  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • J jkandasa
    @moskovskiy82 If you use MyController, Yes, you should assign the firmware for the node and send reboot.
    moskovskiy82
    wrote on last edited by moskovskiy82
    #121
    @jkandasa Thank you!
    One more question. Now need to use a 3,3V arduino Pro (chinese version) (Nano and 5V version flashed via the uno without a hitch)
    This is what i put into boards.txt The MYSBootloader_8Mhz.hex is from the dev branch
    proMYSBL8.name=ATmega328 8Mhz MYSBootloader
    proMYSBL8.name=ATmega328 internal 8Mhz with MYSBootloader
    proMYSBL8.upload.tool=avrdude
    proMYSBL8.upload.protocol=arduino
    proMYSBL8.upload.maximum_size=30720
    proMYSBL8.upload.maximum_data_size=2048
    proMYSBL8.upload.speed=57600
    proMYSBL8.bootloader.tool=avrdude
    proMYSBL8.bootloader.low_fuses=0xE2
    proMYSBL8.bootloader.high_fuses=0xDA
    proMYSBL8.bootloader.extended_fuses=0x06
    proMYSBL8.bootloader.unlock_bits=0x3F
    proMYSBL8.bootloader.lock_bits=0xFF
    proMYSBL8.bootloader.file=MySensors/MYSBootloader_8Mhz.hex
    proMYSBL8.build.mcu=atmega328p
    proMYSBL8.build.f_cpu=8000000L
    proMYSBL8.build.board=AVR_UNO
    proMYSBL8.build.core=arduino
    proMYSBL8.build.variant=standard
    Tried to flash the mysbootloader but get the following error
    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
    avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
             Using Port                    : COM7
             Using Programmer              : stk500v1
             Overriding Baud Rate          : 19200
             AVR Part                      : ATmega328P
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : STK500
             Description     : Atmel STK500 Version 1.x firmware
             Hardware Version: 2
             Firmware Version: 1.18
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.03s
    avrdude: Device signature = 0x1e950f (probably m328p)
    avrdude: erasing chip
    avrdude: reading input file "0x3F"
    avrdude: writing lock (1 bytes):
    Writing | ################################################## | 100% 0.01s
    avrdude: 1 bytes of lock written
    avrdude: verifying lock memory against 0x3F:
    avrdude: load data lock data from input file 0x3F:
    avrdude: input file 0x3F contains 1 bytes
    avrdude: reading on-chip lock data:
    Reading | ################################################## | 100% 0.01s
    avrdude: verifying ...
    avrdude: 1 bytes of lock verified
    avrdude: reading input file "0x06"
    avrdude: writing efuse (1 bytes):
    Writing |  ***failed;
    ################################################## | 100% 0.07s
    avrdude: 1 bytes of efuse written
    avrdude: verifying efuse memory against 0x06:
    avrdude: load data efuse data from input file 0x06:
    avrdude: input file 0x06 contains 1 bytes
    avrdude: reading on-chip efuse data:
    avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
    This behaviour is deprecated and will result in an error in future version
    You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
    avrdude: 1 bytes of efuse verified
    avrdude: reading input file "0xDA"
    avrdude: writing hfuse (1 bytes):
    avrdude: 1 bytes of hfuse written
    avrdude: verifying hfuse memory against 0xDA:
    avrdude: load data hfuse data from input file 0xDA:
    avrdude: input file 0xDA contains 1 bytes
    avrdude: reading on-chip hfuse data:
    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:i -Ulock:w:0xFF:m
    avrdude: 1 bytes of hfuse verified
    avrdude: reading input file "0xE2"
    avrdude: writing lfuse (1 bytes):
    avrdude: 1 bytes of lfuse written
    avrdude: verifying lfuse memory against 0xE2:
    avrdude: load data lfuse data from input file 0xE2:
    avrdude: input file 0xE2 contains 1 bytes
    avrdude: reading on-chip lfuse data:
    avrdude: 1 bytes of lfuse verified
    avrdude done.  Thank you.
