  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
    @jolo yes, MYSbootlader supports only ota. No serial.
    I have updated the ota page to mention the lack of serial.
    G
    G
    gonzalonal
    @mfalkvidd actually looking at the code of mysbootloder, it does support STK500 protocol. I haven't test if it really works...maybe it doesn't.
    • G gonzalonal
      @gonzalonal it did not a while ago according to this, but that might have changed. Maybe @tekka can shed a light?
      • tekkaT
        tekkaT
        tekka
        @mfalkvidd The most recent MYSBootloader supports OTA and serial uploads via STK500, see here: https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
        • tekkaT tekka
          @tekka thanks.
          I did look there, but didn't find anything that I understood was related to serial. I also looked at the list of commit messages but none of them mentions anything about added support.
          Anyway, thanks for clarifying. I'll update the ota page again.
            Does that work for both nrf24 and rfm69?
            • J
              J
              jolo
              wrote on last edited by jolo
              #106
              Many thanks for help - today I made it work :) Here are my steps that worked for me:
              • I used MYSController 1.0.0 beta, took bootloader MYSBootloaderV13pre.hex and uploaded to Arduino Mini Pro with AVRDUDESS and USBasp programmer
              • then uploaded serial gateway sketch to another Mini Pro
              • attached nR24L01+ radios to both
              • connected MYSController, configured serial connection and all just started to work
              • then uploaded simple DHT sketch, edited csv file in MYSController and selected it for OTA FW update
              After less than minute new FW was already at the node and it started to send data. I am very happy :) I played with Arduino projects for several years, but this stuff you have made is absolutely amazing! Now time for some real nodes - first one will be stepper controller for telescope focuser.
              astrojolo.com
              • J
                J
                jolo
                It still works fine - however I have one more question, maybe stupid :) About RF channels. I use nR24L01+ radios at default channel 76, however for final solution I would like to switch to some higher freq. Does precompiled bootlader work only at this default channel 76? So if I would like to switch to channel 101 I need to compile bootloader with this setting? Or there is some magic behind that makes it work some other way?
                astrojolo.com
                tekkaT 1 Reply Last reply
                • J jolo
                  tekkaT
                  tekkaT
                  tekka
                  @jolo Glad to hear that :) re RF24 channel: yes, you need to change and recompile the bootloader for different communication settings. See here: https://github.com/mysensors/MySensorsBootloaderRF24/blob/development/MYSBootloader.c#L45-L51
                    moskovskiy82
                    Really want to try FOTA with MYSBoatloader but a little bit confused. First - do i have to burn the fuses (i'm using a chinese arduino mini pro 16Mhz) or can simply download MYSBootloader_16MHz.hex from dev brach and i'm good to go?
                    Another thing - i'm using an MQTT gateway attached to RPi3. Don't really want to change the gateway type - so is there a way to do OTA update? I have a spare UNO which i can connect to a notebook.
                      It was mentioned in a previous thread that mycontroller can do fota also through mqtt
                      M 1 Reply Last reply
                        moskovskiy82
                        wrote on last edited by moskovskiy82
                        #111
                        @gohan Excellent. Searched through the thread but couldn't find any mentions how it can be done via mqtt What about the fuses?
                          Just try using mycontroller, the procedure should be the same as the ethernet gateway
                            moskovskiy82
                            Yes thank you for the tip! Mycontroller works.
                            For Mini Pro - no fuses are needed. Just download the hex - rename and flash.
                            What about the nano?
                            Looking at boards.txt i see only two difeerences
                            Nano
                            nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                            nano.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
                            Mys
                            proMYSBL.bootloader.low_fuses=0xF7
                            proMYSBL.bootloader.extended_fuses=0x06
                            But at the same time PRO mini is same as nano... So can also flash straight away?
                              moskovskiy82
                              Nano also doesn't need any fuses. So everything works. Except to begin the flash procedure i have to unplug and plug the node. Is this intended behaviour? Otherwise i only see in MQTT one line of code and no response from node
                                Is the node doing any kind of sleep?
                                  moskovskiy82
                                  No it's powered off mains so no sleep functions added
                                    I think you have to issue a reboot node from the mycontroller or myscontroller to have the OTA start
                                      moskovskiy82
                                      @gohan So is it first reboot. Or start flashing - reboot?
                                      J 1 Reply Last reply
                                        You assign firmware to upload to node and then you send a reboot, if I remember correctly
                                        • M moskovskiy82
                                          J
                                          J
                                          jkandasa
                                          @moskovskiy82 If you use MyController, Yes, you should assign the firmware for the node and send reboot.
