  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 95.2k Views 42 Watching
  • tekkaT
    tekkaT
    tekka
    And here comes another release for public testing:
    MYSBootloader v1.3.0-beta.3
    Source / compiled .HEX and additional information can be found here.
    One more (and last) time: :tada: Happy New Year 2017!
    • C
      C
      cdr
      Hi Tekka,
      Happy 2017! Thanks for the update, can you upload a 8Mhz precompiled bootloader? (and update boards.txt) :)
      I'm curious is there a changelog since last version?
      • TetnobicT
        TetnobicT
        Tetnobic
        @tekka Hi Happy new year 2017 !!!
        Many thanks for release source of MYSBootloader!!! A very good news !!!
        Can you explain how to compile ?
        Makefile in Master Branch failed with :
        make: *** No rule to make target 'MYSBootloader.c', needed by 'MYSBootloader.o'.
        I would like to compile an ATMega328 1Mhz version
        • MiKaM
          MiKaM
          MiKa
          To tekka:
          +1 to "Can you explain how to compile ?"
          OTA with MYSBootloader is possible also with gateway based on ESP8266 ? I cant do it, node is just rebooting after firmware update request and thats all.
          tekkaT 1 Reply Last reply
          • MiKaM MiKa
            To tekka:
            tekkaT
            tekkaT
            tekka
            @MiKa @Tetnobic:
            Issue created, please feel free to add any comments: https://github.com/mysensors/MySensorsBootloaderRF24/issues/3
            • FejiF
              FejiF
              Feji
              Hi Tekka,
              First, thx for all your hard work.
              +1 for the How-to cause I'm on a try to compile since two hours, :(. There is an include missing : RF24_registers.h.
              While I'm here, is there a timout if the node can't reach the gateway in order to boot anyway in this version ?
              Thx again.
              • FejiF Feji
                Hi Tekka,
                Thx again.
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @Tetnobic, @Feji
                Dev branch updated: https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
                • updated Makefile, added include files to same dir
                • To compile (under win): install make (I'm using mingw32-make from MinGW)
                • clone dev repo
                • update paths to avr tools and includes in Makefile (BINPATH, INLCUDES)
                • run Makefile to obtain .hex file
                • Flash .hex file using ISP
                • MiKaM
                  MiKaM
                  MiKa
                  Hi Tekka,
                  can You compile for ATMega328P 8MHz pls?
                  THX,
                  MiKa
                  • FejiF
                    FejiF
                    Feji
                    There is a 8 MHz version.
                    I can't get the serial uploading working, don't know why.
                    MYSBootloader_8MHZ.hex
                    MiKaM 1 Reply Last reply
                    • FejiF Feji
                      MiKaM
                      MiKaM
                      MiKa
                      I already have it ;) finnaly I compile it after one hour :)
                      • MiKaM MiKa
                        MiKaM
                        MiKaM
                        MiKa
                        wrote on last edited by MiKa
                        To Feji: You have speed 38400 Bd?
                        FejiF 1 Reply Last reply
                        • MiKaM MiKa
                          FejiF
                          FejiF
                          Feji
                          @MiKa
                          It's a 56K version, I haven't try 38k yet.
                          • FejiF Feji
                            @MiKa
                            MiKaM
                            MiKaM
                            MiKa
                            @Feji
                            try 38400Bd it should work
                            HW.h
                            #ifndef BAUD_RATE
                            #if F_CPU >= 16000000L
                            #define BAUD_RATE 115200
                            #elif F_CPU >= 8000000L
                            #define BAUD_RATE 38400L
                            #elif F_CPU >= 1000000L
                            #define BAUD_RATE 9600L
                            #elif F_CPU >= 128000L
                            #define BAUD_RATE 4800L
                            #else
                            #define BAUD_RATE 1200L
                            • MiKaM MiKa
                              @Feji
                              HW.h
                              #ifndef BAUD_RATE
                              #else
                              FejiF
                              FejiF
                              Feji
                              @MiKa
                              My bad, it's a 38k version but I was trying to upload the sketch at 56k...
                              • FejiF Feji
                                @MiKa
                                FejiF
                                FejiF
                                Feji
                                @Feji
                                After modifying the HW.h, it's work much better :). Obviously...
                                Serial upload confirmed work at 57600.
                                • W
                                  W
                                  Werwolfx
                                  wrote on last edited by Werwolfx
                                  Hello everybody.