             Using Port                    : COM7
             PAGEL                         : PD7
             BS2                           : PC2
             RETRY pulse                   : SCK
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
             Hardware Version: 2
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
    Reading | ################################################## | 100% 0.02s
    avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
    avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex"
    avrdude: writing flash (32754 bytes):
    Writing | ################################################## | 100% 0.00s
    avrdude: 32754 bytes of flash written
    avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:
    avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex:
    avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader_8Mhz.hex contains 32754 bytes
    avrdude: reading on-chip flash data:
    Reading | ################################################## | 100% 0.00s
    avrdude: verification error, first mismatch at byte 0x7800
             0x00 != 0x11
    avrdude: verification error; content mismatch
    Error while burning bootloader.
    luizrrochaL 1 Reply Last reply
    • M moskovskiy82
               Using Port                    : COM7
               PAGEL                         : PD7
               BS2                           : PC2
               RETRY pulse                   : SCK
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
               Hardware Version: 2
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
               Using Port                    : COM7
               PAGEL                         : PD7
               BS2                           : PC2
               RETRY pulse                   : SCK
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
               Hardware Version: 2
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
               0x00 != 0x11
      luizrrochaL
      luizrrochaL
      luizrrocha
      @moskovskiy82 My boards.txt specify bootloader.low_fuses=0xF7 as the Arduino being programmed has a crystal on board.
      One other thing: I built my own programming board, to support programming ATMega 328p chips and Pro boards in 3.3v@8MHz and 5v@16Mhz... I used a switch and a level converter board to connect the Uno ICSP port to the pins of the Pro.
      Uno pins are 5V output, they would burn the input pins of the 3.3v Pro chip, did you account for that ?
        You can use 5v to program a 3.3v pro mini as the chip is the same, one is only clocked down to 8Mhz in order to be stable at 3.3v
          luizrrochaL
          luizrrochaL
          luizrrocha
          @gohan I beg to differ. On Page 299 of Atmel's ATMega 328p datasheet you can verify that the Absolute Maximum Ratings table states : "Voltage on any Pin except RESET with respect to Ground . . . . . . . . . .-0.5V to VCC+0.5V" which adds to 3.8V for a 3.3V Pro.
          And also: *NOTICE: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device.
          Perhaps you have mistaken the Pro for the NRF24L01+ radio which is supplied by 3.3v but has 5Volt tolerant inputs ?
          Otherwise there would be no need for those USB to FTDI boards with 3v3/5V selection jumpers ...
            wrote on last edited by gohan
            #125
            I programmed the pro mini with 5v and it worked. Maybe I was lucky. The 3v ftdi adapter is mandatory for esp8266 for example.
            • tekkaT tekka
              @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
              A Former User
              @tekka for OSX, the sequencing of flags matters. So, line 45 can be:
              $(PROJECT).o: $(PROJECT).c
              "$(BINPATH)avr-gcc" $(CFLAGS) -I$(INCLUDES) $< -o $@
              can be improved to
              "$(BINPATH)avr-gcc" -I$(INCLUDES) $(CFLAGS) $< -o $@
              and it all works.
              Also, if anyone is getting error for "avr-gcc" not found, then just add the path to avr-gcc in your path.
              tekkaT 1 Reply Last reply
              • ? A Former User
                can be improved to
                and it all works.
                tekkaT
                tekkaT
                tekka
                @Bhavin-Doshi Thanks for reporting - could you prepare a PR?
                https://github.com/mysensors/MySensorsBootloaderRF24
                ? 1 Reply Last reply
                • tekkaT tekka
                  A Former User
                  @tekka Submitted https://github.com/mysensors/MySensorsBootloaderRF24/pull/20.
                  • ? A Former User
                    tekkaT
                    tekkaT
                    tekka
                    @Bhavin-Doshi PR merged. Thank you!
                    N 1 Reply Last reply
                    • tekkaT tekka
                      N
                      N
                      nagurao.basude
                      @tekka, I am planning to move from MySensors v2.0.0 to v2.1.1, do I need to use the updated MYSBootloader? Currently I am using MYSBootloader 1.3 pre-relase (https://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta).
                      Can you please also help me understand the differences in the low_fuses and high_fuses values in the older version of bootloader and the latest version?
                      • N nagurao.basude
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        #131
                        @nagurao.basude no, you don't need to but the new version has some stability improvements. The fuse differences are to better match HW (osc type) & clearing eeprom.
                        AVR fuse calculator: http://www.engbedded.com/fusecalc/
                        • Nca78N
                          Nca78N
                          Hello, has someone used the 1MHz precompiled bootloader ? If yes what baud rate did you use to communicate via serial ?
                          I flashed it on a node but I can't upload any script ("not in sync" error). If I believe HW.h it should be 9600 bauds but I have tried hat and nearly every baudrate with no luck.
                          I had no problem using the 8MHz version.
                          The only way I could use the 1MHz bootloader at the moment is to flash the hex file containing both bootloader and script.
