  3. Heatpump controller
Heatpump controller
55 Posts 15 Posters 32.8k Views 11 Watching
  • T ToniA
    Just got my Sensebenders this week. I can confirm that the HeatpumpIR library works also on the Sensebender :) Nice...
    F
    F
    Fredrik Carlsson
    @ToniA
    Hey, thanks for all the work you have put down. I have had some other projects going the last year so have not really put down more time on this.
    How is it working with the sensebender? Are you using it on batteries?
    Any ide about battery usage?
    • T
      ToniA
      I just got it running on Sensebender today, on my desk. The problem is that this is not a 'sensor', but an 'actuator'. So it needs to listen to the radio all the time. I believe it would not run on batteries for too long.
      I was asking about how to power the Sensebender in another thread, but didn't yet get any real answers. So let's try once more:
      What kind of schema should I use to power the Sensebender (with NRF24), provided that I have +5V DC available, and I have a bunch of different capacitors and 'LE33ACZ 5V-3.3V Step Down Regulators'?
      • F
        F
        Fredrik Carlsson
        wrote on last edited by Fredrik Carlsson
        #40
        Hello
        It would be nice to make it run on batteries, maybe with 10 seconds sleep, and then wake up only to check with gateway if there is a new command and then sleep again.
        I am building a pir sensor now based on 3*aa batteris running on 4,5 volt.I will ust use an LE33 step down directly after the battery pack to provide power to both sensebender+radio+pir. Dont know if that is the optimal way to do it but it should work
        • BR3NDAB
          BR3NDAB
          BR3NDA
          I have my heatpump mysensor working, and hooked up to Openhab.
          Arduino code here:
          #include <Arduino.h>
          #include <PanasonicCKPHeatpumpIR.h>
          #include <PanasonicHeatpumpIR.h>
          #define POWER_ID 0
          #define MODE_ID 1
          #define FAN_ID 2
          #define TEMP_ID 3
          #define VDIR_ID 4
          #define HDIR_ID 5
          MyMessage powerMsg(POWER_ID, V_STATUS);
          MyMessage modeMsg(MODE_ID, V_HVAC_FLOW_STATE);
          MyMessage fanMsg(FAN_ID, V_PERCENTAGE);
          MyMessage tempMsg(TEMP_ID, V_TEMP);
          MyMessage vdirMsg(VDIR_ID, V_VAR1);
          MyMessage hdirMsg(HDIR_ID, V_VAR2);
          IRSenderPWM irSender(3);       // IR led on Arduino digital pin 3, using Arduino PWM
          HeatpumpIR *heatpumpIR = new PanasonicNKEHeatpumpIR();
          //Some global variables to hold the states
          int POWER_STATE;
          int TEMP_STATE;
          int FAN_STATE;
          int MODE_STATE;
            gw.begin(incomingMessage, AUTO, false);
            gw.sendSketchInfo("Heatpump", "1.0");
            gw.present(POWER_ID, S_BINARY);
            gw.present(MODE_ID, S_HVAC);
            gw.present(FAN_ID, S_HVAC);
            gw.present(TEMP_ID, S_HVAC);
            gw.present(VDIR_ID, S_CUSTOM);
            gw.present(HDIR_ID, S_CUSTOM);
            // Load our values on start
            POWER_STATE = gw.loadState(POWER_ID);
            TEMP_STATE = gw.loadState(TEMP_ID);
            FAN_STATE = gw.loadState(FAN_ID);
            MODE_STATE = gw.loadState(MODE_ID);
            sendHeatpumpCommand();
          void handlePowerMessage(bool newState) {
            if (newState) {
              POWER_STATE = POWER_ON;
            else {
              POWER_STATE = POWER_OFF;
            gw.saveState(POWER_ID, newState);
          void handleModeMessge(int newMode) {
            switch(newMode) {
              case 0:
                MODE_STATE = MODE_HEAT; break;
              case 1:
                MODE_STATE = MODE_COOL; break;
              case 2:
                MODE_STATE = MODE_AUTO; break;
              case 3:
                MODE_STATE = MODE_FAN; break;
               case 4:
                MODE_STATE = MODE_DRY; break;
            MODE_STATE = newMode;
            gw.saveState(MODE_ID, newMode);
          void handleFanMessage(int newFan) {
            if (newFan > 5) newFan=5;
            switch(newFan) {
              case 0:
                FAN_STATE = FAN_AUTO; break;
              case 1:
                FAN_STATE = FAN_1; break;
              case 2:
                FAN_STATE = FAN_2; break;
              case 3:
                FAN_STATE = FAN_3; break;
