  3. 💬 4-channel switcher/dimmer
contest2017mysensorsdimmer
28 Posts 10 Posters 11.5k Views 9 Watching
  • HouseIOTH HouseIOT
    @hhalibo
    Check for neutral and phase connected right. I can see only one wire of load connected to X1. Other one must be connected to neutral if on X4.1 is phase. Otherwise try to reduce down to zero R5,7,9,11. May be not open the optocouplers.
    hhaliboH Offline
    hhaliboH Offline
    hhalibo
    @HouseIOT THANKS for rapid reply!
    I changed the resistor(r5) to 0 as pitcture shown, no function...
    HouseIOTH 1 Reply Last reply
    • hhaliboH hhalibo
      HouseIOTH Offline
      HouseIOTH Offline
      HouseIOT
      @hhalibo
      What supply voltage? 3.3V?..
      Usually if properly assembled, there should be no problems.
      hhaliboH 2 Replies Last reply
        @hhalibo
        hhaliboH Offline
        hhaliboH Offline
        hhalibo
        @HouseIOT supply voltage is 220v.
          @hhalibo
          hhaliboH Offline
          hhaliboH Offline
          hhalibo
          @HouseIOT Hi,in your schematics, the D1 is a DIODE, but in your BOM, D1 is nothing. Maybe the problem is here?
          • hhaliboH hhalibo
            HouseIOTH Offline
            HouseIOTH Offline
            HouseIOT
            @hhalibo said in 💬 4-channel switcher/dimmer:
            is 220v
            My English not so good, sorry. I say about low voltage on Atmega. There should be not less than 3.3v. If it is less then may not be enough current to open the optocoupler.
            D1 i not problem. The zero crossing detect works correctly. You see it on LEDs.
            hhaliboH 1 Reply Last reply
              is 220v
              hhaliboH Offline
              hhaliboH Offline
              hhalibo
              wrote on last edited by hhalibo
              #26
              @HouseIOT The voltage output from the AMS1117-3.3 is 3.29v, and the voltage of the JP1 (VCC & GND) is 3.29v.
              And when the V_PERCENTAGE is 100, the voltage input of the pin1&2 with OK2(3,4,5) is 0.825V.
              when V_PERCENTAGE is 30, the voltage input of the pin1&2 with OK2(3,4,5) is 0.25V.
              except the voltage input of OK(2,3,4,5) is definitely low,others seems OK.
              • hhaliboH Offline
                hhaliboH Offline
                hhalibo
                #27
                @HouseIOT
                I replaced the led1 with a 0Ω resistor, YEAH! Works!:laughing:
                and I will replace the led 2,3,4
                • hhaliboH Offline
                  hhaliboH Offline
                  hhalibo
                  #28
                  @HouseIOT Sorry to trouble you, i use a mysensors-wifi-gateway with protocol 2.1.1 , and my homeautomation is home-assistant. I can't use your dimmer in my system.
                  After read the reference, there need to add V-percentage and V-status in the code, as a newbie , I can't do it myself. So I wondered,can you do me a favor?
                  Thanks a lot.
