  3. Node to node comunication with optional controller
nodecontroller
12 Posts 3 Posters 4.6k Views 3 Watching
  • DoomicD
    DoomicD
    Doomic
    I have a very small node.. planning to build into the wall... I know there are a lot of topics about this.. but the hadware is not THE problem.
    The purpose of the node is when it is switched on.. call to another node that he is online... the other node will switch on the house ventilation system.. and will check once in a while the node that requested the highest fan speed if that node is still on...
    The whole system can run without the need of a controller. Most of the time my home server is on.. but i don't want to depend on it.
    My only last problem is.
    when the node is starting up. it will first connect to the controller.. if it can't connect.. it is looping until it will connect.
    I am using the newest version of the api (V2.1). I tried to set the
    #define MY_REGISTRATION_RETRIES (1u)
    and
    #undef MY_REGISTRATION_FEATURE
    but it stays looping.
    i also found these 2 lines
    #define MY_PARENT_NODE_ID 0
    but than the controller is trying to send a nack message.
    i prefer to see it will connect to the controller if it is online.. but doent wait for it before sending messages to the other nodes.
    However, if that isn't posible.. disconnecting this node from the controller is also an option.
    anyone knows how?
    AWIA 1 Reply Last reply
    • DoomicD Doomic
      and
      anyone knows how?
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @Doomic use: #define MY_TRANSPORT_WAIT_READY_MS 1 // sketch moves on if no registration and you can skip the other definitions (if not needed for something else). Great for use in 'autonomous' nodes.
      • DoomicD
        DoomicD
        Doomic
        looks good. I will try this later today.
        • DoomicD
          DoomicD
          Doomic
          @AWI get an error. [!MCO:SND:NODE NOT REG]
          perhaps you have changed more? in you MyConfig.h maybe?
          • DoomicD Doomic
            AWIA
            AWIA
            AWI
            @Doomic This is what I have in the sketch.. no changes in the config
            #define MY_NODE_ID 90											// fixed node number
            #define MY_RF24_CHANNEL 83										// 83, radio channel, default = 76
            #define MY_RF24_PA_LEVEL RF24_PA_LOW							// helps (sometimes) to get a stable communication
            • DoomicD
              DoomicD
              Doomic
              I don't get it.
              It keep saying "NODE NOT REG"
              I have cleaned my sketch completly and it is now looking like below. But no progress on this.
              Compared myconfig.h file.. no changes with the one on github.
              removed some defines, tried all kind of combination.
              What am i missing?
              #define MY_NODE_ID 21
              #define MY_REGISTRATION_RETRIES 0
              MyMessage msgTest(2, V_LIGHT);
                msgTest.setDestination(20);
                sendSketchInfo("Test", "1.0");
                Serial.println("send");
                send(msgTest.set(false));
                wait(3000);
              Boots33B AWIA 2 Replies Last reply
              • DoomicD Doomic
                I don't get it.
                What am i missing?
                  wait(3000);
                Boots33B
                Boots33B
                Boots33
                @Doomic
                That compiles ok for me. Are you using MySensors v2.1.1 ?
                it might be best to re install the mysensor library and try again
                • DoomicD
                  DoomicD
                  Doomic
                  Yes i am using the newest 2.1 version. I may try to reinstall mysensors, however i dont think that is the problem.
                  Compiling isnt the problem, but when i run the sketch on my Arduino, It tells me trough the serial monitor that the node is not registered. (Because i doesnt have a gateway/controller nearby). Therefor it can't make calls.
                  • DoomicD Doomic
                    I don't get it.
                    What am i missing?
                      wait(3000);
                    AWIA
                    AWIA
                    AWI
                    @Doomic I have compiled (a stripped version of) you sketch and it show the behaviour I would expect. i.e. it does not loop any more but gets going. Next thing is that it cannot send messages because it did not find any node in the network where it can register. For me that is certain as I purposely set #define MY_RF24_CHANNEL ... to a non used channel in my network.
                    You need a gateway with the same communicaton characteristics to get communication going....
                    • DoomicD
                      DoomicD
                      Doomic
                      wrote on last edited by Doomic
                      A gateway you say..
                      There is a problem.. because the gateway is connected to my pc where the controller is running.
                      The Gateway is not always switched on.
                      That is the reason why i want to use node to node communication. Not depending on anther node (gateway) to work.
                      But why does it need a gateway?
                      Both nodes have a fixed id. Therefor there is nothing to register, is it?
                      The title should be: "Node to node communication with optional controller gateway"
                      Lets ask my question a litle bit different:
                      Is it posible to only have 2 standalone nrf24/arduino devices running the mysensors library to communicate with each other.
                      And if there is; what should the sketches look like?
                      • DoomicD Doomic
                        A gateway you say..
                        AWIA
                        AWIA
                        AWI
                        @Doomic A pretty similar discussion in this thread. Should give you some answers :abc:
                        • DoomicD
                          DoomicD
                          Doomic
                          i think i finally get it.
                          It is impossible... well the only way to let nodes communicate with each other is when a gateway is available (directly or trough other nodes) when the node is starting up.
                          This forum discussion is explaining me the most..
                          a solution may be.. transform the node that is always on to an gateway. And use antoher channel.. Sidenode; then you can't tell the controller what the status is.
                          Is there realy no way that this can supported? Node to node comunication without the need of an gateway inside the network? Skipping the registration and just send the message around.
                          perhaps i will dive into the source one day and change the registration behavior.
                          Thanks anyway for the help and the very fast responding.
