  3. Heatpump controller
Heatpump controller
55 Posts 15 Posters 31.2k Views 11 Watching
  • BR3NDAB Offline
    BR3NDAB Offline
    BR3NDA
    I have my heatpump mysensor working, and hooked up to Openhab.
    Arduino code here:
    #include <Arduino.h>
    #include <PanasonicCKPHeatpumpIR.h>
    #include <PanasonicHeatpumpIR.h>
    #define POWER_ID 0
    #define MODE_ID 1
    #define FAN_ID 2
    #define TEMP_ID 3
    #define VDIR_ID 4
    #define HDIR_ID 5
    MyMessage powerMsg(POWER_ID, V_STATUS);
    MyMessage modeMsg(MODE_ID, V_HVAC_FLOW_STATE);
    MyMessage fanMsg(FAN_ID, V_PERCENTAGE);
    MyMessage tempMsg(TEMP_ID, V_TEMP);
    MyMessage vdirMsg(VDIR_ID, V_VAR1);
    MyMessage hdirMsg(HDIR_ID, V_VAR2);
    IRSenderPWM irSender(3);       // IR led on Arduino digital pin 3, using Arduino PWM
    HeatpumpIR *heatpumpIR = new PanasonicNKEHeatpumpIR();
    //Some global variables to hold the states
    int POWER_STATE;
    int TEMP_STATE;
    int FAN_STATE;
    int MODE_STATE;
      gw.begin(incomingMessage, AUTO, false);
      gw.sendSketchInfo("Heatpump", "1.0");
      gw.present(POWER_ID, S_BINARY);
      gw.present(MODE_ID, S_HVAC);
      gw.present(FAN_ID, S_HVAC);
      gw.present(TEMP_ID, S_HVAC);
      gw.present(VDIR_ID, S_CUSTOM);
      gw.present(HDIR_ID, S_CUSTOM);
      // Load our values on start
      POWER_STATE = gw.loadState(POWER_ID);
      TEMP_STATE = gw.loadState(TEMP_ID);
      FAN_STATE = gw.loadState(FAN_ID);
      MODE_STATE = gw.loadState(MODE_ID);
      sendHeatpumpCommand();
      gw.process();
    void handlePowerMessage(bool newState) {
      if (newState) {
        POWER_STATE = POWER_ON;
      else {
        POWER_STATE = POWER_OFF;
      gw.saveState(POWER_ID, newState);
    void handleModeMessge(int newMode) {
      switch(newMode) {
        case 0:
          MODE_STATE = MODE_HEAT; break;
        case 1:
          MODE_STATE = MODE_COOL; break;
        case 2:
          MODE_STATE = MODE_AUTO; break;
        case 3:
          MODE_STATE = MODE_FAN; break;
         case 4:
          MODE_STATE = MODE_DRY; break;
      MODE_STATE = newMode;
      gw.saveState(MODE_ID, newMode);
    void handleFanMessage(int newFan) {
      if (newFan > 5) newFan=5;
      switch(newFan) {
        case 0:
          FAN_STATE = FAN_AUTO; break;
        case 1:
          FAN_STATE = FAN_1; break;
        case 2:
          FAN_STATE = FAN_2; break;
        case 3:
          FAN_STATE = FAN_3; break;
        case 4:
          FAN_STATE = FAN_4; break;
        case 5:
          FAN_STATE = FAN_5; break;
        default:
      FAN_STATE = newFan;
      gw.saveState(FAN_ID, newFan);
    void handleTempMessage(int newTemp) {
      TEMP_STATE = newTemp;
      gw.saveState(TEMP_ID, newTemp);
    void sendHeatpumpCommand() {
      Serial.println("Power = " + (String)POWER_STATE);
      Serial.println("Mode = " + (String)MODE_STATE);
      Serial.println("Fan = " + (String)FAN_STATE);
      Serial.println("Temp = " + (String)TEMP_STATE);
      heatpumpIR->send(irSender, POWER_STATE, MODE_STATE, FAN_STATE, TEMP_STATE, VDIR_AUTO, HDIR_AUTO);
      if (message.isAck()) {
       Serial.print(message.sensor);
       switch(message.sensor) {
        case POWER_ID: {
          bool newState = message.getBool();
          handlePowerMessage(newState);
          break;
        case MODE_ID: {
          int newMode = message.getInt();
          handleModeMessge(newMode);
          break;
