  3. Double click | Hold for buttons
7 Posts 6 Posters 4.2k Views 6 Watching
    moskovskiy82
    Couldn't find any examples on utilising hold or double clicks for the buttons on my sensor nodes. With all the wifi lamps around it would be great to control them via the mysensor nodes and controller
      No, I can't recall any examples for for double click or hold either.
      • E
        E
        ericvdb
        Maybe this will help: http://jmsarduino.blogspot.be/2009/10/4-way-button-click-double-click-hold.html
        • TD22057T
          TD22057T
          TD22057
          I have short and long press status reports on my switch class here. There are example sketches one directory up in the tests area. Double click gets more complicated because you have to decide are you going to delay reporting the press/release from the first click until enough time has passed for it not to be a double click? Or do you report the press/release from the first click, and then report a double click? I'd be surprised if there aren't a lot of arduino double-click switch examples around...
          • vorowskiV
            vorowskiV
            vorowski
            https://github.com/mathertel/OneButton
            This is what I use for this.
            M 1 Reply Last reply
            • vorowskiV vorowski
              moskovskiy82
              Mind sharing some mysensors code to see how you got it implemented?
              • D
                D
                dakipro
                Hi, it is some time since I made this (and used it to be honest) but you can check this post where I integrated what you are asking about.
                https://forum.mysensors.org/topic/4552/sleeping-while-waiting-for-double-click-delayed-sleep/3
                Node and the code is unfortunately not in use currently so I do not recall all the details, but maybe you can get something out of it :)
