  3. Radio FAIL after ~3 weeks [SOLVED]
61 Posts 7 Posters 23.9k Views 5 Watching
  • J Jan Gatzke
    @Reza
    The Problem is most likely a problem with your hardware. Try to lower the distance and see if the problem still exists. If not you should replace your radios. Look for radios with pa / lna.
    R
    R
    Reza
    i test with lower distance . there is problem yet. i think problem is related to my sketch. i can not fix this :(
    • J Jan Gatzke
      @tboha
      Great analysis. I will surely send you my code for review next time. :D
      tboha
      @Jan-Gatzke You are welcome.
      @Reza : don´t worry, there will be a simple solution.
      I´m in a hurry at the moment, I was ordered to do some party tonight. If my supreme command detects my current activities I will have very bad Karma for the next days.
      To whom it may already apply: Happy new Year!! :boom:
      if (applies == 0) {
      wait.some(hours);
      read.again();
      rayanR R 2 Replies Last reply
      • T tboha
        if (applies == 0) {
        wait.some(hours);
        read.again();
        rayanR
        rayanR
        rayan
        wrote on last edited by rayan
        #23
        This post is deleted!
        • T tboha
          if (applies == 0) {
          wait.some(hours);
          read.again();
          R
          R
          Reza
          @tboha
          happy new year to you and your family <3
          my friend i am beginner . can you edit and fix my sketch next day? and paste here ? please .thank you
          T 1 Reply Last reply
          • R Reza
            @tboha
            tboha
            @reza:
            I made some modifications to your sketch, trying to adhere to your style of programming. So it may be easier to adapt it to your needs.
            #define MY_RF24_CHANNEL 0
            #define MY_REPEATER_FEATURE
            #define MY_NODE_ID 5
            #include <Bounce2.h>
            #define RELAY_ON 0
            #define RELAY_OFF 1
            #define A_ID 1
            #define B_ID 2
            #define C_ID 3
            #define D_ID 4
            #define E_ID 5
            #define F_ID 6
            #define DISPLAY_INTERVALL 10000
            const int buttonPinA = 14;
            const int buttonPinB = 15;
            const int buttonPinC = 16;
            const int buttonPinD = 17;
            const int buttonPinE = 18;
            const int buttonPinF = 19;
            const int relayPinA = 3;
            const int relayPinB = 4;
            const int relayPinC = 5;
            const int relayPinD = 6;
            const int relayPinE = 7;
            const int relayPinF = 8;
            int oldValueA = 0;
            int oldValueB = 0;
            int oldValueC = 0;
            int oldValueD = 0;
            int oldValueE = 0;
            int oldValueF = 0;
            unsigned long loop_count = 0;           // counter for loop activity
            unsigned long last_time;
            bool toggleA = false, toggleB = false, toggleC = false, toggleD = false, toggleE = false, toggleF = false;
            Bounce debouncerA = Bounce();
            Bounce debouncerB = Bounce();
            Bounce debouncerC = Bounce();
            Bounce debouncerD = Bounce();
            Bounce debouncerE = Bounce();
            Bounce debouncerF = Bounce();
            MyMessage msgA(A_ID, V_STATUS);
            MyMessage msgB(B_ID, V_STATUS);
            MyMessage msgC(C_ID, V_STATUS);
            MyMessage msgD(D_ID, V_STATUS);
            MyMessage msgE(E_ID, V_STATUS);
            MyMessage msgF(F_ID, V_STATUS);
              pinMode(buttonPinA, INPUT_PULLUP);
              pinMode(buttonPinB, INPUT_PULLUP);
              pinMode(buttonPinC, INPUT_PULLUP);
              pinMode(buttonPinD, INPUT_PULLUP);
              pinMode(buttonPinE, INPUT_PULLUP);
              pinMode(buttonPinF, INPUT_PULLUP);
              // After setting up the buttons, setup debouncer
              debouncerA.attach(buttonPinA);
              debouncerA.interval(5);
              debouncerB.attach(buttonPinB);
              debouncerB.interval(5);
              debouncerC.attach(buttonPinC);
              debouncerC.interval(5);
              debouncerD.attach(buttonPinD);
              debouncerD.interval(5);
              debouncerE.attach(buttonPinE);
              debouncerE.interval(5);
              debouncerF.attach(buttonPinF);
              debouncerF.interval(5);
              digitalWrite(relayPinA, RELAY_OFF);
              digitalWrite(relayPinB, RELAY_OFF);
              digitalWrite(relayPinC, RELAY_OFF);
              digitalWrite(relayPinD, RELAY_OFF);
              digitalWrite(relayPinE, RELAY_OFF);
              digitalWrite(relayPinF, RELAY_OFF);
              pinMode(relayPinA, OUTPUT);
              pinMode(relayPinB, OUTPUT);
              pinMode(relayPinC, OUTPUT);
              pinMode(relayPinD, OUTPUT);
              pinMode(relayPinE, OUTPUT);
              pinMode(relayPinF, OUTPUT);
              wait(1000);                                    // testing LEDs. should be omitted for Relais.
