  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 92.5k Views 42 Watching
  • tekkaT tekka
    @Werwolfx I don't see any MYSBootloader startup message in your log. Please re-download the .hex from the github repo to ensure you are on the most recent version and flash it following these instructions: https://www.mysensors.org/about/ota
    W
    W
    Werwolfx
    @tekka
    i tryed it
    My little instructions for Arduino Atmega328p 5v ext
    1)download from https://github.com/mysensors/MySensorsBootloaderRF24
    2)copy to arduino folder arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors and paste boards.txt
    proMYSBL.name=ATmega328 16Mhz MYSBootloader
    proMYSBL.upload.tool=avrdude
    proMYSBL.upload.protocol=arduino
    proMYSBL.upload.maximum_size=30720
    proMYSBL.upload.maximum_data_size=2048
    proMYSBL.upload.speed=115200
    proMYSBL.bootloader.tool=avrdude
    proMYSBL.bootloader.low_fuses=0xF7
    proMYSBL.bootloader.high_fuses=0xDA
    proMYSBL.bootloader.extended_fuses=0x06
    proMYSBL.bootloader.unlock_bits=0x3F
    proMYSBL.bootloader.lock_bits=0x0F
    proMYSBL.bootloader.file=MySensors/MYSBootloader.hex
    proMYSBL.build.mcu=atmega328p
    proMYSBL.build.f_cpu=16000000L
    proMYSBL.build.board=AVR_UNO
    proMYSBL.build.core=arduino
    proMYSBL.build.variant=standard
    3)In Arduino IDE select downloadex bootloader and burn it to Atmega
    avrdude log
    /home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
    avrdude: Version 6.3, compiled on Dec 16 2016 at 12:32:01
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf"
             User configuration file is "/home/werwolfx/.avrduderc"
             User configuration file does not exist or is not a regular file, skipping
             Using Port                    : usb
             Using Programmer              : usbasp
             AVR Part                      : ATmega328P
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : usbasp
             Description     : USBasp, http://www.fischl.de/usbasp/
    avrdude: auto set sck period (because given equals null)
    avrdude: warning: cannot set sck period. please check for usbasp firmware update.
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.00s
    avrdude: Device signature = 0x1e950f (probably m328p)
    avrdude: erasing chip
    avrdude: reading input file "0x3F"
    avrdude: writing lock (1 bytes):
    /home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -Uflash:w:/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
    Writing | ################################################## | 100% 0.00s
    avrdude: 1 bytes of lock written
    avrdude: verifying lock memory against 0x3F:
    avrdude: load data lock data from input file 0x3F:
    avrdude: input file 0x3F contains 1 bytes
    avrdude: reading on-chip lock data:
    avrdude: verifying ...
    avrdude: 1 bytes of lock verified
    avrdude: reading input file "0x06"
    avrdude: writing efuse (1 bytes):
    Writing |  ***failed;
    ################################################## | 100% 0.03s
    avrdude: 1 bytes of efuse written
    avrdude: verifying efuse memory against 0x06:
    avrdude: load data efuse data from input file 0x06:
    avrdude: input file 0x06 contains 1 bytes
    avrdude: reading on-chip efuse data:
    avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
    This behaviour is deprecated and will result in an error in future version
    You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
    avrdude: 1 bytes of efuse verified
    avrdude: reading input file "0xDA"
    avrdude: writing hfuse (1 bytes):
    avrdude: 1 bytes of hfuse written
    avrdude: verifying hfuse memory against 0xDA:
    avrdude: load data hfuse data from input file 0xDA:
    avrdude: input file 0xDA contains 1 bytes
    avrdude: reading on-chip hfuse data:
    avrdude: 1 bytes of hfuse verified
    avrdude: reading input file "0xF7"
    avrdude: writing lfuse (1 bytes):
    Writing | ################################################## | 100% 0.01s
    avrdude: 1 bytes of lfuse written
    avrdude: verifying lfuse memory against 0xF7:
    avrdude: load data lfuse data from input file 0xF7:
    avrdude: input file 0xF7 contains 1 bytes
    avrdude: reading on-chip lfuse data:
    avrdude: 1 bytes of lfuse verified
             Using Port                    : usb
    avrdude done.  Thank you.
