  3. Heatpump controller
Heatpump controller
55 Posts 15 Posters 32.8k Views 11 Watching
  • T ToniA
    In live in Finland...
    I now have the HeatpumpIR working together with Domoticz, so that I can also define which commands to send from Domoticz. And yes, 24 bits is plenty enough :)
    https://github.com/ToniA/arduino-heatpumpir/tree/master/examples/MySensorsNode
    @johnr, do you happen to have an infrared receiver module? If you do, I could assist you in decoding the protocol. This is how I for example got the Mitsubishi protocol decoded, I've never had a Mitsubishi remote controller myself...
    SGiS
    SGiS
    SGi
    @ToniA Hi, do you have a guide on how to set up Domoticz with this example? I understand enough about mysensors and domoticz to be dangerous but i dont get how Domoticz can send the right command....
    bjacobseB 1 Reply Last reply
    • T
      ToniA
      Take a look at this topic on the Domoticz forum: http://www.domoticz.com/forum/viewtopic.php?f=34&t=8751
      • SGiS SGi
        bjacobseB
        bjacobseB
        bjacobse
        @SGi
        I have created the wiki:
        https://www.domoticz.com/wiki/AC_/_heatpumpIR
        Everything is based in Toni's great effort :-)
        I also first used the mysensors Arduino, but since I am still using "old" mysensors ver 1.5.4 (And currently I don't have time to upgrade to latest and greatest, which support text based commands)
        Then I have taken same approach as Toni and use Wemos D1 Mini Pro that uses HTTP or MQTT wifi
        gohanG 1 Reply Last reply
        • T ToniA
          moskovskiy82
          wrote on last edited by moskovskiy82
          #45
          @ToniA
          Thanks for the library it's great. I can also confirm that it works with Fujitsu remote AR-REB1E out of the box.
          Trying to integrate this into HomeAssistant and just do not know where to start. Is there any example how to post a whole string of commands for the air cond via mysensors-MQTT?
            moskovskiy82
            So nobody is using it this with MQTT gateway?
            • bjacobseB bjacobse
              @SGi
              @bjacobse if I have a new Daikin heat pump with a newer remote that is not in the library, I guess I'm out of luck, right?
              • M moskovskiy82
                bjacobseB
                bjacobseB
                bjacobse
                @moskovskiy82
                hi, I'm not using the MQTT with mysensors
                I think you should direct your questions to a HomeAssistant forum.
                My setup uses Wemos D1 Mini Pro and Domoticz
                  bjacobseB
                  bjacobseB
                  bjacobse
                  @gohan
                  Please use the github for heatpump to ask you question, as I assume that Toni mostly is checking that. It seems that there 2 different Daikin heatpumps supported
                    @moskovskiy82
                    moskovskiy82
                    @bjacobse Can you elaborate a little more on how you wired things up?
                    Also how you combined the libs and compiled everything for easyESP?
                    Have a sonoff with easyESP and docs are not that clear how to that stuff
                    • M moskovskiy82
                      bjacobseB
                      bjacobseB
                      bjacobse
                      @moskovskiy82
                      I took 5v from the heatpump, mine is an IVT, I took it from the Ir receive, soldered 2wires, one GND and on for 5V and drilled a hole on the plastic casing, and then I had power for the Wemos D1 Mini Pro module.
                      Then 100 Ohm resister in series with the Irda LED 940nm Ir LED, connected to GPio16/D0 on the Wemos module.
                      Downlaod the ESPEASYT files + download Tonis heatpump /P115 lib and put it in same Arduino IDE, compile it all together
                      http://www.domoticz.com/wiki/AC_/_heatpumpIR
                      • IspandyI
                        IspandyI
                        Ispandy
                        I want to make heatpumpIR, but after trying to send the signal using simple.ino sketch to my Sharp A/C nothing happened. Confused where to start ....
                        • IspandyI Ispandy
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @Ispandy
                          did you look at the previous comment?
                          to make it easy for you, then don't use mysensors with Arduino for this, it's too difficult to setup, but instead use the Wemos and ESPEASY using your WIFI
                            @Ispandy
                            moskovskiy82
                            @bjacobse There is nothing difficult in setting it up. Just connect the irda to the 3rd PWM leg
                            • M moskovskiy82
                              bjacobseB
                              bjacobseB
                              bjacobse
                              @moskovskiy82
                              I certainly agree, I assume your comment actually was meant to Ispandy ;-)