                                  I have a problem with the update over the air.
                                  Version 2.1.0 mysensors
                                  Gateway on ESP8266 default sketh
                                  I downloaded the loader in atmega328p Arduino pro mini
                                  in MYSController choose firmware
                                  in logs
                                  [12.01.2017 20: 32: 50.118 Info] INFO BL version = 768
                                   [12.01.2017 20: 32: 50.118 Info] INFO Send FW info to node 4: type = A, version = 1, blocks = 0x0050, CRC = 0x46D4
                                   [12/01/2017 20: 32: 50.120 Info] TX 4, 0, 4, 0, 1; 0A0001005000D446
                                   [12/01/2017 20: 32: 52.205 Info] RX 0, 255, 3, 0, 2, 2.1.0
                                   [12.01.2017 20: 32: 53.724 Info] RX 10, 3, 1, 0, 0, 21.2
                                   [12/01/2017 20: 32: 53.736 Info] RX 4; 255; 3, 0, 6, 0
                                   [12/01/2017 20: 32: 53.737 Info] TX 4; 255; 3, 0; 6; M
                                  in arduino serial
                                  0 MCO: BGN: INIT NODE, CP = RNONA -, VER = 2.1.0
                                  3 TSM: INIT
                                  4 TSF: WUR: MS = 0
                                  11 TSM: INIT: TSP OK
                                  13 TSM: INIT: STATID = 4
                                  15 TSF: SID: OK, ID = 4
                                  16 TSM: FPAR
                                  53 TSF: MSG: SEND, 4-4-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, st = OK:
                                  592 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 8, pt = 1, l = 1, sg = 0: 0
                                  598 TSF: MSG: FPAR OK, ID = 0, D = 1
                                  2060 TSM: FPAR: OK
                                  2061 TSM: ID
                                  2062 TSM: ID: OK
                                  2064 TSM: UPL
                                  2069 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 24, pt = 1, l = 1, sg = 0, ft = 0, st = OK: 1
                                  2083 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 25, pt = 1, l = 1, sg = 0: 1
                                  2088 TSF: MSG: PONG RECV, HP = 1
                                  2092 TSM: UPL: OK
                                  2093 TSM: READY: ID = 4, PAR = 0, DIS = 1
                                  2113 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 4, t = 0, pt = 6, l = 10, sg = 0, ft = 0, st = OK: FFFFFFFFD0033C3E0300
                                  2131 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 15, pt = 6, l = 2, sg = 0, ft = 0, st = OK: 0100
                                  2138 TSF: MSG: READ, 0-0-4, s = 0, c = 4, t = 1, pt = 6, l = 8, sg = 0: 0A0001005000D446
                                  2144 OTA: FWP: UPDATE
                                  ! 2146 OTA: FWP: FLASH INIT FAIL
                                  2151 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 15, pt = 6, l = 2, sg = 0: 0100
                                  4074 TSF:! MSG: SEND, 4-4-0-0, s = 255, c = 0, t = 17, pt = 0, l = 5, sg = 0, ft = 0, st = NACK: 2.1. 0
                                  5727 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 6, pt = 1, l = 1, sg = 0, ft = 1, st = OK: 0
                                  5734 TSF: MSG: READ, 10-10-0, s = 3, c = 1, t = 0, pt = 7, l = 5, sg = 0: 21.2
                                  ! 5739 TSF: MSG: REL MSG, NREP
                                  5817 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 6, pt = 0, l = 1, sg = 0: M
                                  ! 7739 TSF: MSG: SEND, 4-4-0-0, s = 1, c = 0, t = 23, pt = 0, l = 0, sg = 0, ft = 0, st = NACK:
                                  8436 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 11, pt = 0, l = 9, sg = 0, ft = 1, st = OK: Yang Node
                                  8462 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 12, pt = 0, l = 4, sg = 0, ft = 0, st = OK: v1.0
                                  confuse line
                                  what could be the problem?
                                  • W Werwolfx
                                    Hello everybody.
                                    in logs
                                    in arduino serial
                                    3 TSM: INIT
                                    4 TSF: WUR: MS = 0
                                    16 TSM: FPAR
                                    2060 TSM: FPAR: OK
                                    2061 TSM: ID
                                    2062 TSM: ID: OK
                                    2064 TSM: UPL
                                    2092 TSM: UPL: OK
                                    confuse line
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Werwolfx
                                    Disable MY_OTA_FIRMWARE_FEATURE, this is only required for the external flash/dualoptiboot OTA method, MYSBootloader handles OTA updates offline.
