  3. Radio FAIL after ~3 weeks [SOLVED]
61 Posts 7 Posters 23.9k Views 5 Watching
  • T tboha
    @Reza No.
    Parallel may not be the exact description, I meant simultaneous recording of GW and node.
    I don`t know about Domoticz - maybe there is a raw log function - then you are done.
    Or if you installed arduino ide on your OrangePi just use the serial monitor.
    Otherwise just hook up a terminal to your gateway.
    I.e. on your OrangePi look for the device GW is bound to and start some terminal program linked hereto (e.g. putty, minicom, kermit).
    R
    R
    Reza
    @tboha
    i understand . ok thank you . i will test it
    T 1 Reply Last reply
    • R Reza
      @tboha
      tboha
      @Reza
      Sometimes it is better to step back and have a look from the distance.
      A receipe for a clean restart.
      you need:
      2 working Arduinos with radio (node 4 and node 3 from your log)
      1 working Computer/Laptop with 2 free USB interfaces
      preferably Windows with Arduino IDE installed. (Linux might work too.)
      connect both arduinos to your USB ports.
      if Arduinos are different - write down which Arduino is on which port (eg. com34: or similar)
      1. start Arduino IDE
      2. from examples/Mysensors load "Gateway serial"
        2a. choose one USB/COM-port.
      3. don´t change anything and load it to the Arduino No.1
      4. from examples/Mysensors load "MockMySensors"
        4a. choose the other USB/COM-Port
      5. don`t change anything and load it to Arduino No.2
      You are done. Watch Arduinos communicating via serial monitor.
      Ok- you are right - it is not truely simultaneaus - but close enough.
      If this is ok you should try to upload the relay-sketch and watch what is happening.
      This should not take to long, and as a result you will hopefully know:
      • my hardware is ok or not
      • my software (MySensors) is ok or not
      • my sketch is ok or not.
      R 1 Reply Last reply
      • T tboha
        @Reza No.
        R
        R
        Reza
        @tboha
        hi friend , i test it and when i have NACK serial monitor is :
        • T tboha
          @Reza
          you need:
          R
          R
          Reza
          @tboha
          i think found problem . i was careless about parent, relay is bad working when use a parent device for connect to gateway.but when connect directly , work better . more better . but now there is 2 questions ! first i am near gateway (1meter) and relay for test is near gateway.but after start or reset , some time relay choose a node (10 m far) for parent, while gateway is near that ! why ?
          i know that i can use static parent for nodes but i want know why node choose a node 10m far for parent while gateway is in near (1m)
          and second question. why with a parent relay work very bad and more command dont send and there is error!? this is related to power of radio of parent ?
          thank you
          • R Reza
            @tboha
            tboha
            @Reza this is weird - i have to think about.
            Just for clarification:
            it seems you issued a command at your controller which results in sending
            60;2;1;0;2;1
            dissected:
            60; = to node 60,
            2; = sensor 2
            1; = set value
            0; = unacknowledged message (?)
            2; = subtype is V_LIGHT
            1; = payload is "1"
            I think you hit button "Relais 2 ON" .
            The weird thing is - you haven`t asked for acknowledge - but system is trying to get acknowledge ---- strange.
            I just got your next question, I have to think about this too.
            • R Reza
              @tboha
              thank you
              tboha
              @Reza I think we are getting close to solution.
              This seems to be the crucial question.
              I never dived into the core functions how MySensors decides about choosing parent.
              Maybe it depends upon speed of answer?
              a little excerpt from an earlier log (which i didn´t read close enough, I told you).
              16 TSM:FPAR
              52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2059 !TSM:FPAR:NO REPLY
              2061 TSM:FPAR
              2097 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2165 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              2170 TSF:MSG:FPAR OK,ID=2,D=2
              2340 TSF:MSG:READ,3-3-4,s=255,c=3,t=8,pt=1,l=1,sg=0:3
              4105 TSM:FPAR:OK
              4106 TSM:ID
              at 2097 Node 4 broadcasts for parent and gets accepted for parenting from Node 2.
              at 2340 Node 3 offers parenting too - upon which request?
              and why doesn`t GW offer parenting ?? GW shows up at 8240 with response to PING, so it is alive and connection was ok.
              at least at the moment - unexpected behavior.
              So reading logs give us some hints.
              Could you provide a little more from the simultaneous logs? And don´t stick to the NACK logs - the other messages are interesting as well.
              tekkaT R 2 Replies Last reply
              • T tboha
                16 TSM:FPAR
                2061 TSM:FPAR
                4105 TSM:FPAR:OK
                4106 TSM:ID
                tekkaT
                tekkaT
                tekka
                @tboha
                Thanks for your time and effort, you're doing an excellent analysis. Please find below some answers to your questions:
                The find parent step is initiated by a local I_FIND_PARENT_REQUEST broadcast, i.e. all repeaters/GW will reply with I_FIND_PARENT_RESPONSE if their uplink connections are operational (this prevents circular referencing). Node 3 (@2340) is replying to the same request, but ignored due to a greater distance to the GW (D=3+1=4 vs D=1+1=2 from node 4). The GW does not offer parenting, because it's either too close (radio interference) or too far from the requesting node. After a timeout (default 2000ms) the node uses the closest repeater/GW that replied to the request unless a static/preferred parent is defined.
