  3. MyController.org
  4. Need volunteer to test dualboot OTA with MyController
Scheduled Pinned Locked Moved MyController.org
28 Posts 5 Posters 6.8k Views 6 Watching
    I have tried on another RPI with the updated branch and still have no communication, if I switch back to normal development branch I get communication back. Anything more I can try?
      @jkandasa I have managed to get FOTA do an update on the latest 2.2 but with a mod for rfm69 from tekka. I am having difficulties to trigger the OTA update even if a assign a different firmware to the node. Do you have any suggestion about this?
      J 1 Reply Last reply
        J
        J
        jkandasa
        @gohan What the issue are you facing? AFAIK, RFM69 supports only for DualOptiboot
          I'm using dual optiboot, the problem is that I was only able to trigger an ota on the node the first time I set it, after that the node is no longer starting a new ota transfer
            J
            J
            jkandasa
            @gohan Enable node debug log and trigger firmware update. Post node debug log.
            A few weeks before, I see an issue with the DualOptiboot firmware update. For some reason, if firmware update failed in between, and when we trigger firmware update once again, node says It is up to date.
              17 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.1-alpha
              26 TSM:INIT
              27 TSF:WUR:MS=10000
              29 RFM69:INIT
              30 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
              34 RFM69:PTX:LEVEL=5 dBm
              36 RFM69:INIT:HWV=36
              38 TSM:INIT:TSP OK
              40 TSF:SID:OK,ID=16
              43 TSM:FPAR
              44 RFM69:SWR:SEND,TO=255,RETRY=0
              47 RFM69:CSMA:RSSI=-109
              51 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              198 RFM69:SAC:SEND ACK,TO=0,RSSI=-44
              201 RFM69:CSMA:RSSI=-44
              210 RFM69:CSMA:RSSI=-109
              215 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              220 TSF:MSG:FPAR OK,ID=0,D=1
              2058 TSM:FPAR:OK
              2059 TSM:ID
              2060 TSM:ID:OK
              2062 TSM:UPL
              2063 RFM69:SWR:SEND,TO=0,RETRY=0
              2066 RFM69:CSMA:RSSI=-109
              2074 RFM69:SWR:ACK,FROM=0,SEQ=3,RSSI=-37
              2078 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=4
              2082 RFM69:PTX:LEVEL=4 dBm
              2084 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2091 RFM69:SAC:SEND ACK,TO=0,RSSI=-105
              2095 RFM69:CSMA:RSSI=-105
              2099 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2104 TSF:MSG:PONG RECV,HP=1
              2106 TSM:UPL:OK
              2108 TSM:READY:ID=16,PAR=0,DIS=1
              2111 RFM69:SWR:SEND,TO=0,RETRY=0
              2114 RFM69:CSMA:RSSI=-104
              2120 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-38
              2123 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=3
              2127 RFM69:PTX:LEVEL=3 dBm
              2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300
              2139 RFM69:SWR:SEND,TO=0,RETRY=0
              2142 RFM69:CSMA:RSSI=-109
              2152 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-36
              2155 RFM69:ATC:ADJ TXL,cR=-36,tR=-80,TXL=2
              2159 RFM69:PTX:LEVEL=2 dBm
              2162 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2168 RFM69:SAC:SEND ACK,TO=0,RSSI=-104
              2172 RFM69:CSMA:RSSI=-104
              2176 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2182 RFM69:SWR:SEND,TO=0,RETRY=0
              2185 RFM69:CSMA:RSSI=-89
              2196 RFM69:CSMA:RSSI=-105
              2398 !RFM69:SWR:NACK
              2399 RFM69:SWR:SEND,TO=0,RETRY=1
              2403 RFM69:CSMA:RSSI=-104
              2607 !RFM69:SWR:NACK
              2608 RFM69:SWR:SEND,TO=0,RETRY=2
              2612 RFM69:CSMA:RSSI=-107
              2816 !RFM69:SWR:NACK
              2817 RFM69:SWR:SEND,TO=0,RETRY=3
              2821 RFM69:CSMA:RSSI=-103
              2852 RFM69:SWR:ACK,FROM=0,SEQ=8,RSSI=-37
              2855 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=1
              2860 RFM69:PTX:LEVEL=1 dBm
              2862 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.2.1-alpha
              2870 RFM69:SWR:SEND,TO=0,RETRY=0
              2873 RFM69:CSMA:RSSI=-103
              2879 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-40
              2882 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=0
              2886 RFM69:PTX:LEVEL=0 dBm
              2889 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2962 RFM69:SAC:SEND ACK,TO=0,RSSI=-45
              2966 RFM69:CSMA:RSSI=-45
              2969 RFM69:CSMA:RSSI=-105
              2972 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
              2978 RFM69:SWR:SEND,TO=0,RETRY=0
              2981 RFM69:CSMA:RSSI=-106
              2990 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-40
              2994 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=-1
              2997 RFM69:PTX:LEVEL=-1 dBm
              3000 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:TEMP HUM dev
              3007 RFM69:SWR:SEND,TO=0,RETRY=0
              3010 RFM69:CSMA:RSSI=-102
              3016 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-39
              3020 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=-2
              3023 RFM69:PTX:LEVEL=-2 dBm
              3026 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
              3033 RFM69:SWR:SEND,TO=0,RETRY=0
              3036 RFM69:CSMA:RSSI=-106
              3043 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-42
              3047 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=-3
              3050 RFM69:PTX:LEVEL=-3 dBm
              3053 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              3059 RFM69:SWR:SEND,TO=0,RETRY=0