             PAGEL                         : PD7
             BS2                           : PC2
             RETRY pulse                   : SCK
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
    avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
    avrdude: reading input file "/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex"
    avrdude: writing flash (32762 bytes):
    avrdude: 32762 bytes of flash written
    avrdude: verifying flash memory against /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
    avrdude: load data flash data from input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
    avrdude: input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex contains 32762 bytes
    avrdude: reading on-chip flash data:
    avrdude: 32762 bytes of flash verified
    avrdude: reading input file "0x0F"
    avrdude: verifying lock memory against 0x0F:
    avrdude: load data lock data from input file 0x0F:
    avrdude: input file 0x0F contains 1 bytes
    1. I loaded test sketh WaterMeterPulssensor (from Mysensors example) to arduino
      wait if the module is start and see to MYSController
      in MYSController
    14.01.2017 11:34:49	RX	5;6;1;0;3;0
    14.01.2017 11:34:52	RX	10;5;1;0;17;5519
    14.01.2017 11:34:52	RX	10;6;1;0;39;23.99
    14.01.2017 11:34:57	RX	6;3;1;0;16;0
    14.01.2017 11:34:58	RX	6;4;1;0;37;170
    14.01.2017 11:34:58	RX	6;6;1;0;3;0
    14.01.2017 11:34:58	RX	6;5;1;0;0;20.50
    14.01.2017 11:35:01	RX	4;255;0;0;17;2.1.0
    14.01.2017 11:35:01	DEBUG	Update child id=255, type=S_ARDUINO_NODE
    14.01.2017 11:35:01	RX	4;255;3;0;6;0
    14.01.2017 11:35:01	TX	4;255;3;0;6;M
    14.01.2017 11:35:02	RX	4;255;3;0;11;Water Meter
    14.01.2017 11:35:02	RX	4;255;3;0;12;1.1
    14.01.2017 11:35:02	RX	4;1;0;0;21;
    14.01.2017 11:35:02	DEBUG	Update child id=1, type=S_WATER
    14.01.2017 11:35:02	RX	4;1;2;0;24;
    14.01.2017 11:35:08	RX	10;5;1;0;17;5462
    14.01.2017 11:35:08	RX	10;6;1;0;39;23.75
    14.01.2017 11:35:18	RX	7;3;1;0;16;0
    14.01.2017 11:35:18	RX	7;4;1;0;37;192
    14.01.2017 11:35:18	RX	7;6;1;0;3;0
    14.01.2017 11:35:19	RX	5;3;1;0;16;0
    14.01.2017 11:35:19	RX	5;4;1;0;37;34
    14.01.2017 11:35:19	RX	5;6;1;0;3;0
    5)in MYSController Assign FW Blink and Reboot
    MYSController
    14.01.2017 11:38:03	TX	4;0;3;0;13;0
    14.01.2017 11:38:09	RX	4;255;0;0;17;2.1.0
    14.01.2017 11:38:09	CHILD	New child discovered, node id=4, child id=internal
    14.01.2017 11:38:09	DEBUG	Update child id=255, type=S_ARDUINO_NODE
    14.01.2017 11:38:09	RX	4;255;3;0;6;0
    14.01.2017 11:38:09	TX	4;255;3;0;6;M
    14.01.2017 11:38:09	RX	4;255;3;0;11;Water Meter
    14.01.2017 11:38:09	RX	4;255;3;0;12;1.1
    14.01.2017 11:38:09	RX	4;1;0;0;21;
    14.01.2017 11:38:09	CHILD	New child discovered, node id=4, child id=1
    14.01.2017 11:38:09	DEBUG	Update child id=1, type=S_WATER
    14.01.2017 11:38:10	RX	4;1;2;0;24;
    14.01.2017 11:38:14	RX	4;255;3;0;21;0
    Serial
    101794 TSF:MSG:READ,0-0-4,s=0,c=3,t=13,pt=0,l=1,sg=0:0
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=4
    14 TSF:SID:OK,ID=4
    16 TSM:FPAR
    52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    345 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    350 TSF:MSG:FPAR OK,ID=0,D=1
    2060 TSM:FPAR:OK
    2061 TSM:ID
    2062 TSM:ID:OK
    2064 TSM:UPL
    2067 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2081 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2086 TSF:MSG:PONG RECV,HP=1
    2089 TSM:UPL:OK
    2091 TSM:READY:ID=4,PAR=0,DIS=1