              digitalWrite(relayPinA, RELAY_ON);
              digitalWrite(relayPinB, RELAY_ON);
              digitalWrite(relayPinC, RELAY_ON);
              digitalWrite(relayPinD, RELAY_ON);
              digitalWrite(relayPinE, RELAY_ON);
              digitalWrite(relayPinF, RELAY_ON);
              /*--------------------- Added these lines for toggle switch-------------------------*/
              oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
              oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
              oldValueC = digitalRead(buttonPinC);
              oldValueD = digitalRead(buttonPinD);
              oldValueE = digitalRead(buttonPinE);
              oldValueF = digitalRead(buttonPinF);
            void presentation()  {
              sendSketchInfo("RELAY6", "0.1");
              present(A_ID, S_LIGHT, "Relais A");
              present(B_ID, S_LIGHT, "Relais B");
              present(C_ID, S_LIGHT, "Relais C");
              present(D_ID, S_LIGHT, "Relais D");
              present(E_ID, S_LIGHT, "Relais E");
              present(F_ID, S_LIGHT, "Relais F");
               Example on how to asynchronously check for new messages from gw
                loop_count ++;                                        // increment loop count
                if ( millis() >= last_time + DISPLAY_INTERVALL ) {    // Display Loop-cycles every DISPLAY_INTERVALL milliseconds
                  last_time = millis();                               // reset and start over again
                  Serial.print("loop_count: ");
                  Serial.println(loop_count);
                  loop_count = 0;
              debouncerA.update();
              // Get the update value
              int valueA = debouncerA.read();
              if (valueA != oldValueA && valueA == 0) {
                send(msgA.set(toggleA, true));                        // Send new state and request ack back
                digitalWrite(relayPinA, toggleA);                     // switch relais
                Serial.println("Switch A pressed");
                toggleA = !toggleA;                                   // this is the actual toggle switch
              oldValueA = valueA;
              debouncerB.update();
              int valueB = debouncerB.read();
              if (valueB != oldValueB) {
                send(msgB.set(valueB ? false : true), true); // Send new state and request ack back
                Serial.println("Switch B pressed");
                oldValueB = valueB;
              debouncerC.update();
              int valueC = debouncerC.read();
              if (valueC != oldValueC) {
                send(msgC.set(valueC ? false : true), true); // Send new state and request ack back
                Serial.println("Switch C pressed");
                oldValueC = valueC;
              debouncerD.update();
              int valueD = debouncerD.read();
              if (valueD != oldValueD) {
                send(msgD.set(valueD ? false : true), true); // Send new state and request ack back
                Serial.println("Switch D pressed");
                oldValueD = valueD;
              debouncerE.update();
              int valueE = debouncerE.read();
              if (valueE != oldValueE) {
                send(msgE.set(valueE ? false : true), true); // Send new state and request ack back
                Serial.println("Switch E pressed");
                oldValueE = valueE;
              debouncerF.update();
              int valueF = debouncerF.read();
              if (valueF != oldValueF) {
                send(msgF.set(valueF ? false : true), true); // Send new state and request ack back
                Serial.println("Switch F pressed");
                oldValueF = valueF;
                switch (message.sensor) {
                  case 1:
                    digitalWrite(message.sensor + 2, message.getBool() ? RELAY_ON : RELAY_OFF);
                    break;
                  case 2:
                    break;
                  case 3:
                    break;
                  case 4:
                    break;
                  case 5:
                    break;
                  case 6:
                    break;
                  default:
                    Serial.println("bad message (child_id >6)");
                    break;
                // Write some debug info
                Serial.print(message.sensor);
                Serial.print("  from node:");
                Serial.print(message.sender);
            I haven`t copied the code for all push-buttons - I leave this to you if this sketch is functional for your needs.