                                    W 1 Reply Last reply
                                    • tekkaT tekka
                                      @Werwolfx
                                      W
                                      W
                                      Werwolfx
                                      @tekka oh, my mistake, thank you very much for your work.
                                      • W
                                        W
                                        Werwolfx
                                        I try to disable MY_OTA_FIRMWARE_FEATURE in arduino/
                                        but no effect =(
                                        In arduino load example code PingpongSensor and add in sketch
                                        #define MY_NODE_ID 4
                                        MYSController log
                                        14.01.2017 8:43:45	CLICK	Board with MYSBootloader=TRUE
                                        14.01.2017 8:43:46	RX	10;5;1;0;17;841
                                        14.01.2017 8:43:46	RX	10;6;1;0;39;3.66
                                        14.01.2017 8:43:52	RX	0;255;3;0;2;2.1.0
                                        14.01.2017 8:43:54	TX	4;0;3;0;13;0
                                        14.01.2017 8:43:54	INFO	FW "TimeReporter" assigned to node 4
                                        14.01.2017 8:43:57	RX	6;3;1;0;16;0
                                        14.01.2017 8:43:57	RX	6;6;1;0;3;0
                                        14.01.2017 8:43:57	RX	5;3;1;0;16;0
                                        14.01.2017 8:43:57	RX	5;6;1;0;3;0
                                        14.01.2017 8:43:57	RX	6;5;1;0;0;20.25
                                        14.01.2017 8:44:00	RX	4;255;0;0;17;2.1.0
                                        14.01.2017 8:44:00	CHILD	New child discovered, node id=4, child id=internal
                                        14.01.2017 8:44:00	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                                        14.01.2017 8:44:00	RX	4;255;3;0;6;0
                                        14.01.2017 8:44:00	TX	4;255;3;0;6;M
                                        14.01.2017 8:44:00	RX	4;1;0;0;23;
                                        14.01.2017 8:44:00	CHILD	New child discovered, node id=4, child id=1
                                        14.01.2017 8:44:00	DEBUG	Update child id=1, type=S_CUSTOM
                                        14.01.2017 8:44:00	RX	4;255;3;0;12;v1.0
                                        Arduino serial
                                        38602 TSF:MSG:READ,0-0-4,s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                                        3 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        12 TSM:INIT:STATID=4
                                        14 TSF:SID:OK,ID=4
                                        16 TSM:FPAR
                                        52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        153 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        157 TSF:MSG:FPAR OK,ID=0,D=1
                                        2060 TSM:FPAR:OK
                                        2061 TSM:ID
                                        2062 TSM:ID:OK
                                        2064 TSM:UPL
                                        2067 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        2081 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        2086 TSF:MSG:PONG RECV,HP=1
                                        2088 TSM:UPL:OK
                                        2091 TSM:READY:ID=4,PAR=0,DIS=1
                                        2122 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                        2128 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        2139 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                                        2151 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                        2170 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        2184 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                                        2192 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Yang Node
                                        2236 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v1.0
                                        Yang NodeReady.
                                        2243 MCO:REG:REQ
                                        2249 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                        2265 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        2269 MCO:PIM:NODE REG=1
                                        2272 MCO:BGN:STP
                                        2273 MCO:BGN:INIT OK,TSP=1
                                        2315 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                                        0_1484381990012_upload-678581ea-b243-4cea-8b4b-12fd2faf9c9b
                                        • W Werwolfx
                                          but no effect =(
                                          MYSController log
                                          Arduino serial
                                          3 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          11 TSM:INIT:TSP OK
                                          14 TSF:SID:OK,ID=4
                                          16 TSM:FPAR
                                          2060 TSM:FPAR:OK
                                          2061 TSM:ID
                                          2062 TSM:ID:OK
                                          2064 TSM:UPL
                                          2088 TSM:UPL:OK
                                          Yang NodeReady.
                                          2243 MCO:REG:REQ
                                          2272 MCO:BGN:STP
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Werwolfx I don't see any MYSBootloader startup message in your log. Please re-download the .hex from the github repo to ensure you are on the most recent version and flash it following these instructions: https://www.mysensors.org/about/ota
