  3. MyController.org
  4. Need volunteer to test dualboot OTA with MyController
Scheduled Pinned Locked Moved MyController.org
28 Posts 5 Posters 6.9k Views 6 Watching
  • J
    J
    jkandasa
    Hello, I need volunteer to test dualboot(with external flash memory) OTA with MyController. I have tested MYSBootloader with MyController and works well. I do not have any hardware to test dualboot. If any one have this setup and intersterd on MyController kindly use this SNAPSHOT version
    • Johnny B GoodJ
      Johnny B GoodJ
      Johnny B Good
      wrote on last edited by Johnny B Good
      Hi JKandasa,
      I love to, but I try a lot but the OTA thing won't work here.
      I followed diff tutorials to setup, and tried with MYSController to update the firmware, but so far no success...
      So I kinda give up try update over air, I really don't know what I do wrong...
      Further ... MyController is working awesome here... +1
      MyController
      Version
      0.0.3.Alpha2
      Database version
      1.02.10 - 2016 Jul 29
      Git commit:branch
      e8afb0266ab685dcfc59b0691ec301d3a17d3fd6:master
      Built on
      2016-07-30T01:04:37+0530
      Build JDK
      1.8.0_92
      Build tool
      Apache Maven 3.3.9
      Java virtual machine specification
      VM vendor
      Oracle Corporation
      VM name
      Java HotSpot(TM) Client VM
      VM version
      1.8.0_121-b13
      Java home
      /opt/jdk1.8.0_121/jre
      Operating system
      Operating system
      Linux
      Architecture
      arm
      Version/Kernel
      4.4.34-v7+
      Location
      /home/pi/mycontroller
      -= GreetingZzz and may the sensors be with you =-
      • F
        F
        Fabien
        I'm updating all my firmware with MyController without any problem (dualoptiboot)
        Johnny B GoodJ 1 Reply Last reply
        • F Fabien
          Johnny B GoodJ
          Johnny B GoodJ
          Johnny B Good
          @Fabien Hi, can you please help me to set it up and push me into the right direction ?
            if you need help with further testing I am trying out the dualboot FOTA with mixed results
              J
              J
              jkandasa
              @gohan Sure, Please report back your results.
                wrote on last edited by gohan
                I am using the sensebender bootloader and in MyContoller I don't know if it is normal that when I assign a FW and choose the Upload FW action, most of the time I need also to hit the reboot action to make the node start the new firmware transfer. Sometimes I needed to power down the node since hitting the reset button wasn't enough. I posted in another topic some issues I had during upload process and now seems better after I added this in beginning of loop (it still fails most of the times)
                if (!isFirmwareUpdateOngoing())
                but transfer speed is still painfully slow with RFM69 433Mhz as it takes between 10 to 20 minutes to complete (with MysController it is pretty much the same). I asked if it is possible to increase the datarate on the TX of the gateway, but so far I got no response
                  J
                  J
                  jkandasa
                  @gohan What type of gateway are you using? MQTT? Serial? What is the Tx message processing delay(Milliseconds) in MyController gateway configuration?
                  Is Controller and Gateway on the same network?
                    It's ethernet controller on same raspberry pi as the controller. That tx message processing is set to zero. So far I got 3 successful fw updates only, I lost count of the trials.
                    tekkaT 1 Reply Last reply
                      tekkaT
                      tekkaT
                      tekka
                      @gohan hmm, 10-20 mins is pretty long, indeed. Can you post all logs with rfm69 debug verbose enabled?
                      gohanG 1 Reply Last reply
                      • tekkaT tekka
                        @tekka from the node side?
                          tekkaT
                          tekkaT
                          tekka
                          wrote on last edited by tekka
                          @gohan ideally both, GW and node
                            Do I need to enable it in myconfig.h and recompile the rpi gateway?
                              tekkaT
                              tekkaT
                              tekka
                              @gohan yes, you can enable/add #define MY_DEBUG_VERBOSE_RFM69 in either myconfig.h or mysgw.cpp and recompile the RPI GW
                                this is what I get on the gateway
                                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FB03611D231F849F600D211D822F762F6A2F
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-41
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500FA03
                                mysgw: RFM69:SWR:SEND,TO=16,RETRY=0
                                mysgw: !RFM69:SWR:NACK
                                mysgw: RFM69:SWR:SEND,TO=16,RETRY=1
                                mysgw: RFM69:SWR:SEND,TO=16,RETRY=2
                                mysgw: RFM69:SWR:SEND,TO=16,RETRY=3
                                mysgw: RFM69:SWR:SEND,TO=16,RETRY=4
                                mysgw: RFM69:SWR:SEND,TO=16,RETRY=5
                                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FA03621F839FA00D611D221F749F3327A00D
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-55
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F903
                                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500F903829F2227B00DA11D621F739FB00DA11D
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-42
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F803
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=166,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F903829F2227B00DA11D621F739FB00DA11D
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=168,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F803F00DB11DAA1F649F6627B00DA11D661F
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-43
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F703
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=170,RSSI=-51
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=171,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F703629FF001729FBB27F00DB11D639FAA27
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F603
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=173,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F6030E94322070F3959FC1F3950F50E0551F
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-44
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F503
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=175,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F50311F00C940A200C94102011240C945520
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F403
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=177,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F40321200E94132038F00E941A2020F09523
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F303
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=179,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F303A6958FEF811D811D08950E94B01F0C94
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-45
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F203
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=181,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F203232B242B252B21F408950A2609F4A140
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-46
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F103
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=183,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F10398F0621B730B840B950B39F40A2661F0
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-47
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F003
                                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=185,RSSI=-51
                                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F0031706E807F907C0F012161306E407F507
                                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-48
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EF03
                                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EF030895990F0008550FAA0BE0E8FEEF1616
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EE03
                                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EE03660F771F881FDAF7880F9695879597F9
                                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500ED03
                                I guess there is something wrong since the node is 3 meters away
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @gohan please also post the full node log + node sketch
                                    This is node at boot even if I selected to upload firmware
                                    0 MCO:BGN:INIT NODE,CP=RPONA--X,VER=2.2.0-beta
                                    49 TSM:INIT
                                    51 TSF:WUR:MS=10000
                                    53 RFM69:INIT
                                    53 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                    59 RFM69:PTX:LEVEL=5 dBm
                                    61 TSM:INIT:TSP OK
                                    63 TSF:SID:OK,ID=16
                                    65 TSM:FPAR
                                    67 RFM69:SWR:SEND,TO=255,RETRY=0
                                    73 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    192 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    200 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    206 TSF:MSG:FPAR OK,ID=0,D=1
                                    405 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    413 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    2082 TSM:FPAR:OK
                                    2082 TSM:ID
                                    2084 TSM:ID:OK
                                    2086 TSM:UPL
                                    2088 RFM69:SWR:SEND,TO=0,RETRY=0
                                    2103 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-47
                                    2107 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=4
                                    2111 RFM69:PTX:LEVEL=4 dBm
                                    2113 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    2121 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    2129 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    2136 TSF:MSG:PONG RECV,HP=1
                                    2138 TSM:UPL:OK
                                    2140 TSM:READY:ID=16,PAR=0,DIS=1
                                    2144 RFM69:SWR:SEND,TO=0,RETRY=0
                                    2355 !RFM69:SWR:NACK
                                    2357 RFM69:PTX:LEVEL=5 dBm
                                    2400 RFM69:SWR:SEND,TO=0,RETRY=1
                                    2609 !RFM69:SWR:NACK
                                    2611 RFM69:PTX:LEVEL=6 dBm
                                    2654 RFM69:SWR:SEND,TO=0,RETRY=2
                                    2863 !RFM69:SWR:NACK
                                    2865 RFM69:PTX:LEVEL=7 dBm
                                    2899 RFM69:SWR:SEND,TO=0,RETRY=3
                                    3108 !RFM69:SWR:NACK
                                    3110 RFM69:PTX:LEVEL=8 dBm
                                    3121 RFM69:SWR:SEND,TO=0,RETRY=4
                                    3330 !RFM69:SWR:NACK
                                    3332 RFM69:PTX:LEVEL=9 dBm
                                    3375 RFM69:SWR:SEND,TO=0,RETRY=5
                                    3457 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-44
                                    3461 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
                                    3465 RFM69:PTX:LEVEL=8 dBm
                                    3467 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
                                    3477 RFM69:SWR:SEND,TO=0,RETRY=0
                                    3491 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-45
                                    3495 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=7
                                    3500 RFM69:PTX:LEVEL=7 dBm
                                    3502 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    3510 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    3518 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    3524 RFM69:SWR:SEND,TO=0,RETRY=0
                                    3735 !RFM69:SWR:NACK
                                    3737 RFM69:PTX:LEVEL=8 dBm
                                    3747 RFM69:SWR:SEND,TO=0,RETRY=1
                                    3956 !RFM69:SWR:NACK
                                    3958 RFM69:PTX:LEVEL=9 dBm
                                    4001 RFM69:SWR:SEND,TO=0,RETRY=2
                                    4210 !RFM69:SWR:NACK
