  3. MyController.org
  4. Need volunteer to test dualboot OTA with MyController
Scheduled Pinned Locked Moved MyController.org
28 Posts 5 Posters 6.9k Views 6 Watching
    Do I need to enable it in myconfig.h and recompile the rpi gateway?
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    @gohan yes, you can enable/add #define MY_DEBUG_VERBOSE_RFM69 in either myconfig.h or mysgw.cpp and recompile the RPI GW
      this is what I get on the gateway
      mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FB03611D231F849F600D211D822F762F6A2F
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-41
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500FA03
      mysgw: RFM69:SWR:SEND,TO=16,RETRY=0
      mysgw: !RFM69:SWR:NACK
      mysgw: RFM69:SWR:SEND,TO=16,RETRY=1
      mysgw: RFM69:SWR:SEND,TO=16,RETRY=2
      mysgw: RFM69:SWR:SEND,TO=16,RETRY=3
      mysgw: RFM69:SWR:SEND,TO=16,RETRY=4
      mysgw: RFM69:SWR:SEND,TO=16,RETRY=5
      mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FA03621F839FA00D611D221F749F3327A00D
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-55
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F903
      mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500F903829F2227B00DA11D621F739FB00DA11D
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-42
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F803
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=166,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F903829F2227B00DA11D621F739FB00DA11D
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=168,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F803F00DB11DAA1F649F6627B00DA11D661F
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-43
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F703
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=170,RSSI=-51
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=171,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F703629FF001729FBB27F00DB11D639FAA27
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F603
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=173,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F6030E94322070F3959FC1F3950F50E0551F
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-44
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F503
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=175,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F50311F00C940A200C94102011240C945520
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F403
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=177,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F40321200E94132038F00E941A2020F09523
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F303
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=179,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F303A6958FEF811D811D08950E94B01F0C94
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-45
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F203
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=181,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F203232B242B252B21F408950A2609F4A140
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-46
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F103
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=183,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F10398F0621B730B840B950B39F40A2661F0
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-47
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F003
      mysgw: RFM69:SWR:ACK,FROM=16,SEQ=185,RSSI=-51
      mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F0031706E807F907C0F012161306E407F507
      mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-48
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EF03
      mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EF030895990F0008550FAA0BE0E8FEEF1616
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EE03
      mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EE03660F771F881FDAF7880F9695879597F9
      mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500ED03
      I guess there is something wrong since the node is 3 meters away
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @gohan please also post the full node log + node sketch
          wrote on last edited by gohan
          This is node at boot even if I selected to upload firmware
          0 MCO:BGN:INIT NODE,CP=RPONA--X,VER=2.2.0-beta
          49 TSM:INIT
          51 TSF:WUR:MS=10000
          53 RFM69:INIT
          53 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
          59 RFM69:PTX:LEVEL=5 dBm
          61 TSM:INIT:TSP OK
          63 TSF:SID:OK,ID=16
          65 TSM:FPAR
          67 RFM69:SWR:SEND,TO=255,RETRY=0
          73 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          192 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          200 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          206 TSF:MSG:FPAR OK,ID=0,D=1
          405 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          413 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          2082 TSM:FPAR:OK
          2082 TSM:ID
          2084 TSM:ID:OK
          2086 TSM:UPL
          2088 RFM69:SWR:SEND,TO=0,RETRY=0
          2103 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-47
          2107 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=4
          2111 RFM69:PTX:LEVEL=4 dBm
          2113 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          2121 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          2129 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          2136 TSF:MSG:PONG RECV,HP=1
          2138 TSM:UPL:OK
          2140 TSM:READY:ID=16,PAR=0,DIS=1
          2144 RFM69:SWR:SEND,TO=0,RETRY=0
          2355 !RFM69:SWR:NACK
          2357 RFM69:PTX:LEVEL=5 dBm
          2400 RFM69:SWR:SEND,TO=0,RETRY=1
          2609 !RFM69:SWR:NACK
          2611 RFM69:PTX:LEVEL=6 dBm
          2654 RFM69:SWR:SEND,TO=0,RETRY=2
          2863 !RFM69:SWR:NACK
          2865 RFM69:PTX:LEVEL=7 dBm
          2899 RFM69:SWR:SEND,TO=0,RETRY=3
          3108 !RFM69:SWR:NACK
          3110 RFM69:PTX:LEVEL=8 dBm
          3121 RFM69:SWR:SEND,TO=0,RETRY=4
          3330 !RFM69:SWR:NACK
          3332 RFM69:PTX:LEVEL=9 dBm
          3375 RFM69:SWR:SEND,TO=0,RETRY=5
          3457 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-44
          3461 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
          3465 RFM69:PTX:LEVEL=8 dBm
          3467 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
          3477 RFM69:SWR:SEND,TO=0,RETRY=0
          3491 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-45
          3495 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=7
          3500 RFM69:PTX:LEVEL=7 dBm
          3502 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          3510 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          3518 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          3524 RFM69:SWR:SEND,TO=0,RETRY=0
          3735 !RFM69:SWR:NACK
          3737 RFM69:PTX:LEVEL=8 dBm
          3747 RFM69:SWR:SEND,TO=0,RETRY=1
          3956 !RFM69:SWR:NACK
          3958 RFM69:PTX:LEVEL=9 dBm
          4001 RFM69:SWR:SEND,TO=0,RETRY=2
          4210 !RFM69:SWR:NACK
          4212 RFM69:PTX:LEVEL=10 dBm
          4255 RFM69:SWR:SEND,TO=0,RETRY=3
          4464 !RFM69:SWR:NACK
          4466 RFM69:PTX:LEVEL=11 dBm
          4501 RFM69:SWR:SEND,TO=0,RETRY=4
          4710 !RFM69:SWR:NACK
          4712 RFM69:PTX:LEVEL=12 dBm
          4722 RFM69:SWR:SEND,TO=0,RETRY=5
          4909 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-43
          4913 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
          4917 RFM69:PTX:LEVEL=11 dBm
          4919 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
          4929 RFM69:SWR:SEND,TO=0,RETRY=0
          4943 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-43
          4947 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
          4952 RFM69:PTX:LEVEL=10 dBm
          4954 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          5584 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          5593 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          5599 RFM69:SWR:SEND,TO=0,RETRY=0
          5810 !RFM69:SWR:NACK
          5812 RFM69:PTX:LEVEL=11 dBm
