  3. what is related this error ?
11 Posts 2 Posters 2.6k Views 2 Watching
  • R Offline
    R Offline
    Reza
    hi
    what is related this errors?
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
    4 MCO:BGN:BFR
    PRESERVE_RELAY_STATE: NO
    Setting relay 1 on pin 3 to state: 0
    Setting relay 2 on pin 4 to state: 0
    Setting relay 3 on pin 5 to state: 0
    Setting relay 4 on pin 6 to state: 0
    Setting relay 5 on pin 7 to state: 0
    Setting relay 6 on pin 8 to state: 0
    Setting relay 7 on pin 14 to state: 0
    Setting relay 8 on pin 15 to state: 0
    Setting relay 9 on pin 16 to state: 0
    Setting relay 10 on pin 17 to state: 0
    Setting relay 11 on pin 18 to state: 0
    Setting relay 12 on pin 19 to state: 0
    41 TSM:INIT
    54 TSM:INIT:TSP OK
    55 TSM:INIT:STATID=160
    57 TSF:SID:OK,ID=160
    59 TSM:FPAR
    96 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2103 !TSM:FPAR:NO REPLY
    2105 TSM:FPAR
    2141 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4149 !TSM:FPAR:NO REPLY
    4151 TSM:FPAR
    4187 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6195 !TSM:FPAR:NO REPLY
    6197 TSM:FPAR
    6233 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    7376 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    7382 TSF:MSG:BC
    8241 !TSM:FPAR:FAIL
    8242 TSM:FAIL:CNT=1
    8244 TSM:FAIL:PDT
    18247 TSM:FAIL:RE-INIT
    18249 TSM:INIT
    18256 TSM:INIT:TSP OK
    18258 TSM:INIT:STATID=160
    18260 TSF:SID:OK,ID=160
    18263 TSM:FPAR
    18299 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20308 !TSM:FPAR:NO REPLY
    20311 TSM:FPAR
    20347 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22355 !TSM:FPAR:NO REPLY
    22358 TSM:FPAR
    22394 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24402 !TSM:FPAR:NO REPLY
    24404 TSM:FPAR
    24441 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    25563 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    25568 TSF:MSG:BC
    26449 !TSM:FPAR:FAIL
    26450 TSM:FAIL:CNT=2
    26452 TSM:FAIL:PDT
    36456 TSM:FAIL:RE-INIT
    36458 TSM:INIT
    36465 TSM:INIT:TSP OK
    36467 TSM:INIT:STATID=160
    36469 TSF:SID:OK,ID=160
    36471 TSM:FPAR
    36508 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38516 !TSM:FPAR:NO REPLY
    38518 TSM:FPAR
    38555 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    40562 !TSM:FPAR:NO REPLY
    40564 TSM:FPAR
    40601 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    42608 !TSM:FPAR:NO REPLY
    42610 TSM:FPAR
    42647 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    44654 !TSM:FPAR:FAIL
    44655 TSM:FAIL:CNT=3
    44657 TSM:FAIL:PDT
    54660 TSM:FAIL:RE-INIT
    54662 TSM:INIT
    54669 TSM:INIT:TSP OK
    54671 TSM:INIT:STATID=160
    54673 TSF:SID:OK,ID=160
    54675 TSM:FPAR
    54712 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    56720 !TSM:FPAR:NO REPLY
    56722 TSM:FPAR
    56759 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    58766 !TSM:FPAR:NO REPLY
    58768 TSM:FPAR
    58805 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    60812 !TSM:FPAR:NO REPLY
    60814 TSM:FPAR
    60851 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    61939 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    61944 TSF:MSG:BC
    62858 !TSM:FPAR:FAIL
    62859 TSM:FAIL:CNT=4
    62861 TSM:FAIL:PDT
    72864 TSM:FAIL:RE-INIT
    72866 TSM:INIT
    72873 TSM:INIT:TSP OK
    72876 TSM:INIT:STATID=160
    72878 TSF:SID:OK,ID=160
    72880 TSM:FPAR
    72916 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    74925 !TSM:FPAR:NO REPLY
    74927 TSM:FPAR
    74963 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    76971 !TSM:FPAR:NO REPLY
    76973 TSM:FPAR
    77009 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    79017 !TSM:FPAR:NO REPLY
    79020 TSM:FPAR
    79056 TSF:MSG:SEND,160-160-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    80124 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    80130 TSF:MSG:BC
    81064 !TSM:FPAR:FAIL
    81065 TSM:FAIL:CNT=5
    81068 TSM:FAIL:PDT
    • martinhjelmareM Offline
      martinhjelmare
      The node tries to find a parent within the network but gets no reply. Radio/range problems? Follow the troubleshooting flowchart here:
      https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
      R 1 Reply Last reply
        R Offline
        R Offline
        Reza
        @martinhjelmare
        i see this. but i can not found my problem ! i have this error but my device is near(1 meter) gateway and dont need search parent i change gateway. change radio , arduino , wire etc... but i have this problem yet
          martinhjelmare
          What does the corresponding log from the gateway look like? Does it receive, respond and send ok when the node sends the find parent message? Looking at both ends of the conversation usually helps determining at which end the problem might be.
