  3. πŸ’¬ Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
  • danbiD danbi
    Maybe a good solution to the node/gateway dilemma is adding WiFi transport for nodes to MySensors? Then defining one or more WiFi gateways to connect sensors to. You could then use WiFi enabled devices, such as ESP8266 as sensor nodes. You could use these as radio interfaces to Arduino nodes, with their original serial-to-WiFi firmware and treat it much like the RS485 transport.
    @danbi
    Configuring it as a gateway allows you to directly add it to the controller even it is isn't routing anything else than it's local I/O, making it very straightforward
    • J Jan Gatzke
      @Efflon
      Ok, I just wiped out (hopefully) all my passwords and IP information. :D
         REVISION HISTORY
         Version 1.0 - Henrik EKblad
         Contribution by a-lurker and Anticimex,
         Contribution by Norbert Truchsess <norbert.truchsess@t-online.de>
         Contribution by Ivo Pullens (ESP8266 support)
         DESCRIPTION
         The EthernetGateway sends data received from sensors to the WiFi link.
         The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
         VERA CONFIGURATION:
         Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
         E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
         LED purposes:
         - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
         - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
         - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
         - ERR (red) - fast blink on error during transmission error or recieve crc error
         See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         nRF24L01+  ESP8266
         VCC        VCC
         CE         GPIO4
         CSN/CS     GPIO15
         SCK        GPIO14
         MISO       GPIO12
         MOSI       GPIO13
         GND        GND
         Not all ESP8266 modules have all pins available on their external interface.
         This code has been tested on an ESP-12 module.
         The ESP8266 requires a certain pin configuration to download code, and another one to run code:
         - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
         - Connect GPIO15 via 10K pulldown resistor to GND
         - Connect CH_PD via 10K resistor to VCC
         - Connect GPIO2 via 10K resistor to VCC
         - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
          Inclusion mode button:
         - Connect GPIO5 via switch to GND ('inclusion switch')
         Hardware SHA204 signing is currently not supported!
         Make sure to fill in your ssid and WiFi password below for ssid & pass.
      #define MY_BAUD_RATE 9600
      //#define MY_RADIO_NRF24
      #define MY_GATEWAY_ESP8266
      #define MY_ESP8266_SSID "MySSID"
      #define MY_ESP8266_PASSWORD "MyPSK"
      // Enable UDP communication
      //#define MY_USE_UDP
      // #define MY_ESP8266_HOSTNAME "sensor-gateway"
      #define MY_IP_ADDRESS 192,168,1,200
      #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
      #define MY_PORT 5003
      // Enable inclusion mode
      // #define MY_INCLUSION_BUTTON_FEATURE
      // Flash leds on rx/tx/err
      // #define MY_LEDS_BLINKING_FEATURE
      // Set blinking period
      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
      #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
      #include <ESP8266WiFi.h>
      #include <WiFiClient.h>
      #include <ESP8266WebServer.h>
      #include <ESP8266mDNS.h>
      #include <ESP8266HTTPUpdateServer.h>
      #define RELAY_1_Pin  12
      #define LED_1_Pin 13
      #define TOUCH_1_Pin 0
      #define RELAY_1  1
      #define TOUCH_1 3
      #define TOUCH_2 4
      boolean relayon = false;
      int activescene = 1;
      volatile unsigned long LastChange = 0;
      volatile boolean RelayToggleRequired = false;
      volatile boolean SceneSwitchRequired = false;
      volatile boolean SceneSwitchTriggeredByTimeout = false;
      volatile boolean SceneSwitchTriggeredByTimeout2 = false;
      MyMessage msg(RELAY_1, V_LIGHT);
      MyMessage msg1(TOUCH_1, V_SCENE_ON);
      MyMessage msg2(TOUCH_2, V_LIGHT);
      ESP8266WebServer httpServer(80);
      ESP8266HTTPUpdateServer httpUpdater;
      const char* host = "sonofftouch1";
      const char* location = "Couch";
      char* update_username = "admin";        //Benutzername zum login fΓΌr die OTA-Programmierung
      char* update_password = "MyPassword";      //Passwort
      String webPage = "";
      unsigned long lastheartbeat = 0;
      void buttonChangeCallback() {
        if (digitalRead(TOUCH_1_Pin) == 1) {
          //LED off for feedback
          digitalWrite(LED_1_Pin, 1);
          //Button has been released, trigger one of the two possible options.
          if (millis() - LastChange > 500) {
            //Long Press
            if (!SceneSwitchTriggeredByTimeout) {
              SceneSwitchRequired = true;
          else if (millis() - LastChange > 50) {
            //Short press at least 50 ms for debounce
            RelayToggleRequired = true;
          else {
            //Too short to register as a press
        else {
          //LED on for feedback
          digitalWrite(LED_1_Pin, 0);
          //Just been pressed - do nothing until released.
