  3. Error while compiling any MySensor sketch
compilation
4 Posts 2 Posters 2.2k Views 1 Watching
  • T Offline
    T Offline
    Totony
    Hi everyone,
    I have just installed the MySensor library:
    • copied the whole content of the library folder in my arduino lib folder
    • restarted the IDE (1.0.5-r2)
    I tried compiling several MySensors exemples directly from the example menu and always get the same error:
    M:\PRJ - Domotics\arduino\libraries\MySensors\Relay.cpp: In member function 'void Relay::begin(uint8_t, rf24_pa_dbm_e, uint8_t, rf24_datarate_e)':
    M:\PRJ - Domotics\arduino\libraries\MySensors\Relay.cpp:23: error: 'EEPROM' was not declared in this scope
    M:\PRJ - Domotics\arduino\libraries\MySensors\Relay.cpp: In member function 'void Relay::addChildRoute(uint8_t, uint8_t)':
    M:\PRJ - Domotics\arduino\libraries\MySensors\Relay.cpp:220: error: 'EEPROM' was not declared in this scope
    M:\PRJ - Domotics\arduino\libraries\MySensors\Relay.cpp: In member function 'void Relay::removeChildRoute(uint8_t)':
    M:\PRJ - Domotics\arduino\libraries\MySensors\Relay.cpp:227: error: 'EEPROM' was not declared in this scope
    I'm able to compile other sketches on that environment.
    I didn't find that error on the forum, so I wondered if I had another Relay.h in my environment, which could conflict with yours, but it's not the case.
    Any idea?
    Thanks in advance for your help.
    Totony.
    • hekH Offline
      hekH Offline
      wrote on last edited by hek
      Looks like there are old 1.3 files in the MySensors folder. Did you really replace it and not just overwrite?
      Restart IDE after installing libraries.
      • T Offline
        T Offline
        Totony
        Thanks for the quick answer!
        I thought it was my first install of the lib, but I might have put it in my lib folder when I found out about MySensors.
        So I just extracted there and replaced conflict. I'll remove the MySensor folder and extract again.
        • T Offline
          T Offline
          Totony
          Fixed, thanks!!!!