        case FAN_ID: {
          int newFan = message.getInt();
          handleFanMessage(newFan);
          break;
        case TEMP_ID: {
          int newTemp = message.getInt();
          handleTempMessage(newTemp);
          break;
    Openhab items
    Switch	Power_HeatPump	"Heatpump on/off" <aircon>
    Number	Mode_HeatPump	"Heatpump mode"
    Number	Fan_HeatPump	"Heatpump fan" <airing>
    Number	Temp_HeatPump	"Heatpump temperature [%d C]"	<temperature>
    String	VDir_HeatPump	"vertical"
    String	HDir_HeatPump	"horizontal"
    Openhab sitemap
    sitemap heatpump label="Heatpump" {
      Frame {
        Switch item=Power_HeatPump
        Selection item=Mode_HeatPump mappings=[0="heat", 1="cool", 2="auto", 3="fan", 4="dry"]
        Selection item=Fan_HeatPump mappings=[0="auto", 1="Level 1", 2="Level 2", 3="Level 3", 4="Level 4", 5="Level 5"]
        Setpoint item=Temp_HeatPump minValue=10 maxValue=30 step=1
        Text item=VDir_HeatPump
        Text item=HDir_HeatPump
    Openhab rules
    val org.eclipse.xtext.xbase.lib.Functions$Function4 numberOperation = [
        org.openhab.core.library.items.NumberItem numberItem,
        org.openhab.core.library.items.StringItem arduinoItem,
        String arduinoDevMap,
        Integer subType|
        logInfo("number", "Sending number message to mysensors node")
        var Integer state = numberItem.state
        logInfo("mysensors", "Function: numberOperation >> "+arduinoDevMap + "1;1;" + subType + ";" + state )
        arduinoItem.sendCommand(arduinoDevMap + "1;0;" + subType + ";" + state + "\n")
    //switch function
    val org.eclipse.xtext.xbase.lib.Functions$Function4 switchOperation = [
        org.openhab.core.library.items.SwitchItem relayItem,
        Integer subType|
        logInfo("switch", "Sending switch message to mysensors node")
        var Integer state = 0
        if (relayItem.state == OFF) {
            state = 0
        else {
            state = 1
        logInfo("mysensors", "Function: switchOperation >> "+arduinoDevMap + "1;1;" + subType + ";" + state )
    rule "Heatpump on"
    when
        Item Power_HeatPump received command
    then
        switchOperation.apply(Power_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Power_HeatPump"),  V_STATUS)
    end
    rule "Heatpump mode"
    when
        Item Mode_HeatPump received update
    then
        numberOperation.apply(Mode_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Mode_HeatPump"),  V_VAR1)
    end
    rule "Heatpump temp"
    when
        Item Temp_HeatPump received command
    then
        numberOperation.apply(Temp_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Temp_HeatPump"),  V_TEMP)
    end
    rule "heatpump fan"
    when
        Item Fan_HeatPump received command
    then
        numberOperation.apply(Fan_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Fan_HeatPump"),  V_PERCENTAGE)
    end
    • T ToniA
      In live in Finland...
      I now have the HeatpumpIR working together with Domoticz, so that I can also define which commands to send from Domoticz. And yes, 24 bits is plenty enough :)
      https://github.com/ToniA/arduino-heatpumpir/tree/master/examples/MySensorsNode
      @johnr, do you happen to have an infrared receiver module? If you do, I could assist you in decoding the protocol. This is how I for example got the Mitsubishi protocol decoded, I've never had a Mitsubishi remote controller myself...