                                    4212 RFM69:PTX:LEVEL=10 dBm
                                    4255 RFM69:SWR:SEND,TO=0,RETRY=3
                                    4464 !RFM69:SWR:NACK
                                    4466 RFM69:PTX:LEVEL=11 dBm
                                    4501 RFM69:SWR:SEND,TO=0,RETRY=4
                                    4710 !RFM69:SWR:NACK
                                    4712 RFM69:PTX:LEVEL=12 dBm
                                    4722 RFM69:SWR:SEND,TO=0,RETRY=5
                                    4909 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-43
                                    4913 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
                                    4917 RFM69:PTX:LEVEL=11 dBm
                                    4919 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                                    4929 RFM69:SWR:SEND,TO=0,RETRY=0
                                    4943 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-43
                                    4947 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                                    4952 RFM69:PTX:LEVEL=10 dBm
                                    4954 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    5584 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    5593 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    5599 RFM69:SWR:SEND,TO=0,RETRY=0
                                    5810 !RFM69:SWR:NACK
                                    5812 RFM69:PTX:LEVEL=11 dBm
                                    5855 RFM69:SWR:SEND,TO=0,RETRY=1
                                    6064 !RFM69:SWR:NACK
                                    6066 RFM69:PTX:LEVEL=12 dBm
                                    6100 RFM69:SWR:SEND,TO=0,RETRY=2
                                    6309 !RFM69:SWR:NACK
                                    6311 RFM69:PTX:LEVEL=13 dBm
                                    6322 RFM69:SWR:SEND,TO=0,RETRY=3
                                    6531 !RFM69:SWR:NACK
                                    6533 RFM69:PTX:NO ADJ
                                    6576 RFM69:SWR:SEND,TO=0,RETRY=4
                                    6785 !RFM69:SWR:NACK
                                    6787 RFM69:PTX:NO ADJ
                                    6830 RFM69:SWR:SEND,TO=0,RETRY=5
                                    6950 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-42
                                    6955 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=12
                                    6961 RFM69:PTX:LEVEL=12 dBm
                                    6963 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
                                    6971 RFM69:SWR:SEND,TO=0,RETRY=0
                                    6985 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-43
                                    6989 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
                                    6995 RFM69:PTX:LEVEL=11 dBm
                                    6998 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                                    7006 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7020 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-43
                                    7024 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                                    7030 RFM69:PTX:LEVEL=10 dBm
                                    7032 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    7041 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7055 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-43
                                    7061 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=9
                                    7065 RFM69:PTX:LEVEL=9 dBm
                                    7067 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                    7075 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7090 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-44
                                    7096 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
                                    7100 RFM69:PTX:LEVEL=8 dBm
                                    7102 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                    7110 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7127 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
                                    7131 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=7
                                    7135 RFM69:PTX:LEVEL=7 dBm
                                    7139 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                    7145 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7163 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-51
                                    7168 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=6
                                    7172 RFM69:PTX:LEVEL=6 dBm
                                    7174 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                    7182 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7198 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-45
                                    7202 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=5
                                    7206 RFM69:PTX:LEVEL=5 dBm
                                    7211 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                                    7219 MCO:REG:REQ
                                    7219 RFM69:SWR:SEND,TO=0,RETRY=0
                                    7235 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-49
                                    7239 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=4
                                    7243 RFM69:PTX:LEVEL=4 dBm
                                    7247 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                    7254 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                                    7262 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    7268 MCO:PIM:NODE REG=1
                                    7272 MCO:BGN:STP
                                    7784 MCO:BGN:INIT OK,TSP=1
                                    7786 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    7794 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    7800 MCO:PIM:NODE REG=1
                                    8804 RFM69:SWR:SEND,TO=0,RETRY=0
                                    8822 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-48
                                    8826 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=3
                                    8833 RFM69:PTX:LEVEL=3 dBm
                                    8835 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.62
                                    T: 19.62
                                    9345 RFM69:SWR:SEND,TO=0,RETRY=0
                                    9361 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-51
                                    9365 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=2
                                    9369 RFM69:PTX:LEVEL=2 dBm
                                    9373 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0
                                    H: 47
                                    9381 RFM69:SWR:SEND,TO=0,RETRY=0
                                    9396 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-49
                                    9400 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=1
                                    9406 RFM69:PTX:LEVEL=1 dBm
                                    9408 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-51
                                    9916 RFM69:SWR:SEND,TO=0,RETRY=0
                                    9934 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-50
                                    9938 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=0
                                    9943 RFM69:PTX:LEVEL=0 dBm
                                    9947 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-52
                                    10156 RFM69:SWR:SEND,TO=0,RETRY=0
                                    10168 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-51
                                    10172 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-1
                                    10178 RFM69:PTX:LEVEL=-1 dBm
                                    10180 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:58
                                    11190 RFM69:SWR:SEND,TO=0,RETRY=0
                                    11206 RFM69:SWR:ACK,FROM=0,SEQ=28,RSSI=-51
                                    11212 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-2
                                    11216 RFM69:PTX:LEVEL=-2 dBm
                                    11220 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                                    11229 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                    11235 RFM69:SWR:SEND,TO=0,RETRY=0
                                    11253 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-52
                                    11257 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-3
                                    11261 RFM69:PTX:LEVEL=-3 dBm
                                    11266 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                                    11450 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                    11458 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                                    11776 TSF:TDI:TSL
                                    11778 RFM69:RSL
                                    Sketch
                                    #include <Adafruit_SHT31.h>
                                    #include <Adafruit_Sensor.h>
                                    #define MY_DEBUG  // Enable debug prints
                                    //#define MY_RADIO_NRF24
                                    #define MY_RADIO_RFM69
                                    #define MY_RFM69_FREQUENCY RFM69_433MHZ
                                    #define MY_RFM69_NEW_DRIVER
                                    //#define MY_IS_RFM69HW
                                    #define MY_TRANSPORT_WAIT_READY_MS 10000
                                    //#define MY_NODE_ID 16
                                    #define VBAT_VCC
                                    //Enable OTA feature
                                    #define MY_OTA_FIRMWARE_FEATURE
                                    #define MY_OTA_FLASH_JDECID 0x00
                                    #define CHILD_ID_HUM 0
                                    #define CHILD_ID_TEMP 1
                                    #define CHILD_ID_VBAT 201						 // Battery voltage
                                    unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
                                    #define SKETCH_NAME "TEMP HUM"                // Change to a fancy name you like
                                    #define SKETCH_VERSION "1.2"                    // Your version
                                    float lastTemp;
                                    float lastHum;
                                    boolean metric = true;
                                    MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE);
                                    Adafruit_SHT31 sht31 = Adafruit_SHT31();
                                    #ifdef MY_RADIO_RFM69
                                    	int rssi;                                    // RSSI RFM69 chip
                                    	#define CHILD_ID_RSSI_HIGH  202                // RSSI received signal level
                                    	#define CHILD_ID_RSSI_LOW   203                // RSSI background noise level
                                      #define CHILD_ID_POWER 204
                                    	MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_LEVEL);
                                    	MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_LEVEL);
                                      MyMessage msgPWR(CHILD_ID_POWER, V_LIGHT_LEVEL);
                                    // BATTERY VOLTAGE DIVIDER SETUP
                                    #define VBAT_PER_BITS 0.003363075
                                    //#define VBAT_PER_BITS 0.005448028                 //
                                    #define VMIN 2.8                                  //  Vmin (radio Min Volt)=1.9V (564v)
                                    #define VMAX 3.4                                 //  Vmax = (2xAA bat)=3.0V (892v)
                                    int batteryPcnt , PwrPcnt = 0;                    // Calc value for battery %
                                    int batLoop = 0;                                  // Loop to help calc average
                                    int batArray[3];                                  // Array to store value for average calc.
