  3. Usage problem with 2.0 library
15 Posts 4 Posters 3.8k Views 2 Watching
  • rnollenR
    rnollenR
    rnollen
    HI,
    I have several sensors running on the V1.0 my sensors library, this for quite some time now... All works like a charm.
    Now, i wanted to create a new Lux sensor, so I have decided to make this one using the v2.0 library code
    For starters I had some installation issues. I I didn't know how to upgrade the library from v1 to v2, so I have decided to uninstall/install Arduino software and to use the tutorial how to add the 2.0 library to the arduino software. For some reason the new sketches didn't work and I didn't saw how to upgrade it on my earlier version of the Arduino software. But this fixed it.
    Then, I was not able to use Bh1750.h library, so I have donwloaded it from gifthub and added it to the library. All was working and compiling wel from then.
    But now, the lux sensor itself is not working. It gives me an error:
    TSM:ID
    TSM:CHKID:OK (ID=6)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 6-6-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSP:MSG:SEND 6-6-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-6 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=6)
    TSM:UPL
    I see a fail on TCP:CHKUPL:FAIL.. I found on the internet, that maybe ID 0 was used in the (used the example sketch from this site), changed this to a different value, but with no luck..
    I need to say that my GW is still using the V1.0 library code. I didn't upgraded this yet because I am not sure when I change my GW that I need to upgrade all my other sensors? Hopefully this is not the case :).....
    Anyone got an idea what this error could mean?
    • dbemowskD
      dbemowskD
      Version 2.0 sensors will not work on a 1.x gateway. You should update your gateway. I can't say for certain about 1.0, but I can say that I had 1.5 sensors running fine on my new 2.0 gateway.
      tekkaT 1 Reply Last reply
      • dbemowskD dbemowsk
        tekkaT
        tekkaT
        tekka
        @dbemowsk @rnollen Yes you're right, 2.x is not backwards compatible with 1.x setups. Ideally, all nodes/GW should be on the same version.
        dbemowskD 1 Reply Last reply
        • rnollenR
          rnollenR
          rnollen
          OK... I will try to find v2.0 code for my projects :) And will upgrade the GW first then :)
          • tekkaT tekka
            dbemowskD
            dbemowskD
            You say that ideally they should be on the same version, but you should be able to run the nodes on a 2.0 gateway. My suggestion would be to change your gateway first and see how things run. If the nodes run okay, then you can update them at your leisure. I ran my 1.5 nodes for a while on my 2.0 gateway before I changed them all completely.
            @rnollen The hard part for you right now is that you have your MySensors arduino library code changed to 2.0 now, so it would be a pain to go back. If you have the parts, you could make yourself a whole new 2.0 gateway and leave your old 1.0 gateway in tact. That way if you have sensors that don't work with the 2.0 gateway, you can swap your 1.0 gateway back for normal operation and switch in the 2.0 gateway when you want to test new nodes. You could at least lessen the burden on the update of all your nodes.
            • scalzS
              scalzS
              ideally meaning if you want to be sure to have no issue :)
              but for testing, you're right, it's perahps better to assemble a small test setup and see how it behaves before updating.
              • rnollenR
                rnollenR
                rnollen
                wrote on last edited by rnollen
                Ofcourse.. No Nuts no glory, I thought :) So updated my gateway..
                Now, updating went well: I see this in the logs of the gateway:
                IP: 192.168.0.20
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                IP: 192.168.0.20
                IP: 192.168.0.20
                IP: 192.168.0.20
                IP: 192.168.0.20
                And it doing this in a loop... So I think this is OK?
                But now, my domoticz doesn't connect correclty :( It does an initial connection, but I get an connection reset after a few seconds.