    2098 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2104 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2114 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
    2126 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2157 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2164 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Water Meter
    2176 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    2183 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=21,pt=0,l=0,sg=0,ft=0,st=OK:
    2189 MCO:REG:REQ
    2193 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2245 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2250 MCO:PIM:NODE REG=1
    2252 MCO:BGN:STP
    2255 TSF:MSG:SEND,4-4-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    2262 MCO:BGN:INIT OK,TSP=1
    2335 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
    2866 TSF:MSG:READ,0-0-4,s=1,c=1,t=24,pt=0,l=6,sg=0:400100
    Received last pulse count from gw:400100
    6381 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    6386 TSF:MSG:BC
    6637 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0```
    tekkaT 1 Reply Last reply
    • W Werwolfx
      @tekka
      i tryed it
      avrdude log
               Using Port                    : usb
               PAGEL                         : PD7
               BS2                           : PC2
               RETRY pulse                   : SCK
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
               Using Port                    : usb
               PAGEL                         : PD7
               BS2                           : PC2
               RETRY pulse                   : SCK
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
        in MYSController
      MYSController
      Serial
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      14 TSF:SID:OK,ID=4
      16 TSM:FPAR
      2060 TSM:FPAR:OK
      2061 TSM:ID
      2062 TSM:ID:OK
      2064 TSM:UPL
      2089 TSM:UPL:OK
      2189 MCO:REG:REQ
      2252 MCO:BGN:STP
      6386 TSF:MSG:BC
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #22
      @Werwolfx but still no signs of MYSBootloader - what RF channel are you on?
      W 1 Reply Last reply
      • tekkaT tekka
        W
        W
        Werwolfx
        wrote on last edited by Werwolfx
        #23
        @tekka
        NRF24L01+
        What is the "no signs of MYSBootloader"?
        • W Werwolfx
          @tekka
          NRF24L01+
          tekkaT
          tekkaT
          tekka
          @Werwolfx As soon as the bootloader takes over, in your case after the reboot request (1), but before the MYS lib 2.1.0 init message (2):
          (1) 14.01.2017 11:38:03 TX  4;0;3;0;13;0
          (2) 14.01.2017 11:38:09 RX  4;255;0;0;17;2.1.0
          it will send a I_FIRMWARE_CONFIG_REQUEST message to inform the controller about the currently loaded FW and request a new FW.
          looks like this:
          4;255;4;0;0;BE0001003003D8490102
          This is missing in your case, therefore I'm wondering if you have incompatible radio settings. Please post your GW sketch and upload your MYSBootloader.hex file for further troubleshooting.
          • tekkaT tekka
            looks like this:
            W
            W
            Werwolfx
            #25
            @tekka GW on esp8266 (default sketch) + NRF24L01+
            on GW
             * Version 1.0 - Henrik EKblad
             * Contribution by Ivo Pullens (ESP8266 support)
             * The EthernetGateway sends data received from sensors to the WiFi link.