                                    #ifdef VBAT_VCC
                                    #include <Vcc.h>
                                    	const float VccCorrection = 1.0 / 1.0;  // Measured Vcc by multimeter divided by reported Vcc
                                    	Vcc vcc(VccCorrection);
                                    #else
                                    	int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
                                    #endif // VBAT_VCC
                                    	analogReference(INTERNAL);             // For battery sensing
                                    	delay(500); // Allow time for radio if power used as reset
                                    	// metric = getControllerConfig().isMetric;
                                    	if (!sht31.begin(0x44)) {   // Set to 0x45 for alternate i2c addr
                                    		Serial.println("Couldn't find SHT31");
                                    		//while (1) delay(1);
                                    	present(CHILD_ID_HUM, S_HUM);
                                    	present(CHILD_ID_RSSI_HIGH, S_SOUND);
                                    	present(CHILD_ID_RSSI_LOW, S_SOUND);
                                      present(CHILD_ID_POWER, S_LIGHT_LEVEL);
                                    	present(CHILD_ID_VBAT, S_MULTIMETER);
                                    	// Fetch temperatures from SHT sensor
                                    	float temperature = sht31.readTemperature();
                                    	//temperature = round(temperature*10)/10; //round to 1 decimal place
                                    	if (isnan(temperature)) {
                                    		Serial.println("Failed reading temperature from SHT31");
                                    	else if (temperature != lastTemp) {
                                    		lastTemp = temperature;
                                    		send(msgTemp.set(temperature, 2));
                                    		Serial.print("T: ");
                                    		Serial.println(temperature);
                                    	// Fetch humidity from SHT sensor
                                    	uint8_t humidity = sht31.readHumidity();
                                    	if (isnan(humidity)) {
                                    		Serial.println("Failed reading humidity from SHT");
                                    	else if (humidity != lastHum) {
                                    		lastHum = humidity;
                                    		Serial.print("H: ");
                                    		Serial.println(humidity);
                                    	rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
                                    	send(msgRSSI1.set(rssi));                  // send RSSI level
                                    	wait(500);                                 // wait to get idle
                                    	rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
                                    	send(msgRSSI2.set(rssi));                  // send RSSI level
                                     	wait(200);                                 // wait for next send
                                      PwrPcnt = RFM69_getTxPowerPercent();      // read TX Power in RFM69
                                      send(msgPWR.set(PwrPcnt));            // send TX Power
                                    	batM();
                                    	smartSleep(SLEEP_TIME); //sleep a bit
                                    void batM() //The battery calculations
                                    	delay(500);
                                    	float Vbat;
                                    	int batteryPcnt;
                                      	// Battery monitoring reading
                                    #ifdef VBAT_VCC
                                    	Vbat = vcc.Read_Volts();
                                    	batteryPcnt = vcc.Read_Perc(VMIN, VMAX);
                                    #else
                                    	Vbat = (sensorValue * VBAT_PER_BITS) - 0.2 ;
                                    	// Calculate the battery in %
                                    	batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
                                      delay(500);
                                    	send(msgVBat.set(Vbat, 2));
                                    	//Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
                                    	// Add it to array so we get an average of 3 (3x20min)
                                    	batArray[batLoop] = batteryPcnt;
                                    	if (batLoop > 2) {
                                    		batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
                                    		batteryPcnt = batteryPcnt / 3;
                                    		if (batteryPcnt > 100) {
                                    			batteryPcnt = 100;
                                    		Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
                                    		batLoop = 0;
                                    	else
                                    		batLoop++;
                                      Here is the firmware upload that finally I managed to start, of course I only cut the first part
                                      49 TSM:INIT
                                      51 TSF:WUR:MS=10000
                                      53 RFM69:INIT
                                      61 TSM:INIT:TSP OK
                                      63 TSF:SID:OK,ID=16
                                      65 TSM:FPAR
                                      126 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      133 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      139 TSF:MSG:FPAR OK,ID=0,D=1
                                      337 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      344 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      2082 TSM:FPAR:OK
                                      2082 TSM:ID
                                      2084 TSM:ID:OK
                                      2086 TSM:UPL
                                      2105 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-44
                                      2109 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=4
                                      2113 RFM69:PTX:LEVEL=4 dBm
                                      2117 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2123 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      2131 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2138 TSF:MSG:PONG RECV,HP=1
                                      2142 TSM:UPL:OK
                                      2144 TSM:READY:ID=16,PAR=0,DIS=1
                                      2146 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2168 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-43
                                      2172 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
                                      2177 RFM69:PTX:LEVEL=3 dBm
                                      2181 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
                                      2191 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2205 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-44
                                      2209 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
                                      2213 RFM69:PTX:LEVEL=2 dBm
                                      2217 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2224 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      2232 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2240 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2258 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-45
                                      2263 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=1
                                      2269 RFM69:PTX:LEVEL=1 dBm
                                      2271 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                                      2279 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2295 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-71
                                      2299 RFM69:ATC:ADJ TXL,cR=-71,tR=-80,TXL=0
                                      2304 RFM69:PTX:LEVEL=0 dBm
                                      2308 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      2334 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                                      2342 TSF:MSG:READ,0-0-16,s=255,c=4,t=1,pt=6,l=8,sg=0:02000400600466EF
                                      2351 OTA:FWP:UPDATE
                                      2467 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                                      2471 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2682 !RFM69:SWR:NACK
                                      2684 RFM69:PTX:LEVEL=1 dBm
                                      2719 RFM69:SWR:SEND,TO=0,RETRY=1
                                      2928 !RFM69:SWR:NACK
                                      2930 RFM69:PTX:LEVEL=2 dBm
                                      2965 RFM69:SWR:SEND,TO=0,RETRY=2
                                      3174 !RFM69:SWR:NACK
                                      3176 RFM69:PTX:LEVEL=3 dBm
                                      3186 RFM69:SWR:SEND,TO=0,RETRY=3
                                      3395 !RFM69:SWR:NACK
                                      3397 RFM69:PTX:LEVEL=4 dBm
                                      3440 RFM69:SWR:SEND,TO=0,RETRY=4
                                      3649 !RFM69:SWR:NACK
                                      3651 RFM69:PTX:LEVEL=5 dBm
                                      3694 RFM69:SWR:SEND,TO=0,RETRY=5
                                      3903 !RFM69:SWR:NACK
                                      3905 RFM69:PTX:LEVEL=6 dBm
                                      3940 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005F04
