  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
  • C ceech
    @NeverDie 20mV is stat-up voltage.
    alexsh1A
    alexsh1A
    alexsh1
    @ceech very impressive Roman! Keep us posted when the board is ready for orders
    • NeverDieN
      NeverDieN
      @ceech Is there a particular brand/source of supercaps that you recommend to fit your PCB? Or do they come pre-installed?
      C alexsh1A 2 Replies Last reply
      • NeverDieN NeverDie
        C
        C
        ceech
        wrote on last edited by ceech
        #123
        @NeverDie I like those:
        http://www.mouser.com/ds/2/40/AVX-SCC-1018831.pdf
        Super capacitors will be installed on boards.
          alexsh1A
          alexsh1A
          alexsh1
          #124
          @NeverDie @Nca78
          I must admit, I got totally lost in the middle of this thread with so many links.
          Did you manage to find a holy grail? I'm keep to change a 400mA LiPO for supercapacitors on one of my nodes
          NeverDieN 1 Reply Last reply
          • alexsh1A alexsh1
            @NeverDie @Nca78
            NeverDieN
            NeverDieN
            #125
            @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
            @NeverDie @Nca78
            I haven't received the supercaps from China, so I can't comment on them as yet. I expect they should arrive by next weekend, or possibly before. However, there are lots of other supercaps that one might use.
            I still think that for most people a simple 6v solar panel for around $1 on Aliexpress, together with https://www.openhardware.io/view/382/Tiny-Solar-Charger-for-27v-Mote-Supercap
            and a sufficiently large supercap is all you're going to need for most things. If you have a sensor that needs 3.3v, then you will want to add a pass-through boost charger such as:
            https://www.openhardware.io/view/285/33v-Boost-Converter-with-Pass-Through
            or
            https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
            that you enable when your node wakes up and disable before going back to sleep.
            One can get more elaborate to handle more challenging low-light cases, but for 80%+ of the cases, I would expect the above to be enough.
            Fortunately, all this stuff is fairly inexpensive and easy to assemble.
            alexsh1A 1 Reply Last reply
            • TerrenceT
              TerrenceT
              Terrence
              I have this Solar Powered IoT Device Kit from Cypress....but have not started using it yet. though I would post it in case you might find the BOM useful.
              http://www.cypress.com/documentation/development-kitsboards/s6sae101a00sa1002-solar-powered-iot-device-kit
                @NeverDie @Nca78
                or
                alexsh1A
                alexsh1A
                alexsh1
                #127
                @NeverDie Thanks for your suggestion. Here is a thing - I cannot find MAX8887EZK27 anywhere.
                Meantime, I did manage to find this interesting article - https://www.ti5.tu-harburg.de/publications/2009/fgsn09_lifetime.pdf
                And these boost converters on the e-bay:
                1. http://www.ebay.co.uk/itm/ClosedCube-TPS61221-Low-Input-Voltage-from-0-7V-Boost-3-3V-Converter-Breakout-/182051630756
                2. http://www.ebay.co.uk/itm/ClosedCube-TPS61291-Low-Iq-Boost-Converter-with-Bypass-Operation-Breakout-/182304011227?var=&hash=item2a722a73db:m:mCSTFZtUluPLYwuCR7RYaeQ
                A bit expensive, but based on a very advanced chip which may be used with supercaps.
                • alexsh1A alexsh1
                  NeverDieN
                  NeverDieN
                  https://www.digikey.com/product-detail/en/maxim-integrated/MAX8887EZK27-/MAX8887EZK27--ND/6227255
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @NeverDie it is a no go for me at USD 18 delivery charge to the UK. Unfortunately, there are no other sources for this chip.
                    • NeverDieN
                      NeverDieN
                      You'll need to substitute a different LDO for it then.
                      • alexsh1A alexsh1
                        #131
                        @alexsh1 in case you don't already know, octopart is great for finding sources. https://octopart.com/search?q=MAX8887EZK27
                        There seems to be only american sources for this component though :(
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @mfalkvidd
                          I did not know about this source
                          Well, that's the problem. The postage is golden and then if the value is greater than 20 bucks (including postage), I have to pay 20% VAT.
                          C NeverDieN 2 Replies Last reply
                          • alexsh1A alexsh1
                            @mfalkvidd
                            C
                            C
                            ceech
                            #133
                            @alexsh1 @NeverDie You can substitute the MAX8887 with MIC5365.
                            This whole thing got me so intrigued that I'm going to make a board myself. With charger, super capacitors and DC-DC converter. I'll use MIC5365 and for DC-DC conversion TPS610986. It has loads of options. And the whole thing will cost less than 10 bucks. I've made a schematic
                            alexsh1A NeverDieN 2 Replies Last reply
                            • C ceech
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @ceech said in How best to find the "best" small solar panel of a particular size?:
                              TPS610986
                              Excellent choice - TPS610986 - The TPS61098x
                              suits for low power systems very well, especially for the system which
                              spends the most of time in sleep mode and wakes up periodically to sense or transmit signals.
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                @NeverDie I am sure you saw this brilliant write up by Nick Gammon:
                                http://www.gammon.com.au/forum/?id=12821
                                He experimented with 0.47F capacitor. It was enough to run a mote (<10uA in a sleep mode) overnight
                                • alexsh1A alexsh1
                                  NeverDieN
                                  NeverDieN
                                  @alexsh1
                                  I hadn't seen it, but a mote in sleep mode draws practically nothing (<300na for combined draw from both atmega328p and RFM69). It's the self discharge rate of the capacitor more than anything which seems to govern.
                                    @alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @NeverDie This is what he experienced! Have a look at the link. Within a few charges though, self discharge stabilised
                                    • alexsh1A alexsh1
                                      @mfalkvidd
                                      NeverDieN
                                      NeverDieN
                                      #138
                                      @alexsh1
                                      Regarding the choice of replacement LDO. If the LDO you pick turns out to have unacceptably large reverse current flow, just place the blocking diode after it instead of before it. That particular diode will leak only about 20na, and the entire issue doesn't even come up until the last ~0.3v of charging, where you'll then have a very long charge tail. However, if that were to be an issue, you could just use a larger Farad supercap, and then it wouldn't matter because you'd have enough charge already before encountering the long tail of the charge process.
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @NeverDie Thanks for heads-up. I'll keep it in mind
                                        I found an interesting cap -
                                        https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691204E3/4705PHBK-ND/5015889
                                        Its voltage is very close to the solar panel so I think it may be connected directly via diode (0.7v drop = 6 - 0.7 = 5.3V vs 5.6V max rating)
                                        • alexsh1A alexsh1
                                          NeverDieN
                                          NeverDieN
                                          I've tried that cap already, and I wouldn't recommend it. It has a fairly high ESR.
