  3. Home Assistant
  4. [solved] Sensor missing after restart
5 Posts 3 Posters 2.3k Views 3 Watching
  • abmantisA Offline
    abmantisA Offline
    abmantis
    wrote on last edited by hek
    After restarting Home Assistant, my motion and light sensors do not show up until they send values again. They are being correctly saved on the persistence .json file, so I expected them to show up.
    E martinhjelmareM 2 Replies Last reply
    • abmantisA abmantis
      E Offline
      E Offline
      exxamalte
      Have you followed the recommendation in the documentation to send an initial value to the controller? The symptom you're describing sounds as if that may not be the case.
      abmantisA 1 Reply Last reply
        martinhjelmareM Offline
        martinhjelmare
        @abmantis
        What version of home assistant are you using? There was an issue in 0.33 that lead to the behavior you've reported here.
        • E exxamalte
          abmantisA Offline
          abmantisA Offline
          abmantis
          wrote on last edited by abmantis
          @exxamalte The sensor appears correctly after sending values. Also, the .json file is correctly filled with the sensor data.
          @martinhjelmare Well, I'm using 0.33.4! I'll try updating and report back :) Thanks.
            @abmantis
            abmantisA Offline
            abmantisA Offline
            abmantis
            @martinhjelmare I just updated to the latest version and now they appear correctly after rebooting! Thank you very much.