                                      3948 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      3956 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      3962 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                                      3966 RFM69:SWR:SEND,TO=0,RETRY=0
                                      4177 !RFM69:SWR:NACK
                                      4179 RFM69:PTX:LEVEL=7 dBm
                                      4190 RFM69:SWR:SEND,TO=0,RETRY=1
                                      4399 !RFM69:SWR:NACK
                                      4401 RFM69:PTX:LEVEL=8 dBm
                                      4435 RFM69:SWR:SEND,TO=0,RETRY=2
                                      4644 !RFM69:SWR:NACK
                                      4646 RFM69:PTX:LEVEL=9 dBm
                                      4657 RFM69:SWR:SEND,TO=0,RETRY=3
                                      4866 !RFM69:SWR:NACK
                                      4868 RFM69:PTX:LEVEL=10 dBm
                                      4911 RFM69:SWR:SEND,TO=0,RETRY=4
                                      5046 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-39
                                      5050 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=9
                                      5054 RFM69:PTX:LEVEL=9 dBm
                                      5058 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005F04
                                      5066 RFM69:SWR:SEND,TO=0,RETRY=0
                                      5083 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-63
                                      5087 RFM69:ATC:ADJ TXL,cR=-63,tR=-80,TXL=8
                                      5091 RFM69:PTX:LEVEL=8 dBm
                                      5093 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
                                      5103 RFM69:SWR:SEND,TO=0,RETRY=0
                                      5310 !RFM69:SWR:NACK
                                      5312 RFM69:PTX:LEVEL=9 dBm
                                      5347 RFM69:SWR:SEND,TO=0,RETRY=1
                                      5554 !RFM69:SWR:NACK
                                      5556 RFM69:PTX:LEVEL=10 dBm
                                      5599 RFM69:SWR:SEND,TO=0,RETRY=2
                                      5806 !RFM69:SWR:NACK
                                      5808 RFM69:PTX:LEVEL=11 dBm
                                      5842 RFM69:SWR:SEND,TO=0,RETRY=3
                                      6049 !RFM69:SWR:NACK
                                      6051 RFM69:PTX:LEVEL=12 dBm
                                      6062 RFM69:SWR:SEND,TO=0,RETRY=4
                                      6268 !RFM69:SWR:NACK
                                      6270 RFM69:PTX:LEVEL=13 dBm
                                      6305 RFM69:SWR:SEND,TO=0,RETRY=5
                                      6512 !RFM69:SWR:NACK
                                      6514 RFM69:PTX:NO ADJ
                                      6549 !TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.2
                                      6557 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6580 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
                                      6584 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                                      6588 RFM69:PTX:LEVEL=12 dBm
                                      6590 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                                      6598 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6615 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-37
                                      6619 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=11
                                      6623 RFM69:PTX:LEVEL=11 dBm
                                      6627 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6633 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6651 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-38
                                      6656 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=10
                                      6660 RFM69:PTX:LEVEL=10 dBm
                                      6662 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6670 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6686 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-48
                                      6692 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=9
                                      6696 RFM69:PTX:LEVEL=9 dBm
                                      6699 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6707 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6723 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-48
                                      6729 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=8
                                      6733 RFM69:PTX:LEVEL=8 dBm
                                      6735 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6744 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6760 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-40
                                      6764 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=7
                                      6770 RFM69:PTX:LEVEL=7 dBm
                                      6772 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6780 MCO:REG:REQ
                                      6782 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6797 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-49
                                      6801 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=6
                                      6807 RFM69:PTX:LEVEL=6 dBm
                                      6809 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      6817 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                                      6825 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      6832 MCO:PIM:NODE REG=1
                                      6834 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                                      6838 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6862 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-42
                                      6866 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
                                      6871 RFM69:PTX:LEVEL=5 dBm
                                      6873 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005F04
                                      6883 MCO:BGN:STP
                                      7395 MCO:BGN:INIT OK,TSP=1
                                      7397 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      7405 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005F04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      7415 OTA:FWP:RECV B=045F
                                      7419 OTA:FRQ:FW REQ,T=0002,V=0004,B=045E
                                      7424 RFM69:SWR:SEND,TO=0,RETRY=0
                                      7440 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-43
                                      7446 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
                                      7450 RFM69:PTX:LEVEL=4 dBm
                                      7452 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005E04
                                      7512 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      7520 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005E04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      7530 OTA:FWP:RECV B=045E
                                      7534 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                                      7538 RFM69:SWR:SEND,TO=0,RETRY=0
                                      7555 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-44
                                      7561 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                                      7565 RFM69:PTX:LEVEL=3 dBm
                                      7567 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                                      8036 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                                      8040 RFM69:SWR:SEND,TO=0,RETRY=0
                                      8249 !RFM69:SWR:NACK
                                      8251 RFM69:PTX:LEVEL=4 dBm
                                      8286 RFM69:SWR:SEND,TO=0,RETRY=1
                                      8495 !RFM69:SWR:NACK
                                      8497 RFM69:PTX:LEVEL=5 dBm
                                      8531 RFM69:SWR:SEND,TO=0,RETRY=2
                                      8740 !RFM69:SWR:NACK
                                      8742 RFM69:PTX:LEVEL=6 dBm
                                      8753 RFM69:SWR:SEND,TO=0,RETRY=3
                                      8962 !RFM69:SWR:NACK
                                      8964 RFM69:PTX:LEVEL=7 dBm
                                      9007 RFM69:SWR:SEND,TO=0,RETRY=4
                                      9029 RFM69:SWR:ACK,FROM=0,SEQ=30,RSSI=-41
                                      9033 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=6
                                      9037 RFM69:PTX:LEVEL=6 dBm
                                      9039 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                                      9050 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                                      9054 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9074 RFM69:SWR:ACK,FROM=0,SEQ=31,RSSI=-42
                                      9078 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
                                      9082 RFM69:PTX:LEVEL=5 dBm
                                      9086 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                                      9127 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      9136 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9146 OTA:FWP:RECV B=045D
                                      9148 OTA:FRQ:FW REQ,T=0002,V=0004,B=045C
                                      9152 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9172 RFM69:SWR:ACK,FROM=0,SEQ=33,RSSI=-43
