  3. Debug to a sd-card module?
28 Posts 8 Posters 9.4k Views 10 Watching
  • sundberg84S
    I have a hardware question for you!
    Problem:
    I need to protect the input of the bluetooth modules RX line (and also keep the ttl logic levels withing MIN/MAX as well)
    In the same time I want to be able to read data from both battery devices (say 2.0v) to 5v devices.
    @ 2.0 V you are way to close to a floating level which makes me a bit uncomfortable and @ 5v I will destroy the 3.3v input on the bluettoth module....
    A classic logic level converter should work for 5v to 3.3v, but I want to make one circuit that can handle also 2.0v to 3.3v - anyone that has an idea? I have ordered some Logic Level transistors to test... but if anyone can point me in any direction to create such a gate i would be happy...
    • NeverDieN
      NeverDieN
      #22
      I just noticed this thread, so sorry for jumping in late. However, regarding the OP, I use this:
      https://www.openhardware.io/view/273/ESP-LINK-ESP8266-WeMos-D1-Mini-Adapter-Board
      or, more lately, this:
      https://www.openhardware.io/view/443/nRF52832-ESP-LINK-Shield-for-ESP8266-Wemos-D1-Mini
      It's better than logging to an SD card, because you can see in real-time what is happening. Just open a putty terminal to the node and watch or come back later (anytime) to see what happened. With a lot of serial terminals, like Termite for instance, you can easily timestamp the serial output as well. Or, if you're only interested in seeing what's happened relatively recently, you can check directly by connecting directly to the node's serial console webpage. The nice thing too is that it all "just works." :) No extra coding required.
      • NeverDieN NeverDie
        #23
        @NeverDie - I have seen your projects and im sure they are very usefull, but as you can see above in the thread its been discussed with wifi/esp loggers. I looked at mentioned FTDI over Wifi.
        They have a great advantage in some areas but they do not fulfill my needs because I have nodes where I dont have wifi connection and they consume to much power to run on batteries for as long as i want.
        Just as the Wifi logger that just works, this module will be a one time upload and it will be able to write to a sd-card or Bluetooth (real time!) so no extra coding will be requiered here as well :)
        • NeverDieN
          NeverDieN
          Are you getting adequate range out of it?
            #25
            @NeverDie - What do you mean with Range - for bluetooth?
            My idea is to have one long term function and one short term, which is bluetooth. So for a "quick" look I would use the bluetooth module and for this I have not seen myself in need of alot of range. I wish to debug the node on-site and if there are errors I know why. I dont know the range exacly yet - but im sure its like normal bluetooth.
            With the more long term logging Im going to leave the logger at the node-site and let it be for a while - and evaluate the logs later to understand what im facing.
            • NeverDieN
              NeverDieN
              #26
              Not sure if it would matter to you or not, but the nRF51822-4 module is a very small and inexpensive module, and I would imagine it could be similarly programmed to behave the same as the bluetooth module you're using.
              Nice project!
                Nice project!
                @NeverDie didn't know! I will sure look into it. Thank you.
                • sundberg84S
                  Please use this thread for further discussion:
                  https://forum.mysensors.org/topic/8040/the-logger-machine-short-and-long-term-serial-logging
