          @Anticimex - thanks, starting to understanding things now
          @gregl - Which sensor did you use?
          I just googled "waterproof DS18b20" and got waterproof versions coming back like http://www.adafruit.com/product/381 . So I guess with one of these (in place of the one mentioned in the example) everything should work?
          PS. Is there a way to get a "email notification" for any updates to a forum topic here? Haven't found how to do this yet...
          PSS. The temperature reported into VeraLite would then be accessible by any LUA code I write/use within VeraLite then? (haven't got this far, but I'd like to use the temperature to control other devices)
          hekH 1 Reply Last reply
          • AnticimexA
            AnticimexA
            Anticimex
            You can connect your forum account to Pushbullet to receive notifications. Works like a charm!
            • C callagga
              @callagga said:
              PSS
              Yes.
              • greglG
                greglG
                gregl
                @callagga Yes DS18B20 - really easy to use!
                • C
                  C
                  callagga
                  ok - thanks guys