             * VERA CONFIGURATION:
             * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
             * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
             * LED purposes:
             * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
             * nRF24L01+  ESP8266
             * VCC        VCC
             * CE         GPIO4
             * CSN/CS     GPIO15
             * SCK        GPIO14
             * MISO       GPIO12
             * MOSI       GPIO13
             * GND        GND
              * Inclusion mode button:
            #define MY_BAUD_RATE 115200
            #define MY_GATEWAY_ESP8266
            #define MY_ESP8266_SSID "WiFI"
            #define MY_ESP8266_PASSWORD "password[0_1484386469111_MYSBootloader.hex](/uploads/files/1484386469171-mysbootloader.hex) "
            // Enable UDP communication
            //#define MY_USE_UDP
            // #define MY_ESP8266_HOSTNAME "sensor-gateway"
            #define MY_PORT 5003
            // Enable inclusion mode
            // #define MY_INCLUSION_BUTTON_FEATURE
            // Set blinking period
            // #define MY_DEFAULT_LED_BLINK_PERIOD 300
            // Flash leds on rx/tx/err
            // Led pins used if blinking feature is enabled above
            #if defined(MY_USE_UDP)
              #include <WiFiUdp.h>
            #include <ESP8266WiFi.h>
            void presentation() {
            In MYSController on mudule i click INFO
            FW Update = no
            Bootloader = N/A
            may be problem in the Bootloader.hex?
            0_1484386859986_upload-c59e469e-e015-4099-88d8-607a7408a1da
            • W Werwolfx
              on GW
               * LED purposes:
               * nRF24L01+  ESP8266
               * VCC        VCC
               * CE         GPIO4
               * CSN/CS     GPIO15
               * SCK        GPIO14
               * MISO       GPIO12
               * MOSI       GPIO13
               * GND        GND
              FW Update = no
              Bootloader = N/A
              tekkaT
              tekkaT
              tekka
              @Werwolfx Please also update the bootloader file.
              W 2 Replies Last reply
              • tekkaT tekka
                W
                W
                Werwolfx
                I'll update more than once, but there is no effect.
                avrdude writes that everything is OK
                I do not know what to do = (
                • W Werwolfx
                  tekkaT
                  tekkaT
                  tekka
                  @Werwolfx sorry, maybe I was not clear - please upload it here to the forum I will try to reproduce your setup.
                  • tekkaT tekka
                    W
                    W
                    Werwolfx
                    #29
                    @tekka If i ENABLE #define MY_OTA_FIRMWARE_FEATURE
                    i see ST_FIRMWARE_CONFIG_REQUEST in MYSCONTROLLER logs!!!
                    if i DISABLE //#define MY_OTA_FIRMWARE_FEATURE msg not in log
                    i not have external flash/
                    402	14.01.2017 21:29:28	TX	4 - Water Meter	N/A	C_INTERNAL	NO	I_REBOOT	0
                    403	14.01.2017 21:29:28	RX	4	1	C_REQ	NO	V_VAR1
                    408	14.01.2017 21:29:34	RX	4	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFF48044E100300
                    409	14.01.2017 21:29:34	TX	4	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
                    410	14.01.2017 21:29:34	RX	4	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_NODE	2.1.0
                    411	14.01.2017 21:29:34	RX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	0
                    412	14.01.2017 21:29:34	TX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	M
                    414	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_NAME	Water Meter
                    417	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_VERSION	1.1
                    419	14.01.2017 21:29:34	RX	4 - Water Meter	1 - S_WATER	C_PRESENTATION	NO	S_WATER
                    i load this HEX
                    load from Arduino IDE 1.8.0
                    0_1484418874223_MYSBootloader.hex
                    board.txt
                    proMYSBL.bootloader.low_fuses=0xFF
                    proMYSBL.bootloader.extended_fuses=0xFE
                    • W Werwolfx
                      i load this HEX
                      board.txt
                      tekkaT
                      tekkaT
                      tekka
                      @Werwolfx Ok, seems like you also upload the sketch via USBasp thereby erasing/overwriting the bootloader. Try uploading the sketch via serial or OTA after flashing the bootloader.
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        wrote on last edited by Mark Swift
                        #31
                        @tekka am I correct in thinking the HEX found on Github can be used with all Arduino's? I noticed my old folder has one hex for 16, 8 and 1Mhz?