                                      9177 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
                                      9181 RFM69:PTX:LEVEL=4 dBm
                                      9183 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005C04
                                      9234 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      9242 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9252 OTA:FWP:RECV B=045D
                                      9254 !OTA:FWP:WRONG FWB
                                      9451 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                                      9459 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9469 OTA:FWP:RECV B=045D
                                      9472 !OTA:FWP:WRONG FWB
                                      9480 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      9488 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005C04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9500 OTA:FWP:RECV B=045C
                                      9502 OTA:FRQ:FW REQ,T=0002,V=0004,B=045B
                                      9506 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9525 RFM69:SWR:ACK,FROM=0,SEQ=37,RSSI=-44
                                      9529 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                                      9533 RFM69:PTX:LEVEL=3 dBm
                                      9537 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005B04
                                      9637 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      9646 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005B04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9658 OTA:FWP:RECV B=045B
                                      9660 OTA:FRQ:FW REQ,T=0002,V=0004,B=045A
                                      9664 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9682 RFM69:SWR:ACK,FROM=0,SEQ=39,RSSI=-44
                                      9687 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
                                      9691 RFM69:PTX:LEVEL=2 dBm
                                      9695 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005A04
                                      9725 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      9734 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005A04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9744 OTA:FWP:RECV B=045A
                                      9746 OTA:FRQ:FW REQ,T=0002,V=0004,B=0459
                                      9750 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9768 RFM69:SWR:ACK,FROM=0,SEQ=41,RSSI=-46
                                      9775 RFM69:ATC:ADJ TXL,cR=-46,tR=-80,TXL=1
                                      9779 RFM69:PTX:LEVEL=1 dBm
                                      9781 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005904
                                      9834 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      9842 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005904FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9854 OTA:FWP:RECV B=0459
                                      9857 OTA:FRQ:FW REQ,T=0002,V=0004,B=0458
                                      9861 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9879 RFM69:SWR:ACK,FROM=0,SEQ=43,RSSI=-48
                                      9883 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=0
                                      9889 RFM69:PTX:LEVEL=0 dBm
                                      9891 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005804
                                      9934 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                                      9943 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005804FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                      9953 OTA:FWP:RECV B=0458
                                      9957 OTA:FRQ:FW REQ,T=0002,V=0004,B=0457
                                      9961 RFM69:SWR:SEND,TO=0,RETRY=0
                                      9979 RFM69:SWR:ACK,FROM=0,SEQ=45,RSSI=-47
                                      9984 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=-1
                                      9988 RFM69:PTX:LEVEL=-1 dBm
                                      9992 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005704
                                      10043 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      10051 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005704250054454D502048554D00312E310000
                                      10061 OTA:FWP:RECV B=0457
                                      10065 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
                                      10070 RFM69:SWR:SEND,TO=0,RETRY=0
                                      10280 !RFM69:SWR:NACK
                                      10283 RFM69:PTX:LEVEL=0 dBm
                                      10317 RFM69:SWR:SEND,TO=0,RETRY=1
                                      10526 !RFM69:SWR:NACK
                                      10528 RFM69:PTX:LEVEL=1 dBm
                                      10530 RFM69:SWR:SEND,TO=0,RETRY=2
                                      10741 !RFM69:SWR:NACK
                                      10743 RFM69:PTX:LEVEL=2 dBm
                                      10786 RFM69:SWR:SEND,TO=0,RETRY=3
                                      10995 !RFM69:SWR:NACK
                                      10997 RFM69:PTX:LEVEL=3 dBm
                                      11040 RFM69:SWR:SEND,TO=0,RETRY=4
                                      11249 !RFM69:SWR:NACK
                                      11251 RFM69:PTX:LEVEL=4 dBm
                                      11294 RFM69:SWR:SEND,TO=0,RETRY=5
                                      11468 RFM69:SWR:ACK,FROM=0,SEQ=47,RSSI=-43
                                      11472 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
                                      11476 RFM69:PTX:LEVEL=3 dBm
                                      11481 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
                                      11489 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
                                      11493 RFM69:SWR:SEND,TO=0,RETRY=0
                                      11513 RFM69:SWR:ACK,FROM=0,SEQ=48,RSSI=-87
                                      11520 RFM69:ATC:ADJ TXL,cR=-87,tR=-80,TXL=4
                                      11524 RFM69:PTX:LEVEL=4 dBm
                                      11526 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
                                      11536 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      11544 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
                                      11554 OTA:FWP:RECV B=0456
                                      11558 OTA:FRQ:FW REQ,T=0002,V=0004,B=0455
                                      11563 RFM69:SWR:SEND,TO=0,RETRY=0
                                      11581 RFM69:SWR:ACK,FROM=0,SEQ=50,RSSI=-44
                                      11585 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                                      11589 RFM69:PTX:LEVEL=3 dBm
                                      11593 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005504
                                      11741 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      11749 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
                                      11761 OTA:FWP:RECV B=0456
                                      11763 !OTA:FWP:WRONG FWB
                                      11833 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                                      11841 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040055045400483A200042617474657279204176
                                      11851 OTA:FWP:RECV B=0455
                                      11855 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
                                      11859 RFM69:SWR:SEND,TO=0,RETRY=0
                                      12070 !RFM69:SWR:NACK
                                      12072 RFM69:PTX:LEVEL=4 dBm
                                      12083 RFM69:SWR:SEND,TO=0,RETRY=1
                                      12294 !RFM69:SWR:NACK
                                      12296 RFM69:PTX:LEVEL=5 dBm
                                      12339 RFM69:SWR:SEND,TO=0,RETRY=2
                                      12548 !RFM69:SWR:NACK
                                      12550 RFM69:PTX:LEVEL=6 dBm
                                      12593 RFM69:SWR:SEND,TO=0,RETRY=3
                                      12802 !RFM69:SWR:NACK
                                      12804 RFM69:PTX:LEVEL=7 dBm
                                      12847 RFM69:SWR:SEND,TO=0,RETRY=4
                                      13056 !RFM69:SWR:NACK
                                      13058 RFM69:PTX:LEVEL=8 dBm
                                      13092 RFM69:SWR:SEND,TO=0,RETRY=5
                                      13273 RFM69:SWR:ACK,FROM=0,SEQ=53,RSSI=-41
                                      13277 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=7
                                      13283 RFM69:PTX:LEVEL=7 dBm
                                      13285 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
                                      13293 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
                                      13299 RFM69:SWR:SEND,TO=0,RETRY=0
                                      13320 RFM69:SWR:ACK,FROM=0,SEQ=54,RSSI=-42
                                      13324 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=6
                                      13330 RFM69:PTX:LEVEL=6 dBm
                                      13332 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
                                      13342 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      13350 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
                                      13361 OTA:FWP:RECV B=0454
