  2. Feature Requests
  3. Z-uno Gateway
Z-uno Gateway
2 Posts 2 Posters 1.7k Views 2 Watching
  • thommeT
    thommeT
    thomme
    Has anyone tried to make a Gateway on the z-uno module. It would be nice to connect a couple of temp/humidity sensors like DHT22 via NRF24L01.
    The idea of using z-uno is to connect it to a Fibaro HC2. As for now i have the z-uno connected with two wired DHT22 and that works fine.
    Tell me if it seems impossible. I know it strange to connect one wireless module on another.
    Regards
    FotoFieberF 1 Reply Last reply
    • thommeT thomme
      Regards
      FotoFieberF
      FotoFieberF
      FotoFieber
      @thomme
      This gateway has to remember all the sensors on the mysensors network. If you would add a new sensor, you would have to detach and reattach the Z-Uno from zWave network.
      I don't think you have enough memory on the Z-Uno to do such a gateway and AFAIK the sensor types supported on the Z-Uno are very limited.
      My solution for integrating different iot systems is mqtt with node-red. All systems have an adapter to a generic message structure and can be connected to all the others.
      I use a mix of homegear,/homematic mysensors, netatmo, zWave, owntracks, Alexa, imperihome, Sonoff...