            Acting carefully, you may mingle some parts with blacey´s sketch successfully (by the way - impressing coding style).
            Reenacting your sketch I found some strange behavior: no reaction to push-button-press - meaning the sketch didn´t even take notice of the push-button after it had been pressed once - or sometimes twice.
            Adding an external pull-up resistor (4.7k) fixed this problem.
            So maybe it has not been a sending problem but a hardware problem (internal pull-ups to weak?).
            Please flood your sketch with print statements - like "button A pressed" "send command issued" etc. and watch your serial terminal carefully and/or post your logs.
            Thinking about the modulo-driven time-statement - actually it is a cute idea. Something like
             time_m = millis();
                a = (time_m / 1000) % 3600;
            should make it immune to uneven starting values an even loop-cycle duration. (loop-cycle-time of the above sketch: approximately 125 µs)
            These are the lesser problems. I fear you have to do some boring English lecture.
            Please read: https://en.wikipedia.org/wiki/Finite-state_machine
            https://en.wikipedia.org/wiki/State_machine_replication
            and first: https://en.wikipedia.org/wiki/Two_Generals'_Problem
            https://en.wikipedia.org/wiki/Byzantine_fault_tolerance
            as an excerpt :
            The Two Generals Problem was the first computer communication problem to be proved to be unsolvable.
            This is not "we don´t have a solution until now" but: "it is sure there can´t be a solution"
            So you will have to live with a certain amount of uncertainty .....
            Conclusion:
            1. Check correct function of push-button with Serial.print(), with and without external pull-up resistor.
            2. Please post your logs afterwards.
            3. be prepared to make some decisions concerning tolerable fuzziness.
            4. if necessary start learning about scripting capabilities of your controller.
            R 1 Reply Last reply
            • T tboha
              @reza:
              #define RELAY_ON 0
              #define RELAY_OFF 1
              #define A_ID 1
              #define B_ID 2
              #define C_ID 3
              #define D_ID 4
              #define E_ID 5
              #define F_ID 6
              int oldValueA = 0;
              int oldValueB = 0;
              int oldValueC = 0;
              int oldValueD = 0;
              int oldValueE = 0;
              int oldValueF = 0;
                    loop_count = 0;
                oldValueA = valueA;
                  oldValueB = valueB;
                  oldValueC = valueC;
                  oldValueD = valueD;
                  oldValueE = valueE;
                  oldValueF = valueF;
                    case 1:
                      break;
                    case 2:
                      break;
                    case 3:
                      break;
                    case 4:
                      break;
                    case 5:
                      break;
                    case 6:
                      break;
                    default:
                      break;
               time_m = millis();
              as an excerpt :
              Conclusion:
              R
              R
              Reza
              @tboha
              i think my problem is related to other reason
              this is out of sketch with change you:
              0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
              4 TSM:INIT
              11 TSM:INIT:TSP OK
              12 TSM:INIT:STATID=4
              14 TSF:SID:OK,ID=4
              16 TSM:FPAR
              52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2059 !TSM:FPAR:NO REPLY
              2061 TSM:FPAR
              2097 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2165 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              2170 TSF:MSG:FPAR OK,ID=2,D=2
              2340 TSF:MSG:READ,3-3-4,s=255,c=3,t=8,pt=1,l=1,sg=0:3
              4105 TSM:FPAR:OK
              4106 TSM:ID
              4107 TSM:ID:OK
              4109 TSM:UPL
              4146 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
              6153 TSM:UPL
              6190 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
              8197 TSM:UPL
              8206 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=OK:1
              8240 TSF:MSG:READ,0-2-4,s=255,c=3,t=25,pt=1,l=1,sg=0:2
              8245 TSF:MSG:PONG RECV,HP=2
              8248 TSM:UPL:OK
              8249 TSM:READY
              8266 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              8292 TSF:MSG:READ,0-2-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              8338 !TSF:MSG:SEND,4-4-2-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
