  3. HELP!! NODE WITH RELAY VOLTAGE AND DETECTOR
4 Posts 3 Posters 1.7k Views 3 Watching
    Marco Avallone
    Hi I'm trying to make a script of Arduino to create a node with home automation: relay, light sensor, and sensor noise.
    The problem is that the only solution for the installation of the coupling relay with a switch.
    The script should be divided into 2 sections:
    1. asynchronous control with photoresistor
    2. Turn off relay asynchronously, following a first draft to be modified:
    int stato = statorelay[message.getBool()]; //leggo stato da array
    Serial.print("stato:");
    Serial.println(stato);
    Serial.print("getbboolo:");
    Serial.print("messaggio sensore:");
    Serial.println(message.sensor);
    if (message.getBool()== 1, stato ==0) { // MESSAGGIO DI ACCENSIONE CON LAMPADINA SPENTA
    Serial.print("ACCENDI RELAY - Lampanida accesa ");
    digitalWrite(message.sensor-1+RELAY_3, RELAY_ON);
    statorelay[message.getBool()] = 1; // salvo in memoria stato relay
    return; // blocco script
    if (message.getBool()== 0, stato ==1) { // MESSAGGIO DI SPEGNIMENTO CON LAMPADINA ACCESA
    Serial.print("SPEGNI RELAY - Lampanida spenta");
    digitalWrite(message.sensor-1+RELAY_3, RELAY_OFF);
    statorelay[message.getBool()] = 0; // salvo in memoria stato relay
    return;
    if (message.getBool()== 0, stato ==0) { //MESSAGGIO DI SPEGNIMENTO CON LAMPADINA SPENTA
    Serial.print("ACCENDI RELAY - Lampanida spenta ");
    return;
    if (message.getBool()== 1, stato ==1) { //MESSAGGIO DI ACCENSIONE CON LAMPADINA ACCESA
    Serial.print("SPEGNI RELAY - Lampanida accesa ");
    return;
    I NEED HELP!!! THANK YOU!
    If I was not clear please ask, sorry for my english
    • pansenP
      pansenP
      pansen
      • I NEED HELP!!!! is not a question. Describe your problem and then we might be able to help.
      • Please rewrite this sentence: "The problem is that the only solution for the installation of the coupling relay with a switch." I do not understand it at all. Better use google translate if your English is not so good.
      • You wrote something about asynchronously, I do not see any interrupts so your code is fully synchronous.
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      M 1 Reply Last reply
      • pansenP pansen
        Marco Avallone
        wrote on last edited by AWI
        OK, I rephrase the request.
        I have at home this CONFIGURATION
        I created the following script:
        // Enabled repeater feature for this node
        #define MY_REPEATER_FEATURE
        #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
        #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
        #define RELAY_ON 0
        #define RELAY_OFF 1
          bool state;
          int luce;
          int soglia = 25; //  imposed sensor sensitivity
          int statorelay = 0; //  variable that saves in memory initial state relay
        MyMessage msg(CHILD_ID,V_LIGHT);
          pinMode(RELAY_PIN, OUTPUT); //
          digitalWrite(RELAY_PIN, RELAY_OFF); //  Initial setting relay on off
        void presentation()  {
          sendSketchInfo("RELAY DEVERTER", "1.0");
          present(CHILD_ID, S_LIGHT);
              int value;
              luce = (1023-analogRead(A0))/10.23;  //
        I note if there is current on the bulb. I use a 220v led with a photoresistor.
              if(luce < soglia) {
                send(msg.set(value==HIGH ? 1 : 0)); //voltage yes
              else {
                send(msg.set(value==LOW ? 1 : 0)); // voltage no
              delay (1000);
          //  SECTION ENTER POWER RELAY WITH REVERSE
             if (message.getBool()== 1, statorelay ==0)  {    // POWER ON MESSAGE WITH BULB OFF
                      digitalWrite(RELAY_PIN, RELAY_ON);
                      statorelay=1; // salvo in memoria stato relay
             if (message.getBool()== 0, statorelay ==1)  {   //  SHUTDOWN WITH MESSAGE ON BULB
                       statorelay=0;
                       return;
             if (message.getBool()== 0, statorelay ==0)  {   // SHUTDOWN MESSAGE WITH BULB OFF - REVERSE
                         statorelay=1;
                         return;
             if (message.getBool()== 1, statorelay ==1)  {   //POWER ON MESSAGE WITH BULB ON - REVERSED
                           statorelay=1;
                           return;
        This script works, and allows me to see if the bulb is actually on or off, and turn it off or turn it on indipendetemente the state of the relay.
        The problem is the script:
        1. I would like to add more relays with detectors.
        2. I would like to send the status of the bulb to the gateway only when actually changes.
        Can you help me? I'VE BEEN CLEAR?
        THANK YOU!!!
        L 1 Reply Last reply
        • M Marco Avallone
          #define RELAY_ON 0
          #define RELAY_OFF 1
            bool state;
            int luce;
                int value;
                if(luce < soglia) {
                else {
                delay (1000);
                         statorelay=0;
                         return;
                           statorelay=1;
                           return;
                             statorelay=1;
                             return;
          THANK YOU!!!
          L
          L
          LastSamurai
          @Marco-Avallone Please use the code syntax for your code snipet. Like this it's very hard to read. Also why do you use caps so much?
          For me your question isn't clear. What have you tried to actually do that did not work?
          • for 1: just add another child to your sketch for another relay... basically duplicate most of your code
          • for 2: then safe the last state and check it before sending a message
          Hope that helped.