          R 2 Replies Last reply
            R Offline
            R Offline
            Reza
            @martinhjelmare
            most node first can not connect to gateway.similar to error in up.but some node connect hardly but after connect, in serial monitor , most of command is NACK.
            i have not this problem with sensors. this problem is just related to relays. power of node is ok (also i test this with a 5v 10A power supply. but power of gateway is from orangepi board.
            this is complicate for me. sensors is ok and report all states but relays... perhaps is related my sketchs. i dont know :(
              R Offline
              R Offline
              Reza
              @martinhjelmare
              i think this is related to power of gateway! because sensors just report to gateway and gateway dont send any command, so work well. but for relay, gateway want send command and ack... so have problem , i dont know i am confuse:(
                martinhjelmare
                You could be on to something. Although the gateway will still have to send some things to sensors, like parent reply etc. If you want more input I suggest you record logs of both gateway and a node in parallel, and post it here.
                Previously there's been reports of the gateway performing better with two capacitors in parallel with the radio instead of the regular one capacitor, or a higher value on the capacitor compared to nodes.
                  R Offline
                  R Offline
                  Reza
                  @martinhjelmare
                  thank you, i want put a capacitor for serial gateway. where i put capacitor ? serial gateway is connect to controller with a usb cable , now where i put capacitor?
                    martinhjelmare
                    I was referring to the recommended decoupling capacitor for the radio. This is described here:
                    https://www.mysensors.org/build/connect_radio#connecting-a-decoupling-capacitor
                    Next step would be to try to change the power source for the arduino and/or radio entirely.
                    This page has several important points at the top about power:
                    https://www.mysensors.org/build/debug
                    These are some questions that might be important:
                    You said you're powering the gateway from an OrangePi. How are you powering the OrangePi? Do you know the power specs of the USB ports on your OrangePi? How have you built your gateway, and what power does it require? Particularly, what radio module is the gateway using, amplified or non-amplified?
                      R Offline
                      R Offline
                      Reza
                      wrote on last edited by Reza
                      @martinhjelmare
                      i test all of state for gateway and nodes. states:
                      serial gateway and relay nodes + usual radio
                      serial gateway and relay nodes + usual radio + 4.7u and 100u capacitor
                      serial gateway and relay nodes + nRF24L01+PA+LNA with antenna
                      serial gateway and relay nodes + nRF24L01+PA+LNA with antenna + 4.7u and 100 capacitor
                      serial gateway and relay nodes + usual radio + adapter radio
                      serial gateway and relay nodes + nRF24L01+PA+LNA with antenna + adapter radio
                      i am tired really:( now i think power of gateway is weak.(power of nodes is ok and i test it) but power of serial gate way is with usb from orangepi. this is orangepi one and have one port usb and i use this for serial gateway. i dont know how i see power of usb port! but i think most of error is NACK so gateway can not work well. so i want from you to help for capacitor for input arduino , no input radio. i test all of state input for radio....
                      power of orange pi is 5v 2A.
                      thank you
                      • R Reza
                        @martinhjelmare
                        thank you
                        martinhjelmare
                        @Reza
                        You seem to be getting help with the same problem in the other thread, so I'll stop here.
                        12.1k