          5855 RFM69:SWR:SEND,TO=0,RETRY=1
          6064 !RFM69:SWR:NACK
          6066 RFM69:PTX:LEVEL=12 dBm
          6100 RFM69:SWR:SEND,TO=0,RETRY=2
          6309 !RFM69:SWR:NACK
          6311 RFM69:PTX:LEVEL=13 dBm
          6322 RFM69:SWR:SEND,TO=0,RETRY=3
          6531 !RFM69:SWR:NACK
          6533 RFM69:PTX:NO ADJ
          6576 RFM69:SWR:SEND,TO=0,RETRY=4
          6785 !RFM69:SWR:NACK
          6787 RFM69:PTX:NO ADJ
          6830 RFM69:SWR:SEND,TO=0,RETRY=5
          6950 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-42
          6955 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=12
          6961 RFM69:PTX:LEVEL=12 dBm
          6963 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
          6971 RFM69:SWR:SEND,TO=0,RETRY=0
          6985 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-43
          6989 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
          6995 RFM69:PTX:LEVEL=11 dBm
          6998 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
          7006 RFM69:SWR:SEND,TO=0,RETRY=0
          7020 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-43
          7024 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
          7030 RFM69:PTX:LEVEL=10 dBm
          7032 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          7041 RFM69:SWR:SEND,TO=0,RETRY=0
          7055 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-43
          7061 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=9
          7065 RFM69:PTX:LEVEL=9 dBm
          7067 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
          7075 RFM69:SWR:SEND,TO=0,RETRY=0
          7090 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-44
          7096 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
          7100 RFM69:PTX:LEVEL=8 dBm
          7102 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
          7110 RFM69:SWR:SEND,TO=0,RETRY=0
          7127 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
          7131 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=7
          7135 RFM69:PTX:LEVEL=7 dBm
          7139 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
          7145 RFM69:SWR:SEND,TO=0,RETRY=0
          7163 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-51
          7168 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=6
          7172 RFM69:PTX:LEVEL=6 dBm
          7174 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
          7182 RFM69:SWR:SEND,TO=0,RETRY=0
          7198 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-45
          7202 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=5
          7206 RFM69:PTX:LEVEL=5 dBm
          7211 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
          7219 MCO:REG:REQ
          7219 RFM69:SWR:SEND,TO=0,RETRY=0
          7235 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-49
          7239 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=4
          7243 RFM69:PTX:LEVEL=4 dBm
          7247 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          7254 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
          7262 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          7268 MCO:PIM:NODE REG=1
          7272 MCO:BGN:STP
          7784 MCO:BGN:INIT OK,TSP=1
          7786 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          7794 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          7800 MCO:PIM:NODE REG=1
          8804 RFM69:SWR:SEND,TO=0,RETRY=0
          8822 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-48
          8826 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=3
          8833 RFM69:PTX:LEVEL=3 dBm
          8835 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.62
          T: 19.62
          9345 RFM69:SWR:SEND,TO=0,RETRY=0
          9361 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-51
          9365 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=2
          9369 RFM69:PTX:LEVEL=2 dBm
          9373 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0
          H: 47
          9381 RFM69:SWR:SEND,TO=0,RETRY=0
          9396 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-49
          9400 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=1
          9406 RFM69:PTX:LEVEL=1 dBm
          9408 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-51
          9916 RFM69:SWR:SEND,TO=0,RETRY=0
          9934 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-50
          9938 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=0
          9943 RFM69:PTX:LEVEL=0 dBm
          9947 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-52
          10156 RFM69:SWR:SEND,TO=0,RETRY=0
          10168 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-51
          10172 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-1
          10178 RFM69:PTX:LEVEL=-1 dBm
          10180 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:58
          11190 RFM69:SWR:SEND,TO=0,RETRY=0
          11206 RFM69:SWR:ACK,FROM=0,SEQ=28,RSSI=-51
          11212 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-2
          11216 RFM69:PTX:LEVEL=-2 dBm
          11220 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
          11229 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
          11235 RFM69:SWR:SEND,TO=0,RETRY=0
          11253 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-52
          11257 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-3
          11261 RFM69:PTX:LEVEL=-3 dBm
          11266 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
          11450 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
          11458 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
          11776 TSF:TDI:TSL
          11778 RFM69:RSL
          Sketch
          #include <Adafruit_SHT31.h>
          #include <Adafruit_Sensor.h>
          #define MY_DEBUG  // Enable debug prints
          //#define MY_RADIO_NRF24
          #define MY_RADIO_RFM69
          #define MY_RFM69_FREQUENCY RFM69_433MHZ
          #define MY_RFM69_NEW_DRIVER
          //#define MY_IS_RFM69HW
          #define MY_TRANSPORT_WAIT_READY_MS 10000
          //#define MY_NODE_ID 16
          #define VBAT_VCC
          //Enable OTA feature
          #define MY_OTA_FIRMWARE_FEATURE
          #define MY_OTA_FLASH_JDECID 0x00
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define CHILD_ID_VBAT 201						 // Battery voltage
          unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
          #define SKETCH_NAME "TEMP HUM"                // Change to a fancy name you like
          #define SKETCH_VERSION "1.2"                    // Your version
          float lastTemp;
          float lastHum;
          boolean metric = true;
          MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE);
          Adafruit_SHT31 sht31 = Adafruit_SHT31();
          #ifdef MY_RADIO_RFM69
          	int rssi;                                    // RSSI RFM69 chip
          	#define CHILD_ID_RSSI_HIGH  202                // RSSI received signal level
          	#define CHILD_ID_RSSI_LOW   203                // RSSI background noise level
            #define CHILD_ID_POWER 204
          	MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_LEVEL);
          	MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_LEVEL);
            MyMessage msgPWR(CHILD_ID_POWER, V_LIGHT_LEVEL);
          //#define VBAT_PER_BITS 0.005448028                 //
          #define VMIN 2.8                                  //  Vmin (radio Min Volt)=1.9V (564v)
          #define VMAX 3.4                                 //  Vmax = (2xAA bat)=3.0V (892v)
          int batteryPcnt , PwrPcnt = 0;                    // Calc value for battery %
          #ifdef VBAT_VCC
          #include <Vcc.h>
          	const float VccCorrection = 1.0 / 1.0;  // Measured Vcc by multimeter divided by reported Vcc
          	Vcc vcc(VccCorrection);
          #endif // VBAT_VCC
          	// metric = getControllerConfig().isMetric;
          	if (!sht31.begin(0x44)) {   // Set to 0x45 for alternate i2c addr
          		Serial.println("Couldn't find SHT31");
          		//while (1) delay(1);
          	present(CHILD_ID_HUM, S_HUM);
          	present(CHILD_ID_RSSI_HIGH, S_SOUND);
          	present(CHILD_ID_RSSI_LOW, S_SOUND);