        LastChange = millis();
        webPage += "<h1>ESP8266 Web Server</h1>";
        webPage += "<br><h1>";
        webPage += host;
        webPage += "</h1>";
        webPage += location;
        webPage += "</h1>";
        webPage += "<br><a href=/update>Click here to update</a>";
        pinMode(TOUCH_1_Pin, INPUT_PULLUP);      // sets the digital pin as output
        pinMode(RELAY_1_Pin, OUTPUT);
        pinMode(LED_1_Pin, OUTPUT);
        //LED off
        MDNS.begin(host);
        httpUpdater.setup(&httpServer, "/update", update_username, update_password);
        httpServer.begin();
        MDNS.addService("http", "tcp", 80);
        httpServer.on("/", []() {
          httpServer.send(200, "text/html", webPage);
        Serial.println("Enabling touch switch interrupt");
        attachInterrupt(digitalPinToInterrupt(TOUCH_1_Pin), buttonChangeCallback, CHANGE);
        sendSketchInfo("Sonoff Touch Mysensors", "1.0");
        present(RELAY_1, S_LIGHT, "single click/onboard relay");
        present(TOUCH_1, S_SCENE_CONTROLLER, "double click/scene controller");
        present(TOUCH_2, S_LIGHT, "long press virtuel switch");
        httpServer.handleClient();
        if (millis() - lastheartbeat > 30000) {
          //sendHeartbeat();
          sendBatteryLevel(90);
          lastheartbeat = millis();
        if (RelayToggleRequired) {
          ToggleRelay();
        if (SceneSwitchRequired) {
          SwitchScene();
        if (millis() - LastChange > 600) {
          if (digitalRead(TOUCH_1_Pin) == 0) {
            if (SceneSwitchTriggeredByTimeout == false) {
              SceneSwitchTriggeredByTimeout = true;
              SwitchScene();
        if (millis() - LastChange > 3000) {
            if (SceneSwitchTriggeredByTimeout2 == false) {
              SceneSwitchTriggeredByTimeout2 = true;
              SwitchSceneOff();
          // Change relay state
          if (message.sensor == RELAY_1) {
            digitalWrite(RELAY_1_Pin, message.getBool() ? 1 : 0);
            relayon = message.getBool() ? 1 : 0;
      void ToggleRelay() {
        Serial.println("Single Click");
        if (relayon) {
          digitalWrite(RELAY_1_Pin, 0);
          relayon = false;
        else {
          digitalWrite(RELAY_1_Pin, 1);
          relayon = true;
        send(msg.set(relayon ? 1 : 0));
      void SwitchScene() {
        //Domoticz does not like 1 as scene. So we start with scene 2.
        Serial.println("Long press");
        activescene += 1;
        if (activescene > 6) {
          activescene = 2;
        Serial.print("Activating Scene ");
        Serial.println(activescene);
        send(msg1.set(activescene));
      void SwitchSceneOff() {
        Serial.println("3sec Long Press");
        send(msg1.set(7));
      EfflonE
      EfflonE
      Efflon
      @Jan-Gatzke Thanks! A Interesting and inspiring code example. Did you think about using the arduinoOTA option instead of the httpUpdater?
      J 1 Reply Last reply
      • EfflonE Efflon
        J
        J
        Jan Gatzke
        @Efflon
        Yes, I thought about that. But during my tests the web updater was just most reliable and easiest to use. Arduino ota needs extensions to the IDE and sometimes the node was not found. Web updater works out of the box and never made any problems.
        EfflonE 1 Reply Last reply
        • J Jan Gatzke
          @Efflon
          EfflonE
          EfflonE
          Efflon
          @Jan-Gatzke Great to know!
          • BrydenB
            BrydenB
            Bryden
            This sketch is awesome, First MySensors sketch I have used that worked straight off the bat.
            The details page does need a few extra bits of info....
            3.3v FTDI tool needed
            Hold down the button on the Sonoff when you power it up to enter flash mode.
            • BrydenB Bryden
              EfflonE
              EfflonE
              Efflon
              @Bryden It's hidden in the code of the sketch "* Hold Sonoff button when attaching FTDI to flash."
              • warmaniacW
                warmaniacW
                warmaniac
                @Efflon
                Can I ask please ? I don't know if I understand correctly principle of working Sonoff under mysensors , I uploaded sketch from here to Sonoff , Sonoff is connected to my WiFi network , now I need to make MQTT gateway connected trought LAN or WiFi to the raspberry where is running Domoticz ? I had nodeMCU will it work ? Thanks much
                  You would need to use the esp8266 gateway sketch and connect it to domoticz as a new mysensors gateway. IMHO in this case it is easier to flash ESPEasy or espurna and use it as mqtt stand alone, not mysensors since you don't have a real benefit to have it running mysensors
                    @gohan,
                    it depends on if the controller supports ESPEasy/espurna "out of the box". Not all controllers even have MQTT support.
