  3. NRF24L01+PA+LNA distance problem
25 Posts 6 Posters 12.7k Views 6 Watching
  • yd kimY
    yd kimY
    yd kim
    wrote on last edited by yd kim
    Hi All,
    My project has 1 gateway + 5 node with temperature sensor and it is installed in orchard.
    All node is within 20meter from gateway but seems there are a lot of packet loss.
    I bought module from aliexpress which is mysensors link (https://www.aliexpress.com/item/1sets-Special-promotions-1100-meter-long-distance-NRF24L01-PA-LNA-wireless-modules-with-antenna/32341792715.html)
    Communication was fine in the office but when I install in the orchard it loose some data.
    I did try a lot of things on the web.
    Here is the list I have been try to solve the problem but no luck yet.
    1. 800mA 3.3V LDO saperate Power to the module
    2. 2x 10uF LDO in/out
    3. 100UF Al Cap, 2x 10UF ceramic Capacitor on base board
    4. 100uF , 2x 10uf On the module
    5. warp the module with tinfoil
    6. bigger antenna ( a little bit improved)
    7. 3M corded antenaa ( no difference)
    8. change mysensors config to MY_RF24_PA_LEVEL RF24_PA_MAX ( no difference)
    Is there any other option?
    It's really strange, the module specification is 1km but even not working properly within 20meter..
    I don't think there is interference because it is installed rural area..
    Sorry for bad English;;
    • F
      F
      fleinze
      I had some issues with pa+lna modules. The solution was a better ground connection.
      yd kimY 1 Reply Last reply
      • F
        F
        flopp
        wrote on last edited by flopp
        When it was in your office, was it 20 meters distance?
        Try another nRF+PA+LNA
        What kind of nRF does the nodes have?
        • F fleinze
          yd kimY
          yd kimY
          yd kim
          @fleinze
          Thank you for your reply. Can you share how to make better ground connection?
          I made tinfoil wrap on the module and connect gold antenna connector.
          F 1 Reply Last reply
          • yd kimY yd kim
            @fleinze
            F
            F
            fleinze
            @yd-kim In my case I added an extra wire-connection fromm the 5V-side of the LDO-module to the 3.3V-side.
            • F flopp
              yd kimY
              yd kimY
              yd kim
              @flopp
              Well I guess it was 10-15meter in the office.
              Also when I check the orchard on google, it probably 25-35meter. Sorry for making confusion.
              I used first 5 node + 1 gateway and it was same distance issue so I made another 5 node and 1 gateway with more capacitor but same distance problem.
              The title on aliexpress is "1100-meter long-distance NRF24L01+PA+LNA wireless modules"
              Sorry I put correct link. The link is the product what I bought from aliexpres.
              • yd kimY yd kim
                @flopp
                F
                F
                flopp
                @yd-kim
                Do you have nRF+LNA+PA on gateway?
                Do you have nRF+LNA+PA on nodes?
                • F fleinze
                  yd kimY
                  yd kimY
                  yd kim
                  @fleinze
                  Thank you for your quick response. Well I use custom PCB which has plenty of GND area on the board.
                  Anyway will keep think how to make better ground for the module.
                  • F flopp
                    @yd-kim
                    yd kimY
                    yd kimY
                    yd kim
                    @flopp
                    I use nRF+LNA+PA on both.
                    • yd kimY yd kim
                      @flopp
                      F
                      F
                      flopp
                      @yd-kim
                      Check that you have correct antenna.
                      I was using female antenna and the nRF was also female which resulted in very bad connection.
                      Nodes are not battery powered?
                      yd kimY 2 Replies Last reply
                      • MiKaM
                        MiKaM
                        MiKa
                        Also check with RF scanner if its not a "jamming" from other RF device, or simply try to change channel to different one.
                        • F flopp
                          @yd-kim
                          yd kimY
                          yd kimY
                          yd kim
                          @flopp
                          At the first time I use default antenna but it was same issue so I bought exactly same long antenna. It make a little bit better but not perfect..
                          I knew what you are talking about. It wasn't normal so a little bit expensive compare to normal wifi antenna.
                          Thank for your concern.
                          • F flopp
                            @yd-kim
                            yd kimY
                            yd kimY
                            yd kim
                            @flopp
                            Whole system is Li-Ion battery powered system with solar.
                            Gateway has 3S2P Li-Ion battery with proper solar panel. Battery voltage never go under 11V.
                            Node has 1x18650 Li-Ion battery with small solar panel.
                            Node goes sleep mode for 10 minutes then wake up and send data within 10 second.
                            • MiKaM MiKa
                              yd kimY
                              yd kimY
                              yd kim
                              @MiKa
                              Device is installed in rural area. There is only one wifi. I don't think there is jamming or interference..
                              I don't have RF scanner. If I couldn't find any other solution , probably I need to build RF scanner to check it..
                              • yd kimY yd kim
                                @MiKa
                                @yd-kim https://www.mysensors.org/controller/sniffer might be an easy way if you want to scan.
                                • F
                                  F
                                  fleinze
                                  Sometimes we get shitty modules from china:
                                  https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
                                  I made good experiance with these rather expensive ones:
                                  https://de.aliexpress.com/item/2pcs-RF2401F20-2-4G-high-integrated-RF-module-with-Nordic-s-RF-chip-nRF24L01-For-Free/32302870943.html
                                  But even with these I had to be very careful about antenna placement
                                  • MiKaM
                                    MiKaM
                                    MiKa
                                    Another RF scanner with mini OLED 0.96 display
                                    https://www.rcgroups.com/forums/showthread.php?2777178-Very-cheap-Arduino-based-2-4-GHz-band-monitor
                                    • yd kimY yd kim
                                      @flopp
                                      F
                                      F
                                      flopp
                                      @yd-kim said:
                                      @flopp
                                      What kind of Arduino do you use?
                                      • F flopp
                                        @yd-kim said:
                                        @flopp
                                        yd kimY
                                        yd kimY
                                        yd kim
                                        @flopp
                                        Gateway : ESP8266 ( use 3A switching step down power module)
                                        Node : Arduino pro mini 3V ( Arduino use battery power directly and nRF24L01 use 3.3V LDO 800mA one with 0.3V drop down )
                                        • G
                                          G
                                          gloob
                                          Why don't you connect the NRF also directly to the battery?