            present(CHILD_ID_POWER, S_LIGHT_LEVEL);
          	present(CHILD_ID_VBAT, S_MULTIMETER);
            if (!isFirmwareUpdateOngoing())
          	// Fetch temperatures from SHT sensor
          	float temperature = sht31.readTemperature();
          	//temperature = round(temperature*10)/10; //round to 1 decimal place
          	if (isnan(temperature)) {
          		Serial.println("Failed reading temperature from SHT31");
          	else if (temperature != lastTemp) {
          		lastTemp = temperature;
          		send(msgTemp.set(temperature, 2));
          		Serial.print("T: ");
          	// Fetch humidity from SHT sensor
          	uint8_t humidity = sht31.readHumidity();
          	if (isnan(humidity)) {
          		Serial.println("Failed reading humidity from SHT");
          	else if (humidity != lastHum) {
          		lastHum = humidity;
          		Serial.print("H: ");
          		Serial.println(humidity);
          	rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
          	send(msgRSSI1.set(rssi));                  // send RSSI level
          	wait(500);                                 // wait to get idle
          	rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
          	send(msgRSSI2.set(rssi));                  // send RSSI level
           	wait(200);                                 // wait for next send
            PwrPcnt = RFM69_getTxPowerPercent();      // read TX Power in RFM69
            send(msgPWR.set(PwrPcnt));            // send TX Power
          	batM();
          	smartSleep(SLEEP_TIME); //sleep a bit
          	delay(500);
          	float Vbat;
          	int batteryPcnt;
            	// Battery monitoring reading
          #ifdef VBAT_VCC
          	Vbat = vcc.Read_Volts();
          	batteryPcnt = vcc.Read_Perc(VMIN, VMAX);
          	Vbat = (sensorValue * VBAT_PER_BITS) - 0.2 ;
          	// Calculate the battery in %
          	batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
            delay(500);
          	send(msgVBat.set(Vbat, 2));
          	//Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
          	if (batLoop > 2) {
          		if (batteryPcnt > 100) {
          			batteryPcnt = 100;
          		batLoop = 0;
          		batLoop++;
            Here is the firmware upload that finally I managed to start, of course I only cut the first part
            49 TSM:INIT
            51 TSF:WUR:MS=10000
            53 RFM69:INIT
            61 TSM:INIT:TSP OK
            63 TSF:SID:OK,ID=16
            65 TSM:FPAR
            126 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            133 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            139 TSF:MSG:FPAR OK,ID=0,D=1
            337 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            344 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            2082 TSM:FPAR:OK
            2082 TSM:ID
            2084 TSM:ID:OK
            2086 TSM:UPL
            2105 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-44
            2109 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=4
            2113 RFM69:PTX:LEVEL=4 dBm
            2117 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2123 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            2131 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2138 TSF:MSG:PONG RECV,HP=1
            2142 TSM:UPL:OK
            2144 TSM:READY:ID=16,PAR=0,DIS=1
            2146 RFM69:SWR:SEND,TO=0,RETRY=0
            2168 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-43
            2172 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
            2177 RFM69:PTX:LEVEL=3 dBm
            2181 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
            2191 RFM69:SWR:SEND,TO=0,RETRY=0
            2205 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-44
            2209 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
            2213 RFM69:PTX:LEVEL=2 dBm
            2217 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2224 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            2232 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2240 RFM69:SWR:SEND,TO=0,RETRY=0
            2258 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-45
            2263 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=1
            2269 RFM69:PTX:LEVEL=1 dBm
            2271 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
            2279 RFM69:SWR:SEND,TO=0,RETRY=0
            2295 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-71
            2299 RFM69:ATC:ADJ TXL,cR=-71,tR=-80,TXL=0
            2304 RFM69:PTX:LEVEL=0 dBm
            2308 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2334 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
            2342 TSF:MSG:READ,0-0-16,s=255,c=4,t=1,pt=6,l=8,sg=0:02000400600466EF
            2351 OTA:FWP:UPDATE
            2467 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
            2471 RFM69:SWR:SEND,TO=0,RETRY=0
            2682 !RFM69:SWR:NACK
            2684 RFM69:PTX:LEVEL=1 dBm
            2719 RFM69:SWR:SEND,TO=0,RETRY=1
            2928 !RFM69:SWR:NACK
            2930 RFM69:PTX:LEVEL=2 dBm
            2965 RFM69:SWR:SEND,TO=0,RETRY=2
            3174 !RFM69:SWR:NACK
            3176 RFM69:PTX:LEVEL=3 dBm
            3186 RFM69:SWR:SEND,TO=0,RETRY=3
            3395 !RFM69:SWR:NACK
            3397 RFM69:PTX:LEVEL=4 dBm
            3440 RFM69:SWR:SEND,TO=0,RETRY=4
            3649 !RFM69:SWR:NACK
            3651 RFM69:PTX:LEVEL=5 dBm
            3694 RFM69:SWR:SEND,TO=0,RETRY=5
            3903 !RFM69:SWR:NACK
            3905 RFM69:PTX:LEVEL=6 dBm
            3940 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005F04
            3948 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            3956 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            3962 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
            3966 RFM69:SWR:SEND,TO=0,RETRY=0
            4177 !RFM69:SWR:NACK
            4179 RFM69:PTX:LEVEL=7 dBm
            4190 RFM69:SWR:SEND,TO=0,RETRY=1
            4399 !RFM69:SWR:NACK
            4401 RFM69:PTX:LEVEL=8 dBm
            4435 RFM69:SWR:SEND,TO=0,RETRY=2
            4644 !RFM69:SWR:NACK
            4646 RFM69:PTX:LEVEL=9 dBm
            4657 RFM69:SWR:SEND,TO=0,RETRY=3
            4866 !RFM69:SWR:NACK
            4868 RFM69:PTX:LEVEL=10 dBm
            4911 RFM69:SWR:SEND,TO=0,RETRY=4
            5046 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-39
            5050 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=9
            5054 RFM69:PTX:LEVEL=9 dBm
            5058 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005F04
            5066 RFM69:SWR:SEND,TO=0,RETRY=0
            5083 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-63
            5087 RFM69:ATC:ADJ TXL,cR=-63,tR=-80,TXL=8
            5091 RFM69:PTX:LEVEL=8 dBm
            5093 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
            5103 RFM69:SWR:SEND,TO=0,RETRY=0
            5310 !RFM69:SWR:NACK
            5312 RFM69:PTX:LEVEL=9 dBm
            5347 RFM69:SWR:SEND,TO=0,RETRY=1
            5554 !RFM69:SWR:NACK
            5556 RFM69:PTX:LEVEL=10 dBm
            5599 RFM69:SWR:SEND,TO=0,RETRY=2
            5806 !RFM69:SWR:NACK
            5808 RFM69:PTX:LEVEL=11 dBm
            5842 RFM69:SWR:SEND,TO=0,RETRY=3
            6049 !RFM69:SWR:NACK
            6051 RFM69:PTX:LEVEL=12 dBm
            6062 RFM69:SWR:SEND,TO=0,RETRY=4
            6268 !RFM69:SWR:NACK
            6270 RFM69:PTX:LEVEL=13 dBm
            6305 RFM69:SWR:SEND,TO=0,RETRY=5
            6512 !RFM69:SWR:NACK
            6514 RFM69:PTX:NO ADJ
            6549 !TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.2
            6557 RFM69:SWR:SEND,TO=0,RETRY=0
            6580 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
            6584 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
            6588 RFM69:PTX:LEVEL=12 dBm
            6590 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
            6598 RFM69:SWR:SEND,TO=0,RETRY=0
            6615 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-37
            6619 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=11
            6623 RFM69:PTX:LEVEL=11 dBm
            6627 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