                    • warmaniacW warmaniac
                      @Efflon
                      EfflonE
                      EfflonE
                      Efflon
                      @warmaniac the sonoff works just like any sensor except its configured as a gateway since that is what is needed for esp8266+mysensors . Mqtt or ethernet/wifi is just a matter of taste and your setup, skip mqtt if you don't have anything else using it.
                      warmaniacW 1 Reply Last reply
                      • EfflonE Efflon
                        warmaniacW
                        warmaniacW
                        warmaniac
                        @Efflon said in πŸ’¬ Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                        I want to use standalone Sonoff (one device) than I must install broker (Mosquito) on my raspberry where is Domoticz running ? And how can I add than that device or how can this setup looks like.
                        EfflonE E 2 Replies Last reply
                          EfflonE
                          EfflonE
                          Efflon
                          @warmaniac You dont need mqtt/mosquitto. Just follow the guide at https://www.domoticz.com/wiki/MySensors for adding a "MySensors Gateway with LAN interface (Ethernet)" then follow the ethernet sketch here https://www.openhardware.io/view/318/Sonoff-relay-using-MySensors-ESP8266-wifi-or-mqtt-gateway
                          • EfflonE Efflon
                            warmaniacW
                            warmaniacW
                            warmaniac
                            wrote on last edited by warmaniac
                            #28
                            @Efflon
                            Tried LAN sketch after adding new hardware in domoticz this error occurs
                            2017-04-06 06:28:07.230 MQTT: Connecting to 192.168.2.209:5003
                            2017-04-06 06:28:07.335 Error: MQTT: disconnected, restarting (rc=2)
                            after that Sonoff blik twice. What may be wrong ?
                            Edit:
                            Understand now , it is added as classic mysensor LAN gateway , now working fine ! I tried to do it complicated way , but it was easy :D
                            2017-04-06 06:30:29.756 MySensors: trying to connect to: 192.168.2.209:5003
                            2017-04-06 06:30:30.757 MySensors: connected to: 192.168.2.209:5003
                            2017-04-06 06:30:30.758 MySensors: Gateway Ready...
                            2017-04-06 06:30:30.762 MySensors: Node: 0, Sketch Name: Sonoff ethernet
                            2017-04-06 06:30:30.763 MySensors: Node: 0, Sketch Version: 1.0
                            2017-04-06 06:30:30.769 (MQTT) Light/Switch (Light)
                            2017-04-06 06:30:31.778 MySensors: Gateway Version: 2.1.1
                            2017-04-06 06:30:31.779 MySensors: Gateway Version: 2.1.1
                            2017-04-06 06:31:11.939 User: Admin initiated a switch command (87/Sonoff-1/On)
                            2017-04-06 06:31:11.942 (MQTT) Light/Switch (Sonoff-1)
                            2017-04-06 06:31:12.789 (MQTT) Light/Switch (Sonoff-1)
                              @Efflon
                              Edit:
                              EfflonE
                              EfflonE
                              Efflon
                              @warmaniac Excellent!
                              • BrydenB
                                BrydenB
                                Bryden
                                Does anyone know how I can request the current state of the relay via MQTT.
                                Eg HASS has rebooted, forgotten what state the switch was previously in, then it wont work untill power is cycled to the sonoff.
                                I want to send an MQTT message to the sonoff to get its current state. Tried looking over the forums and page and cant seem to see anything about requesting a state from a binary switch / relay actuator
                                • BrydenB Bryden
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @Bryden
                                  If you're using the mysensors component in home assistant, you can activate persistence to load devices and last known state when home assistant restarts.
                                  Another option is to use the retain flag when publishing mqtt messages from the gateway. Support for this has been added in mysensors dev branch:
                                  https://github.com/mysensors/MySensors/pull/793
                                    Matthew Ohlson de Fine
                                    How do you load the relay sensor in Vera after connecting the Sonoff as a wifi gateway as described?
                                    • warmaniacW
                                      warmaniacW
                                      warmaniac
                                      After electricity plugged off , it stops working / not connecting to wifi router, but on manual click it turns on and of , it is problem because I don't use haas config ? I dont know where can I place them, can you help me ? :) thanks
                                      • U
                                        U
                                        user2684
                                        Hi, I see in the instruction a note about not being tested against 220v so just to confirm it is working fine, I've uploaded the sketch to one of those with the power socket plug embedded and I'm able to control it remotely. Great job!
                                        As a side note, I'd copy and paste the "Sonoff specific details" instructions from the sketch also into the build page. My bad because I've missed them and had to google a bit on how to upload the sketch but maybe also others may experience the same.
                                        • U user2684
                                          EfflonE
                                          EfflonE
                                          Efflon
                                          @user2684 Thanks for reporting. I have updated the instructions with the Sonoff details.
                                          With your input, this post could be even better πŸ’—