                        I'm using this board.txt
                        menu.cpu=Processor
                        MYSBL13.name=MYS Bootloader - atmega328p
                        MYSBL13.upload.tool=arduino:avrdude
                        MYSBL13.upload.protocol=arduino
                        MYSBL13.upload.maximum_size=30720
                        MYSBL13.upload.maximum_data_size=2048
                        MYSBL13.bootloader.tool=arduino:avrdude
                        MYSBL13.bootloader.unlock_bits=0x3F
                        MYSBL13.bootloader.lock_bits=0x0F
                        MYSBL13.build.mcu=atmega328p
                        MYSBL13.build.board=AVR_PRO
                        MYSBL13.build.core=arduino:arduino
                        MYSBL13.build.variant=arduino:standard
                        MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
                        MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
                        MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                        MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                        MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                        MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                        MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                        MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
                        MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
                        MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                        MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                        MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                        MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                        MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                        MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
                        MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
                        MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                        MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                        MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                        MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                        MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L```
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          I guess not... The old hex for 8Mhz works, but the one from this thread does not... :(
                          I'm trying to upload this to my Pro Mini, does anyone have an 8Mhz that works?
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            #33
                            @tekka I've noticed some odd things with my nodes when running the bootloader.
                            To test I uploaded a simple count time sketch. When running the MYS bootloader the timer resets every 10 seconds, see:
                            Time: 999
                            Time: 2000
                            Time: 3000
                            Time: 4001
                            Time: 5001
                            Time: 6002
                            Time: 7004
                            Time: 8003
                            Time: 9005
                            Time: 0
                            Time: 999
                            Time: 2000
                            Time: 3000
                            Time: 4001
                            Time: 5001
                            Time: 6002
                            Time: 7004
                            Time: 8003
                            Time: 9005
                            Time: 0
                            Using the stock Pro Mim 8Mhz 3.3v bootloader it works fine, any ideas?
                            Perhaps this is because I'm testing using a non-MySensors sketch?
                            • Mark SwiftM Mark Swift
                              Time: 999
                              Time: 2000
                              Time: 3000
                              Time: 4001
                              Time: 5001
                              Time: 6002
                              Time: 7004
                              Time: 8003
                              Time: 9005
                              Time: 0
                              Time: 999
                              Time: 2000
                              Time: 3000
                              Time: 4001
                              Time: 5001
                              Time: 6002
                              Time: 7004
                              Time: 8003
                              Time: 9005
                              Time: 0
                              tekkaT
                              tekkaT
                              tekka
                              #34
                              @Mark-Swift yeah, this is intended behavior: the watchdog kicks in after ~8s, so either you reset it in loop() or disable it in setup().
                              • rmtuckerR
                                rmtuckerR
                                rmtucker
                                Is there a version or branch of this for the rfm69?
                                • rmtuckerR rmtucker
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @rmtucker No, but everybody is welcome to contribute and enhance the functionality.
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    @tekka, I'm trying to compile the HEX using OSX. I have installed avr-gcc with homebrew but I get
                                    rm *.o
                                    rm: *.o: No such file or directory
                                    make: [clean] Error 1 (ignored)
                                    rm *.elf
                                    rm: *.elf: No such file or directory
                                    rm *.hex
                                    rm: *.hex: No such file or directory
                                    "avr-gcc" -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o" -I MYSBootloader.c -o MYSBootloader.o
                                    avr-gcc: fatal error: no input files
                                    compilation terminated.
                                    make: *** [MYSBootloader.o] Error 1
                                    When issueing the Make command, can you help, any suggestions?
                                      rm *.o
                                      rm *.elf
                                      rm *.hex
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
                                      ? 1 Reply Last reply
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        @tekka, started a windows VM, run via MinGW and got this when running makefile, does it look okay?
                                        C:\MySensorsBootloaderRF24-development>mingw32-make.exe
                                        rm *.o
                                        process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                                        make (e=2): The system cannot find the file specified.
