  3. !TSM:FPAR: FAIL !TSM: FAILURE TSM:PDT
9 Posts 6 Posters 4.7k Views 6 Watching
  • DaviepumpD Offline
    DaviepumpD Offline
    Daviepump
    HI,
    i have updated to version 2.0 and not having any luck communicating anymore.
    steps i have done:
    updated GW to V2.0
    updated node to V2.0
    below is the serial output from the Node.
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=17)
    TSM:FPAR
    TSP:MSG:SEND 17-17-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    anyone had this problem and fixed it ?
    cheers
    R 1 Reply Last reply
    • hekH Offline
      hekH Offline
      The node does not receive any parent response from the gateway. You have to look in the gateway log and check why communication fails (power/cap?)
      • K Offline
        K Offline
        ksga
        I'm getting this error quite frequently when flashing new sketches to my nodes.
        Flash the EPROM clear sketch and reflash the sketch you want on the node should fix it.
          DaviepumpD Offline
          Daviepump
          gateway log shows:
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSM:RADIO:OK
          0;255;3;0;9;TSM:GW MODE
          0;255;3;0;9;TSM:READY
          0;255;0;0;18;2.0.0
          i am supplying it with 3.3V and the capacitor is a 4.7 UF
          • S Offline
            wrote on last edited by scalz
            @Daviepump
            Hi.
            could you give us a bit more infos please?
            • which radio
            • which hardware (mini pro, esp...)
            • which sketch, so we can also see your defines
            • of course complete logs for both
            With a little ClearEeprom before to be sure.
              DaviepumpD Offline
              Daviepump
              GATEWAY
              Radio : NRF24L01+
              Board : arduino Nano
              Sketch: SerialGateway.ino'.
              0;255;0;0;18;2.0.0
              0;255;3;0;9;TSP:SANCHK:OK
              NODE
              Radio : NRF24L01+
              Sketch: MockMySensors'.
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=13)
              TSM:FPAR
              TSP:MSG:SEND 13-13-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              • DaviepumpD Daviepump
                HI,
                steps i have done:
                updated GW to V2.0
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                cheers
                R Offline
                R Offline
                Reza
                @Daviepump said in !TSM:FPAR: FAIL !TSM: FAILURE TSM:PDT:
                HI,
                steps i have done:
                updated GW to V2.0
                i have same problem . when i use mysensors lib version 1.5 i have not problem with my nodes and gateway. after update to 2.1 i see this problem ... when you use lib 1.5 , did you have this problem ?
                • toddsantoroT Offline
                  toddsantoro
                  The reason I was getting errors was because I happen to purchase some really bad Chinese junk radios. If you cannot see the square chip on your radios and it has sort of a black glob of hard mat looking substance where the chip should be chances are the radio is just not compatible. This is mentioned in the troubleshooting area of the site. It is best to make sure you buy on eBay from sellers that my sensors sort of approves of.
                  • toddsantoroT toddsantoro
                    R Offline
                    R Offline
                    Reza
                    @toddsantoro
                    I've survey with carefully . devices (same devices that i used before) are in certain places (before update and after update) and i dont move and i dont change hardware. but before i dont have any error in connect to gateway and any error NACK for commands! but after update i have many error NACK and for first connection to gateway i have some errors !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    i think there are a problem about mysensors lib 2.1
                    my radio (if this is chinese or other countries) before update work very well. but after update....