                                      13365 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
                                      13369 RFM69:SWR:SEND,TO=0,RETRY=0
                                      13580 !RFM69:SWR:NACK
                                      13582 RFM69:PTX:LEVEL=7 dBm
                                      13584 RFM69:SWR:SEND,TO=0,RETRY=1
                                      13795 !RFM69:SWR:NACK
                                      13797 RFM69:PTX:LEVEL=8 dBm
                                      13807 RFM69:SWR:SEND,TO=0,RETRY=2
                                      14016 !RFM69:SWR:NACK
                                      14018 RFM69:PTX:LEVEL=9 dBm
                                      14053 RFM69:SWR:SEND,TO=0,RETRY=3
                                      14262 !RFM69:SWR:NACK
                                      14264 RFM69:PTX:LEVEL=10 dBm
                                      14307 RFM69:SWR:SEND,TO=0,RETRY=4
                                      14516 !RFM69:SWR:NACK
                                      14518 RFM69:PTX:LEVEL=11 dBm
                                      14561 RFM69:SWR:SEND,TO=0,RETRY=5
                                      14770 !RFM69:SWR:NACK
                                      14772 RFM69:PTX:LEVEL=12 dBm
                                      14815 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005304
                                      14823 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      14831 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
                                      14841 OTA:FWP:RECV B=0454
                                      14845 !OTA:FWP:WRONG FWB
                                      14848 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
                                      14852 RFM69:SWR:SEND,TO=0,RETRY=0
                                      15063 !RFM69:SWR:NACK
                                      15065 RFM69:PTX:LEVEL=13 dBm
                                      15075 RFM69:SWR:SEND,TO=0,RETRY=1
                                      15284 !RFM69:SWR:NACK
                                      15286 RFM69:PTX:NO ADJ
                                      15329 RFM69:SWR:SEND,TO=0,RETRY=2
                                      15538 !RFM69:SWR:NACK
                                      15540 RFM69:PTX:NO ADJ
                                      15583 RFM69:SWR:SEND,TO=0,RETRY=3
                                      15792 !RFM69:SWR:NACK
                                      15794 RFM69:PTX:NO ADJ
                                      15828 RFM69:SWR:SEND,TO=0,RETRY=4
                                      16037 !RFM69:SWR:NACK
                                      16039 RFM69:PTX:NO ADJ
                                      16050 RFM69:SWR:SEND,TO=0,RETRY=5
                                      16191 RFM69:SWR:ACK,FROM=0,SEQ=58,RSSI=-39
                                      16195 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                                      16201 RFM69:PTX:LEVEL=12 dBm
                                      16203 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005304
                                      16214 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      16222 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
                                      16232 OTA:FWP:RECV B=0453
                                      16234 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
                                      16240 RFM69:SWR:SEND,TO=0,RETRY=0
                                      16449 !RFM69:SWR:NACK
                                      16451 RFM69:PTX:LEVEL=13 dBm
                                      16494 RFM69:SWR:SEND,TO=0,RETRY=1
                                      16703 !RFM69:SWR:NACK
                                      16705 RFM69:PTX:NO ADJ
                                      16740 RFM69:SWR:SEND,TO=0,RETRY=2
                                      16949 !RFM69:SWR:NACK
                                      16951 RFM69:PTX:NO ADJ
                                      16994 RFM69:SWR:SEND,TO=0,RETRY=3
                                      17203 !RFM69:SWR:NACK
                                      17205 RFM69:PTX:NO ADJ
                                      17248 RFM69:SWR:SEND,TO=0,RETRY=4
                                      17457 !RFM69:SWR:NACK
                                      17459 RFM69:PTX:NO ADJ
                                      17502 RFM69:SWR:SEND,TO=0,RETRY=5
                                      17625 RFM69:SWR:ACK,FROM=0,SEQ=60,RSSI=-39
                                      17631 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                                      17635 RFM69:PTX:LEVEL=12 dBm
                                      17637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
                                      17647 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      17655 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
                                      17666 OTA:FWP:RECV B=0453
                                      17668 !OTA:FWP:WRONG FWB
                                      17672 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
                                      17676 RFM69:SWR:SEND,TO=0,RETRY=0
                                      17690 RFM69:SWR:ACK,FROM=0,SEQ=62,RSSI=-39
                                      17694 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=11
                                      17700 RFM69:PTX:LEVEL=11 dBm
                                      17702 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
                                      17731 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      17739 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
                                      17750 OTA:FWP:RECV B=0452
                                      17754 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
                                      17758 RFM69:SWR:SEND,TO=0,RETRY=0
                                      17969 !RFM69:SWR:NACK
                                      17971 RFM69:PTX:LEVEL=12 dBm
                                      18014 RFM69:SWR:SEND,TO=0,RETRY=1
                                      18223 !RFM69:SWR:NACK
                                      18225 RFM69:PTX:LEVEL=13 dBm
                                      18259 RFM69:SWR:SEND,TO=0,RETRY=2
                                      18468 !RFM69:SWR:NACK
                                      18470 RFM69:PTX:NO ADJ
                                      18481 RFM69:SWR:SEND,TO=0,RETRY=3
                                      18690 !RFM69:SWR:NACK
                                      18692 RFM69:PTX:NO ADJ
                                      18735 RFM69:SWR:SEND,TO=0,RETRY=4
                                      18944 !RFM69:SWR:NACK
                                      18946 RFM69:PTX:NO ADJ
                                      18980 RFM69:SWR:SEND,TO=0,RETRY=5
                                      19079 RFM69:SWR:ACK,FROM=0,SEQ=64,RSSI=-39
                                      19085 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                                      19089 RFM69:PTX:LEVEL=12 dBm
                                      19091 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
                                      19101 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      19109 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
                                      19120 OTA:FWP:RECV B=0452
                                      19124 !OTA:FWP:WRONG FWB
                                      19126 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
                                      19130 RFM69:SWR:SEND,TO=0,RETRY=0
                                      19341 !RFM69:SWR:NACK
                                      19343 RFM69:PTX:LEVEL=13 dBm
                                      19345 RFM69:SWR:SEND,TO=0,RETRY=1
                                      19556 !RFM69:SWR:NACK
                                      19558 RFM69:PTX:NO ADJ
                                      19568 RFM69:SWR:SEND,TO=0,RETRY=2
                                      19777 !RFM69:SWR:NACK
                                      19779 RFM69:PTX:NO ADJ
                                      19822 RFM69:SWR:SEND,TO=0,RETRY=3
                                      20031 !RFM69:SWR:NACK
                                      20033 RFM69:PTX:NO ADJ
                                      20068 RFM69:SWR:SEND,TO=0,RETRY=4
                                      20277 !RFM69:SWR:NACK
                                      20279 RFM69:PTX:NO ADJ
                                      20322 RFM69:SWR:SEND,TO=0,RETRY=5
                                      20482 RFM69:SWR:ACK,FROM=0,SEQ=66,RSSI=-39
                                      20486 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                                      20490 RFM69:PTX:LEVEL=12 dBm
                                      20494 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
                                      20502 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                                      20510 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040051046D70657261747572652066726F6D2053
                                      20520 OTA:FWP:RECV B=0451
                                      20525 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
                                      20529 RFM69:SWR:SEND,TO=0,RETRY=0
                                      20740 !RFM69:SWR:NACK
                                      20742 RFM69:PTX:LEVEL=13 dBm
                                      20785 RFM69:SWR:SEND,TO=0,RETRY=1
                                      20994 !RFM69:SWR:NACK
                                      20996 RFM69:PTX:NO ADJ
                                      21039 RFM69:SWR:SEND,TO=0,RETRY=2
                                      21248 !RFM69:SWR:NACK
                                      21250 RFM69:PTX:NO ADJ
                                      21284 RFM69:SWR:SEND,TO=0,RETRY=3
                                      21493 !RFM69:SWR:NACK