                          Sorry to ask this stupid question, I wanted to compile the bootloader but Internet connection is nearly down and I can't even download Atmel Studio :(
                          • tekkaT tekka
                            N
                            N
                            nagurao.basude
                            @tekka Thank you very much for the response. I will just start migrating my existing nodes to MySensors v2.1.1library.
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @tekka try as I might, I can't get the nodes to respond to the new 'signal report' option in MYS Controller, any ideas why?
                              • Mark SwiftM Mark Swift
                                tekkaT
                                tekkaT
                                tekka
                                @Mark-Swift This feature only works on MySensors >=2.2.0
                                Mark SwiftM 1 Reply Last reply
                                • tekkaT tekka
                                  Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  @tekka said in MYSBootloader 1.3.0-beta.3:
                                  @tekka I'm using the latest dev branch on all my nodes and gateway...
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Mark-Swift Hmm, that's odd - just tested it here with the latest dev and all is ok. Can you post the logs + node sketch?
                                    • J
                                      J
                                      jacikaas
                                      wrote on last edited by jacikaas
                                      #138
                                      I have notice strange behavior with MYSBootloaderV13pre.hex 8MHz internal bootloader.
                                      Problem: When I burn MYSBootloaderV13pre.hex 8MHz internal bootloader to my Standalone Atmega328p i testing it with Arduino Blink and Fade sketches. Problem is that theese sketches doesn't work on this bootloader. LED is just always ON.
                                      I also tested the same sketches, same wiring, same Arduino Uno (5V when programming), same FTDI programmer (3.3V), same PC with Win 10 with same drivers, same Atmega328p with Nick Gammon Atmega Board Programmer when I burn Lilypad bootloader and then upload Blink and Fade sketches, they perfectly working.
                                      I tried same uploading with Arduino IDE 1.6.5 and also with the newest version 1.8.5.
                                      As a programmer I using Arduino as ISP. I theese tests when burning bootloader I don't connect external oscilator.
                                      With Nick Gammon software I also checked fuses for both Lilypad and MYSBootloader settings, becose i was thought it is becose of them. Once I configure wrong fuses and it had a lot of time to reset it to default value.
                                      Question: So now before changing fuses I want to ask maybe someone have been faced with similar problem?
                                      I paste below info about Lilipad and MYSBootloader 8MHz internal oscilator boards fuse settings:
                                      Lilypad bootloader
                                      Atmega fuse calculator.
                                      Written by Nick Gammon.
                                      Version 1.11
                                      Compiled on Nov 30 2017 at 17:36:58 with Arduino IDE 10805.
                                      Attempting to enter programming mode ...
                                      Entered programming mode OK.
                                      Signature = 0x1E 0x95 0x0F
                                      Processor = ATmega328P
                                      Flash memory size = 32768
                                      LFuse = 0xE2
                                      HFuse = 0xDA
                                      EFuse = 0xFD
                                      Lock byte = 0xEF
                                      Clock calibration = 0x8E
                                      External Reset Disable.................. [ ]
                                      Debug Wire Enable....................... [ ]
                                      Enable Serial (ICSP) Programming........ [X]
                                      Watchdog Timer Always On................ [ ]
                                      Preserve EEPROM through chip erase...... [ ]
                                      Boot into bootloader.................... [X]
                                      Divide clock by 8....................... [ ]
                                      Clock output............................ [ ]
                                      Bootloader size: 2048 bytes.
                                      Start-up time: SUT0: [X]  SUT1: [ ] (see datasheet)
                                      Clock source: calibrated internal oscillator.
                                      Brownout detection at: 2.7V.
                                      MYSBootloaderV13pre bootloader
                                      Version 1.11
                                      Compiled on Nov 30 2017 at 19:48:16 with Arduino IDE 10805.
                                      LFuse = 0xE2
                                      HFuse = 0xD2
                                      EFuse = 0xFE
                                      Lock byte = 0xFF
                                      Preserve EEPROM through chip erase...... [X]
                                      Brownout detection at: 1.8V.
                                      I appreciate any helpful info!
                                      EDIT: I think I already found that there is newer MYSBootloader files of development version which working without problems. I will test it if I write good fuses :)
                                      • tekkaT tekka
                                        Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        @tekka, just tried again, perhaps I'm missing something obvious?
                                        I have the gateway and node using the latest dev branch, I click the node in MYS and then request a signal report - I see a tx in the log but nothing further? Do I need anything in the node sketch or the gateway? Does this work with the NRF's?
                                          tekkaT
                                          tekkaT
                                          tekka
                                          #140