              3062 RFM69:CSMA:RSSI=-109
              3069 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-50
              3074 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-4
              3078 RFM69:PTX:LEVEL=-4 dBm
              3080 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              3086 RFM69:SWR:SEND,TO=0,RETRY=0
              3089 RFM69:CSMA:RSSI=-105
              3096 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-50
              3100 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-5
              3104 RFM69:PTX:LEVEL=-5 dBm
              3106 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
              3112 RFM69:SWR:SEND,TO=0,RETRY=0
              3116 RFM69:CSMA:RSSI=-107
              3123 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-51
              3127 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-6
              3131 RFM69:PTX:LEVEL=-6 dBm
              3133 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
              3139 RFM69:SWR:SEND,TO=0,RETRY=0
              3142 RFM69:CSMA:RSSI=-107
              3149 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-52
              3153 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-7
              3158 RFM69:PTX:LEVEL=-7 dBm
              3160 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
              3166 RFM69:SWR:SEND,TO=0,RETRY=0
              3169 RFM69:CSMA:RSSI=-107
              3176 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-53
              3180 RFM69:ATC:ADJ TXL,cR=-53,tR=-80,TXL=-8
              3184 RFM69:PTX:LEVEL=-8 dBm
              3186 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
              3192 MCO:REG:REQ
              3194 RFM69:SWR:SEND,TO=0,RETRY=0
              3197 RFM69:CSMA:RSSI=-109
              3208 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-54
              3212 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=-9
              3216 RFM69:PTX:LEVEL=-9 dBm
              3218 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              3225 RFM69:SAC:SEND ACK,TO=0,RSSI=-107
              3228 RFM69:CSMA:RSSI=-107
              3232 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              3237 MCO:PIM:NODE REG=1
              3239 MCO:BGN:STP
              3751 MCO:BGN:INIT OK,TSP=1
              4755 RFM69:SWR:SEND,TO=0,RETRY=0
              4758 RFM69:CSMA:RSSI=-103
              4767 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-56
              4771 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-10
              4775 RFM69:PTX:LEVEL=-10 dBm
              4777 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.40
              T: 20.40
              5286 RFM69:SWR:SEND,TO=0,RETRY=0
              5289 RFM69:CSMA:RSSI=-110
              5296 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-56
              5299 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-11
              5303 RFM69:PTX:LEVEL=-11 dBm
              5306 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.0
              H: 41
              5312 RFM69:SWR:SEND,TO=0,RETRY=0
              5316 RFM69:CSMA:RSSI=-106
              5322 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-57
              5326 RFM69:ATC:ADJ TXL,cR=-57,tR=-80,TXL=-12
              5330 RFM69:PTX:LEVEL=-12 dBm
              5334 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-56
              5840 RFM69:SWR:SEND,TO=0,RETRY=0
              5842 RFM69:CSMA:RSSI=-107
              5851 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-58
              5855 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-13
              5859 RFM69:PTX:LEVEL=-13 dBm
              5861 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-44
              6068 RFM69:SWR:SEND,TO=0,RETRY=0
              6071 RFM69:CSMA:RSSI=-108
              6081 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-58
              6084 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-14
              6088 RFM69:PTX:LEVEL=-14 dBm
              6091 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:16
              7099 RFM69:SWR:SEND,TO=0,RETRY=0
              7101 RFM69:CSMA:RSSI=-105
              7109 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-60
              7113 RFM69:ATC:ADJ TXL,cR=-60,tR=-80,TXL=-15
              7117 RFM69:PTX:LEVEL=-15 dBm
              7119 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
              7127 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
              7132 RFM69:SWR:SEND,TO=0,RETRY=0
              7135 RFM69:CSMA:RSSI=-107
              7142 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-61
              7146 RFM69:ATC:ADJ TXL,cR=-61,tR=-80,TXL=-16
              7150 RFM69:PTX:LEVEL=-16 dBm
              7152 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
              7659 TSF:TDI:TSL
              7660 RFM69:RSL
                26 TSM:INIT
                27 TSF:WUR:MS=10000
                29 RFM69:INIT
                38 TSM:INIT:TSP OK
                40 TSF:SID:OK,ID=16
                43 TSM:FPAR
                2058 TSM:FPAR:OK
                2059 TSM:ID
                2060 TSM:ID:OK
                2062 TSM:UPL
                2106 TSM:UPL:OK
                3192 MCO:REG:REQ
                3239 MCO:BGN:STP
                T: 20.40
                H: 41
                7659 TSF:TDI:TSL
                7660 RFM69:RSL
                J
                J
                jkandasa
                @gohan This node looks like sleeping node? Is it. I guess it won't walk up to update the entire firmware.
                And I do not see any response for this request 2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300. Is there any firmware assigned for this node in MyController?
                  There is, I have loaded 5 but none work, besides the first time that actually did started the ota transfer