      SGiS Offline
      SGiS Offline
      SGi
      @ToniA Hi, do you have a guide on how to set up Domoticz with this example? I understand enough about mysensors and domoticz to be dangerous but i dont get how Domoticz can send the right command....
      B 1 Reply Last reply
      • T Offline
        T Offline
        ToniA
        Take a look at this topic on the Domoticz forum: http://www.domoticz.com/forum/viewtopic.php?f=34&t=8751
        M 1 Reply Last reply
        • SGiS SGi
          B Offline
          B Offline
          bjacobse
          @SGi
          I have created the wiki:
          https://www.domoticz.com/wiki/AC_/_heatpumpIR
          Everything is based in Toni's great effort :-)
          I also first used the mysensors Arduino, but since I am still using "old" mysensors ver 1.5.4 (And currently I don't have time to upgrade to latest and greatest, which support text based commands)
          Then I have taken same approach as Toni and use Wemos D1 Mini Pro that uses HTTP or MQTT wifi
          gohanG 1 Reply Last reply
          • T ToniA
            M Offline
            M Offline
            moskovskiy82
            wrote on last edited by moskovskiy82
            #45
            @ToniA
            Thanks for the library it's great. I can also confirm that it works with Fujitsu remote AR-REB1E out of the box.
            Trying to integrate this into HomeAssistant and just do not know where to start. Is there any example how to post a whole string of commands for the air cond via mysensors-MQTT?
            • M Offline
              M Offline
              moskovskiy82
              So nobody is using it this with MQTT gateway?
              • B bjacobse
                @SGi
                @bjacobse if I have a new Daikin heat pump with a newer remote that is not in the library, I guess I'm out of luck, right?
                • M moskovskiy82
                  B Offline
                  B Offline
                  bjacobse
                  @moskovskiy82
                  hi, I'm not using the MQTT with mysensors
                  I think you should direct your questions to a HomeAssistant forum.
                  My setup uses Wemos D1 Mini Pro and Domoticz
                    B Offline
                    B Offline
                    bjacobse
                    @gohan
                    Please use the github for heatpump to ask you question, as I assume that Toni mostly is checking that. It seems that there 2 different Daikin heatpumps supported
                    • B bjacobse
                      @moskovskiy82
                      M Offline
                      M Offline
                      moskovskiy82
                      @bjacobse Can you elaborate a little more on how you wired things up?
                      Also how you combined the libs and compiled everything for easyESP?
                      Have a sonoff with easyESP and docs are not that clear how to that stuff
                      • M moskovskiy82
                        B Offline
                        B Offline
                        bjacobse
                        @moskovskiy82
                        I took 5v from the heatpump, mine is an IVT, I took it from the Ir receive, soldered 2wires, one GND and on for 5V and drilled a hole on the plastic casing, and then I had power for the Wemos D1 Mini Pro module.
                        Then 100 Ohm resister in series with the Irda LED 940nm Ir LED, connected to GPio16/D0 on the Wemos module.
                        Downlaod the ESPEASYT files + download Tonis heatpump /P115 lib and put it in same Arduino IDE, compile it all together
                        http://www.domoticz.com/wiki/AC_/_heatpumpIR
                        • IspandyI Offline
                          IspandyI Offline
                          Ispandy
                          I want to make heatpumpIR, but after trying to send the signal using simple.ino sketch to my Sharp A/C nothing happened. Confused where to start ....
                          • IspandyI Ispandy
                            B Offline
                            B Offline
                            bjacobse
                            @Ispandy
                            did you look at the previous comment?
                            to make it easy for you, then don't use mysensors with Arduino for this, it's too difficult to setup, but instead use the Wemos and ESPEASY using your WIFI
                            • B bjacobse
                              @Ispandy
                              M Offline
                              M Offline
                              moskovskiy82
                              @bjacobse There is nothing difficult in setting it up. Just connect the irda to the 3rd PWM leg
                              • M moskovskiy82
                                B Offline
                                B Offline
                                bjacobse
                                @moskovskiy82
                                I certainly agree, I assume your comment actually was meant to Ispandy ;-)