            6633 RFM69:SWR:SEND,TO=0,RETRY=0
            6651 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-38
            6656 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=10
            6660 RFM69:PTX:LEVEL=10 dBm
            6662 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
            6670 RFM69:SWR:SEND,TO=0,RETRY=0
            6686 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-48
            6692 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=9
            6696 RFM69:PTX:LEVEL=9 dBm
            6699 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
            6707 RFM69:SWR:SEND,TO=0,RETRY=0
            6723 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-48
            6729 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=8
            6733 RFM69:PTX:LEVEL=8 dBm
            6735 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
            6744 RFM69:SWR:SEND,TO=0,RETRY=0
            6760 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-40
            6764 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=7
            6770 RFM69:PTX:LEVEL=7 dBm
            6772 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
            6780 MCO:REG:REQ
            6782 RFM69:SWR:SEND,TO=0,RETRY=0
            6797 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-49
            6801 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=6
            6807 RFM69:PTX:LEVEL=6 dBm
            6809 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            6817 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
            6825 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            6832 MCO:PIM:NODE REG=1
            6834 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
            6838 RFM69:SWR:SEND,TO=0,RETRY=0
            6862 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-42
            6866 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
            6871 RFM69:PTX:LEVEL=5 dBm
            6873 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005F04
            6883 MCO:BGN:STP
            7395 MCO:BGN:INIT OK,TSP=1
            7397 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            7405 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005F04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            7415 OTA:FWP:RECV B=045F
            7419 OTA:FRQ:FW REQ,T=0002,V=0004,B=045E
            7424 RFM69:SWR:SEND,TO=0,RETRY=0
            7440 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-43
            7446 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
            7450 RFM69:PTX:LEVEL=4 dBm
            7452 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005E04
            7512 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            7520 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005E04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            7530 OTA:FWP:RECV B=045E
            7534 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
            7538 RFM69:SWR:SEND,TO=0,RETRY=0
            7555 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-44
            7561 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
            7565 RFM69:PTX:LEVEL=3 dBm
            7567 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
            8036 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
            8040 RFM69:SWR:SEND,TO=0,RETRY=0
            8249 !RFM69:SWR:NACK
            8251 RFM69:PTX:LEVEL=4 dBm
            8286 RFM69:SWR:SEND,TO=0,RETRY=1
            8495 !RFM69:SWR:NACK
            8497 RFM69:PTX:LEVEL=5 dBm
            8531 RFM69:SWR:SEND,TO=0,RETRY=2
            8740 !RFM69:SWR:NACK
            8742 RFM69:PTX:LEVEL=6 dBm
            8753 RFM69:SWR:SEND,TO=0,RETRY=3
            8962 !RFM69:SWR:NACK
            8964 RFM69:PTX:LEVEL=7 dBm
            9007 RFM69:SWR:SEND,TO=0,RETRY=4
            9029 RFM69:SWR:ACK,FROM=0,SEQ=30,RSSI=-41
            9033 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=6
            9037 RFM69:PTX:LEVEL=6 dBm
            9039 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
            9050 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
            9054 RFM69:SWR:SEND,TO=0,RETRY=0
            9074 RFM69:SWR:ACK,FROM=0,SEQ=31,RSSI=-42
            9078 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
            9082 RFM69:PTX:LEVEL=5 dBm
            9086 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
            9127 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            9136 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9146 OTA:FWP:RECV B=045D
            9148 OTA:FRQ:FW REQ,T=0002,V=0004,B=045C
            9152 RFM69:SWR:SEND,TO=0,RETRY=0
            9172 RFM69:SWR:ACK,FROM=0,SEQ=33,RSSI=-43
            9177 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
            9181 RFM69:PTX:LEVEL=4 dBm
            9183 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005C04
            9234 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            9242 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9252 OTA:FWP:RECV B=045D
            9254 !OTA:FWP:WRONG FWB
            9451 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
            9459 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9469 OTA:FWP:RECV B=045D
            9472 !OTA:FWP:WRONG FWB
            9480 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            9488 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005C04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9500 OTA:FWP:RECV B=045C
            9502 OTA:FRQ:FW REQ,T=0002,V=0004,B=045B
            9506 RFM69:SWR:SEND,TO=0,RETRY=0
            9525 RFM69:SWR:ACK,FROM=0,SEQ=37,RSSI=-44
            9529 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
            9533 RFM69:PTX:LEVEL=3 dBm
            9537 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005B04
            9637 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            9646 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005B04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9658 OTA:FWP:RECV B=045B
            9660 OTA:FRQ:FW REQ,T=0002,V=0004,B=045A
            9664 RFM69:SWR:SEND,TO=0,RETRY=0
            9682 RFM69:SWR:ACK,FROM=0,SEQ=39,RSSI=-44
            9687 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
            9691 RFM69:PTX:LEVEL=2 dBm
            9695 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005A04
            9725 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            9734 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005A04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9744 OTA:FWP:RECV B=045A
            9746 OTA:FRQ:FW REQ,T=0002,V=0004,B=0459
            9750 RFM69:SWR:SEND,TO=0,RETRY=0
            9768 RFM69:SWR:ACK,FROM=0,SEQ=41,RSSI=-46
            9775 RFM69:ATC:ADJ TXL,cR=-46,tR=-80,TXL=1
            9779 RFM69:PTX:LEVEL=1 dBm
            9781 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005904
            9834 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            9842 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005904FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9854 OTA:FWP:RECV B=0459
            9857 OTA:FRQ:FW REQ,T=0002,V=0004,B=0458
            9861 RFM69:SWR:SEND,TO=0,RETRY=0
            9879 RFM69:SWR:ACK,FROM=0,SEQ=43,RSSI=-48
            9883 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=0
            9889 RFM69:PTX:LEVEL=0 dBm
            9891 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005804
            9934 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
            9943 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005804FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            9953 OTA:FWP:RECV B=0458
            9957 OTA:FRQ:FW REQ,T=0002,V=0004,B=0457
            9961 RFM69:SWR:SEND,TO=0,RETRY=0
            9979 RFM69:SWR:ACK,FROM=0,SEQ=45,RSSI=-47
            9984 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=-1
            9988 RFM69:PTX:LEVEL=-1 dBm
            9992 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005704
            10043 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            10051 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005704250054454D502048554D00312E310000
