  3. Radio FAIL after ~3 weeks [SOLVED]
61 Posts 7 Posters 24.4k Views 5 Watching
  • J Jan Gatzke
    @Reza
    Can you try to add the following line to your sketch?
    Right at the top, along with the other defines. I had similar problems with a LED Dimmer node. This solved the problem.
    R
    R
    Reza
    @Jan-Gatzke
    use this just for nrf +pa+lna? now i use just usual nrf+
    • T tboha
      @Reza No, an additional repeater was not intended (though it may be a solution).
      From your "Node 4" log I conclude:
      • you got at least 3 fully functional nodes (node 2,3,4). These nodes talk to each other in the environment of MySensors in an expected way.
      • so hardware (radio and power) is ok. Software is ok too.
      • GW functionality is partially ok - maybe hard- or software issues.
      Now there is a decision to make: go on testing potentially defective hardware or start over with known intact hardware.
      Go on testing means: are this failures reproducible? So I asked for logs of repeated boot sequences.
      Until now we don´t know the exact failure. The parallel log from Gateway would show if there are really missing transmissions (and the extent of missing messages) or only missing ACKs.
      I used ACKs last time in MySensors 1.4 and those days it made more trouble than profit. At last is showed up transmissions were ok (enough) the ACK system was not ok.
      For my purposes MySensors keeps up with transmission difficulties so I have not to care about (15m Distance, in house, reinforced concrete). So I decided not to use ACKs anymore and this did not reduce performance.
      If there are not to many missing transmissions (compare node messages vs. GW messages) I would skip the whole ACK thing.
      I would test potentially defective hardware first because it is easy to get some logs an costs not much time.
      Jan Gatzkes proposal is done quickly too.
      An additional repeater would only obscure severe GW-problems. For the GW is the heart of MySensors system - you should not tolerate any problems (hard- or software) because it will come on top again in the very near future.
      Starting over with known hardware takes more effort but should be doable in a manageable amount of time.
      R
      R
      Reza
      @tboha
      i test my hardware, change these and test again with some radio and wire and arduino ....
      now about parallel log .what am i do ? this is means i build 2 gateway?
      • R Reza
        @tboha
        tboha
        @Reza No.
        Parallel may not be the exact description, I meant simultaneous recording of GW and node.
        I don`t know about Domoticz - maybe there is a raw log function - then you are done.
        Or if you installed arduino ide on your OrangePi just use the serial monitor.
        Otherwise just hook up a terminal to your gateway.
        I.e. on your OrangePi look for the device GW is bound to and start some terminal program linked hereto (e.g. putty, minicom, kermit).
        R 2 Replies Last reply
        • T tboha
          @Reza No.
          R
          R
          Reza
          @tboha
          i understand . ok thank you . i will test it
          • R Reza
            @tboha
            tboha
            @Reza
            Sometimes it is better to step back and have a look from the distance.
            A receipe for a clean restart.
            you need:
            2 working Arduinos with radio (node 4 and node 3 from your log)
            1 working Computer/Laptop with 2 free USB interfaces
            preferably Windows with Arduino IDE installed. (Linux might work too.)
            connect both arduinos to your USB ports.
            if Arduinos are different - write down which Arduino is on which port (eg. com34: or similar)
            1. start Arduino IDE
            2. from examples/Mysensors load "Gateway serial"
              2a. choose one USB/COM-port.
            3. don´t change anything and load it to the Arduino No.1
            4. from examples/Mysensors load "MockMySensors"
              4a. choose the other USB/COM-Port
            5. don`t change anything and load it to Arduino No.2
            You are done. Watch Arduinos communicating via serial monitor.
            Ok- you are right - it is not truely simultaneaus - but close enough.
            If this is ok you should try to upload the relay-sketch and watch what is happening.
            This should not take to long, and as a result you will hopefully know:
            • my hardware is ok or not
            • my software (MySensors) is ok or not
            • my sketch is ok or not.
            R 1 Reply Last reply
            • T tboha
              @Reza No.
              R
              R
              Reza
              @tboha
              hi friend , i test it and when i have NACK serial monitor is :
              • T tboha
                @Reza
                you need:
                R
                R
                Reza
                @tboha
                i think found problem . i was careless about parent, relay is bad working when use a parent device for connect to gateway.but when connect directly , work better . more better . but now there is 2 questions ! first i am near gateway (1meter) and relay for test is near gateway.but after start or reset , some time relay choose a node (10 m far) for parent, while gateway is near that ! why ?
                i know that i can use static parent for nodes but i want know why node choose a node 10m far for parent while gateway is in near (1m)
                and second question. why with a parent relay work very bad and more command dont send and there is error!? this is related to power of radio of parent ?
                thank you
                • R Reza
                  @tboha
                  tboha
                  @Reza this is weird - i have to think about.
                  Just for clarification:
                  it seems you issued a command at your controller which results in sending
                  60;2;1;0;2;1
                  dissected:
                  60; = to node 60,
                  2; = sensor 2
                  1; = set value
                  0; = unacknowledged message (?)
                  2; = subtype is V_LIGHT
                  1; = payload is "1"
                  I think you hit button "Relais 2 ON" .
                  The weird thing is - you haven`t asked for acknowledge - but system is trying to get acknowledge ---- strange.
                  I just got your next question, I have to think about this too.
                  • R Reza
                    @tboha
                    thank you
                    tboha
                    @Reza I think we are getting close to solution.
                    This seems to be the crucial question.
                    I never dived into the core functions how MySensors decides about choosing parent.
                    Maybe it depends upon speed of answer?
                    a little excerpt from an earlier log (which i didn´t read close enough, I told you).