              8373 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:2
              8402 TSF:MSG:READ,0-2-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              8445 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=0,st=NACK:RELAY6
              8477 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=OK:0.1
              8523 !TSF:MSG:SEND,4-4-2-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=NACK:Relais A
              8569 !TSF:MSG:SEND,4-4-2-0,s=2,c=0,t=3,pt=0,l=8,sg=0,ft=1,st=NACK:Relais B
              8615 !TSF:MSG:SEND,4-4-2-0,s=3,c=0,t=3,pt=0,l=8,sg=0,ft=2,st=NACK:Relais C
              8662 !TSF:MSG:SEND,4-4-2-0,s=4,c=0,t=3,pt=0,l=8,sg=0,ft=3,st=NACK:Relais D
              8708 !TSF:MSG:SEND,4-4-2-0,s=5,c=0,t=3,pt=0,l=8,sg=0,ft=4,st=NACK:Relais E
              8754 !TSF:MSG:SEND,4-4-2-0,s=6,c=0,t=3,pt=0,l=8,sg=0,ft=5,st=NACK:Relais F
              8761 MCO:REG:REQ
              8783 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=6,st=OK:2
              8809 TSF:MSG:READ,0-2-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              8814 MCO:PIM:NODE REG=1
              8816 MCO:BGN:STP
              9818 MCO:BGN:INIT OK,ID=4,PAR=2,DIS=2,REG=1
              loop_count: 1552
              loop_count: 87002
              loop_count: 86993
              loop_count: 87002
              loop_count: 87002
              • R
                R
                Reza
                wrote on last edited by Reza
                #27
                i have problem in send and receive ack ! i dont know where is problem ! i change radio and wire and arduino ... but this problem dont resolve :(
                also in my sketch i want when relay module is power on (relays off (LED OFF) ) and when i send command LED on and relay on. also i use a key with up / down button. so i want when key is up send one command and when key is down send other command...
                • R
                  R
                  Reza
                  4 TSM:INIT
                  11 TSM:INIT:TSP OK
                  14 TSF:SID:OK,ID=4
                  16 TSM:FPAR
                  2061 TSM:FPAR
                  2830 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  2835 TSF:MSG:FPAR OK,ID=2,D=2
                  4105 TSM:FPAR:OK
                  4106 TSM:ID
                  4107 TSM:ID:OK
                  4109 TSM:UPL
                  6153 TSM:UPL
                  8197 TSM:UPL
                  8233 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                  10241 TSM:UPL
                  10277 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                  12285 !TSM:UPL:FAIL
                  12286 TSM:FPAR
                  12323 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
                  14332 !TSM:FPAR:NO REPLY
                  14334 TSM:FPAR
                  14371 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  16378 !TSM:FPAR:NO REPLY
                  16380 TSM:FPAR
                  16417 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  18424 !TSM:FPAR:NO REPLY
                  18426 TSM:FPAR
                  18463 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  20470 !TSM:FPAR:FAIL
                  20471 TSM:FAIL:CNT=1
                  20473 TSM:FAIL:PDT
                  30476 TSM:FAIL:RE-INIT
                  30478 TSM:INIT
                  30485 TSM:INIT:TSP OK
                  30487 TSM:INIT:STATID=4
                  30489 TSF:SID:OK,ID=4
                  30491 TSM:FPAR
                  30528 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  32535 !TSM:FPAR:NO REPLY
                  32537 TSM:FPAR
                  32574 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  34581 !TSM:FPAR:NO REPLY
                  34583 TSM:FPAR
                  34620 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  36627 !TSM:FPAR:NO REPLY
                  36629 TSM:FPAR
                  36666 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  • R Reza
                    4 TSM:INIT
                    11 TSM:INIT:TSP OK
                    14 TSF:SID:OK,ID=4
                    16 TSM:FPAR
                    2061 TSM:FPAR
                    4105 TSM:FPAR:OK
                    4106 TSM:ID
                    4107 TSM:ID:OK
                    4109 TSM:UPL
                    6153 TSM:UPL
                    8197 TSM:UPL
                    10241 TSM:UPL
                    12285 !TSM:UPL:FAIL
                    12286 TSM:FPAR
                    14334 TSM:FPAR
                    16380 TSM:FPAR
                    18426 TSM:FPAR
                    20473 TSM:FAIL:PDT
                    30478 TSM:INIT
                    30491 TSM:FPAR
                    32537 TSM:FPAR
                    34583 TSM:FPAR
                    36629 TSM:FPAR
                    tboha
                    @Reza I got your nodes behavior mostly reproduced (see protocol below).
