  3. RFM95 Soil Moisture Sensor
1 Posts 1 Posters 1.2k Views 1 Watching
  • L
    L
    lafleur
    wrote on last edited by lafleur
    This is a work in progress! , but most everything works.
    It measures soil moisture from 1 to 4 sensors, has options for soil and air temperature.
    Support MCP9800 or Si7021 (humidity also) or Temp sensor in DS3231 for air temp
    DS18B20 for soil temp
    Support of a water pressure sensor via an analog port
    Has a DS3231 Real Time clock to wake up processor at designated hour
    Has support on the board for a flow meter (but no software in this code base)
    Uses a RocketScream Mini-Pro M0 CPU with an RFM95 radio
    Solar, battery Powered or via 8 to 28v AC or DC
    Sleep's most of the time and just wakes up to see if its time to send a report.
    (Board is designed to fit in a Hammond 1554 case)
    https://github.com/trlafleur/Soil_Moisture_Sensor_MS_R1.1-RFM95
    Sensor are made from plaster of paris (gypsum)
    http://vanderleevineyard.com/1/post/2012/07/the-vinduino-project-2-making-and-installing-gypsum-soil-moisture-sensors.html
    http://www.irrometer.com/sensors.html#wm
    https://www.amazon.com/Delmhorst-GB-1-Gypsum-Sensor-Moisture/dp/B0002IKRUS
    Based on the work of: Reinier van der Lee, www.vanderleevineyard.com