                                      21495 RFM69:PTX:NO ADJ
                                      21538 RFM69:SWR:SEND,TO=0,RETRY=4
                                      21747 !RFM69:SWR:NACK
                                      21749 RFM69:PTX:NO ADJ
                                      21792 RFM69:SWR:SEND,TO=0,RETRY=5
                                      21884 RFM69:SWR:ACK,FROM=0,SEQ=68,RSSI=-37
                                      21889 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
                                      21895 RFM69:PTX:LEVEL=12 dBm
                                      21897 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
                                      21907 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
                                      21911 RFM69:SWR:SEND,TO=0,RETRY=0
                                      22122 !RFM69:SWR:NACK
                                      22124 RFM69:PTX:LEVEL=13 dBm
                                      22159 RFM69:SWR:SEND,TO=0,RETRY=1
                                      22368 !RFM69:SWR:NACK
                                      22370 RFM69:PTX:NO ADJ
                                      22372 RFM69:SWR:SEND,TO=0,RETRY=2
                                      22583 !RFM69:SWR:NACK
                                      22585 RFM69:PTX:NO ADJ
                                      22628 RFM69:SWR:SEND,TO=0,RETRY=3
                                      22837 !RFM69:SWR:NACK
                                      22839 RFM69:PTX:NO ADJ
                                      22882 RFM69:SWR:SEND,TO=0,RETRY=4
                                      23091 !RFM69:SWR:NACK
                                      23093 RFM69:PTX:NO ADJ
                                      23136 RFM69:SWR:SEND,TO=0,RETRY=5
                                      23343 RFM69:SWR:ACK,FROM=0,SEQ=69,RSSI=-37
                                      23347 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
                                      23353 RFM69:PTX:LEVEL=12 dBm
                                      23355 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
                                      23365 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      23373 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400500461696C65642072656164696E67207465
                                      23384 OTA:FWP:RECV B=0450
                                      23386 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                                      23392 RFM69:SWR:SEND,TO=0,RETRY=0
                                      23601 !RFM69:SWR:NACK
                                      23603 RFM69:PTX:LEVEL=13 dBm
                                      23646 RFM69:SWR:SEND,TO=0,RETRY=1
                                      23855 !RFM69:SWR:NACK
                                      23857 RFM69:PTX:NO ADJ
                                      23891 RFM69:SWR:SEND,TO=0,RETRY=2
                                      24100 !RFM69:SWR:NACK
                                      24102 RFM69:PTX:NO ADJ
                                      24113 RFM69:SWR:SEND,TO=0,RETRY=3
                                      24322 !RFM69:SWR:NACK
                                      24324 RFM69:PTX:NO ADJ
                                      24367 RFM69:SWR:SEND,TO=0,RETRY=4
                                      24576 !RFM69:SWR:NACK
                                      24578 RFM69:PTX:NO ADJ
                                      24612 RFM69:SWR:SEND,TO=0,RETRY=5
                                      24758 RFM69:SWR:ACK,FROM=0,SEQ=71,RSSI=-38
                                      24762 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                                      24766 RFM69:PTX:LEVEL=12 dBm
                                      24770 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                                      24778 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                                      24782 RFM69:SWR:SEND,TO=0,RETRY=0
                                      24993 !RFM69:SWR:NACK
                                      24995 RFM69:PTX:LEVEL=13 dBm
                                      25006 RFM69:SWR:SEND,TO=0,RETRY=1
                                      25214 !RFM69:SWR:NACK
                                      25217 RFM69:PTX:NO ADJ
                                      25251 RFM69:SWR:SEND,TO=0,RETRY=2
                                      25460 !RFM69:SWR:NACK
                                      25462 RFM69:PTX:NO ADJ
                                      25505 RFM69:SWR:SEND,TO=0,RETRY=3
                                      25714 !RFM69:SWR:NACK
                                      25716 RFM69:PTX:NO ADJ
                                      25759 RFM69:SWR:SEND,TO=0,RETRY=4
                                      25968 !RFM69:SWR:NACK
                                      25970 RFM69:PTX:NO ADJ
                                      26005 RFM69:SWR:SEND,TO=0,RETRY=5
                                      26183 RFM69:SWR:ACK,FROM=0,SEQ=72,RSSI=-38
                                      26189 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                                      26193 RFM69:PTX:LEVEL=12 dBm
                                      26195 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                                      26206 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                                      26210 RFM69:SWR:SEND,TO=0,RETRY=0
                                      26421 !RFM69:SWR:NACK
                                      26423 RFM69:PTX:LEVEL=13 dBm
                                      26466 RFM69:SWR:SEND,TO=0,RETRY=1
                                      26675 !RFM69:SWR:NACK
                                      26677 RFM69:PTX:NO ADJ
                                      26720 RFM69:SWR:SEND,TO=0,RETRY=2
                                      26929 !RFM69:SWR:NACK
                                      26931 RFM69:PTX:NO ADJ
                                      26974 RFM69:SWR:SEND,TO=0,RETRY=3
                                      27183 !RFM69:SWR:NACK
                                      27185 RFM69:PTX:NO ADJ
                                      27219 RFM69:SWR:SEND,TO=0,RETRY=4
                                      27428 !RFM69:SWR:NACK
                                      27430 RFM69:PTX:NO ADJ
                                      27441 RFM69:SWR:SEND,TO=0,RETRY=5
                                      27555 RFM69:SWR:ACK,FROM=0,SEQ=73,RSSI=-41
                                      27561 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=12
                                      27566 RFM69:PTX:LEVEL=12 dBm
                                      27568 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                                      27578 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                                      27586 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
                                      27596 OTA:FWP:RECV B=044F
                                      27600 OTA:FRQ:FW REQ,T=0002,V=0004,B=044E
                                      27604 RFM69:SWR:SEND,TO=0,RETRY=0
                                      27625 RFM69:SWR:ACK,FROM=0,SEQ=75,RSSI=-42
                                      27629 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=11
                                      27633 RFM69:PTX:LEVEL=11 dBm
                                      27637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004E04
                                      27645 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                                      27654 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
                                      27666 OTA:FWP:RECV B=044F
                                      27668 !OTA:FWP:WRONG FWB
                                      27742 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                      27750 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004E0400000098196819C8193C1960194C193D
                                      27760 OTA:FWP:RECV B=044E
                                      27762 OTA:FRQ:FW REQ,T=0002,V=0004,B=044D
                                      27768 RFM69:SWR:SEND,TO=0,RETRY=0
                                      27789 RFM69:SWR:ACK,FROM=0,SEQ=78,RSSI=-43
                                      27793 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                                      27797 RFM69:PTX:LEVEL=10 dBm
                                      27801 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004D04
                                      27850 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                                      27858 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004D0400530BC00AEB0A9A0B1C0BFA0A0E0B00
                                      27869 OTA:FWP:RECV B=044D
                                      27873 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                                      27877 RFM69:SWR:SEND,TO=0,RETRY=0
                                      28088 !RFM69:SWR:NACK
                                      28090 RFM69:PTX:LEVEL=11 dBm
                                      28133 RFM69:SWR:SEND,TO=0,RETRY=1
                                      28342 !RFM69:SWR:NACK
                                      28344 RFM69:PTX:LEVEL=12 dBm
                                      28387 RFM69:SWR:SEND,TO=0,RETRY=2
                                      28596 !RFM69:SWR:NACK
                                      28598 RFM69:PTX:LEVEL=13 dBm
                                      28641 RFM69:SWR:SEND,TO=0,RETRY=3
                                      28850 !RFM69:SWR:NACK
                                      28852 RFM69:PTX:NO ADJ
                                      28895 RFM69:SWR:SEND,TO=0,RETRY=4
                                      29104 !RFM69:SWR:NACK
                                      29106 RFM69:PTX:NO ADJ
                                      29140 RFM69:SWR:SEND,TO=0,RETRY=5
                                      29233 RFM69:SWR:ACK,FROM=0,SEQ=80,RSSI=-39
                                      29237 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                                      29241 RFM69:PTX:LEVEL=12 dBm