                    Only difference:
                    4105 TSM:FPAR:OK
                    4106 TSM:ID
                    In my network I got direct connections to my gateway.
                    so most messages in your logs document all nodes broadcasting all the time searching for your gateway and getting no response.
                    If there is no connection - there can be no ACK.
                    Would you please check your gateway sketch for the RF-channel in use?
                    Protocol with non matching RF-channel (#define MY_RF24_CHANNEL 0)
                    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    13 TSM:INIT:STATID=5
                    15 TSF:SID:OK,ID=5
                    17 TSM:FPAR
                    53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2060 !TSM:FPAR:NO REPLY
                    2062 TSM:FPAR
                    2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4105 !TSM:FPAR:NO REPLY
                    4107 TSM:FPAR
                    4143 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6150 !TSM:FPAR:NO REPLY
                    6152 TSM:FPAR
                    6188 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8195 !TSM:FPAR:FAIL
                    8196 TSM:FAIL:CNT=1
                    8198 TSM:FAIL:PDT
                    18201 TSM:FAIL:RE-INIT
                    18203 TSM:INIT
                    18210 TSM:INIT:TSP OK
                    18212 TSM:INIT:STATID=5
                    18214 TSF:SID:OK,ID=5
                    18216 TSM:FPAR
                    18253 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    20260 !TSM:FPAR:NO REPLY
                    20262 TSM:FPAR
                    20298 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    22306 !TSM:FPAR:NO REPLY
                    22308 TSM:FPAR
                    22344 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    24352 !TSM:FPAR:NO REPLY
                    24354 TSM:FPAR
                    24390 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    26398 !TSM:FPAR:FAIL
                    26399 TSM:FAIL:CNT=2
                    26401 TSM:FAIL:PDT
                    Protocol with matching RF-Channel (without #define MY_RF24_CHANNEL 0,i.e. using default channel)
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    15 TSF:SID:OK,ID=5
                    17 TSM:FPAR
                    2062 TSM:FPAR
                    2377 TSF:MSG:READ,14-14-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                    2382 TSF:MSG:FPAR OK,ID=14,D=2
                    2811 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    2817 TSF:MSG:FPAR OK,ID=0,D=1
                    3289 TSF:MSG:READ,7-7-5,s=255,c=3,t=8,pt=1,l=1,sg=0:2
                    3734 TSF:MSG:READ,4-4-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                    4105 TSM:FPAR:OK
                    4106 TSM:ID
                    4107 TSM:ID:OK
                    4109 TSM:UPL
                    4112 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    4118 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    4123 TSF:MSG:PONG RECV,HP=1
                    4126 TSM:UPL:OK
                    4127 TSM:READY:ID=5,PAR=0,DIS=1
                    4132 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    4139 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    4146 TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                    4155 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    4584 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                    4590 TSF:MSG:ACK REQ
                    4594 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=0,l=6,sg=0,ft=0,st=OK:Metric
                    4602 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=0,st=OK:RELAY6
                    4611 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                    4620 TSF:MSG:SEND,5-5-0-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais A
                    4628 TSF:MSG:SEND,5-5-0-0,s=2,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais B
                    4637 TSF:MSG:SEND,5-5-0-0,s=3,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais C
                    4645 TSF:MSG:SEND,5-5-0-0,s=4,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais D
                    4655 TSF:MSG:SEND,5-5-0-0,s=5,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais E
                    4663 TSF:MSG:SEND,5-5-0-0,s=6,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais F
                    4670 MCO:REG:REQ
                    4673 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    4679 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    4684 MCO:PIM:NODE REG=1
                    4686 MCO:BGN:STP
                    4714 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                    5688 MCO:BGN:INIT OK,TSP=1
                    7503 TSF:MSG:READ,8-8-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                    7508 !TSF:MSG:FPAR INACTIVE
                    loop_count: 36610
                    loop_count: 85099
                    loop_count: 85091
                    31153 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:0.0
                    Switch A pressed
                    34217 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:1.0
                    Switch A pressed
                    36277 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:0.0
                    Switch A pressed
                    loop_count: 84876
                    Which kind of Gateway are you using?