            10061 OTA:FWP:RECV B=0457
            10065 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
            10070 RFM69:SWR:SEND,TO=0,RETRY=0
            10280 !RFM69:SWR:NACK
            10283 RFM69:PTX:LEVEL=0 dBm
            10317 RFM69:SWR:SEND,TO=0,RETRY=1
            10526 !RFM69:SWR:NACK
            10528 RFM69:PTX:LEVEL=1 dBm
            10530 RFM69:SWR:SEND,TO=0,RETRY=2
            10741 !RFM69:SWR:NACK
            10743 RFM69:PTX:LEVEL=2 dBm
            10786 RFM69:SWR:SEND,TO=0,RETRY=3
            10995 !RFM69:SWR:NACK
            10997 RFM69:PTX:LEVEL=3 dBm
            11040 RFM69:SWR:SEND,TO=0,RETRY=4
            11249 !RFM69:SWR:NACK
            11251 RFM69:PTX:LEVEL=4 dBm
            11294 RFM69:SWR:SEND,TO=0,RETRY=5
            11468 RFM69:SWR:ACK,FROM=0,SEQ=47,RSSI=-43
            11472 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
            11476 RFM69:PTX:LEVEL=3 dBm
            11481 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
            11489 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
            11493 RFM69:SWR:SEND,TO=0,RETRY=0
            11513 RFM69:SWR:ACK,FROM=0,SEQ=48,RSSI=-87
            11520 RFM69:ATC:ADJ TXL,cR=-87,tR=-80,TXL=4
            11524 RFM69:PTX:LEVEL=4 dBm
            11526 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
            11536 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            11544 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
            11554 OTA:FWP:RECV B=0456
            11558 OTA:FRQ:FW REQ,T=0002,V=0004,B=0455
            11563 RFM69:SWR:SEND,TO=0,RETRY=0
            11581 RFM69:SWR:ACK,FROM=0,SEQ=50,RSSI=-44
            11585 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
            11589 RFM69:PTX:LEVEL=3 dBm
            11593 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005504
            11741 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            11749 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
            11761 OTA:FWP:RECV B=0456
            11763 !OTA:FWP:WRONG FWB
            11833 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
            11841 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040055045400483A200042617474657279204176
            11851 OTA:FWP:RECV B=0455
            11855 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
            11859 RFM69:SWR:SEND,TO=0,RETRY=0
            12070 !RFM69:SWR:NACK
            12072 RFM69:PTX:LEVEL=4 dBm
            12083 RFM69:SWR:SEND,TO=0,RETRY=1
            12294 !RFM69:SWR:NACK
            12296 RFM69:PTX:LEVEL=5 dBm
            12339 RFM69:SWR:SEND,TO=0,RETRY=2
            12548 !RFM69:SWR:NACK
            12550 RFM69:PTX:LEVEL=6 dBm
            12593 RFM69:SWR:SEND,TO=0,RETRY=3
            12802 !RFM69:SWR:NACK
            12804 RFM69:PTX:LEVEL=7 dBm
            12847 RFM69:SWR:SEND,TO=0,RETRY=4
            13056 !RFM69:SWR:NACK
            13058 RFM69:PTX:LEVEL=8 dBm
            13092 RFM69:SWR:SEND,TO=0,RETRY=5
            13273 RFM69:SWR:ACK,FROM=0,SEQ=53,RSSI=-41
            13277 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=7
            13283 RFM69:PTX:LEVEL=7 dBm
            13285 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
            13293 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
            13299 RFM69:SWR:SEND,TO=0,RETRY=0
            13320 RFM69:SWR:ACK,FROM=0,SEQ=54,RSSI=-42
            13324 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=6
            13330 RFM69:PTX:LEVEL=6 dBm
            13332 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
            13342 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            13350 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
            13361 OTA:FWP:RECV B=0454
            13365 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
            13369 RFM69:SWR:SEND,TO=0,RETRY=0
            13580 !RFM69:SWR:NACK
            13582 RFM69:PTX:LEVEL=7 dBm
            13584 RFM69:SWR:SEND,TO=0,RETRY=1
            13795 !RFM69:SWR:NACK
            13797 RFM69:PTX:LEVEL=8 dBm
            13807 RFM69:SWR:SEND,TO=0,RETRY=2
            14016 !RFM69:SWR:NACK
            14018 RFM69:PTX:LEVEL=9 dBm
            14053 RFM69:SWR:SEND,TO=0,RETRY=3
            14262 !RFM69:SWR:NACK
            14264 RFM69:PTX:LEVEL=10 dBm
            14307 RFM69:SWR:SEND,TO=0,RETRY=4
            14516 !RFM69:SWR:NACK
            14518 RFM69:PTX:LEVEL=11 dBm
            14561 RFM69:SWR:SEND,TO=0,RETRY=5
            14770 !RFM69:SWR:NACK
            14772 RFM69:PTX:LEVEL=12 dBm
            14815 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005304
            14823 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            14831 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
            14841 OTA:FWP:RECV B=0454
            14845 !OTA:FWP:WRONG FWB
            14848 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
            14852 RFM69:SWR:SEND,TO=0,RETRY=0
            15063 !RFM69:SWR:NACK
            15065 RFM69:PTX:LEVEL=13 dBm
            15075 RFM69:SWR:SEND,TO=0,RETRY=1
            15284 !RFM69:SWR:NACK
            15286 RFM69:PTX:NO ADJ
            15329 RFM69:SWR:SEND,TO=0,RETRY=2
            15538 !RFM69:SWR:NACK
            15540 RFM69:PTX:NO ADJ
            15583 RFM69:SWR:SEND,TO=0,RETRY=3
            15792 !RFM69:SWR:NACK
            15794 RFM69:PTX:NO ADJ
            15828 RFM69:SWR:SEND,TO=0,RETRY=4
            16037 !RFM69:SWR:NACK
            16039 RFM69:PTX:NO ADJ
            16050 RFM69:SWR:SEND,TO=0,RETRY=5
            16191 RFM69:SWR:ACK,FROM=0,SEQ=58,RSSI=-39
            16195 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
            16201 RFM69:PTX:LEVEL=12 dBm
            16203 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005304
            16214 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            16222 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
            16232 OTA:FWP:RECV B=0453
            16234 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
            16240 RFM69:SWR:SEND,TO=0,RETRY=0
            16449 !RFM69:SWR:NACK
            16451 RFM69:PTX:LEVEL=13 dBm
            16494 RFM69:SWR:SEND,TO=0,RETRY=1
            16703 !RFM69:SWR:NACK
            16705 RFM69:PTX:NO ADJ
            16740 RFM69:SWR:SEND,TO=0,RETRY=2
            16949 !RFM69:SWR:NACK
            16951 RFM69:PTX:NO ADJ
            16994 RFM69:SWR:SEND,TO=0,RETRY=3
            17203 !RFM69:SWR:NACK
            17205 RFM69:PTX:NO ADJ
            17248 RFM69:SWR:SEND,TO=0,RETRY=4
            17457 !RFM69:SWR:NACK
            17459 RFM69:PTX:NO ADJ
            17502 RFM69:SWR:SEND,TO=0,RETRY=5
            17625 RFM69:SWR:ACK,FROM=0,SEQ=60,RSSI=-39
            17631 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
            17635 RFM69:PTX:LEVEL=12 dBm
            17637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
            17647 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            17655 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
            17666 OTA:FWP:RECV B=0453
            17668 !OTA:FWP:WRONG FWB
            17672 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
            17676 RFM69:SWR:SEND,TO=0,RETRY=0
            17690 RFM69:SWR:ACK,FROM=0,SEQ=62,RSSI=-39
            17694 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=11
            17700 RFM69:PTX:LEVEL=11 dBm
            17702 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
            17731 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            17739 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
            17750 OTA:FWP:RECV B=0452
            17754 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
            17758 RFM69:SWR:SEND,TO=0,RETRY=0
            17969 !RFM69:SWR:NACK
            17971 RFM69:PTX:LEVEL=12 dBm
            18014 RFM69:SWR:SEND,TO=0,RETRY=1
            18223 !RFM69:SWR:NACK
            18225 RFM69:PTX:LEVEL=13 dBm
            18259 RFM69:SWR:SEND,TO=0,RETRY=2
            18468 !RFM69:SWR:NACK
            18470 RFM69:PTX:NO ADJ
            18481 RFM69:SWR:SEND,TO=0,RETRY=3
            18690 !RFM69:SWR:NACK
            18692 RFM69:PTX:NO ADJ
            18735 RFM69:SWR:SEND,TO=0,RETRY=4
            18944 !RFM69:SWR:NACK
            18946 RFM69:PTX:NO ADJ
