  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
  • Jonathan CaesJ
    Jonathan CaesJ
    Jonathan Caes
    @efflon Do you know how I can setup the sonoff gateway on the Vera Edge? I used the MySensors plugin to add the sonoff to the network but can't get the relay to toggle.. :/ Help is much appreciated!! Thanks!!
    dbemowskD 1 Reply Last reply
    • T
      tkald
      wrote on last edited by tkald
      #62
      If someone wants, I create a modification to cooperate with DHT22. Data pin of DHT22 is connected to pin 5 of sonoff.
       * Version 1.0 - Henrik EKblad
       * Contribution by Ivo Pullens (ESP8266 support)
       * The EthernetGateway sends data received from sensors to the WiFi link.
       * VERA CONFIGURATION:
       * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
       * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
       * LED purposes:
       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
        * Inclusion mode button:
       * Sonoff specific details (IM15116002)
       * The sonoff header left to right, relay above, LED below.
       *  [1]  vcc 3v3
       *   2   rx
       *   3   tx
       *   4   gnd
       *   5
       * In arduinoIDE 1.6.* choose Generic ESP8226 module.
       * Hold Sonoff button when attaching FTDI to flash.
      #define MY_BAUD_RATE 9600
      // No radio in Sonoff
      // #define MY_RADIO_NRF24
      // #define MY_RADIO_RFM69
      #define MY_GATEWAY_ESP8266
      #define MY_ESP8266_SSID "wifissid"
      #define MY_ESP8266_PASSWORD "wifipassword"
      // Enable UDP communication
      //#define MY_USE_UDP
      // #define MY_ESP8266_HOSTNAME "sensor-gateway"
      #define MY_IP_ADDRESS 192,168,2,200
      #define MY_IP_GATEWAY_ADDRESS 192,168,2,1
      #define MY_PORT 5003
      #define MY_GATEWAY_MAX_CLIENTS 1
      // #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
      // Enable inclusion mode
      // #define MY_INCLUSION_BUTTON_FEATURE
      // Set blinking period
      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
      // Flash leds on rx/tx/err
      // Led pins used if blinking feature is enabled above
      #if defined(MY_USE_UDP)
      #include <WiFiUdp.h>
      #include <ESP8266WiFi.h>
      #include <Bounce2.h>
      #include <DHT.h>
      #define BUTTON_PIN 0  // Sonoff pin number for button
      #define RELAY_PIN 12  // Sonoff pin number for relay
      #define LED_PIN 13    // Sonoff pin number for LED
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define LED_ON 0
      #define LED_OFF 1
      #define DHT_DATA_PIN 14
      #define SENSOR_TEMP_OFFSET 0
      static const uint64_t UPDATE_INTERVAL = 5000;
      unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
      unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
      // Id of the sensor child
      // Set unique id for each sonoff if sub/pub on same mqtt topic
      #define CHILD_ID 0
      #define CHILD_ID_HUM 1
      #define CHILD_ID_TEMP 2
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      bool metric = true;
      MyMessage msg(CHILD_ID,V_STATUS);
      DHT dht;
      Bounce debouncer = Bounce();
      int oldValue = 0;
      bool state = false;
        // Setup the button
        pinMode(BUTTON_PIN, INPUT_PULLUP);
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        // Make sure relays and LED are off when starting up
        digitalWrite(LED_PIN, LED_OFF);
        pinMode(RELAY_PIN, OUTPUT);
        pinMode(LED_PIN, OUTPUT);
      void presentation()  {
        // Send the sketch version information
        sendSketchInfo("Sonoff ethernet DHT22", "1.0");
        // Register sensor
        present(CHILD_ID, S_BINARY);
        present(CHILD_ID_HUM, S_HUM);
        // Send the current state
        send(msg.set(state?true:false));
        // Blink when ready
        blink();
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue && value==0) {
          // Toggle the state
          state = state?false:true;
          // Change relay state
          // Change LED state
          digitalWrite(LED_PIN, state?LED_ON:LED_OFF);
          // Send new state
          send(msg.set(state));
        oldValue = value;
        boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
        if (needRefresh)
            lastRefreshTime = millis();
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
        } else {
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
        } else {
          nNoUpdatesHum++;
        //sleep(UPDATE_INTERVAL);
        // We only react on status messages from the controller
        // to this CHILD_ID.