                • T tboha
                  16 TSM:FPAR
                  2061 TSM:FPAR
                  4105 TSM:FPAR:OK
                  4106 TSM:ID
                  R
                  R
                  Reza
                  @tboha
                  my friend . i am so sorry , i am weak in english and i can not know what am i do and you told to me what am i do!!
                  very very thank you for time and tried for me and my problem. i can not get your time more i am sorry . i am very thank you for tried for me but i think , i am failure.
                  this is very complicate for me because i am beginner.
                  problems is many. this serial monitor is some problem. every time in serial monitor there is new problem and new error.
                  i am Ashamed for your time and thank you . i can not understand your guidance.
                  • tekkaT tekka
                    @tboha
                    tboha
                    @tekka This is very interesting. I think i will review my own system - just for curiosity. Thank you for this explanation.
                    @Reza: don´t get desperate. I think you are not a beginner - but if you are - your learning curve is fairly steep.
                    As mentioned before, sometimes it is better to step backwards and look from the distance.
                    If you aren´t too annoyed, I would offer to guide you to a working two-arduino system. (and I am sure @tekka will give advice if necessary) From there you will probably manage it on your own.
                    Started correctly MySensors will supply you with a lot of fun -- but today it is not funny for you.
                    So put away this stuff for today, go fishing and have a cold one.
                    Tomorrow (or Wednesday, because I don´t know my schedule for tomorrow now) we will build up things in an ordered way. (and please don´t scavenge your current gateway, I think it is the source of all evil and I am too curious about the reason).
                    footnote: if you are worried about your English (I am not) - give google translate a try - if available for your language
                    • T tboha
                      R
                      R
                      Reza
                      @tboha
                      thank you . very thank you
                      • R Reza
                        @tboha
                        tboha
                        @Reza
                        So let us start from scratch.
                        Before i want to know
                        • what type of computer are you using (laptop?)
                        • Operating system? (Windows?, which version)
                        • are you familiar with any kind of terminal? (Putty, Kermit?)
                        • does your OrangePi have wifi?
                        • T tboha
                          @Reza
                          R
                          R
                          Reza
                          @tboha
                          i use a loptop with win 7 . i use putty for connect to orangepi. no orange pi is connect with LAN
                          • R Reza
                            @tboha
                            tboha
                            Hopefully your Nodes 2, 3 and 4 are ok (they communicated correctly according to your log).
                            So take two of them.
                            Make one a new serial GW and the other a "MockMySensors" Node.
                            Despite my old Message - please change RF-Channels to another Channel (i don´t know is 72 legal?) for both Arduinos,
                            Please connect both to your Windows 7 machine with some longer USB cables so you can space them a little apart.
                            I built meanwhile the same complex - one serial GW and one Mock-Node
                            • T tboha
                              R
                              R
                              Reza
                              @tboha
                              i dont know what is mock my sensors ! so you told me build a new gateway with channel for example 1 ? ( my gateway is channel 0 now) and build a node(relay with channel 1)? gateway connect to my loptop with usb cable ?
                              T 2 Replies Last reply
                              • R Reza
                                @tboha
                                tboha
                                @Reza "MockMySensors" is a Sketch from Mysensors Examples - it doesn´t need any hardware and simulates input for your GW and controller (e.g. giving random numbers as temperature or as humidity - you can chose within the sketch). So you get some Network traffic to check your components without any effort.
                                Yes change Channel to a private one - far away from channel 0. Maybe 72 is ok - I will look for it.
                                • R Reza
                                  @tboha
                                  tboha
                                  @Reza
                                  Sorry for missing part two:
                                  Yes, connect GW with USB cable , and Node too. so you can monitor GW with arduino IDE and Node with putty -- or both with putty. Just as you like. For monitoring basic functions we don´t need a controller now.
                                  • T tboha
                                    R
                                    R
                                    Reza
                                    @tboha
                                    my dear friend i suggest continue about this my problem in personal chat or a new topic from me! because other friend may be sad about this long chat.thank you
                                    • R Reza
                                      @tboha
                                      tboha
                                      Please look at the Check boxes on the right side and click accordingly.
                                      • T tboha
                                        R
                                        R
                                        Reza
                                        my friend node is near gateway and this is ok. but after some test see. there is a error NACK. but if i more distance error of NACK will be more...
                                        • T tboha
                                          R
                                          R
                                          Reza