            18980 RFM69:SWR:SEND,TO=0,RETRY=5
            19079 RFM69:SWR:ACK,FROM=0,SEQ=64,RSSI=-39
            19085 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
            19089 RFM69:PTX:LEVEL=12 dBm
            19091 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
            19101 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            19109 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
            19120 OTA:FWP:RECV B=0452
            19124 !OTA:FWP:WRONG FWB
            19126 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
            19130 RFM69:SWR:SEND,TO=0,RETRY=0
            19341 !RFM69:SWR:NACK
            19343 RFM69:PTX:LEVEL=13 dBm
            19345 RFM69:SWR:SEND,TO=0,RETRY=1
            19556 !RFM69:SWR:NACK
            19558 RFM69:PTX:NO ADJ
            19568 RFM69:SWR:SEND,TO=0,RETRY=2
            19777 !RFM69:SWR:NACK
            19779 RFM69:PTX:NO ADJ
            19822 RFM69:SWR:SEND,TO=0,RETRY=3
            20031 !RFM69:SWR:NACK
            20033 RFM69:PTX:NO ADJ
            20068 RFM69:SWR:SEND,TO=0,RETRY=4
            20277 !RFM69:SWR:NACK
            20279 RFM69:PTX:NO ADJ
            20322 RFM69:SWR:SEND,TO=0,RETRY=5
            20482 RFM69:SWR:ACK,FROM=0,SEQ=66,RSSI=-39
            20486 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
            20490 RFM69:PTX:LEVEL=12 dBm
            20494 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
            20502 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
            20510 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040051046D70657261747572652066726F6D2053
            20520 OTA:FWP:RECV B=0451
            20525 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
            20529 RFM69:SWR:SEND,TO=0,RETRY=0
            20740 !RFM69:SWR:NACK
            20742 RFM69:PTX:LEVEL=13 dBm
            20785 RFM69:SWR:SEND,TO=0,RETRY=1
            20994 !RFM69:SWR:NACK
            20996 RFM69:PTX:NO ADJ
            21039 RFM69:SWR:SEND,TO=0,RETRY=2
            21248 !RFM69:SWR:NACK
            21250 RFM69:PTX:NO ADJ
            21284 RFM69:SWR:SEND,TO=0,RETRY=3
            21493 !RFM69:SWR:NACK
            21495 RFM69:PTX:NO ADJ
            21538 RFM69:SWR:SEND,TO=0,RETRY=4
            21747 !RFM69:SWR:NACK
            21749 RFM69:PTX:NO ADJ
            21792 RFM69:SWR:SEND,TO=0,RETRY=5
            21884 RFM69:SWR:ACK,FROM=0,SEQ=68,RSSI=-37
            21889 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
            21895 RFM69:PTX:LEVEL=12 dBm
            21897 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
            21907 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
            21911 RFM69:SWR:SEND,TO=0,RETRY=0
            22122 !RFM69:SWR:NACK
            22124 RFM69:PTX:LEVEL=13 dBm
            22159 RFM69:SWR:SEND,TO=0,RETRY=1
            22368 !RFM69:SWR:NACK
            22370 RFM69:PTX:NO ADJ
            22372 RFM69:SWR:SEND,TO=0,RETRY=2
            22583 !RFM69:SWR:NACK
            22585 RFM69:PTX:NO ADJ
            22628 RFM69:SWR:SEND,TO=0,RETRY=3
            22837 !RFM69:SWR:NACK
            22839 RFM69:PTX:NO ADJ
            22882 RFM69:SWR:SEND,TO=0,RETRY=4
            23091 !RFM69:SWR:NACK
            23093 RFM69:PTX:NO ADJ
            23136 RFM69:SWR:SEND,TO=0,RETRY=5
            23343 RFM69:SWR:ACK,FROM=0,SEQ=69,RSSI=-37
            23347 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
            23353 RFM69:PTX:LEVEL=12 dBm
            23355 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
            23365 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            23373 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400500461696C65642072656164696E67207465
            23384 OTA:FWP:RECV B=0450
            23386 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
            23392 RFM69:SWR:SEND,TO=0,RETRY=0
            23601 !RFM69:SWR:NACK
            23603 RFM69:PTX:LEVEL=13 dBm
            23646 RFM69:SWR:SEND,TO=0,RETRY=1
            23855 !RFM69:SWR:NACK
            23857 RFM69:PTX:NO ADJ
            23891 RFM69:SWR:SEND,TO=0,RETRY=2
            24100 !RFM69:SWR:NACK
            24102 RFM69:PTX:NO ADJ
            24113 RFM69:SWR:SEND,TO=0,RETRY=3
            24322 !RFM69:SWR:NACK
            24324 RFM69:PTX:NO ADJ
            24367 RFM69:SWR:SEND,TO=0,RETRY=4
            24576 !RFM69:SWR:NACK
            24578 RFM69:PTX:NO ADJ
            24612 RFM69:SWR:SEND,TO=0,RETRY=5
            24758 RFM69:SWR:ACK,FROM=0,SEQ=71,RSSI=-38
            24762 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
            24766 RFM69:PTX:LEVEL=12 dBm
            24770 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
            24778 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
            24782 RFM69:SWR:SEND,TO=0,RETRY=0
            24993 !RFM69:SWR:NACK
            24995 RFM69:PTX:LEVEL=13 dBm
            25006 RFM69:SWR:SEND,TO=0,RETRY=1
            25214 !RFM69:SWR:NACK
            25217 RFM69:PTX:NO ADJ
            25251 RFM69:SWR:SEND,TO=0,RETRY=2
            25460 !RFM69:SWR:NACK
            25462 RFM69:PTX:NO ADJ
            25505 RFM69:SWR:SEND,TO=0,RETRY=3
            25714 !RFM69:SWR:NACK
            25716 RFM69:PTX:NO ADJ
            25759 RFM69:SWR:SEND,TO=0,RETRY=4
            25968 !RFM69:SWR:NACK
            25970 RFM69:PTX:NO ADJ
            26005 RFM69:SWR:SEND,TO=0,RETRY=5
            26183 RFM69:SWR:ACK,FROM=0,SEQ=72,RSSI=-38
            26189 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
            26193 RFM69:PTX:LEVEL=12 dBm
            26195 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
            26206 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
            26210 RFM69:SWR:SEND,TO=0,RETRY=0
            26421 !RFM69:SWR:NACK
            26423 RFM69:PTX:LEVEL=13 dBm
            26466 RFM69:SWR:SEND,TO=0,RETRY=1
            26675 !RFM69:SWR:NACK
            26677 RFM69:PTX:NO ADJ
            26720 RFM69:SWR:SEND,TO=0,RETRY=2
            26929 !RFM69:SWR:NACK
            26931 RFM69:PTX:NO ADJ
            26974 RFM69:SWR:SEND,TO=0,RETRY=3
            27183 !RFM69:SWR:NACK
            27185 RFM69:PTX:NO ADJ
            27219 RFM69:SWR:SEND,TO=0,RETRY=4
            27428 !RFM69:SWR:NACK
            27430 RFM69:PTX:NO ADJ
            27441 RFM69:SWR:SEND,TO=0,RETRY=5
            27555 RFM69:SWR:ACK,FROM=0,SEQ=73,RSSI=-41
            27561 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=12
            27566 RFM69:PTX:LEVEL=12 dBm
            27568 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
            27578 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
            27586 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
            27596 OTA:FWP:RECV B=044F
            27600 OTA:FRQ:FW REQ,T=0002,V=0004,B=044E
            27604 RFM69:SWR:SEND,TO=0,RETRY=0
            27625 RFM69:SWR:ACK,FROM=0,SEQ=75,RSSI=-42
            27629 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=11
            27633 RFM69:PTX:LEVEL=11 dBm
            27637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004E04
            27645 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
            27654 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
            27666 OTA:FWP:RECV B=044F
            27668 !OTA:FWP:WRONG FWB
            27742 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
            27750 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004E0400000098196819C8193C1960194C193D
            27760 OTA:FWP:RECV B=044E
            27762 OTA:FRQ:FW REQ,T=0002,V=0004,B=044D
            27768 RFM69:SWR:SEND,TO=0,RETRY=0
            27789 RFM69:SWR:ACK,FROM=0,SEQ=78,RSSI=-43
            27793 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
            27797 RFM69:PTX:LEVEL=10 dBm
            27801 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004D04
            27850 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
            27858 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004D0400530BC00AEB0A9A0B1C0BFA0A0E0B00
            27869 OTA:FWP:RECV B=044D
            27873 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
            27877 RFM69:SWR:SEND,TO=0,RETRY=0
            28088 !RFM69:SWR:NACK
            28090 RFM69:PTX:LEVEL=11 dBm
            28133 RFM69:SWR:SEND,TO=0,RETRY=1
            28342 !RFM69:SWR:NACK
            28344 RFM69:PTX:LEVEL=12 dBm