                    16 TSM:FPAR
                    52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2059 !TSM:FPAR:NO REPLY
                    2061 TSM:FPAR
                    2097 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2165 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                    2170 TSF:MSG:FPAR OK,ID=2,D=2
                    2340 TSF:MSG:READ,3-3-4,s=255,c=3,t=8,pt=1,l=1,sg=0:3
                    4105 TSM:FPAR:OK
                    4106 TSM:ID
                    at 2097 Node 4 broadcasts for parent and gets accepted for parenting from Node 2.
                    at 2340 Node 3 offers parenting too - upon which request?
                    and why doesn`t GW offer parenting ?? GW shows up at 8240 with response to PING, so it is alive and connection was ok.
                    at least at the moment - unexpected behavior.
                    So reading logs give us some hints.
                    Could you provide a little more from the simultaneous logs? And don´t stick to the NACK logs - the other messages are interesting as well.
                    tekkaT R 2 Replies Last reply
                    • T tboha
                      16 TSM:FPAR
                      2061 TSM:FPAR
                      4105 TSM:FPAR:OK
                      4106 TSM:ID
                      tekkaT
                      tekkaT
                      tekka
                      @tboha
                      Thanks for your time and effort, you're doing an excellent analysis. Please find below some answers to your questions:
                      The find parent step is initiated by a local I_FIND_PARENT_REQUEST broadcast, i.e. all repeaters/GW will reply with I_FIND_PARENT_RESPONSE if their uplink connections are operational (this prevents circular referencing). Node 3 (@2340) is replying to the same request, but ignored due to a greater distance to the GW (D=3+1=4 vs D=1+1=2 from node 4). The GW does not offer parenting, because it's either too close (radio interference) or too far from the requesting node. After a timeout (default 2000ms) the node uses the closest repeater/GW that replied to the request unless a static/preferred parent is defined.
                      • T tboha
                        16 TSM:FPAR
                        2061 TSM:FPAR
                        4105 TSM:FPAR:OK
                        4106 TSM:ID
                        R
                        R
                        Reza
                        @tboha
                        my friend . i am so sorry , i am weak in english and i can not know what am i do and you told to me what am i do!!
                        very very thank you for time and tried for me and my problem. i can not get your time more i am sorry . i am very thank you for tried for me but i think , i am failure.
                        this is very complicate for me because i am beginner.
                        problems is many. this serial monitor is some problem. every time in serial monitor there is new problem and new error.
                        i am Ashamed for your time and thank you . i can not understand your guidance.
                        • tekkaT tekka
                          @tboha
                          tboha
                          @tekka This is very interesting. I think i will review my own system - just for curiosity. Thank you for this explanation.
                          @Reza: don´t get desperate. I think you are not a beginner - but if you are - your learning curve is fairly steep.
                          As mentioned before, sometimes it is better to step backwards and look from the distance.
                          If you aren´t too annoyed, I would offer to guide you to a working two-arduino system. (and I am sure @tekka will give advice if necessary) From there you will probably manage it on your own.
                          Started correctly MySensors will supply you with a lot of fun -- but today it is not funny for you.
                          So put away this stuff for today, go fishing and have a cold one.
                          Tomorrow (or Wednesday, because I don´t know my schedule for tomorrow now) we will build up things in an ordered way. (and please don´t scavenge your current gateway, I think it is the source of all evil and I am too curious about the reason).
                          footnote: if you are worried about your English (I am not) - give google translate a try - if available for your language
                          • T tboha
                            R
                            R
                            Reza
                            @tboha
                            thank you . very thank you
                            • R Reza
                              @tboha
                              tboha
                              @Reza
                              So let us start from scratch.
                              Before i want to know
                              • what type of computer are you using (laptop?)
                              • Operating system? (Windows?, which version)
                              • are you familiar with any kind of terminal? (Putty, Kermit?)
                              • does your OrangePi have wifi?
                              • T tboha
                                @Reza
                                R
                                R
                                Reza
                                @tboha
                                i use a loptop with win 7 . i use putty for connect to orangepi. no orange pi is connect with LAN
                                • R Reza
                                  @tboha
                                  tboha
                                  Hopefully your Nodes 2, 3 and 4 are ok (they communicated correctly according to your log).
                                  So take two of them.
                                  Make one a new serial GW and the other a "MockMySensors" Node.
                                  Despite my old Message - please change RF-Channels to another Channel (i don´t know is 72 legal?) for both Arduinos,
                                  Please connect both to your Windows 7 machine with some longer USB cables so you can space them a little apart.
                                  I built meanwhile the same complex - one serial GW and one Mock-Node
                                  • T tboha
                                    R
                                    R
                                    Reza
                                    @tboha
                                    i dont know what is mock my sensors ! so you told me build a new gateway with channel for example 1 ? ( my gateway is channel 0 now) and build a node(relay with channel 1)? gateway connect to my loptop with usb cable ?
                                    T 2 Replies Last reply
                                    • R Reza
                                      @tboha
                                      tboha
                                      @Reza "MockMySensors" is a Sketch from Mysensors Examples - it doesn´t need any hardware and simulates input for your GW and controller (e.g. giving random numbers as temperature or as humidity - you can chose within the sketch). So you get some Network traffic to check your components without any effort.
                                      Yes change Channel to a private one - far away from channel 0. Maybe 72 is ok - I will look for it.
                                      • R Reza
                                        @tboha
                                        tboha
                                        @Reza
                                        Sorry for missing part two:
                                        Yes, connect GW with USB cable , and Node too. so you can monitor GW with arduino IDE and Node with putty -- or both with putty. Just as you like. For monitoring basic functions we don´t need a controller now.
                                        • T tboha
                                          R
                                          R
                                          Reza
                                          @tboha
                                          my dear friend i suggest continue about this my problem in personal chat or a new topic from me! because other friend may be sad about this long chat.thank you
