  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • E ejlane
    @Trand Do you mean that it stops at "Unable to begin"?? I don't see "Enable" in there.
    If it's "Unable" then I would suspect that you don't have it wired up correctly. Are you sure about the RX_PIN and TX_PIN? If it were me, I would double check them again. And then swap them in the code after double checking them, just in case.
    If there's absolutely no doubt that you have the correct wires connected, do you also have a ground wire connected between the Arduino and the DFplayer? Finally, are you sure that 9600 is a good speed to communicate with the DFplayer? (I have no experience with this module, so these are just general troubleshooting ideas.)
    Trand
    @ejlane Thank you for your answer. I don't think I have any connection problem, it's soldered on a PCB and it works with the original NANO Bootloader. The speed 9600 is the one given in the example of the library, and I think that the problem comes from SoftwarSerial... I continue to search.
    E 1 Reply Last reply
    • T Trand
      E
      E
      ejlane
      @Trand Well, sorry, but nothing else comes to mind. If you have a scope or logic analyzer then you need to watch the actual signals on the wires and see what is happening.
      If you don't, then you should pick up a cheap logic analyzer. You can get one for $10 and it's invaluable for tracking down things like this. I don't know where you are based, but I see them on Aliexpress all the time.