              case 4:
                FAN_STATE = FAN_4; break;
              case 5:
                FAN_STATE = FAN_5; break;
              default:
            FAN_STATE = newFan;
            gw.saveState(FAN_ID, newFan);
          void handleTempMessage(int newTemp) {
            TEMP_STATE = newTemp;
            gw.saveState(TEMP_ID, newTemp);
          void sendHeatpumpCommand() {
            Serial.println("Power = " + (String)POWER_STATE);
            Serial.println("Mode = " + (String)MODE_STATE);
            Serial.println("Fan = " + (String)FAN_STATE);
            Serial.println("Temp = " + (String)TEMP_STATE);
            heatpumpIR->send(irSender, POWER_STATE, MODE_STATE, FAN_STATE, TEMP_STATE, VDIR_AUTO, HDIR_AUTO);
            if (message.isAck()) {
             switch(message.sensor) {
              case POWER_ID: {
                bool newState = message.getBool();
                handlePowerMessage(newState);
              case MODE_ID: {
                int newMode = message.getInt();
                handleModeMessge(newMode);
              case FAN_ID: {
                int newFan = message.getInt();
                handleFanMessage(newFan);
              case TEMP_ID: {
                int newTemp = message.getInt();
                handleTempMessage(newTemp);
          Openhab items
          Switch	Power_HeatPump	"Heatpump on/off" <aircon>
          Number	Mode_HeatPump	"Heatpump mode"
          Number	Fan_HeatPump	"Heatpump fan" <airing>
          Number	Temp_HeatPump	"Heatpump temperature [%d C]"	<temperature>
          String	VDir_HeatPump	"vertical"
          String	HDir_HeatPump	"horizontal"
          Openhab sitemap
          sitemap heatpump label="Heatpump" {
            Frame {
              Switch item=Power_HeatPump
              Selection item=Mode_HeatPump mappings=[0="heat", 1="cool", 2="auto", 3="fan", 4="dry"]
              Selection item=Fan_HeatPump mappings=[0="auto", 1="Level 1", 2="Level 2", 3="Level 3", 4="Level 4", 5="Level 5"]
              Setpoint item=Temp_HeatPump minValue=10 maxValue=30 step=1
              Text item=VDir_HeatPump
              Text item=HDir_HeatPump
          Openhab rules
          val org.eclipse.xtext.xbase.lib.Functions$Function4 numberOperation = [
              org.openhab.core.library.items.NumberItem numberItem,
              org.openhab.core.library.items.StringItem arduinoItem,
              String arduinoDevMap,
              Integer subType|
              logInfo("number", "Sending number message to mysensors node")
              var Integer state = numberItem.state
              logInfo("mysensors", "Function: numberOperation >> "+arduinoDevMap + "1;1;" + subType + ";" + state )
              arduinoItem.sendCommand(arduinoDevMap + "1;0;" + subType + ";" + state + "\n")
          //switch function
          val org.eclipse.xtext.xbase.lib.Functions$Function4 switchOperation = [
              org.openhab.core.library.items.SwitchItem relayItem,
              Integer subType|
              logInfo("switch", "Sending switch message to mysensors node")
              var Integer state = 0
              if (relayItem.state == OFF) {
                  state = 0
              else {
                  state = 1
              logInfo("mysensors", "Function: switchOperation >> "+arduinoDevMap + "1;1;" + subType + ";" + state )
          rule "Heatpump on"
          when
              Item Power_HeatPump received command
          then
              switchOperation.apply(Power_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Power_HeatPump"),  V_STATUS)
          end
          rule "Heatpump mode"
          when
              Item Mode_HeatPump received update
          then
              numberOperation.apply(Mode_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Mode_HeatPump"),  V_VAR1)
          end
          rule "Heatpump temp"
          when
              Item Temp_HeatPump received command
          then
              numberOperation.apply(Temp_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Temp_HeatPump"),  V_TEMP)
          end
          rule "heatpump fan"
          when
              Item Fan_HeatPump received command
          then
              numberOperation.apply(Fan_HeatPump, MySensors_Gateway, sensorToItemsMap.get("Fan_HeatPump"),  V_PERCENTAGE)
          end
          • T ToniA
            In live in Finland...