                    • T tboha
                      Only difference:
                      4105 TSM:FPAR:OK
                      4106 TSM:ID
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      15 TSF:SID:OK,ID=5
                      17 TSM:FPAR
                      2062 TSM:FPAR
                      4107 TSM:FPAR
                      6152 TSM:FPAR
                      8195 !TSM:FPAR:FAIL
                      8196 TSM:FAIL:CNT=1
                      8198 TSM:FAIL:PDT
                      18203 TSM:INIT
                      18216 TSM:FPAR
                      20262 TSM:FPAR
                      22308 TSM:FPAR
                      24354 TSM:FPAR
                      26401 TSM:FAIL:PDT
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      15 TSF:SID:OK,ID=5
                      17 TSM:FPAR
                      2062 TSM:FPAR
                      4105 TSM:FPAR:OK
                      4106 TSM:ID
                      4107 TSM:ID:OK
                      4109 TSM:UPL
                      4126 TSM:UPL:OK
                      4670 MCO:REG:REQ
                      4686 MCO:BGN:STP
                      loop_count: 36610
                      loop_count: 85099
                      loop_count: 85091
                      Switch A pressed
                      Switch A pressed
                      Switch A pressed
                      loop_count: 84876
                      R
                      R
                      Reza
                      @tboha
                      i use #define MY_RF24_CHANNEL 0 and all of node are #define MY_RF24_CHANNEL 0
                      T 2 Replies Last reply
                      • R Reza
                        @tboha
                        tboha
                        @Reza
                        Based on your answer I have to confess I didn´t read your log carefully enough - being fixed to missing ACKs I didn´t pay attention to successful transmissions.
                        Difference between Node 160 log and Node 4 log is the complete absence of any messages from Node 0 (GW) in Node 160 log, whereas in Node 4 log there are answers from GW.
                        So my next question would be: are these failures consistent?
                        If you are not feed up already, would you please log some boot sequences from Node 4? And some button-presses too?
                        I think it would be interesting if failures are the exact identical or just almost identical.
                        (exact identical favors software problem, almost identical favors hardware problem).
                        A parallel log from the GW would be nice too. Maybe there is a problem in the ACK system.
                        If you don´t trust your OrangePi hardware - would a temporarily switch to Laptop/Windows/Linux make much effort? Just to prove integrity of GW-Arduino and radio.
                        • R Reza
                          @tboha
                          tboha
                          @Reza
                          I forgot - you are completely right. Why is there any need for a repeater node in between at 1m distance?
                          To get a clean solution you could isolate your GW and Node 4 by changing RF-channels and have a look at their private conversation without being disturbed by other (healthy) nodes.
                          • J
                            J
                            Jan Gatzke
                            Coul it be you are using modules with different chips? See https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
                            • T tboha
                              @Reza
                              R
                              R
                              Reza
                              @tboha
                              sorry for english
                              generally , my problem is connection.