        if (message.type==V_STATUS  && message.sensor==CHILD_ID) {
          // Only switch if the state is new
          if (message.getBool() != state) {
            state = message.getBool();
            // Change LED state
      void blink()
        digitalWrite(LED_PIN, digitalRead(LED_PIN)?LED_ON:LED_OFF);
        wait(200);
        wait(200);
        wait(200);
      • Morten MathiasenM
        Morten MathiasenM
        Morten Mathiasen
        I think it is an easier and more general solution to use https://github.com/arendst/Sonoff-Tasmota
        gohanG 1 Reply Last reply
        • Morten MathiasenM Morten Mathiasen
          @Morten-Mathiasen that is the one I'm using on my sonoff pow
          • Jonathan CaesJ Jonathan Caes
            dbemowskD
            dbemowskD
            @Jonathan-Caes said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
            I am using a Vera Plus. I did not go the route of MySensors for my Sonoffs. I use the ESP Easy firmware with a slightly modified Vera plugin. Here is my BLOG post on how to do it.
            https://dan.bemowski.info/2017/07/04/using-a-sonoff-with-espeasy-and-vera/
            You could still go the MySensors route. I just figured I'd show another alternative to this.
            sam9sS 1 Reply Last reply
            • J
              J
              Jan Gatzke
              It's a shame that we cannot have both, mysensors and the ESP Easy stuff. There has been a project for this: https://github.com/letscontrolit/ESPEasyMySensors :disappointed_relieved:
              dbemowskD gohanG 2 Replies Last reply
              • J Jan Gatzke
                dbemowskD
                dbemowskD
                @Jan-Gatzke It is my understanding that ESP Easy can send and receive MQTT messages, couldn't you just use a MySensors MQTT gateway if you wanted to keep it on the MySensors path?
                J 1 Reply Last reply
                • dbemowskD dbemowsk
                  J
                  J
                  Jan Gatzke
                  @dbemowsk You cannot because MQTT is just a transport and not a strict data format. You can however use MySenSors MQTT + ESP Easy MQTT + a broker + node red + a controller. Node Red can do data conversions and integrate everything.
                  • J Jan Gatzke
                    dbemowskD
                    dbemowskD
                    @Jan-Gatzke I was just speculating. I do not use MQTT, so I am by no means an authority on the subject.
                    • J Jan Gatzke
                      @Jan-Gatzke said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                      There is no real benefit to have the sonoff running mysensors instead of other firmwares, if your controller is able to communicate over mqtt to switch on/off the relay, you are fine
                      J Nca78N 2 Replies Last reply
                        J
                        J
                        Jan Gatzke
                        @gohan I know some controller are aware of ESP Easy via MQTT. If you controller does not support this directly, you have to integrate it manually (with node red). In my opinion scenarios, where MySensors with ESP Easy frontend would be of use, do still exist.
                          Nca78N
                          Nca78N
                          @gohan said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                          IMHO there is one, when your controller is down, gateway is down or whatever, you could still have direct control or the light switch from a MySensors button with node to node communication.
                            How do you do that if the sonoff is only having wifi?
                            Nca78N 1 Reply Last reply
                              Nca78N
                              Nca78N
                              Ah yes in that case you can't and yes there's no benefit :)
                                A wired button would be a much fail safe option for sonoffs 😀
                                  J
                                  J
                                  Jan Gatzke
                                  @gohan won't this option miss some features? :D
                                  • J Jan Gatzke
                                    @Jan-Gatzke for a sonoff there aren't many options and also a wired button you are pretty sure it would always work. 😀
                                    • dbemowskD
                                      dbemowskD
                                      For the Sonoffs, you could wire an external button directly to the onboard button which is on GPIO 0, or you could wire it to GPIO 14 which is broken out on the programming header on most Sonoffs. Some older Sonoffs didn't have GPIO 14 on that header. Once you have a button or switch wired on, you can then change the code or do some firmware scripting depending which flavor of firmware you use.
                                        sam9sS
                                        sam9sS
                                        sam9s
                                        @dbemowsk Do you know if there is a way to use vera edge / plus with Tasmota firmware instead of EasyESP??
                                        • sam9sS sam9s
                                          dbemowskD
                                          dbemowskD
                                          @sam9s I have never played with Tasmota, so I have to say that I don't know. A Vera plugin would have to be coded or modified as I did with the HTTP Switch plugin to make it work if there is not one out there already. I am assuming that you looked at my blog post on the ESP Easy way.