            I now have the HeatpumpIR working together with Domoticz, so that I can also define which commands to send from Domoticz. And yes, 24 bits is plenty enough :)
            https://github.com/ToniA/arduino-heatpumpir/tree/master/examples/MySensorsNode
            @johnr, do you happen to have an infrared receiver module? If you do, I could assist you in decoding the protocol. This is how I for example got the Mitsubishi protocol decoded, I've never had a Mitsubishi remote controller myself...
            SGiS
            SGiS
            SGi
            @ToniA Hi, do you have a guide on how to set up Domoticz with this example? I understand enough about mysensors and domoticz to be dangerous but i dont get how Domoticz can send the right command....
            bjacobseB 1 Reply Last reply
            • T
              ToniA
              Take a look at this topic on the Domoticz forum: http://www.domoticz.com/forum/viewtopic.php?f=34&t=8751
              • SGiS SGi
                bjacobseB
                bjacobseB
                bjacobse
                @SGi
                I have created the wiki:
                https://www.domoticz.com/wiki/AC_/_heatpumpIR
                Everything is based in Toni's great effort :-)
                I also first used the mysensors Arduino, but since I am still using "old" mysensors ver 1.5.4 (And currently I don't have time to upgrade to latest and greatest, which support text based commands)
                Then I have taken same approach as Toni and use Wemos D1 Mini Pro that uses HTTP or MQTT wifi
                gohanG 1 Reply Last reply
                • T ToniA
                  moskovskiy82
                  wrote on last edited by moskovskiy82
                  #45
                  @ToniA
                  Thanks for the library it's great. I can also confirm that it works with Fujitsu remote AR-REB1E out of the box.
                  Trying to integrate this into HomeAssistant and just do not know where to start. Is there any example how to post a whole string of commands for the air cond via mysensors-MQTT?
                    moskovskiy82
                    So nobody is using it this with MQTT gateway?
                    • bjacobseB bjacobse
                      @SGi
                      @bjacobse if I have a new Daikin heat pump with a newer remote that is not in the library, I guess I'm out of luck, right?
                      • M moskovskiy82
                        bjacobseB
                        bjacobseB
                        bjacobse
                        @moskovskiy82
                        hi, I'm not using the MQTT with mysensors
                        I think you should direct your questions to a HomeAssistant forum.
                        My setup uses Wemos D1 Mini Pro and Domoticz
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @gohan
                          Please use the github for heatpump to ask you question, as I assume that Toni mostly is checking that. It seems that there 2 different Daikin heatpumps supported
                            @moskovskiy82
                            moskovskiy82
                            @bjacobse Can you elaborate a little more on how you wired things up?
                            Also how you combined the libs and compiled everything for easyESP?
                            Have a sonoff with easyESP and docs are not that clear how to that stuff
                            • M moskovskiy82
                              bjacobseB
                              bjacobseB
                              bjacobse
                              @moskovskiy82
                              I took 5v from the heatpump, mine is an IVT, I took it from the Ir receive, soldered 2wires, one GND and on for 5V and drilled a hole on the plastic casing, and then I had power for the Wemos D1 Mini Pro module.
                              Then 100 Ohm resister in series with the Irda LED 940nm Ir LED, connected to GPio16/D0 on the Wemos module.
                              Downlaod the ESPEASYT files + download Tonis heatpump /P115 lib and put it in same Arduino IDE, compile it all together
                              http://www.domoticz.com/wiki/AC_/_heatpumpIR
                              • IspandyI
                                IspandyI
                                Ispandy
                                I want to make heatpumpIR, but after trying to send the signal using simple.ino sketch to my Sharp A/C nothing happened. Confused where to start ....
                                • IspandyI Ispandy
                                  bjacobseB
                                  bjacobseB
                                  bjacobse
                                  @Ispandy
                                  did you look at the previous comment?
                                  to make it easy for you, then don't use mysensors with Arduino for this, it's too difficult to setup, but instead use the Wemos and ESPEASY using your WIFI
                                    @Ispandy
                                    moskovskiy82
                                    @bjacobse There is nothing difficult in setting it up. Just connect the irda to the 3rd PWM leg
                                    • M moskovskiy82
                                      bjacobseB
                                      bjacobseB
                                      bjacobse
                                      @moskovskiy82
                                      I certainly agree, I assume your comment actually was meant to Ispandy ;-)