                              i have a controller (domoticz on orangepi) and one serial gateway with usb cable to controller. and some sensors in all of house (Sporadic) and some relay for test just in my room. id 4 or 160 is choose random for test. i am near controller and test some sketch, some relay , radio and etc...
                              so my problem is just connection between relays and gateway. sensors is good and work well and report all of states. but relays. first can not connection and show error :
                              (4143 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              6152 TSM:FPAR
                              8195 !TSM:FPAR:FAIL
                              8196 TSM:FAIL:CNT=1
                              8198 TSM:FAIL:PDT)
                              but after some time (with some power off/on) relay can connect to gateway . but after connect this is very unstable and some command send and some command dont send and show error ( NACK...)
                              i test and i change hardware and sketch but dont resolve :(
                              this is a solution ?please explain more . what am i do ?
                              use a repeater near gateway and use this for connect all of relays to gateway?
                              • J Jan Gatzke
                                R
                                R
                                Reza
                                @Jan-Gatzke
                                my radios is not fake. i use 3 type of radio nrf+ but i have problem
                                J 1 Reply Last reply
                                • R Reza
                                  @Jan-Gatzke
                                  J
                                  J
                                  Jan Gatzke
                                  @Reza
                                  Can you try to add the following line to your sketch?
                                  Right at the top, along with the other defines. I had similar problems with a LED Dimmer node. This solved the problem.
                                  • R Reza
                                    @tboha
                                    sorry for english
                                    6152 TSM:FPAR
                                    8195 !TSM:FPAR:FAIL
                                    8196 TSM:FAIL:CNT=1
                                    8198 TSM:FAIL:PDT)
                                    tboha
                                    @Reza No, an additional repeater was not intended (though it may be a solution).
                                    From your "Node 4" log I conclude:
                                    • you got at least 3 fully functional nodes (node 2,3,4). These nodes talk to each other in the environment of MySensors in an expected way.
                                    • so hardware (radio and power) is ok. Software is ok too.
                                    • GW functionality is partially ok - maybe hard- or software issues.
                                    Now there is a decision to make: go on testing potentially defective hardware or start over with known intact hardware.
                                    Go on testing means: are this failures reproducible? So I asked for logs of repeated boot sequences.
                                    Until now we don´t know the exact failure. The parallel log from Gateway would show if there are really missing transmissions (and the extent of missing messages) or only missing ACKs.
                                    I used ACKs last time in MySensors 1.4 and those days it made more trouble than profit. At last is showed up transmissions were ok (enough) the ACK system was not ok.
                                    For my purposes MySensors keeps up with transmission difficulties so I have not to care about (15m Distance, in house, reinforced concrete). So I decided not to use ACKs anymore and this did not reduce performance.
                                    If there are not to many missing transmissions (compare node messages vs. GW messages) I would skip the whole ACK thing.
                                    I would test potentially defective hardware first because it is easy to get some logs an costs not much time.
                                    Jan Gatzkes proposal is done quickly too.
                                    An additional repeater would only obscure severe GW-problems. For the GW is the heart of MySensors system - you should not tolerate any problems (hard- or software) because it will come on top again in the very near future.
                                    Starting over with known hardware takes more effort but should be doable in a manageable amount of time.
                                    • J Jan Gatzke
                                      @Reza
                                      R
                                      R
                                      Reza
                                      @Jan-Gatzke
                                      use this just for nrf +pa+lna? now i use just usual nrf+
                                      • T tboha
                                        R
                                        R
                                        Reza
                                        @tboha
                                        i test my hardware, change these and test again with some radio and wire and arduino ....
                                        now about parallel log .what am i do ? this is means i build 2 gateway?
                                        • R Reza
                                          @tboha
                                          tboha
                                          @Reza No.
                                          Parallel may not be the exact description, I meant simultaneous recording of GW and node.
                                          I don`t know about Domoticz - maybe there is a raw log function - then you are done.
                                          Or if you installed arduino ide on your OrangePi just use the serial monitor.
                                          Otherwise just hook up a terminal to your gateway.
                                          I.e. on your OrangePi look for the device GW is bound to and start some terminal program linked hereto (e.g. putty, minicom, kermit).