                                        Makefile:40: recipe for target 'clean' failed
                                        mingw32-make.exe: [clean] Error 2 (ignored)
                                        rm *.elf
                                        process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                                        rm *.hex
                                        process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                                        "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -funsigned-char -funsigned-bitfields
                                        D -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -IC:/Ardu
                                        ino/hardware/tools/avr/avr/include/avr MYSBootloader.c -o MYSBootloader.o
                                        In file included from Core.h:40:0,
                                                         from MYSBootloader.c:69:
                                        HW.h:51:2: warning: #warning is a GCC extension
                                         #warning BAUD_RATE error greater than 2%
                                        HW.h:51:2: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                                        In file included from Core.h:42:0,
                                        MyMessage.h:292:3: warning: ISO C99 doesn't support unnamed structs/unions [-Wpe
                                        dantic]
                                        "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl
                                        ,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-se
                                        ction-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o
                                         -lm
                                        "C:/Arduino/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader
                                        .elf MYSBootloader.hex
                                        "C:/Arduino/hardware/tools/avr/bin/avr-size" MYSBootloader.elf
                                           text    data     bss     dec     hex filename
                                           2036       6      72    2114     842 MYSBootloader.elf
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          @tekka Just wanted to check if the above log looks okay, currently rolling the bootloader out to 14 nodes (painful process!) and wanted to check if it looks okay before I do.
                                          I'm also using this board.txt, I made a separate entry for my Uno's, do they all look okay? I basically used the fuses from the standard Arduino boards.txt with the change of 0x05 to 0x06 for the BOD? I noticed in the makefile that you can specify the fuses, do I need to compile a bootloader for each device with the exact fuses, or will one bootloader for 16 / 8 / 1Mhz suffice?
                                          Thank you very much in advance, the bootloader is amazing work.
                                          menu.cpu=Processor
                                          pro.name=MySensors Bootloader for Pro Mini
                                          pro.upload.tool=arduino:avrdude
                                          pro.upload.protocol=arduino
                                          pro.upload.maximum_size=30720
                                          pro.upload.maximum_data_size=2048
                                          pro.bootloader.tool=arduino:avrdude
                                          pro.bootloader.unlock_bits=0x3F
                                          pro.bootloader.lock_bits=0x0F
                                          pro.build.mcu=atmega328p
                                          pro.build.board=AVR_PRO
                                          pro.build.core=arduino:arduino
                                          pro.build.variant=arduino:standard
                                          ## Arduino with MYSBootloader Beta 2
                                          ## pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                                          ## pro.menu.cpu.16MHzatmega328.upload.speed=115200
                                          ## pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                          ## pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                          ## pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                          ## pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                                          ## pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                          ## pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 2
                                          ## pro.menu.cpu.8MHzatmega328.upload.speed=38400
                                          ## pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                                          ## pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                                          ## pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                                          ## pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_8Mhz.hex
                                          ## pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                                          ## pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 2
                                          ## pro.menu.cpu.1MHzatmega328.upload.speed=9600
                                          ## pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                                          ## pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                                          ## pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                                          ## pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_1Mhz.hex
                                          ## pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
                                          ## Arduino with MYSBootloader Beta 3
                                          pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                                          pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                                          pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 3
                                          pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                                          pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_8Mhz.hex
                                          pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 3
                                          pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_1Mhz.hex
                                          menu.cpu=Processor
                                          uno.name=MySensors Bootloader for Uno
                                          uno.upload.tool=arduino:avrdude
                                          uno.upload.protocol=arduino
                                          uno.upload.maximum_size=32256
                                          uno.upload.maximum_data_size=2048
                                          uno.bootloader.tool=arduino:avrdude
                                          uno.bootloader.unlock_bits=0x3F
                                          uno.bootloader.lock_bits=0x0F
                                          uno.build.mcu=atmega328p
                                          uno.build.board=AVR_UNO
                                          uno.build.core=arduino:arduino
                                          uno.build.variant=arduino:standard
                                          ## uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                                          ## uno.menu.cpu.16MHzatmega328.upload.speed=115200
                                          ## uno.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                          ## uno.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                          ## uno.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                          ## uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                                          ## uno.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                          uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                                          uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
