  3. Home Assistant
  4. Error decoding message from gateway, probably received bad byte.
2 Posts 2 Posters 1.4k Views 2 Watching
  • MaKinM
    MaKinM
    MaKin
    Hello everyone,
    I wanted to implement MySensors with HASS as a students project. I already have it running at home and it works flawlessly. But now I cannot overcome the following error:
    mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
    I've never had such an error before. I tried using the combination of Arduino-Gateway and Arduino-DHT22 AND I also tried to have both on the same Arduino (both ways worked with my sketches at home).
    I also tried to install pyserial 2.5 as it was stated in another thread. :/
    Do you guys have any idea what else I could try?
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @MaKin
      Hi!
      What arduino are you using as gateway? How have you configured the mysensors component in home assistant?
      So at home a similar setup is working together with home assistant, but at school it doesn't? What's the difference between the two environments, hardware and software -wise?