                                      29245 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                                      29253 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                                      29257 RFM69:SWR:SEND,TO=0,RETRY=0
                                      29278 RFM69:SWR:ACK,FROM=0,SEQ=81,RSSI=-45
                                      29282 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=11
                                      29286 RFM69:PTX:LEVEL=11 dBm
                                      29290 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                                      29755 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                                      29759 RFM69:SWR:SEND,TO=0,RETRY=0
                                      29775 RFM69:SWR:ACK,FROM=0,SEQ=82,RSSI=-47
                                      29782 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=10
                                      29786 RFM69:PTX:LEVEL=10 dBm
                                      29790 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                                      30025 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                                      30033 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004C0407070707070707070707070103000000
                                      30044 OTA:FWP:RECV B=044C
                                      30048 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
                                      30052 RFM69:SWR:SEND,TO=0,RETRY=0
                                      30263 !RFM69:SWR:NACK
                                      30265 RFM69:PTX:LEVEL=11 dBm
                                      30308 RFM69:SWR:SEND,TO=0,RETRY=1
                                      30517 !RFM69:SWR:NACK
                                      30519 RFM69:PTX:LEVEL=12 dBm
                                      30562 RFM69:SWR:SEND,TO=0,RETRY=2
                                      30771 !RFM69:SWR:NACK
                                      30773 RFM69:PTX:LEVEL=13 dBm
                                      30816 RFM69:SWR:SEND,TO=0,RETRY=3
                                      31025 !RFM69:SWR:NACK
                                      31027 RFM69:PTX:NO ADJ
                                      31070 RFM69:SWR:SEND,TO=0,RETRY=4
                                      31279 !RFM69:SWR:NACK
                                      31281 RFM69:PTX:NO ADJ
                                      31315 RFM69:SWR:SEND,TO=0,RETRY=5
                                      31449 RFM69:SWR:ACK,FROM=0,SEQ=84,RSSI=-39
                                      31453 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                                      31457 RFM69:PTX:LEVEL=12 dBm
                                      31461 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004B04
                                      31469 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
                                      31473 RFM69:SWR:SEND,TO=0,RETRY=0
                                      31696 !RFM69:SWR:NACK
                                      31698 RFM69:PTX:LEVEL=13 dBm
                                      31709 RFM69:SWR:SEND,TO=0,RETRY=1
                                      31918 !RFM69:SWR:NACK
                                      31920 RFM69:PTX:NO ADJ
                                      31954 RFM69:SWR:SEND,TO=0,RETRY=2
                                      32163 !RFM69:SWR:NACK
                                      32165 RFM69:PTX:NO ADJ
                                      32176 RFM69:SWR:SEND,TO=0,RETRY=3
                                        49 TSM:INIT
                                        51 TSF:WUR:MS=10000
                                        53 RFM69:INIT
                                        61 TSM:INIT:TSP OK
                                        63 TSF:SID:OK,ID=16
                                        65 TSM:FPAR
                                        2082 TSM:FPAR:OK
                                        2082 TSM:ID
                                        2084 TSM:ID:OK
                                        2086 TSM:UPL
                                        2142 TSM:UPL:OK
                                        2351 OTA:FWP:UPDATE
                                        6780 MCO:REG:REQ
                                        6883 MCO:BGN:STP
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @gohan I suspect an ATC and/or timing issue - could you try this: https://github.com/tekka007/MySensors/tree/RFM69_Update
                                        Update GW + node and post the full debug log for further analysis. Thanks
                                          I left the myconfig.h file as the one provided but I get no communication
                                          Node log
                                          18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.2
                                          28 TSM:INIT
                                          28 TSF:WUR:MS=10000
                                          30 RFM69:INIT
                                          32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                          36 RFM69:PTX:LEVEL=5 dBm
                                          40 TSM:INIT:TSP OK
                                          43 TSF:SID:OK,ID=16
                                          45 TSM:FPAR
                                          45 RFM69:SWR:SEND,TO=255,RETRY=0
                                          53 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2060 !TSM:FPAR:NO REPLY
                                          2062 TSM:FPAR
                                          2064 RFM69:SWR:SEND,TO=255,RETRY=0
                                          2070 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4079 !TSM:FPAR:NO REPLY
                                          4081 TSM:FPAR
                                          4083 RFM69:SWR:SEND,TO=255,RETRY=0
                                          4089 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          6100 !TSM:FPAR:NO REPLY
                                          6103 TSM:FPAR
                                          6105 RFM69:SWR:SEND,TO=255,RETRY=0
                                          6111 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          8120 !TSM:FPAR:FAIL
                                          8122 TSM:FAIL:CNT=1
                                          8124 TSM:FAIL:DIS
                                          8126 TSF:TDI:TSL
                                          8126 RFM69:RSL
                                          10031 MCO:BGN:STP
                                          10543 MCO:BGN:INIT OK,TSP=0
                                          11546 !MCO:SND:NODE NOT REG
                                          T: 23.15
                                          12052 !MCO:SND:NODE NOT REG
                                          H: 47
                                          12054 !MCO:SND:NODE NOT REG
                                          12558 !MCO:SND:NODE NOT REG
                                          12761 !MCO:SND:NODE NOT REG
                                          13764 !MCO:SND:NODE NOT REG
                                          13766 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                          13772 !MCO:SLP:TNR
                                          18130 TSM:FAIL:RE-INIT
                                          18132 TSM:INIT
                                          18135 RFM69:INIT
                                          18137 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                          18141 RFM69:PTX:LEVEL=5 dBm
                                          18145 TSM:INIT:TSP OK
                                          18147 TSF:SID:OK,ID=16
                                          18149 TSM:FPAR
                                          18151 RFM69:SWR:SEND,TO=255,RETRY=0
                                          18157 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          20166 !TSM:FPAR:NO REPLY
                                          20168 TSM:FPAR
                                          20170 RFM69:SWR:SEND,TO=255,RETRY=0
                                          20176 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          22188 !TSM:FPAR:NO REPLY
                                          22190 TSM:FPAR
                                          22192 RFM69:SWR:SEND,TO=255,RETRY=0
                                          22198 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          23775 MCO:SLP:MS=589999
                                          23777 !TSF:SND:TNR
                                          24207 !TSM:FPAR:NO REPLY
                                          24209 TSM:FPAR
                                          24211 RFM69:SWR:SEND,TO=255,RETRY=0
                                          24217 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          24279 TSF:TDI:TSL
                                          24281 RFM69:RSL
                                          GW LOG
                                          mysgw: Starting gateway...
                                          mysgw: Protocol version - 2.2.0-rc.2
                                          mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: RFM69:INIT
                                          mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
                                          mysgw: RFM69:PTX:LEVEL=5 dBm
                                          mysgw: TSM:INIT:TSP OK
                                          mysgw: TSM:INIT:GW MODE
                                          mysgw: MCO:REG:NOT NEEDED
                                          mysgw: Listening for connections on 0.0.0.0:5003
                                          mysgw: MCO:BGN:STP
                                          mysgw: MCO:BGN:INIT OK,TSP=1
                                          and nothing more while the node is looking for parent
