  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
  • Nca78N
    Nca78N
    I have few sonoff and I just installed one with this script to replace a dead 433 device. So thank you very much for the script and the tutorial.
    Reports of regular wifi connection losses are what kept me away from sonoff until now. Maybe the script could check wifi connection regularly and force a reconnect. Something like in the link below ?
    http://www.esp8266.com/viewtopic.php?f=32&t=8286
    • BrydenB
      BrydenB
      Bryden
      Another I have had these running posts.
      I have had 3 Sonoff relays running on 240v 50Hz for 2-3 months straight.
      2 of them in IP67 outdoor lights with Phillips LED Lamps, switch on and off several times per day, Not a single hardware issue.
      best $6 ever
      Nca78N 1 Reply Last reply
      • E
        E
        Ed1500
        @betonishard ESPeasy I am not sure, but supposedly Tasmota does
        B 1 Reply Last reply
        • BrydenB Bryden
          best $6 ever
          Nca78N
          Nca78N
          @Bryden said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
          best $6 ever
          Yes over one month and very reliable, but with Domoticz is not integrating very well with my old 433MHz remote controls (that I use for my remaining 433MHz module until they are replaced).
          Making me think about a small plugin board to control the sonoff through serial port, so it would make a real MySensors node for 10$ and avoid all the power supply, relay etc etc soldering and not rely on wifi.
            I remember reading non to connect any other serial device while the Sonoff is connected to mains or it would get damaged.
            E Nca78N 2 Replies Last reply
              E
              E
              Ed1500
              @gohan The only time you would need to connect a serial device is I guess when you are flashing the software. There is no needTheThe only time you need to connect a serial device is when you are flashing the software. There is no need to connect it to the mains grid then. Whether it would damage anything i do not know but it is unnecessary and therefore absolutely not recommended to do it. Avoid working on anything that is connected to mains, especially if there is no need to have it connected
                I was referring to what @Nca78 said about controlling the sonoff through serial port.
                E 1 Reply Last reply
                • warmaniacW warmaniac
                  @Efflon said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                  @warmaniac the sonoff works just like any sensor except its configured as a gateway since that is what is needed for esp8266+mysensors . Mqtt or ethernet/wifi is just a matter of taste and your setup, skip mqtt if you don't have anything else using it.
                  I want to use standalone Sonoff (one device) than I must install broker (Mosquito) on my raspberry where is Domoticz running ? And how can I add than that device or how can this setup looks like.
                  E
                  E
                  Ed1500
                  @warmaniac you might have solved yr problem already. Anyway, I use the github/computourist software for the SonOff. have been using it for many months. very stable
                    E
                    E
                    Ed1500
                    @gohan ah ok. Sometimes I lose track of who is reacting to who. Must be old age :-)
                      Nca78N
                      Nca78N
                      @gohan said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                      I supposed that's when you connect your computer to sonoff using serial adapter ?
                      I see no reason for damage if both es8266 and atmega are connected to the same VCC/GND.
                        I think it's because the gnd on the sonoff is shared with neutral from the mains. I have seen pictures of burned stuff but I actually never wanted to try to see if the computer gets fried or not 😁
                          Nca78N
                          Nca78N
                          @gohan yes with it could happen, but if you just connect a standalone Arduino powered with VCC GND from esp8266 there's no reason to have a problem.
                            But why would you want to connect another arduino to the sonoff?
                            • E Ed1500
                              B
                              B
                              betonishard
                              @Ed1500 Thanks for your answer. Went for espurna.. Tested tasmota, but compared to espurna it was kind of slow. Works stable for quite some time now.
                              • B betonishard
                                E
                                E
                                Ed1500
                                @betonishard Good to know. I was thinking about trying Tasmota for regular Sonoff, but I will keep slowness in mind
                                  Nca78N
                                  Nca78N
                                  To have a real MySensors node that can be directly controlled with another node and not relying on wifi and controller.
                                    Sorry but I am still missing the point. If you have to make a mysensors node anyway, why not make a classic relay node?
                                      Nca78N
                                      Nca78N
                                      wrote on last edited by Nca78
                                      #58
                                      @gohan because when using the sonoff I do not have to care about the power supply/safety, to find a case that is safe for electrical device and I only have a few things to solder.
                                      And sonoff is cheaper than buying separately the power supply, case, relay etc
                                      So just solder a few low voltage components on a PCB, plug in the sonoff and get a safe main powered actuator.
                                      Not 100% sure it's worth it yet, still thinking a out it ;)
                                      But main advantage is to reuse it in more complex sonoff devices with multiple relays, power measurement, in wall plugs etc etc
                                        Once you come up with something I'll take a look to better understand what you want to do 😀
                                        I have seen how to hack some of them to add a couple of wires directly on the esp8266 chip to get an i2c bus.
                                        • Jonathan CaesJ
                                          Jonathan CaesJ
                                          Jonathan Caes
                                          How can I create a new device in Vera for a gateway? Can't seem to get that working :/
