  3. ago control
  4. Integration into the ago control home automation software
Scheduled Pinned Locked Moved ago control
9 Posts 4 Posters 5.4k Views 2 Watching
  • hariH
    hariH
    hari
    wrote on last edited by hari
    I'm working on MySensors support for the ago control home automation and control suite. I've prepared some code already. I'll finish the implementation as soon as the missing parts arrive from china.
    hekH 1 Reply Last reply
    • hariH hari
      @hari
      Great, looking forward to your plugin!
      Always the important stuff that end up on the slow boat ;)
      • hariH
        hariH
        hari
        it is coming along nicely. Adding sensors already works, and ago control is already logging the temperature from the MySensor Temperature sketch. I'll add more devices over the next days as soon as the missing sensors/actuators arrive.
        hekH blaceyB 2 Replies Last reply
        • hariH hari
          Great to hear you are making progress @hari
          • hariH hari
            blaceyB
            blaceyB
            blacey
            @hari
            Sweet! :)
            • A
              A
              andriej
              I can't get ago-control to work, to see how it does perform etc.
              I get the 'netinst' version of raspbian but I also run Domoticz on it, can't really switch to new system-init programs as I probably will f*k something up during the update.. ;-)
              • hariH
                hariH
                hari
                if you don't want to install systemd, there is a sysv init script in GIT from some user, but I never tested that. We'll provide an integrated component startup management in version 2.0
                  @hari
                  Haven't heard from you in a while. Is everything running along for you with the Ago Control integration?
                  • hariH
                    hariH
                    hari
                    it is coming along nicely. I've added most of the sensor types recently. Currently I'm testing on armhf platform (Wandboard) (development was done on amd64). Things look good so far. The relay and some other stuff arrived yesterday. So I will add the missing things these days.