            28387 RFM69:SWR:SEND,TO=0,RETRY=2
            28596 !RFM69:SWR:NACK
            28598 RFM69:PTX:LEVEL=13 dBm
            28641 RFM69:SWR:SEND,TO=0,RETRY=3
            28850 !RFM69:SWR:NACK
            28852 RFM69:PTX:NO ADJ
            28895 RFM69:SWR:SEND,TO=0,RETRY=4
            29104 !RFM69:SWR:NACK
            29106 RFM69:PTX:NO ADJ
            29140 RFM69:SWR:SEND,TO=0,RETRY=5
            29233 RFM69:SWR:ACK,FROM=0,SEQ=80,RSSI=-39
            29237 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
            29241 RFM69:PTX:LEVEL=12 dBm
            29245 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
            29253 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
            29257 RFM69:SWR:SEND,TO=0,RETRY=0
            29278 RFM69:SWR:ACK,FROM=0,SEQ=81,RSSI=-45
            29282 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=11
            29286 RFM69:PTX:LEVEL=11 dBm
            29290 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
            29755 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
            29759 RFM69:SWR:SEND,TO=0,RETRY=0
            29775 RFM69:SWR:ACK,FROM=0,SEQ=82,RSSI=-47
            29782 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=10
            29786 RFM69:PTX:LEVEL=10 dBm
            29790 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
            30025 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
            30033 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004C0407070707070707070707070103000000
            30044 OTA:FWP:RECV B=044C
            30048 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
            30052 RFM69:SWR:SEND,TO=0,RETRY=0
            30263 !RFM69:SWR:NACK
            30265 RFM69:PTX:LEVEL=11 dBm
            30308 RFM69:SWR:SEND,TO=0,RETRY=1
            30517 !RFM69:SWR:NACK
            30519 RFM69:PTX:LEVEL=12 dBm
            30562 RFM69:SWR:SEND,TO=0,RETRY=2
            30771 !RFM69:SWR:NACK
            30773 RFM69:PTX:LEVEL=13 dBm
            30816 RFM69:SWR:SEND,TO=0,RETRY=3
            31025 !RFM69:SWR:NACK
            31027 RFM69:PTX:NO ADJ
            31070 RFM69:SWR:SEND,TO=0,RETRY=4
            31279 !RFM69:SWR:NACK
            31281 RFM69:PTX:NO ADJ
            31315 RFM69:SWR:SEND,TO=0,RETRY=5
            31449 RFM69:SWR:ACK,FROM=0,SEQ=84,RSSI=-39
            31453 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
            31457 RFM69:PTX:LEVEL=12 dBm
            31461 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004B04
            31469 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
            31473 RFM69:SWR:SEND,TO=0,RETRY=0
            31696 !RFM69:SWR:NACK
            31698 RFM69:PTX:LEVEL=13 dBm
            31709 RFM69:SWR:SEND,TO=0,RETRY=1
            31918 !RFM69:SWR:NACK
            31920 RFM69:PTX:NO ADJ
            31954 RFM69:SWR:SEND,TO=0,RETRY=2
            32163 !RFM69:SWR:NACK
            32165 RFM69:PTX:NO ADJ
            32176 RFM69:SWR:SEND,TO=0,RETRY=3
              49 TSM:INIT
              51 TSF:WUR:MS=10000
              53 RFM69:INIT
              61 TSM:INIT:TSP OK
              63 TSF:SID:OK,ID=16
              65 TSM:FPAR
              2082 TSM:FPAR:OK
              2082 TSM:ID
              2084 TSM:ID:OK
              2086 TSM:UPL
              2142 TSM:UPL:OK
              2351 OTA:FWP:UPDATE
              6780 MCO:REG:REQ
              6883 MCO:BGN:STP
              tekkaT
              tekkaT
              tekka
              @gohan I suspect an ATC and/or timing issue - could you try this: https://github.com/tekka007/MySensors/tree/RFM69_Update
              Update GW + node and post the full debug log for further analysis. Thanks
                I left the myconfig.h file as the one provided but I get no communication
                Node log
                18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.2
                28 TSM:INIT
                28 TSF:WUR:MS=10000
                30 RFM69:INIT
                32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                36 RFM69:PTX:LEVEL=5 dBm
                40 TSM:INIT:TSP OK
                43 TSF:SID:OK,ID=16
                45 TSM:FPAR
                45 RFM69:SWR:SEND,TO=255,RETRY=0
                53 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2060 !TSM:FPAR:NO REPLY
                2062 TSM:FPAR
                2064 RFM69:SWR:SEND,TO=255,RETRY=0
                2070 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4079 !TSM:FPAR:NO REPLY
                4081 TSM:FPAR
                4083 RFM69:SWR:SEND,TO=255,RETRY=0
                4089 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6100 !TSM:FPAR:NO REPLY
                6103 TSM:FPAR
                6105 RFM69:SWR:SEND,TO=255,RETRY=0
                6111 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8120 !TSM:FPAR:FAIL
                8122 TSM:FAIL:CNT=1
                8124 TSM:FAIL:DIS
                8126 TSF:TDI:TSL
                8126 RFM69:RSL
                10031 MCO:BGN:STP
                10543 MCO:BGN:INIT OK,TSP=0
                11546 !MCO:SND:NODE NOT REG
                T: 23.15
                12052 !MCO:SND:NODE NOT REG
                H: 47
                12054 !MCO:SND:NODE NOT REG
                12558 !MCO:SND:NODE NOT REG
                12761 !MCO:SND:NODE NOT REG
                13764 !MCO:SND:NODE NOT REG
                13766 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                13772 !MCO:SLP:TNR
                18130 TSM:FAIL:RE-INIT
                18132 TSM:INIT
                18135 RFM69:INIT
                18137 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                18141 RFM69:PTX:LEVEL=5 dBm
                18145 TSM:INIT:TSP OK
                18147 TSF:SID:OK,ID=16
                18149 TSM:FPAR
                18151 RFM69:SWR:SEND,TO=255,RETRY=0
                18157 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20166 !TSM:FPAR:NO REPLY
                20168 TSM:FPAR
                20170 RFM69:SWR:SEND,TO=255,RETRY=0
                20176 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                22188 !TSM:FPAR:NO REPLY
                22190 TSM:FPAR
                22192 RFM69:SWR:SEND,TO=255,RETRY=0
                22198 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                23775 MCO:SLP:MS=589999
                23777 !TSF:SND:TNR
                24207 !TSM:FPAR:NO REPLY
                24209 TSM:FPAR
                24211 RFM69:SWR:SEND,TO=255,RETRY=0
                24217 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                24279 TSF:TDI:TSL
                24281 RFM69:RSL
                GW LOG
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.2.0-rc.2
                mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: RFM69:INIT
                mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
                mysgw: RFM69:PTX:LEVEL=5 dBm
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                and nothing more while the node is looking for parent
                  I have tried on another RPI with the updated branch and still have no communication, if I switch back to normal development branch I get communication back. Anything more I can try?
                    @jkandasa I have managed to get FOTA do an update on the latest 2.2 but with a mod for rfm69 from tekka. I am having difficulties to trigger the OTA update even if a assign a different firmware to the node. Do you have any suggestion about this?
                    J 1 Reply Last reply
                      J
                      J
                      jkandasa
                      @gohan What the issue are you facing? AFAIK, RFM69 supports only for DualOptiboot
                        I'm using dual optiboot, the problem is that I was only able to trigger an ota on the node the first time I set it, after that the node is no longer starting a new ota transfer
                          J
                          J
                          jkandasa
                          @gohan Enable node debug log and trigger firmware update. Post node debug log.
                          A few weeks before, I see an issue with the DualOptiboot firmware update. For some reason, if firmware update failed in between, and when we trigger firmware update once again, node says It is up to date.