                Anyone tried this with Domoticz? I would not have expected this :(
                <edit>
                Hmm.. Gateway is not functioning correctly I guess.. In the troubleshooting guide I think I should see more at the end: (Copy/paste from this site):
                IP: 192.168.10.80
                0;255;3;0;9;MCO:BGN:STP
                0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                0;255;3;0;9;TSF:MSG:READ,12-4-0,s=18,c=1,t=16,pt=1,l=1,sg=0:1
                0;255;3;0;9;TSF:MSG:READ,12-4-0,s=31,c=1,t=16,pt=1,l=1,sg=0:1
                Also, I should see Gateway Startup Complete as the last line, but for some reason it is not working.. The wiring is exactly the same as before..? Also cleared the EEProm; republish the sketch.. but no luck
                So it does not initialize correctly I think... but why?
                • scalzS
                  scalzS
                  looks like your GW is rebooting..
                  What's your hardware for GW?
                  rnollenR 1 Reply Last reply
                  • scalzS scalz
                    rnollenR
                    rnollenR
                    rnollen
                    I use an Arduino Uno and the W5100 Module, not the shield which you can click on an Uno..
                    I know in the past when I created the module, I needed to enable "//#define MY_SOFTSPI" in MyConfig.h... Tried it again, no luck.. Checked the wiring, nothing strange here..also nothing was changed on the wiring part, so I thought I would expect the same result...
                    • scalzS
                      scalzS
                      wrote on last edited by scalz
                      oki so you're using softspi. i guess you're using NRF24 radio ?
                      I am checking with a few people if softspi is working ok with rfm69 (but i'm not using ethernet gw).
                      Just to be sure, can you confirm : W5100 SS/CSN pin on Arduino D10, and Radio SS/CSN pin on D6, right?
                      I'll look later today. I hope we will be able to get rid of the softspi ;)
                      • rnollenR
                        rnollenR
                        rnollen
                        Thanks.. I am not sure what is going wrong at this stage.
                        I am using an indeed a NRF24 radio, but I use the one with an external antenna (such as this one: http://www.ebay.com/itm/2-4G-1100m-Module-NRF24L01-PA-LNA-Communication-SMA-Antenna-Wireless-Transceiver-/172255694961?hash=item281b3d5071)
                        I use an external antenna because of the range and because I can make a cleaner box around it ;)
                        Also my W5100 is slightly different, because alternative names are printed on the bottem. It has the same labels as the topicstarter here: https://forum.mysensors.org/topic/467/ethernet-gateway-troubleshooting-advice
                        But it worked like a charm for the last 1,5 years :)
                        But to give you an answer.. the SS/CSN is called NSS on my W5100 and this is the D10. Think this is OK?
                        The Radio CSN is connected to D6
                        • scalzS
                          scalzS
                          @rnollen
                          noted, thx!
                          i'll give you feedback ;)
                          • scalzS
                            scalzS
                            can you upload your gw and node sketch, so i can see your defines please?
                            • scalzS scalz
                              rnollenR
                              rnollenR
                              rnollen
                              Hi, I am only busy with the GW at this moment, I have not altered any sensor yet to 2.0 (Got 7 nodes).. this was the next phase :) I only have a lux sensor on y Breadboard running on MySensors 2.0
                              I used the sketch from the example libary, the same as on the build page of MySensors: (https://www.mysensors.org/build/ethernet_gateway) and used the "WizNET (W5100) Ethernet module" sketch.
                              Things I have tested:
                              1. Enabled "//#define MY_W5100_SPI_EN 4" in the sketch. This resulted in a radio error:
                              2. Changed the "//#define MY_SOFTSPI" in MyConfig.h, didn't seem to do anything when I enabled that. I have tested it where I have Enabled step 1, then it didn't give me an error on the radio... but it didn't fix anything also. Disabled step 1. Same result.
                              Don't know what I can test more :)
                              If you need anything, just let know. :)
                              • rnollenR
                                rnollenR
                                rnollen
                                Think I have fixed it :)
                                I found this topic: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/5
                                The answer for me was to downgrade the Arduino AVR Boards to version 1.6.11 (Using Tools/Boards/Boardsmanager) ... It seems there is a bug in the newer release of this tool and the W5100. So hopefully this issue can be fixed, so that in newer releases this is OK. Maybe it is wise to add this to the Ethernet Gateway Page when using a W5100 and Mysensors 2.0 ;)
