  2. Feature Requests
  3. Default debug serial port
5 Posts 3 Posters 2.2k Views 1 Watching
  • L Offline
    L Offline
    lafleur
    Is there a way to change the debug serial port in 2.1b code?
    In using a ARM M0, the serial port defaults to the USB port... I would like to reroute to Serial or Serial1
    • S Offline
      in MyHwSAMD.h
      you can try to change MY_SERIALDEVICE define
      you may also need to check the variant files in samd arduino files if sercom, serial and pins are ok.
      • L Offline
        L Offline
        lafleur
        Thanks... Unclear on why I did not see that when I looks for something like that...
        Made these changes... added issue 707 to development branch
        #define MY_SERIALDEVICE SerialUSB
        to:
        #ifndef MY_SERIALDEVICE
        • T Offline
          T Offline
          tbowmo
          By setting MY_SERIALDEVICE you will reroute everything to the other serial port, not only debug messages.
          L 1 Reply Last reply
          • T tbowmo
            L Offline
            L Offline
            lafleur
            @tbowmo thanks... works just as expected.....
            12.1k