                            17 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.1-alpha
                            26 TSM:INIT
                            27 TSF:WUR:MS=10000
                            29 RFM69:INIT
                            30 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                            34 RFM69:PTX:LEVEL=5 dBm
                            36 RFM69:INIT:HWV=36
                            38 TSM:INIT:TSP OK
                            40 TSF:SID:OK,ID=16
                            43 TSM:FPAR
                            44 RFM69:SWR:SEND,TO=255,RETRY=0
                            47 RFM69:CSMA:RSSI=-109
                            51 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            198 RFM69:SAC:SEND ACK,TO=0,RSSI=-44
                            201 RFM69:CSMA:RSSI=-44
                            210 RFM69:CSMA:RSSI=-109
                            215 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            220 TSF:MSG:FPAR OK,ID=0,D=1
                            2058 TSM:FPAR:OK
                            2059 TSM:ID
                            2060 TSM:ID:OK
                            2062 TSM:UPL
                            2063 RFM69:SWR:SEND,TO=0,RETRY=0
                            2066 RFM69:CSMA:RSSI=-109
                            2074 RFM69:SWR:ACK,FROM=0,SEQ=3,RSSI=-37
                            2078 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=4
                            2082 RFM69:PTX:LEVEL=4 dBm
                            2084 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                            2091 RFM69:SAC:SEND ACK,TO=0,RSSI=-105
                            2095 RFM69:CSMA:RSSI=-105
                            2099 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            2104 TSF:MSG:PONG RECV,HP=1
                            2106 TSM:UPL:OK
                            2108 TSM:READY:ID=16,PAR=0,DIS=1
                            2111 RFM69:SWR:SEND,TO=0,RETRY=0
                            2114 RFM69:CSMA:RSSI=-104
                            2120 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-38
                            2123 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=3
                            2127 RFM69:PTX:LEVEL=3 dBm
                            2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300
                            2139 RFM69:SWR:SEND,TO=0,RETRY=0
                            2142 RFM69:CSMA:RSSI=-109
                            2152 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-36
                            2155 RFM69:ATC:ADJ TXL,cR=-36,tR=-80,TXL=2
                            2159 RFM69:PTX:LEVEL=2 dBm
                            2162 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            2168 RFM69:SAC:SEND ACK,TO=0,RSSI=-104
                            2172 RFM69:CSMA:RSSI=-104
                            2176 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            2182 RFM69:SWR:SEND,TO=0,RETRY=0
                            2185 RFM69:CSMA:RSSI=-89
                            2196 RFM69:CSMA:RSSI=-105
                            2398 !RFM69:SWR:NACK
                            2399 RFM69:SWR:SEND,TO=0,RETRY=1
                            2403 RFM69:CSMA:RSSI=-104
                            2607 !RFM69:SWR:NACK
                            2608 RFM69:SWR:SEND,TO=0,RETRY=2
                            2612 RFM69:CSMA:RSSI=-107
                            2816 !RFM69:SWR:NACK
                            2817 RFM69:SWR:SEND,TO=0,RETRY=3
                            2821 RFM69:CSMA:RSSI=-103
                            2852 RFM69:SWR:ACK,FROM=0,SEQ=8,RSSI=-37
                            2855 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=1
                            2860 RFM69:PTX:LEVEL=1 dBm
                            2862 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.2.1-alpha
                            2870 RFM69:SWR:SEND,TO=0,RETRY=0
                            2873 RFM69:CSMA:RSSI=-103
                            2879 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-40
                            2882 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=0
                            2886 RFM69:PTX:LEVEL=0 dBm
                            2889 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                            2962 RFM69:SAC:SEND ACK,TO=0,RSSI=-45
                            2966 RFM69:CSMA:RSSI=-45
                            2969 RFM69:CSMA:RSSI=-105
                            2972 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                            2978 RFM69:SWR:SEND,TO=0,RETRY=0
                            2981 RFM69:CSMA:RSSI=-106
                            2990 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-40
                            2994 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=-1
                            2997 RFM69:PTX:LEVEL=-1 dBm
                            3000 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:TEMP HUM dev
                            3007 RFM69:SWR:SEND,TO=0,RETRY=0
                            3010 RFM69:CSMA:RSSI=-102
                            3016 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-39
                            3020 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=-2
                            3023 RFM69:PTX:LEVEL=-2 dBm
                            3026 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                            3033 RFM69:SWR:SEND,TO=0,RETRY=0
                            3036 RFM69:CSMA:RSSI=-106
                            3043 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-42
                            3047 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=-3
                            3050 RFM69:PTX:LEVEL=-3 dBm
                            3053 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            3059 RFM69:SWR:SEND,TO=0,RETRY=0
                            3062 RFM69:CSMA:RSSI=-109
                            3069 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-50
                            3074 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-4
                            3078 RFM69:PTX:LEVEL=-4 dBm
                            3080 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                            3086 RFM69:SWR:SEND,TO=0,RETRY=0
                            3089 RFM69:CSMA:RSSI=-105
                            3096 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-50
                            3100 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-5
                            3104 RFM69:PTX:LEVEL=-5 dBm
                            3106 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                            3112 RFM69:SWR:SEND,TO=0,RETRY=0
                            3116 RFM69:CSMA:RSSI=-107
                            3123 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-51
                            3127 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-6
                            3131 RFM69:PTX:LEVEL=-6 dBm
                            3133 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                            3139 RFM69:SWR:SEND,TO=0,RETRY=0
                            3142 RFM69:CSMA:RSSI=-107
                            3149 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-52
                            3153 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-7
                            3158 RFM69:PTX:LEVEL=-7 dBm
                            3160 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                            3166 RFM69:SWR:SEND,TO=0,RETRY=0
                            3169 RFM69:CSMA:RSSI=-107
                            3176 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-53
                            3180 RFM69:ATC:ADJ TXL,cR=-53,tR=-80,TXL=-8
                            3184 RFM69:PTX:LEVEL=-8 dBm
                            3186 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                            3192 MCO:REG:REQ
                            3194 RFM69:SWR:SEND,TO=0,RETRY=0
                            3197 RFM69:CSMA:RSSI=-109
                            3208 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-54
                            3212 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=-9
                            3216 RFM69:PTX:LEVEL=-9 dBm
                            3218 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                            3225 RFM69:SAC:SEND ACK,TO=0,RSSI=-107
                            3228 RFM69:CSMA:RSSI=-107
                            3232 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                            3237 MCO:PIM:NODE REG=1
                            3239 MCO:BGN:STP
                            3751 MCO:BGN:INIT OK,TSP=1
                            4755 RFM69:SWR:SEND,TO=0,RETRY=0
                            4758 RFM69:CSMA:RSSI=-103
                            4767 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-56
                            4771 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-10
                            4775 RFM69:PTX:LEVEL=-10 dBm
                            4777 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.40
                            T: 20.40
                            5286 RFM69:SWR:SEND,TO=0,RETRY=0
                            5289 RFM69:CSMA:RSSI=-110
                            5296 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-56
                            5299 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-11
                            5303 RFM69:PTX:LEVEL=-11 dBm
                            5306 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.0
                            H: 41
                            5312 RFM69:SWR:SEND,TO=0,RETRY=0
                            5316 RFM69:CSMA:RSSI=-106
                            5322 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-57
                            5326 RFM69:ATC:ADJ TXL,cR=-57,tR=-80,TXL=-12
                            5330 RFM69:PTX:LEVEL=-12 dBm
                            5334 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-56
                            5840 RFM69:SWR:SEND,TO=0,RETRY=0
                            5842 RFM69:CSMA:RSSI=-107
                            5851 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-58
                            5855 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-13
                            5859 RFM69:PTX:LEVEL=-13 dBm
                            5861 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-44
                            6068 RFM69:SWR:SEND,TO=0,RETRY=0
                            6071 RFM69:CSMA:RSSI=-108
                            6081 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-58
                            6084 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-14
                            6088 RFM69:PTX:LEVEL=-14 dBm
                            6091 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:16
                            7099 RFM69:SWR:SEND,TO=0,RETRY=0
                            7101 RFM69:CSMA:RSSI=-105
                            7109 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-60
                            7113 RFM69:ATC:ADJ TXL,cR=-60,tR=-80,TXL=-15
                            7117 RFM69:PTX:LEVEL=-15 dBm
                            7119 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                            7127 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                            7132 RFM69:SWR:SEND,TO=0,RETRY=0
                            7135 RFM69:CSMA:RSSI=-107
                            7142 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-61
                            7146 RFM69:ATC:ADJ TXL,cR=-61,tR=-80,TXL=-16
                            7150 RFM69:PTX:LEVEL=-16 dBm
                            7152 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                            7659 TSF:TDI:TSL
                            7660 RFM69:RSL
                              26 TSM:INIT
                              27 TSF:WUR:MS=10000
                              29 RFM69:INIT
                              38 TSM:INIT:TSP OK
                              40 TSF:SID:OK,ID=16
                              43 TSM:FPAR
                              2058 TSM:FPAR:OK
                              2059 TSM:ID
                              2060 TSM:ID:OK
                              2062 TSM:UPL
                              2106 TSM:UPL:OK
                              3192 MCO:REG:REQ
                              3239 MCO:BGN:STP
                              T: 20.40
                              H: 41
                              7659 TSF:TDI:TSL
                              7660 RFM69:RSL
                              J
                              J
                              jkandasa
                              @gohan This node looks like sleeping node? Is it. I guess it won't walk up to update the entire firmware.
                              And I do not see any response for this request 2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300. Is there any firmware assigned for this node in MyController?
                                There is, I have loaded 5 but none work, besides the first time that actually did started the ota transfer
