Using two gateways MQTT
Hello!!
As the title I would use for my control Domoticz two Gateway MQTT, being my Etherneth network very well distributed.is it possible to use 2 Gateway MQTT with a Domoticz controller ???
Thank you!!
Hello!!
Thank you!!
Grazie mille!!
Thanks!!
I do not understand. Tell me I'm available
@mfalkvidd How does the system knows which gateway is?
It's not actually the same because the mqtt broker is only one, the controller can not identify the gateway if they are publishing to same topic, unless there is a way to assign an ID for each gateway. Right?
@gohan oh, now I understand. Yes, if you use the same broker you would need to set different topics.
// Set this node's subscribe and publish topic prefix #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out" #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in" -
